Chia sẻ cấu hình chơi nhạc từ máy tính
Discussion in 'Nguồn phát từ máy tính' started by bufaloears, 18/10/09.
  1. supermode
    supermode Advanced Member
    Vietnam
    Kiên nhẫn luôn là điều cần thiết bác ạ ... :D
  2. cdhanh
    cdhanh Advanced Member
    Vâng em nghe bác :D
      75 KB
  3. cdhanh
    Chia sẻ với các bác một cách em cũng đang chơi :p
    Em dùng soundcard Onkyo SE80PCI, soundcard này sử dụng giải mã WM8716 của hãng Wolfson và theo thông tin trong datasheet dưới đây thì em này chơi được 24bit/192kHz.
    DESCRIPTION
    The WM8716 is a high performance stereo DAC designed
    for audio applications such as CD, DVD, home theatre
    systems, set top boxes and digital TV. The WM8716
    supports data input word lengths from 16 to 24-bits and
    sampling rates up to 192kHz. The WM8716 consists of a
    serial interface port, digital interpolation filter, multi-bit sigma
    delta modulator and stereo DAC in a small 28-pin SSOP
    package. The WM8716 also includes a digitally controllable
    mute and attenuator function on each channel.
    The internal digital filter has two selectable roll-off
    characteristics. A sharp or slow roll-off can be selected
    dependent on application requirements. Additionally, the
    internal digital filter can be by-passed and the WM8716
    used with an external digital filter.
    The WM8716 supports two connection schemes for audio
    DAC control. The SPI-compatible serial control port
    provides access to a wide range of features including onchip
    mute, attenuation and phase reversal. A hardware
    controllable interface is also available.
    FEATURES
    • 112dB SNR (‘A’ weighted @ 48kHz), THD: -97dB @
    -1dB FS
    • Sampling frequency: 8kHz to 192kHz
    • Selectable digital filter roll-off
    • Optional interface to industry standard external filters
    • Differential mono mode
    • Input data word: 16 to 24-bit
    • Hardware or SPI compatible serial port control modes:
    − Hardware mode: mute, de-emphasis, audio format
    control
    − Serial mode: mute, de-emphasis, attenuation (256
    steps), phase reversal
    • Compatible upgrade to PCM1716
    APPLICATIONS
    • CD, DVD audio
    • Home theatre systems
    • Set top boxes
    • Digital TV
    Cách em chơi là tách phần I/V sau giải mã ra và thay vào đó phần I/V chạy tube, phần I/V này em làm riêng 1 box bên ngoài. Kết quả là chất âm mềm mượt của giải mã WM8716 trên soundcard mà Onkyo sử dụng công nghệ Vector Linear kết hợp với sự chi tiết và mộc mạc của tube đã cho ra một thứ âm thanh rất ấn tượng :D .
    Vout-L/R được câu vào cọc RCA input trên soundcard để kết nối với I/V tube box :D
  4. BachDuong
    BachDuong Moderator
    Dễ ợt, em có thể đoán trúng tên của con DAC này trong vòng ...1 nốt nhạc :lol:
  5. phuongthu
    phuongthu Advanced Member
    Sai Gon
    thế thì Bác đoán đi..
  6. VQ_audio
    VQ_audio Advanced Member
    Dễ ợt , em có thể đoán trúng tên của con DAC này trong vòng ... 1 phát đo :mrgreen:
    PS : mí con opamp còi JRC 4565DD trên soundcard Onkyo SE80PCI bác cdhanh kô xài tới thì cho nhà em xin nhá :)
  7. cdhanh
    Em vẫn dùng song song cả 2 đường :)
  8. ds2k
    ds2k Advanced Member
    Có phải con ESS ES9018 Sabre32 DAC không các bác? :wink:
  9. BachDuong
    BachDuong Moderator
    Đây đúng là con DAC ngon nhất vào thời điểm hiện tại. Nhưng ý bác Supermode nói là ngon nhất or nhì thì cũng có thể là nhì :D
    Theo em một con DAC tốt để sản xuất đại trà phù hợp với anh em DIY ít xiền trong nước thì phải hội đủ các yếu tố:
    1. Công nghệ mới, phù hợp với mọi định dạng (không chỉ redbook)
    2. Thông số tốt
    3. Rẻ
    4. Nhiều tùy biến
    5. Dễ triển khai
    Con Sabre DAC thiếu mất yếu tố thứ 3
  10. phuongthu
    Sai Gon
    Các Bác ơi làm sao biết con SC4 này bao nhiêu Mhz ? Em muốn nâng cấp nó nhưng tìm hoài không thấy có ghi thông số gì ráo ? Làm sao biết nó bao nhiêu Mhz hay là phải hỏi hãng, các Bác giúp Em với, để Em mua con khác gắn vào..Thank!
