Chia sẻ kinh nghiệm dùng Behringer X Air XR12
Discussion in 'Karaoke - ProAudio' started by Viagraless, 4/2/17.
  1. dokien
    dokien Advanced Member
    Midas có Pro AVL ở HN b liên hệ thử nhé
  2. trai168
    trai168 Advanced Member
    HCM
    xin đa tạ ................
  3. tranman
    tranman Moderator
    Bác nào thích tìm hiểu về chức năng chi tiết của từng cái FX trên X AIR thì tham khảo tại trang này:
    https://www.behringer.com/Categories/Behringer/Mixers/Digital/XR12/p/P0BI6#googtrans(en|en)
    Cụ thể (xem tên các FX trong phần in đậm):
    4 Onboard X32 Effects Engines
    Equipped with the very same FX engines as the now legendary X32 Digital Mixing Console, the onboard virtual FX Rack provides access to four true-stereo (8 mono), multi-effects processors including delay, chorus, dynamics – plus the XR12 can run production-quality, true-stereo reverbs concurrently with 31-band EQ on the main and aux buses, all without the need for any additional hardware.
    You can select any combination of high-end simulations of legendary studio effects, such as the Lexicon 480L and PCM70, as well as the EMT250 and Quantec QRS reverbs. Onboard processing means your computer doesn’t have to do the heavy lifting during a mixing session with DAW plugins as the XR12 has a whole studio of FX under it’s hood.
    Custom-designed, and physically modeled after some of the most iconic and sought-after processors, all effects run inside the low-latency environment of the X32 mix engine, ensuring flawless performance, flexible routing and the end of cable faults forever!
    High-End FX Racks at Your Finger Tips
    The immaculate tube signal path in Teletronix’ LA-2A Leveling Amplifier has left its exceptional clarity, its rich and warm compression on countless albums of the past decades.
    The ultra-smooth optical attenuator is closely modeled in our LEISURE COMPRESSOR. It provides breezy, natural and effortlessly musical compression. (Inspired by Teletronix LA-2A*)
    When Urei released the 1176LN Limiting Amplifier in the late 60’s, it broke new ground. Field Effect Transistors employed were just invented, and the 1176 was one of the first audio processors to benefit from this new technology.
    Our digital reincarnation, ULTIMO COMPRESSOR, is based on the early Rev. E model, and authentically captures the smooth character of the original Class-A output stage and its FET’s legendary fast Attack. (Inspired by Urei 1176LN*)
    The Fairchild 670 tube compressor not only achieves record bids in high-end vintage gear auctions, it also delivers some of the finest colorations in compressor history. Two small trim VR’s preset the control side chain action, a six-step switch determines the timing, and the two large Input and Threshold knobs adjust the levels.
    Our FAIR COMPRESSOR model is true to the original signal path, and conveniently provides models for dual, stereo-linked or M/S operation. (Inspired by Fairchild 670*)
    The COMBINATOR is an amazing 5-band compressor that emulates famous broadcasting and mastering compressors. A highly complex processor, the COMBINATOR utilizes automatic parameter control that produces stunning and “inaudible” results. Makeup-gain for each frequency band will automatically be adjusted by the Spectral Balance Control (SBC) function, to maintain a balanced audio spectrum.
    The XTEC EQ1 emulates one of the undisputedly best passive studio equalizers ever manufactured. Virtually indescribable, recording engineers claim the Pultec EQP-1a to be the “secret sauce” of sound enhancement. We analyzed this classic to the core and created an exact physical model that reproduces the multi-faceted sound in painstaking detail. Even the transformers and tube output stage have been faithfully modeled! (Inspired by Pultec EQP-1a*)
    Put simply, Pultec literally wrote the book on passive equalization. By digitally “rebuilding” every aspect of this original classic, we captured the very essence in our mid-range focused parametric equalizer XTEC EQ5. Our digital re-incarnation authentically emulates the smooth character of its rather unique components. (Inspired by Pultec MEQ5*)
    The new SUB OCTAVER provides two channels of earth-shattering sub-harmonics generation, one or even two octaves below the input signal. While originally designed for bass players, the effect can be adjusted for Hi, Mid and Low frequency tracking to apply to a wide range of applications. This is your secret weapon for beatboxing...
