Dây nguồn có vẻ ko ảnh hưởng gì đến chất lượng âm thanh
Discussion in 'Phụ kiện' started by Chim Sâu, 4/7/22.
  1. cuongtruongvan
    cuongtruongvan Advanced Member
    Tôi có bộ giàn, theo tôi cũng khá nhung tôi cũng không phân biệt sự khác biệt của nhạc khi thay dây nguồn, trừ dây quá nhỏ như dây máy tính. Tôi cũng hay xem các cuộc tranh luận trên audiogon, tôi thấy đồng quan điểm với ông này:
    bigddesign3
    12-14-2018 8:16am
    My take on power cords....
    Power cords are something that need to transfer power from the outlet. The power cords quality of copper is important, and so is the gauge for power amplifiers. What is a safe gauge for amplifier cords drawing a full 20 amps? 10 to 12 guage is enough, but you can buy power cords 7 gauge. The connectors just have to be designed to get the full power of the cable to the amplifier. Makes me wonder why there are power cords that are audiophile cords. The audiophile cords come up with some science that allow the company to charge crazy money. Seems to me that there are just filters built into the cable to change the sound. The designers of amplifiers want the best pure AC power thru copper to come into their powerful amplifiers. And then the amplifier takes care of that power. The best amp designs store enough power inside the amp, and don't stress the power cord at all. Does this wonderful amplifier want filtered power going into the amp from the wall? I would think not. But every amplifier you see at the shows have cables that cost as much as some equipment. I'm not saying that these cables don't change the sound, compared to a good standard cable design. What I'm saying is that these audiophile cables are filtering the sound before it hits the amplifier. This, in itself should not be what the amplifier is looking for. Now this is just an opinion from someone that believes in cables. Just not these $2,000 or more Power Cables. I call these audiophile cables a way of coloring the sound before reaching the amplifier.
    Now the most important that you can do for your system is 2 dedicated 20 amp lines put into your sound room with quality outlets. The difference in sound will be amazing with the amplifier on one circuit, and the rest on the other 20 amp line. If you want the electrician to put Romex 10/3 wiring, you can have a bit of reserve power with Monoblock amps. The dedicated power lines are the best expense you can make. If you have funky power in your town, that you can try some of the high end power stations out there. I would take this advice on where to put your money. My workstation for my computer systems use a number of Uninterruptible Power Supplies (UPS) to get the AC power to sine wave levels. I used to live in a place where there were brownouts like mad. Now I live where the power grid doesn't overload. But any spikes or drops with computer equipment will wear your equipment out. And having battery backup when doing mission critical work on the computer is just as important as backup. But for my stereo system I use AVRs (automatic voltage regulators) for all the equipment other than the amplifier. I calculate how much power draw I want from each AVR and add the amount of them I deem using no more than 40% of the AVRs power envelope. Currently I use 2 of them from APC. They cost around $70 each and are so worth it to make sure there are no voltage drops or spikes going into your expensive equipment. Do you see how cheap these AVRs are? If it was an audiophile item, it would be $2,000. I can only say use your head when spending money. Just an example...... instead of expensive power cords..... get yourself a good streamer, or a better DAC.
    I am not an authority on Power Cords. I just know the science, and have grown up with a Dad that was a wiring genius. I also spent 40 years myself in the industry of audio and being a moonlighting electrician with my Dad. He was an engineer for General Motors. We were wiring and building just about anything you could dream of. It just doesn't make sense to throw all that cash to go along with the audiophile community. It's a high quality copper wire going into the amp that is all it should be.
    và về inter connect cable:
    The Naked Truth about Interconnect Cables
    Cables. Not that old HiFi chestnut again!
    Quick, shut him up HE IS GOING TO TALK ABOUT CABLES!
    The naked truth about cables? It is simply, that all this cable nonsense is Bovine Excrement!
    I am sure some of your initial reactions where like this.
    To write about Cables anywhere is an open invitation to be barbecued. Flame-bait par excellence. Still, I'm going to talk about Cables. And not just any Cables, I'm going to talk about Interconnect Cables.