  11. supermode
    Vietnam
    Chị cứ lói thía lào ấy :D
    Cái DAC ESS này giá không mắc hơn giá con PCM63K (đã là đồ cổ) thời nay và đương nhiên không mắc hơn con TDA1541 loại vương miệng. Hơn nữa nó dùng ít phụ kiện bên ngoài so với những con DAC cổ kể trên nên tổng giá tiền nó không thực sự mắc hơn ...
  12. BachDuong
    BachDuong Moderator
    Vậy chị mua hộ em đi :mrgreen: . Em đang rất máu nhưng bó tay vì con này hình như chỉ bán với số lượng order rất lớn
    Nếu xoay qua mấy con akm hay wm thì khả thi hơn mà vẫn đứng trong top hàng chiến :D
  13. supermode
    Vietnam
    Bên Anh nó bán số lượng đơn chiếc nhưng giá chát hơn 30% nên em chưa định. Còn ở bên đế quốc chỉ có 1 thằng đại lý nhưng em chưa được câu trả lời của nó.
    Cái độc của cái ESS là nó có luôn mạch PLL trong vi mạch nên Jitter được trừ khử rất cao mà không cần tốn quá nhiều tiền cho mạch clock rời. Hơn nữa nó nhận luôn tín hiệu DSD lẫn Digital nên phối trực tiếp được với Coax mà không cần thêm vi mạch nào khác ---> Nhất cữ lưỡng tiện! Thời gian này em quá bận chứ nếu không là em sẽ làm luôn bộ DAC 7.1 LPCM cho cái Playstation 3 lúc đó còn khối cớt xì tâm mơ :D
  14. phuongthu
    Sai Gon
    Không có Bác nào giúp Em hết dậy, thôi Em tự giúp em chứ sao bây chừ... Em mới hỏi hắn cho Em cái này , Vậy Em nhờ Bác PhiCanh nhập dùm Em con Ultraclock 12.000mHz luôn nha khi nào Bác có báo Em với.
    Steve Nugent tới tôi
    hiển thị chi tiết 02:15 (10 giờ trước)
    Huynh - if you can solder, then all you need is Ultraclock at 12MHz. Just cut the power leads to the SC4 and remove it. Then remove the wires with a solding iron and clean-out the holes with solder wick. Then mount Ultraclock (requires different hardware) and solder the two wires in. Then connect clock cable and put back into the box. The hardware is a bit tricky so that it goes back into the box properly. It can be tight with the Ultraclock.
    Steve N.
  15. cdhanh
    Hấp dẫn quá, bác triển khai đi :D
  16. tranguyen
    tranguyen Advanced Member
    Sài Gòn
    ASIO4ALL có version 2.10 beta1. Có ai đã thử chưa ? Hình như không có cải thiện nhiều về chất âm, em nghe có vẻ như là bas mạnh hơn (placebo effect) ?
  17. Супер
    Супер Advanced Member
    Антарктида
    Không có Bác nào giúp Em hết dậy[/quote]
    Tất cả những con dùng giao diện USB đều 12MHz bác ạ.
  18. phuongthu
    Sai Gon
    Bác làm Em tò mò tìm thông tin đọc, nó khen con Dac này là 1 con Dac tốt nhất thế giới, hỏng biết có đúng zậy hông nửa, ráng chờ cụ Siêu mod, làm con review cho Em học hỏi với,nếu được cho Em đánh đu với, Em thấy CD Moon và USB DAC Wavelength cũng sử dụng Dac này giá cũng cao phết...