    The EDISON EX1 is the reincarnation of one of our own analog classics. This remarkably effective tool allows manipulation of the stereo field. Selectable Mono or Stereo I/O modes allow the processing, or creation, of Mono/Stereo recorded sound sources. (Inspired by BEHRINGER EDISON)
    The SOUND MAXER restores natural brilliance and clarity to any audio signal by adjusting the phase and amplitude integrity to reveal more of the natural texture of the sound, which is often hidden when using some effects and equalizers. (Inspired by Sonic Maximizer 482i*)
    The DIMENSIONAL CHORUS is the perfect emulation of what has been referred to as “the best analog Chorus unit ever created”. Four simple Mode preset buttons activate amazing effects, best described as “space” and “dimension”. Absolutely faithful to the original, multiple preset buttons can be pressed simultaneously. (Inspired by Roland Dimension D Chorus*)
    MODULATION DELAY combines three of the most-used time modulation effects into one easy-to-operate unit. Enjoy true-stereo delay with a lush and spacious chorus, topped off with your choice of three very unique reverb models, Ambience, Club and Hall.
    ENHANCERS let you emphasize the Bass, Midrange and Hi output at selectable frequencies, allowing you to generate maximum punch, clarity and detail – without turning up the overall volume. (Inspired by SPL Vitalizer*)
    EXCITERS increase presence and intelligibility in live sound applications, and are indispensable for adding clarity, air and harmonic overtones in the studio. (Inspired by Aphex Aural Exciter*)
    Unlike typical graphic EQs, our STEREO TruEQ delivers the exact frequency response for the new fader setting, taking neighboring fader settings into account – for surgical and responsive filtering or general room equalization (Modeled after BEHRINGER UltraCurve DEQ2496). The XR18 can provide up to 16 mono graphic EQs – one in each of the 6 Aux Buses and Main LR, plus 8 additional mono GEQ effects (4 stereo) that may be inserted into channels.
    VINTAGE ROOM stands out head and shoulders over other competing reverberation strategies in the way it models sound propagation in the air and room resonances. Invented in the early ‘80s, the role model delivered authentic room character from an algorithmic reverb long before convolution-based processing was available. It is an ideal reverb for mixes or sub-groups, as it adds space to complex signals – highly valued in classical music and broadcasting environments. (Inspired by Quantec QRS*)
    PLATE REVERB emulates the characteristics of a plate reverb chamber with control over the damping pad, modulation depth and speed, and crossover. This classic effect will give your tracks the sound heard on countless hit records since the late 1950’s. (Inspired by Lexicon PCM70*)
    The 3-TAP DELAY in the X32 records the input signal and then echoes it back after a user-definable period of time and number of repeats. What makes the stereo and triple delay useful and outstanding is the linked tap-timing and musical choice of echo patterns. Use the 3-TAP DELAY to fatten up vocals and instruments, or to add an enhanced spatial element to any performance.