    And I'm going to say that Interconnect Cables make a difference.
    Do you start to question my sanity? Well, I better type fast, so I can get this all out before the men in white take me away.
    Honestly, Cables make a difference. And "wrong "cables can make the wrong difference.
    In my experience speaker cables make the greater difference, maybe because they are usually a lot longer. Interconnects do however still make a difference.
    True, neither type of cable will make a huge difference. Swapping the cheap and nasty NE5532 Op-Amp in a CD-Player Output-Stage for a really nice one (like the AD811 or my favorite Nat Semi LM6172) makes more of an audible difference.
    To get the ultimate from your system, you need the right cables.
    So what's in a Cable?
    Let's make a bold statement: "The best Cable is No Cable"
    Let's make another one: "The Ideal Cable does not change the Signal traveling through it in ANY way."
    Let's make a third one: "No Cable can improve the sound-quality of a system, they only make it worse in varying degrees."
    And indeed, the best Cables I came across make things worse only a very little bit. The worst however....
    I personally divide "effects" in audio into three "orders". These refer both to magnitude of effects and to the "obscurity" of the underlying principles.
    First Order effects are those that produce massive and immediate changes to the sound. First Order Effects also mostly tend to have a direct, simple, logical and scientific explanation.
    To elaborate, for interconnects capacitance is a first order effect. Use Goertz Interconnects (these are essentially unrolled capacitors) for a few meters and most sources will substantially roll off the treble due to the excessive Capacitance of the Cable.
    Second Order effects make appreciable differences but are harder to pin down with logical explanations, though in most cases they exist and can be found.
    To elaborate, the sonic difference between stranded cable, litz/hyperlitz cable and solid-core cable falls into this category, as does the dielectrical quality. Both matter quite a lot, but ultimately, if our cable has massive problems with First Order Effects any second order effects (for better or worse) will often be swamped out by these.
    Third Order effects are way down and also, in many systems the resolution of the System is not high enough to seriously magnify the differences. In my own system I only begin to get a handle on third order effects.
    I think the Conductor-material argument (silver vs. copper vs. plated copper vs. exotic conductors) falls into this category.
    Cables have a sound!? How?
    I have said; the ideal cable does not alter the signal.
    Sound is a complex acoustic waveform, transformed into electrical signals at the time of recording. It is these signals that we want to keep as intact as possible.
    We can describe these waveforms in terms of timbral, dynamic and temporal accuracy. All these have electrical equivalents. For my various bits of accuracy a lot of math is around to do it all scientifically. I personally prefer to stick to the "popular science" approach.
    Accurate Timbres mean the a voice or instrument sound exactly as we would hear them normally. It includes both the harmonic structure (so no harmonic or intermodulation distortion please) and the basic frequency response.
    Accurate Dynamics mean that the Dynamic Swing of the Signal (music) from the recording should not be reduced. Most Cables usually manage that (as they are passive devices).
    Accurate Timing includes a few effects. There is some heavy math from Prof. Malcom Hawkesford on the Maxwell effect, which stipulates that different frequencies travel with different speed through a piece of wire. Then there are phase-effects from both the lowpass filter function of the cable and the skin effect.
    Now all these effects listed above can usually be quantified in one way or the other, though it is rarely done and many of these measurements are still being treated as suspect by "mainstream" audio.
    If we know what to measure we can easily analyse all first-order effects of the Cable. This simple electric's. We need to determine the complex Impedance of the cable, read all the capacitance's, resistance's and inductance's in the cable.
    >From here on it gets fairly technical. If you just want to know which Cable I think sounds best and how to cheaply make yourself some, just go to Now for a bit of practical stuff.
    The L, the C and the R
    To alter the sound passing through it least, the various parts making up the impedance must have such values, that little or no alteration happens for Audio-frequencies. Interestingly, (for me) Audio-Frequencies means 4Hz - 100kHz in order to guarantee no more than 0.1db deviation at 20Hz or 20kHz.
    If we look at the general impedance's in line-level interconnects, we find (usually) that the source-impedance is in the region of a few ohms to a few kilo-ohm. The load impedance ranges from about 10kOhm to about 1MOhm. The input capacitance is mostly very moderate too (100pF or less).