    Nếu có xiền chơi nguồn Laptop, chơi con USB DAC Wavelength xong chuyện...
    Em thấy con Trâu32S này cũng dùng ESS Sabre32 Reference (ES9018) giá cả hợp lý nhất không biết nghe ra sao cụ Siêumod ơi ???
    http://www.twistedpearaudio.com/digital/buffalo.aspx
    http://www.lampizator.eu/lampizator/REF ... loDAC.html
  19. tranguyen
    Sài Gòn
    Em định vào xem thử ra sao nhưng mà thấy có vẻ như con trâu này có vấn để gì đó, phải làm lại ? hay nâng cấp ?
  20. phuongthu
    Sai Gon
    Con Trâu có sẳn là con Trâu ESS Sabre32 ES9008 còn con trâu ESS Sabre32 ES9018 thì tới January 2010 mới có.
  21. cdhanh
    Các bác cho em hỏi soundcard Prodigy HD2 này có đúng là chơi được 24bit/192kHz?
    Chất âm không biết thế nào?
    Prodigy HD2 shows the latest technology in high end audio playback for audiophile users.
    Prodigy HD2 supports 192 kHz at 24-bit with a sensational dynamic range of 120dB(a) for playback - no other hardware in this price range provides this high level of output quality. Even better: the hardware is equipped with 3 OpAmps on sockets, this makes it possible to swap and exchange the OpAmps based on specific requirements.
    Prodigy HD2 is a Low Profile PCI card, shipping with a metal bracket for a conventional PCI slot and with a bracket that allows the installation in Low Profile slots - this makes Prodigy HD2 perfect for media center and home theater solutions where small PC cases are used.
    The included driver software is providing perfect compatibility (ASIO, GSIF, WDM) under all current Windows versions including Windows Vista 32-bit & 64-bit, offering high performance and low latency operation. DirectWIRE 3.0 support in the driver allows you to virtually patch your digital audio sources internally between different software applications running at the same time.
    Features
    PCI audio interface based on VIA VT1721 (Envy24HT-S)
    PCI card supplied with standard and low profile metal bracket
    24 bit / 192kHz playback (analog & digital)
    24 bit / 96kHz recording
    high quality AKM AK4396 120dB(a) S/N ratio DA converter for extremly high quality 2 channel audio playback via RCA output connectors (5Hz - 40kHz frequency response)
    triple OpAmp design for audio output with three high quality Fairchild NE5532 OpAmps on separate sockets (can be exchanged for tuning & customization)
    headphone output with 1/8" connector routed via JRC4580 dual OpAmp
    analog line input with 1/8" connector via AKM AK5353/7 102dB(a) S/N ratio AD converter (20Hz - 40kHz frequency response)
    optical S/PDIF digital output following IEC-958C standard, can be used for stereo audio playback (PCM) and multichannel streams from such sources (AC-3 or DTS data)
    EWDM driver based on ESI technology for all current Windows Versions
  22. NemS
    NemS Advanced Member
    e biết 1 tay vừa cằm con về buffalo32 này giá sơ sơ cho cả bộ cũng tới hơn 1k$ :(, e thèm nó lắm chắc để dành cả năm lun quá :-s
  23. phuongthu
    Sai Gon
    Em cũng thèm nó lắm , chắc cũng phải ráng để dành xiền làm bộ kit DAC con trâu này qué...từ từ Bác nhể chơi món đồ tốn 1 năm thì cũng nhanh chứ đâu có lâu gì Bác...he he ráng hen Bác
  24. NemS
    e đang me kit này giá ~700$ ^^
    người e quen thì hắn order bên 1 tay nhận làm, thiệt hại toàn bộ là 1k2$, còn e nghĩ nêu mình mua kit về tự diy thì tầm 800-850$ là kịt kim :D
  25. phuongthu
    Sai Gon
    đợi sang năm có bộ kit ESS Sabre32 ES9018 thì hãy mua, bây giờ chỉ có ESS Sabre32 ES9008 thôi, hơn nửa còn mới quá chưa có review nhiều về bộ kit này nên từ từ tìm thông tin review nhiều về nó thế nào hãy chơi...