    The HALL REVERB effect provides a broad spectrum of reverberation possibilities, from small room to large, or even cavernous proportions. When softly mixed with the original signal, Hall Reverb can be used to create a warm, more natural sound. (Inspired by Lexicon 480L*)
    The Lexicon 480L* has been recognized as the gold standard of digital reverb. In addition to the Hall Reverb program, we have included four more of the finest reverb models: Ambience, Rich Plate, Room and Rich Chamber. These models precisely capture all nuances based on our “True Physical Modeling”, and our algorithms even incorporate the unit’s AD/DA gain stepping converters – nailing the entire analog and digital circuit paths right down to the last detail. (Inspired by Lexicon 480L*)
    This handy dynamic FLANGER & DELAY duo blends the “whoosh” of soaring jet planes with classic Delay, and can be adjusted from mild to wild. This combination effect only takes up one FX slot. (Inspired by Lexicon PCM70*)
    WAVE DESIGNER is a powerful tool for adjusting signal transients and dynamics such as attack and sustain. Use it to make a snare drum really “crack” in the mix or level out volume inconsistencies of slap bass tracks. (Inspired by SPL Transient Designer*)
    The STEREO PRECISION LIMITER is perfect for setting a precise volume limits, ensuring distortion-free and optimal signal integrity. Use the Stereo Precision Limiter to boost quiet signals or reduce the level of ”hot” signals to prevent clipping. (Inspired by Sony Oxford Dynamics*)
    The DE-ESSER is a “must-have” tool for reducing the amount of sibilance in vocal mics while adeptly preserving the natural voice timbre of a performance. Use it to enhance the smoothness of the upper mid to high frequencies in vocals as well as drum overheads and strings, etc. (Inspired by SPL 1219*)
    Based on the legendary EMT250, the VINTAGE REVERB delivers a shimmering, bright reverb that won’t drown out or overpower your live/ recorded tracks. Use the VINTAGE REVERB to sweeten vocals and snare drums without sacrificing clarity. (Inspired by EMT250 Plate Reverb*)
    Taking up only one FX slot, the CHORUS & CHAMBER eff ect combines the shimmer and doubling characteristics of a studio-grade Chorus with the sweet sound of a traditional Chamber reverb. (Inspired by Lexicon PCM70*)
    100-Band RTA for all Channel/ Bus EQ’s
    The XR12 includes a high-resolution 100-band Real Time Analyzer (RTA), with full Bar and Spectrograph views. This high-resolution RTA displays the audio energy distribution in 100 frequency bands over time – capturing a sonogram window of a full 10 seconds.
    Switch between the Large RTA view, displaying any available signal in full screen resolution, or the Combined RTA view shown above each of the channel and bus EQ curves – and see the results of your filtering choices. Additionally, the RTA can be displayed on top of the 31-band graphic EQs in the Main LR or Aux buses. Monitoring and controlling frequencies has never been easier!
    Uncompromised Channel Processing
    The XR12 allows you to achieve the same incredible level of EQ finesse as the award-winning X32 thanks to its 100-band Real Time Analyzer, which is built into every input channel and bus EQ. Visual feedback built into the control app allows you to see and make fast, surgical adjustments to frequencies in need of a boost or a cut. You’ll wonder how you ever EQ’d without it! Every input channel also features Low-Cut, 4-band fully parametric EQ and the same Gate and Compressor dynamics suite found in the X32 – with one very special addition; you can choose either Expert or Simple functionality. In Expert mode, you can drill down and get your hands on every nuance of your dynamics. Or, if you’re more of the ‘plug and play’ type, Simple mode lets you either select from one of our 4 carefully-optimized presets – or load your own channel templates. Add to this 40-Bit, floating-point DSP and you’ll experience virtually “unlimited” dynamic range with no internal overload and near-zero overall latency. In addition to the Main L/R bus for Front of House, 6 Aux buses are provided for dialing in the perfect monitor mixes, or creating a dedicated mix for your USB stereo recording – complete with inserts, dynamics, and either a 6-band parametric EQ or 31-band graphic EQ. And if all these outstanding EQ options put a smile on your face, you’ll love it even more when we tell you that 100-band RTAs are available for these, too!
    dokien likes this.
  4. thunghiem
    thunghiem Approved Member
    hcm
    chào cả nhà,
    Mình cũng đọc qua bài của anh Tranman thấy công lực của em tốt quá. Cũng muốn trải nghiệm thử, kinh tế có hạn nên cân nhắc "hàng 2nd", nếu Bác có nâng cấp Behringer có thừa ra thì cho mình 1 chân nha (0903077717 Phúc Ngân).
    Cảm ơn ạ.