    This provides us with some indication as to the relevance of the various electrical parameters that matter.
    It seems that as long as the cable dc-resistance is being kept moderate (a few ohms) there will be little influence. The ratio between the cables resistance and the input resistance is very large. Indeed, the contact resistance of the RCA plugs used (terrible connector by the way) is often much larger.
    A loop resistance of 1Ohm when feeding a 10kOhm Amplifier input will cause an attenuation of 0.001db.
    The Cable inductance also matters little as long as it is kept moderate. The higher the load impedance is, the less relevant the Cable inductance becomes, the lower the load impedance is, the more relevant the cable inductance will become. Interconnect cables of about 1m (3') lengths rarely have an inductance of more than 1uH.
    At 20kHz a 1uH inductor will have an impedance of about 0.13 Ohm, causing an additional -0.0001db attenuation.
    Even with a 1nF input Capacitance in parallel with the 10kOhm Input Resistance (IEC Load) the attenuation by the Inductance is not significantly larger.
    The Cable Capacitance is however crucial for interconnects. I hinted at that when I explained my "first order effects". The Capacitance to cause a -0.1db Roll-off at 20kHz with a 100 Ohm Source Impedance is about 15nF. If our source Impedance is however 1kOhm, a 1.5nF Capacitance will cause this roll-off.
    I have seen Output impedance's of around 1kOhm in many pieces of mass produced Hi-Fi equipment. As the UK HiFi-Choice Magazine regularly prints Cable-Reviews that include technical sections with measurements, I can estimate the sort of maximal capacitance a cable may have. A capacitance of a few nF is easily accumulated on longer runs of various shielded cables, not to speak of the "unrolled capacitor" type Cables.
    I would conclude that in line-level interconnection the DC-Resistance and Inductance of the cable are of purely academic interest. Constructions with significant resistance or inductance will likely not manipulate the sound of the signal passing through it in any significant way.
    A capacitance as low as possible is however desirable. It seems also desirable to have the dielectric (read insulator) in the Cable to be of as good a Quality as possible.
    Given my (and many other peoples) experiences with Capacitors, Teflon seems the best solid dielectric, while Air is even better. Polyethylene is also quite acceptable as dielectric while lesser plastics and specifically PVC are out.
    Many commercial interconnect cables use PVC insulation.
    EMI - all I heard a gentle HUUUUMMMMMMMMMMMMMM
    Another one of my "first order effects" is of course the rejection of interference. This applies mostly to RFI but also lower frequency EMI can become a problem. The best rejection of external EMI and a good rejection of RFI seems to be achieved with woven constructions a'la Kimber and XLO.
    Closely twisted Pairs are also good at rejecting EMI (about -47db for the best) but the degree of RF rejection is not as good and capacitance is high. Most current commercial "specialist" cables use this topology.
    The worst for rejecting EMI and RFI is a "linear pair". Here simply two widely spaced wires are used. At the same time, I nevertheless had good success with this configuration.
    Another way to reduce RFI (but not much EMI) is to shield the Cable. Shielded Cables do of course have their own problems in first and second Order effects (though not insoluble).
    A variation on the shielded Pair is a cable where the shield also acts the "cold" conductor. These cables are known as co-axial cables and are the mainstay for Audio. The rejection of EMI in a coaxial cable is quite good. The cable that came packaged with your CD-Player is likely a coaxial cable.
    To strand, or not to strand - that is the question here
    (from Cabelitis, a very avantguard play - spoken by the Hero - the Son of an audio-cablemaker)
    As we already mentioned second order effects, lets have a look at some other relevant ones.
    In my experience all stranded Cables where each single conductor is made from several strands of copper that are not insulated from each other imparts an unpleasant harshness and brightness to the sound.
    There are a few theories why this is so, if you want to read one of the more nutcake flavored ones, it comes from Ben Duncan. He proposes that copper-oxide forms between the strands that encourages non-linear conduction (little "mV" Diodes).
    I shall keep out of this (there are pages full of letters on this in Wireless World), but as said I prefer solid conductors over stranded ones.
    Litz-Style cables where each conductor is insulated from the others are usually much better or we can use single strands of solid core wire.
    There is an argument that rectangular thin but wide conductors improve at the frequency extremes. Short of using Foil Tapes, one can use a few thin and round conductors (say 42 Gauge Magnet wire) run parallel, similar to the style of Cables from Nordost.
    One more second order effect is the interaction of the signal current (as small as it is) with the shield. This will induce eddy currents in the shield that again will degrade the sound. Plenty of spacing helps but again, it reduces the effectiveness of the shielding.
    Gold plated zirconium Cable in Carbon gels anyone?
    Third order effects as said are mostly shrouded in mystery and I have not found much of handle yet. There are people that dislike silver-plated copper intensely. I have not found that myself, however. So there you just follow your ear or your guru.
    There is the issue of conductor shape or diameter. All sorts of other neat little theories, including my own one.
    I for example say, that immersing the raw conductor in specific oil which is produced from a very rare and highly poisonous snake found in the Brazilian rain forest (and long on the list of endangered species) will provide more "texture" to the music as well as more "bite" to violins. The immersion process needs to be undertaken by certified vestal virgins who are sacrificed to the Audio-God's after completing their task.
    Unfortunately this is a very expensive process due to large numbers of native red Indian's who are bitten by the snakes when trying to collect them to get the oil as well as the large number of snakes needed to provide a small measure full of this precious oil. Also vestal virgins are getting kind'a rare (have I used them up too?). So do not expect an industrial application anytime soon.
    But I'm sure it works.
    Just believe me and buy my cable.
    It's a tad bit expensive, but you see, all the payoff's of the widows, orphans, virgins parents and so on....
    © Copyright 1998
    Wilson Fans likes this.
  2. mtbc
    mtbc Advanced Member
    Q3, Saigon
    Luận điểm trích dẫn thiếu sót cơ bản về truyền dẫn điện.
    1. Chưa cần tới ứng dụng audio gì đâu, chỉ nói tới điện nhà thôi. Ví dụ đơn giản như ảnh hưởng của vỏ dây: nhà em xài dây đồng nhưng vỏ nhựa dỏm của (...phaco), em dùng đồng hồ đo ra té ngửa vì khi tắt công tắt ngắt 1 sợi dây thì đo điện áp trên sợi dây đã bị ngắt đó vẫn ra tới 70V. Mua sợi vỏ dày hơn của Lioa thì hết.
    Vậy nói chỉ cần dây đồng tốt như bác kia là sai bét nhè.
    2. Lý giải về interconnect trong đoạn trên có khá hơn chút khi nói về cả RLC và dielectric, nhưng điều quan trọng là truyền dẫn bề mặt chịu ảnh hưởng của tính chất vật liệu, cách kéo, cách mạ... lại bỏ qua.
    Mượn kỹ thuật để nói về điều mình không biết hoặc sử dụng miền kiến thức này (điện nhà) để lý giải như đúng rồi cho miền kiến thức kia (điện sử dụng cho audio) thì thật nguy hiểm :p
  3. Wildbird
    Wildbird Advanced Member
    BTA - TPHCM
    Cụ cho em hỏi thế "điện sử dụng cho audio có khác gì điện nhà vậy?" và "điện nhà không được sử dụng để cung cấp cho đồ audio sao?"
    Em thực sự hổng hỉu!!!!
    Cụ làm cho em lo lắng quá vì giờ mới biết là dùng điện nhà cho đồ audio là quá sai rồi. Em đi tìm mua điện dùng cho đồ audio đây. Có bác nào biết chỗ nào bán thì chỉ giúp.