  5. lehoangson1983
    lehoangson1983 Advanced Member
    Tôi thấy có anh em nói Behringer XR12 dùng để hát karaoke gia đình xảy ra vấn đề không hoà nguyện giữa tiếng nhạc và lời hát. Có phải thật sự như vậy không ? Tôi dự định mua Behringer XR12 để hát karaoke gia đình. Mong anh em diễn đàn chỉ giáo dùm tôi. Thanks !
  6. Tây Môn Khánh
    Tây Môn Khánh Advanced Member
    Nếu cụ định chơi loa + amp tầm vài trăm triệu thì có thể suy nghĩ mixer số tốt hơn con XR12
    lehoangson1983 likes this.
  7. lehoangson1983
    Tôi chơi Amply Jarguar PA600A - Loa BMB - Micro shure SM 58 không dây (xịn, chính hãng) - đầu phát Arirang 3600 và youtube trên laptop kết nối soundcard Blaster Creative (chủ yếu nhạc vàng bolero). Tôi đầu tư thêm Mixer Behringer XR12 sẽ ổn hơn về chất âm và tiếng hát không ? Thanks !
  8. thunghiem
    hcm
    Mình cũng nằm "Hóng" vụ này, Bác có kinh nghiệm "khai thông" giúp với.
  9. dokien
    Hoà quyện hay ko do cách ae sd effect bác ơi.
    Gửi b clip của Quý Keyboard về chỉnh hiệu ứng cho tiếng hát
  10. lehoangson1983
    Chào anh !
    Rất vui được biết anh. Tôi vừa mới mua mixer Behringer XR12. Tôi ghép với Amply Jarguar PA600A, loa BMB, đầu phát youtube trên laptop đấu qua soundcard Blaster Creative (Micro shure Sm58 xịn, không dây). Khi tôi mua kỹ thuật họ chỉnh cho tôi, về nhà chỉ gắn vào mở lên hát. Xảy ra vấn đề thế này : khi mở micro lên thử (không nhạc) thì tiếng rất to và rõ, delay và reverb tạo vang rất tốt. Nhưng khi mở nhạc lên hát thì, tiếng hát hơi nhỏ, không được thánh thoát, nhạc và lời hát không hoà hợp. Anh có thể giúp tôi giải quyết vấn đề trên hoặc anh có thể gửi cho tôi SCENE anh đang chơi qua email : lehoangson1983@gmail.com. Thanks anh !
  11. lehoangson1983
    Idol ip 200 là thiết bị nâng tiếng hát, còn Sonic exciter sx 3040 Behringer có phải là thiết bị nâng tiếng hát không anh em ? Nếu 2 con này đều là thiết bị nâng tiếng thì nên chọn con nào để ghép với Mixer Behringer XR12 để tạo hiệu ứng âm thanh và lời ca hay hơn vậy anh em ? Tôi đang dùng Mixer Behringer XR12. Anh em chỉ giáo giúp tôi. Thanks !
  12. tranman
    tranman Moderator
    Để chỉnh tốt mixer, cần phải chỉnh thực tế trên bộ dàn đang sử dụng. Vì mỗi bộ dàn khác nhau sẽ cần chỉnh các thông số khác nhau.
    Do vậy, dù mixer đã được cân chỉnh hay tại cửa hàng, khi ráp mixer vào bộ dàn của bác, bác cần phải chỉnh lại một chút, cần nhất là chỉnh về micro, bao gồm: chỉnh volume micro đầu vào (MIC gain - input), chỉnh Gate / EQ / Compressor và EF (effect) của Micro.
    Việc chỉnh micro đúng là cực kỳ quan trọng:
    + vì nếu chỉnh thiếu MIC gain, tiếng hát sẽ yếu không đủ lực, mở volume lớn thì bị hú, effect nghe không hay...
    + nếu chỉnh dư MIC gain thì khi hát lớn hoặc kết hợp vài effect sẽ gây hú...
    Trong bài viết này, mình sẽ giúp bác chỉnh volume của MIC đúng (với scene đã được cài đặt sẵn), bác thử làm theo cách sau:
    1/ Cài đặt các kênh:
    - Giả sử cài đặt kênh 1 là MIC-1, kênh 2 là MIC-2, còn kênh 3&4 là kênh nhạc nền music (link 2 kênh này để tạo LR).