  4. mtbc
    Q3, Saigon
    Anh đang đọc đó chứ anh lớn :)
    Hay là em viết cho rõ: dùng điện cho thiết bị điện như bóng đèn, nồi cơm, máy bơm… ở nhà và dùng điện cho dàn audio nha
  5. phongvan2000
    phongvan2000 Advanced Member
    Trước tới giờ gần 6 năm rồi, chôn vùi em vào sâu mấy tầng đất,giờ mới moi em ra để em cống hiến, tỏa sáng cho cuộc chơi này, em là cội nguồn cho mọi vấn đề , em tên là Supra Lorad 3X2.5 MK2[​IMG]
    6 sợi dây nguồn audio cấp thẳng cho 4 ổ cắm , khi chôn tường bằng những sợi dây nguồn này thì ổ cắm thể loại 3..4 tr như Furutech hay Wattgate nó mới phát huy hết bản chất và công lực chứ còn dăm ba cái loại cáp Trần Phú với Cadivi chôn tường thì có đấu vào cũng chỉ làm cho ổ cắm Furu mạ Rodium hay Audioquest nrg mạ Ag trở thành Phế Vật mà thôi:p:p:p:p
    Khi dân tình vẫn còn đang bàn tán, phân vân- hoang mang , dè bỉu, hoài nghi, Tai Trâu - Tai Dơi-Tai Bò, tôn nhau lên Thánh , dìm nhau xuống hố, cá độ bóng bánh ,cả topic hơn 100 trang vì sự biến ảo của dòng điện và nguồn điện có tác dụng như thế nào đến âm nhạc thì tớ đây đã đặt mua ở nước ngoài cái thiết bị bảo vệ ATM sản xuất tại Đức này từ 6 năm về trước rồi
    Mấy ai ở đây mà đã biết chơi , dám chơi đến cái thứ này, dăm ba mấy cái hàng công nghiệp được mấy ông shop VN Feolinh..feolom chế cháo chọc choẹt mà đòi công nghệ -196 độ ư ??? Bùn cười
    [​IMG][​IMG]
    Ở đây không những Cryo mà còn mạ vàng 24k các tiếp điểm đấu dây , đến con ốc vít bắt cũng là ốc thép không từ tính
    Mình là thợ điện Thủ Đô nên đồ chơi chuyên môn trong nghề của mình ý mà
    " Đây không là Thứ 2 thì xin lỗi cuộc đời ,chỉ có thể loại này mới là Chủ Nhật nhá " :p:p:p:p:p
    Rồi cho các em gặp gỡ và chọc ngoáy cắm vào nhau thôi, trinh nguyên đến mấy thì cũng phải cởi quần giao hòa..giao hợp thôi;);)
    Khi mình là thợ điện , được đào tạo thi công cáp ngầm thì kiến thức của mình đọc tài liệu nước ngoài về tác dụng của các lớp bảo vệ nó giúp ích nhiều lắm, chính cái phần dây bọc xung quanh cáp Supra kia là phần bảo vệ chống nhiễu điện từ (EMI) , không biết mà cắt bỏ nó đi hay ko biết đấu vào chỗ nào thì cáp nguồn audio tiền triệu cũng chỉ là cáp điện Trần Phú cao cấp thôi á :p:p
    Chơi mà không có kiến thức , thời gian tìm đọc, hiểu tài liệu chuyên sâu của hãng , không biết cách thi công cáp nguồn thì chỉ tốn tiền, tốn công mà thôi ;););)
    MUÔN ĐỜI VÀ MÃI MÃI TEST MÙ VỚI SÁNG CŨNG KHÔNG PHÂN BIỆT NỔI DÂY CẮM NỒI CƠM ĐIỆN NÓ KHÁC DÂY NGUỒN AUDIO TIỀN TRIỆU VIỆT- NGÀN MỸ Ở CÁI NỐT NHẠC NÀO ĐÂU
    TRONG CUỘC CHƠI AUDIO NÀY CÁC BÁC MÃI..MÃI VẪN CHỈ ĐANG Ở TRONG CHỖ TỐI TĂM ,U MÊ - LẠC LỐI MÀ THÔI. CỨ Ở ĐẤY ĐI
    MÌNH ĐI ĐẾN CÕI NIẾT BÀN , ĐẠT ĐẾN CẢNH GIỚI "ĐẮC ĐẠO" PHIÊU DU QUỶ MỊ TỪ LÂU RỒI
    nkdang and Thanh Tam like this.