    - Còn effect vẫn giữ nguyên như khi người bán cài đặt.
    - Bài viết này sẽ không đề cập đến các Bus, do vậy nên tắt volume tất cả các bus. Hoặc cài scene nào không dùng Bus. Việc chỉnh đúng, sau đó thêm bus vào là không khó, có thể bổ sung về phần bus này trong bài viết sau.
    2/ Tắt volume:
    - Trong màn hình chính (MAIN) để tất cả các thanh volume MIC / Music về số thấp nhất.
    - Ngay cả volume của MAIN LR (xuất ra loa) cũng đưa về thấp nhất.
    - Các effect tạm thời tắt tiếng (không giảm volume cài đặt sẵn của effect).
    - Kênh MAIN nên tắt Comp. Phần EQ thì bật ON (mặc định nó sẽ là đường thẳng, các trị số bằng 0, cách chỉnh EQ này có thể tham khảo trên mạng, giống như cách chỉnh EQ rời).
    3/ Chỉnh volume nhạc nền:
    Trước khi chỉnh MIC, ta cần chỉnh thử volume của nhạc nền.
    - Trong màn hình Input của kênh Music (3+4), ta chỉnh gain nhạc ở mức 0.
    - Màn hình Gate kênh Music (3+4), bấm Noise Gate và chỉnh Threhold ở mức -60 (hoặc -65).
    - Màn hình EQ kênh Music (3+4), có thể chỉnh tùy theo ý thích hoặc có thể tắt.
    - Màn hình Comp kênh Music (3+4), nếu không biết chỉnh thì tốt nhất nên bỏ chọn Compressor, vì nếu chỉnh thông số không đúng sẽ dẫn đến việc nhạc nền khi to khi nhỏ không đều.
    - Phát nhạc nền, đưa tiếng nhạc vào kênh Music (kênh số 3+4).
    - Trong màn hình MAIN, tăng volume nhạc (kênh 3+4) từ thấp nhất đến mức 0.
    - Sau đó tăng dần volume của MAIN LR từ mức thấp nhất đến mức âm thanh của nền nhạc mình muốn nghe khi hát thực tế.
    - **Lưu ý:
    + Mức volume của MAIN LR nên để nhỏ hơn 0. Nếu volume MAIN LR đến 0 mà tiếng nhạc nền còn chưa đủ, thì ta sẽ tăng volume nhạc nền bằng cách tăng Gain Input trong màn hình Input của kênh 3+4 này.
    + Volume của pow (amplifier) đừng để nhỏ quá vì sẽ rất khó chỉnh mixer đúng. Nên đặt volume pow (nếu pow có volume) ở mức tương đối lớn (khoảng mức 9-10 giờ hoặc hơn, tùy pow).
    - Sau bước 3 này, ta có có thể ước lượng volume (tối đa) của MAIN LR cho bộ dàn của mình.
    4/ Chỉnh volume MIC (MIC gain, Gate, EQ, Comp):
    Giờ thì đến lúc chỉnh volume của MIC. Tắt nhạc và trả volume của kênh Music (3+4) về mức thấp nhất, volume MAIN LR vẫn giữ như ở bước 3.
    - Ở màn hình Input của kênh 1, chỉnh MIC Gain về thấp nhất (-12).
    - Trong màn hình Gate của kênh 1, chọn Noise Gate, và chọn Vocal, nhấn ok. Thông số mặc định của Threshold lúc này là -44, nếu muốn micro nhạy hơn, nghe cả tiếng thì thào thì nên mở cổng này rộng hơn lên -65 đến -70.
    - Màn hình EQ của kênh 1 tạm thời tắt EQ.
    - Màn hình Comp của kênh 1, chọn Compressor, chọn Vocal, nhấn ok. Sau đó giảm Ratio từ 3.0 xuống 2.0. Có thể tăng Gain từ 6.0 lên 8.0 (để nâng tiếng micro, hát nhẹ hơn và phần effect cũng rõ hơn).
    - Cắm micro vào kênh 1 (MIC-1).
    - Tăng volume MIC-1 ở màn hình chính từ thấp nhất lên mức 0.
    - Đến đây thì trở lại màn hình Input của kênh 1, thử nói và tăng dần phần MIC Gain lên đến khi chạm ngưỡng hú thì dừng lại (cần nói lớn chút hoặc hát 1 đoạn cao của bài nhạc để thử micro).
    - Trong quá trình chỉnh ngưỡng volume hú của micro, ta có thể chỉnh EQ của micro theo ý thích.
    5/ Chỉnh Effect của Micro (dành cho scene đã cài effect sẵn):
    Sau bước 3, ta có có thể ước lượng được volume (tối đa) của MAIN LR cho bộ dàn của mình.
    Sau bước 4, ta đã có mức volume MIC (tạm chuẩn) cho bộ dàn của mình.
    Giờ thì đến việc ghép effect và micro để chỉnh mức volume MIC chuẩn hơn.
    Bước 5, ta bật từng effect lên (trong bước 1 ta đã tạm tắt tiếng effect) và hát thử. Chọn bộ effect và mức volume effect mà mình cảm thấy thích. Nếu không biết chỉnh thì giữ nguyên volume và effect như khi người bán cài đặt, chắc sẽ ổn.
    Không nên chỉnh volume effect quá nhiều (tầm -10 đến 5, ổn nhất là khoảng gần 0). Nếu trong quá trình chỉnh bị hú thì giảm chút volume của micro (thanh volume kênh 1).
    * Nếu cài đặt mới, thì việc chỉnh effect cần thêm 1 vài công đoạn đơn giản (chọn effect, chỉnh volume Send / Return của effect), nếu chỉnh sâu hơn các thông số bên trong từng effect thì sẽ phức tạp hơn. Nếu sau này có thời gian mình sẽ nói thêm về effect.
    * Đối với MIC-2, ta chỉ cần copy&paste các thông số của MIC-1 qua.
    6/ Hoàn thành phối ghép volume của nhạc nền + Micro + Effect:
    - Sau bước 5, ta đã có volume chuẩn của Micro + Effect và volume của MAIN LR.
    - Bước 6 này thì đơn giản hơn, chỉ cần bật nhạc nền (kênh 3+4), hát thử và tăng dần volume nhạc nền đến mức mong muốn.
    - Nếu tiếng nhạc nền đủ to mà tiếng micro còn nhỏ, ta làm theo cách sau:
    + Giảm volume tiếng nhạc khoảng -5, giảm volume MAIN LR khoảng -5, tăng volume của amply lên 1 hoặc 2 nấc (sao cho nói lớn mà micro không bị hú).
    + tăng dần volume của nhạc nền đến mức mong muốn.
    + Nếu tiếng hát còn nhỏ, tiếp tục việc giảm volume MAIN LR (mỗi lần khoảng -2) và tăng volume amply như trên.
    - Đến đây thì nếu chỉnh kỹ ta có thể ghép xong tiếng nhạc nền + micro + effect, hát thoải mái nhẹ nhàng.
    Save lại scene này, ví dụ đặt tên là "Scene Karaoke", tốt nhất là nên sao lưu scene này để làm file nền chỉnh cho các scene khác sau này. Trước khi lưu scene, nhớ tắt (mute) volume MAIN LR, để đảm bảo khi load scene này vào thì mixer sẽ không phát nhạc đột ngột ra loa (lưu ý rất quan trọng khi lưu scene, nhiều người thường không quan tâm đển việc này).
    - Trong quá trình chỉnh ở bước cuối này, ta có thể tinh chỉnh thêm các hạng mục tùy thích, sau đó lưu lại với tên scene mới.
    7/ Record (ghi âm vào thẻ USB):
    - Với mixer này thì việc ghi âm quá dễ dàng. Chỉ cắm usb vào và bấm nút ghi âm, khi nào muốn dừng ghi âm thì bấm nút Stop. Sau đó bấm nút Play sẽ phát lại đoạn ghi âm sau cùng. Nếu ghi âm nhiều bài, có thể chọn bài để phát (thao tác khá đơn giản nên mình không cần nói kỹ hơn).
    - Nếu chỉnh theo cách trên, phần Auto Mix sẽ không sử dụng đến (nên tắt).
    8/ Bus:
    - Việc đưa các kênh ra bus, xuất bus ra MAIN LR hoặc không xuất ... cũng không quá khó. Nếu có thời gian mình sẽ viết thêm.
    - Nếu đưa thêm kênh micro/ music/ effect ra bus, sau đó xuất bus ra MAIN LR, sẽ làm tăng volume tổng của MAIN LR (nếu đưa càng nhiều bus xuất ra MAIN LR thì volume tổng càng tăng cao). Do vậy phải chỉnh lại nhiều thông số (như các bước trên) để micro không bị hú khi hát.
    Kết luận:
    - Việc dùng scene cài đặt sẵn của người khác, đôi khi áp dụng cho bộ dàn của mình sẽ không hay, gây hú rít micro, hát bị bí tiếng hay quá vang, nền nhạc quá lớn hay quá nhỏ... do vậy việc chỉnh lại thông số là cần thiết.
    @ghi chú:
    - Phần chỉnh EQ cho tiếng nhạc, tiếng MIC có khá nhiều bài hướng dẫn trên Youtube và internet.
    - Phần chỉnh sâu các thông số bên trong từng effect cũng được tư vấn rất nhiều trên Youtube và internet, mọi người có thể tham khảo thêm.
    - Đối với mixer digital, chỉ cần lưu scene là ta có thể sáng tạo ra nhiều chế độ effect theo riêng ý mình, các bác nào thích vọc thì thoải mái kết hợp các effect nhé. Công dụng từng effect đã ghi trong bài viết ở phía trên.
    Hy vọng bài viết trên hữu ích cho các bác.
    Thân chào.
    TranMan
  13. lehoangson1983
    Cảm ơn anh rất nhiều, tôi sẽ nâng cấp lên cục đẩy main crown XLI 1500 (330 W/kênh-8 ôm). Loa BMB (200-400W/kênh-8 ôm), ghép với Mixer Behringer XR12. Điều tôi muốn ở đây là nâng tiếng nhạc và lời hát trở nên bay bổng, mạnh mẽ, tạo nên hiệu ứng âm thanh vang lên mang hơi hám giống giống 3D như âm thanh sân khấu, đám cưới giúp cho mình hưng phấn khi hát hò. Tôi có tìm hiểu 2 thiết bị này :
    1/ Nâng tiếng Behringer Sonic Exciter SX3040
    2/ Hiệu ứng BEHRINGER VIRTUALIZER 3D FX2000.
    Nếu tôi đầu tư thêm 1 trong 2 con này có giúp dàn karaoke của tôi làm được như vậy không ?
    Thanks anh !
  14. dokien
    1/ Nâng tiếng Behringer Sonic Exciter SX3040: con này ko có effect chỉnh hát hò, bạn đừng mua vì ko đúng với yc của bạn.
    2/ Hiệu ứng BEHRINGER VIRTUALIZER 3D FX2000: có nhiều effect rất hay mà rẻ, đáng chơi
    Phần dưới bạn hỏi thì mình cũng xin trả lời:
    Bạn muốn bay bổng 3D như âm thanh sân khấu thì chân thành khuyên bạn đổi bộ loa vì chỉ có loa sân khấu mới đáp ứng được yêu cầu của bạn. Trong Xr12 có đủ đồ chơi (mình k muốn nói là dư đối với hát KTV gia đình), và như anh Tranman đã nói "Để chỉnh tốt mixer, cần phải chỉnh thực tế trên bộ dàn đang sử dụng". Chỉ có bạn tự chỉnh hoặc thuê soundman chuyên nghiệp đến làm thì bạn mới ưng cái bụng, nhưng bạn nên đổi loa cho đỡ loay hoay.
    Kênh Youtube của bạn David Tuấn khá nhiều clip hướng dẫn về Behringer XR
    1 số dòng loa Behringer active nghe rất khá mà giá rẻ, tầm 5trxx-1xtrxxx/cái bạn có thể tham khảo
    tranman likes this.
  15. lehoangson1983
    Cảm ơn anh Tranman rất nhiều, tôi đã chỉnh lại Mixer Behringer XR 12, thực sự quá bất ngờ luôn, âm thanh rất hay và to, tiếng hát cũng trở nên nhẹ nhàng và thánh thoát không chê vào đâu được. Quan trọng là giữa tiếng nhạc và lời hát hoà nguyện vào nhau rất tuyệt vời và qua đây cũng cho tôi gửi lời cảm ơn đến anh dokien.
    Anh em cứ chỉnh mixer Behringer XR12 như hướng dẫn của cao nhân Tranman, bảo đảm hay không thể diễn tả bằng lời được đâu ! Anh em nào gặp khó khăn, cứ inbox và để lại email cho tôi, tôi sẽ gửi cho anh em scene tôi đã chỉnh xong như của cao nhân Tranman cho mọi người.
    Thanks !
    shinichi1908 and tranman like this.
  16. Kevin901
    Kevin901 Approved Member
    Ban cho minh xin scene cam on
    kevincao902@gmail.com
  17. Tây Môn Khánh
    Cục đẩy Crest mua bao nhiêu đấy cụ ?
    Dùng cục đẩy + vang số hát nó "live" hơn Jargard cụ nhỉ ?
  18. lehoangson1983
    Đúng rồi anh hát nó “Live” hơn, nhạc tính hơn, âm thanh sáng, chắc và mạnh mẽ hơn nhưng cân chỉnh Mixer để phù hợp với giọng hát của mình hơi nhức đầu chút Hihi. Giá main Crest Audio CC1800 đang khuyến mãi cực tốt (8 triệu - công ty nhạc Việt) giá bình thường 15 triệu, mua trực tiếp trên amazon hay từ USA về cũng từ trên 15 triệu. Thân !
    Tây Môn Khánh likes this.
  19. chanoikhanh
    chanoikhanh Approved Member
    Các bác cho hỏi xxx cái là xr12 này nếu so với soundcraft ui12 thì cái nào hơn ạ ?
  20. tranman
    tranman Moderator
    Giữa 2 con này thì bác nên chọn XR12, nhiều tiền hơn và cần ghép nhiều line hơn thì dùng XR18.
    chanoikhanh likes this.
  21. chanoikhanh
    Cảm ơn bác nhiều lắm
  22. luong quoc huy
    luong quoc huy New Member
    Chào các anh.
    Em hỏi thăm muốn set đường sub ra AUX của XR12 nhưng không muốn cắt đường mic thì làm thế nào ạ. Vì hiện giờ con của em vẫn ra tiếng mic của sub nên bị ù do hú của mic.
    Cám ơn các anh.
  23. luong quoc huy
    Em xin lỗi. Ý em là muốn cắt tiếng mic ra sub
  24. Tây Môn Khánh
    Ví dụ sub đang ở Aux 1 - Bus 1, trong bus 1 kéo volume của kênh mic in về thấp nhất, các kênh nhạc vẫn bình thường.
    dokien and 5HIEN like this.
  25. diepnh81
    diepnh81 Advanced Member
    Đọc 1 hồi các bác e thấy hay quá, đang tính nâng cấp từ ampli calipro 468b xịn Mỹ lên pow crown 800 csl và vang kx180 để đánh 2 cặp loa bose 301/3 và bmb 252 nhưng có cụ bảo lên thế tiếng khô còn thua con cali 468 xịn nên phân vân, theo các cụ chơi xr12 hay hơn vang số kx180 và cali 468b nhiều ko cụ để e nhẩy vào hố vôi