  6. Wildbird
    BTA - TPHCM
    Theo em bít thì điện dùng cho audio cũng là điện dùng cho thiết bị điện mà. Có cái gì sai khác đâu nhở.
    Mà cũng đâu có cái hãng audio nào nói rằng bắt buộc phải dùng điện gì khác với điện nhà đâu? Thiết bị audio ghi rõ ở phía sau máy là dùng nguồn điện 100/110/120/220V xoay chiều tức là nguồn điện nhà đang dùng cho tất cả các thiết bị dùng điện chứ có cái điện gì gọi là for audio đâu nhở.
    Ờ, mà nếu có loại điện cho thiết bị audio thì em cũng mua về dùng thử cho biết. Chắc là ngon lém. Chỉ tiếc là ... loại điện này hổng thấy có bán trên thị trường.
    Note: Cụ có thể viết rằng nên chia nguồn điện nhà cho khu vực riêng dùng cho thiết bị audio rồi nghịch ngợm chi đó trong khu vực này thì em đồng ý chứ ... phát biểu rằng nó hổng phải điện nhà thì chắc hổng phải riêng em mà còn rất nhiều bác khác phản đối à nha.
    nkdang likes this.
  7. mtbc
    Q3, Saigon
    Em đồng ý với anh Chim Lớn :D
  8. Wildbird
    BTA - TPHCM
    Thiện tai, thiện tai
  9. lethanhngoc
    lethanhngoc Advanced Member
    haha. lâu lâu xóm dây nguồn nổi lên chưa bao giờ hết va chạm. Thôi coi dây nguồn là thuốc lá cũng được, độc hại có bao giờ dẹp đc nó đâu. Ai cũng khôn cả ;););)
  10. cuongtruongvan
    Bác nào có tai nghe được sự khác biệt khi thay dây nguồn của theo thiết bị với dây nguồn các hãng khác thì rất sung sướng vì lâu lâu muốn đổi gió chỉ thay dây. Còn như mình không phân biệt được khi thay dây nguồn thì mất sự sung sướng này, nhưng được cái không phải lăn tăn về dây nữa và cũng không tốn nhiều tiên để thay dây. Mình đã đọc và tự rút mình rút ra kinh nghiệm: phải nghe thử, nghe nhiều loại nhạc, nhiều thời điểm khác nhau, nếu không thấy khác biệt thì không mua dây đắt tiền.
  11. nkdang
    nkdang Approved Member
    Cá nhân e nghe nhạc từ 1-2 giờ sáng là cảm thấy khác hơn, ko biết có bác nào cùng chung cảnh ngộ giống e ko ? (ít nhiều tuỳ các bác cảm nhận)
    cuongtruongvan likes this.
  12. TrueHD
    TrueHD Advanced Member
    Thực tế trải nghiệm của em là không có vụ "đổi gió" nào đâu. Chỉ có chính xác và màu âm thôi !!
    Dây/ phụ kiện có xu hướng cho âm thanh chính xác (nên cũng thường cho âm trường rộng). Nó hợp với các bản thu tốt (ca sỹ tốt, nhạc công tốt, ghi âm tốt....) và các loại nhạc "nặng đô" sử dụng nhiều nhạc cụ acoustic như classical, cross-over... Dây này thường có xuất hiện bạc/mạ bạc
    Dây/ phụ kiện (nhất là dây Nhật) cho màu âm, thực ra là làm biến đổi âm thanh theo hướng loại bỏ bớt phần chi tiết (đặc biệt ở dải cao), đẩy trung âm lên, nhất là trung trầm làm bass cũng "đậm hơn" ... do đó thường "vo tròn" âm thanh lại, âm trường vì thế cũng thu hẹp. Nó ngược lại với loại "chính xác" nêu trên. Dây loại này thường là đồng.
    Do đó, vụ đổi gió không có mà chỉ có phù hợp hay không. Ví dụ nếu thích nghe tí mùi mẫn, nhão lòng của nhạc Vàng hay những bản ghi âm từ thời kỳ 1980s mà ko muốn đổi loa thì em xài dây "mầu âm". Tuy nhiên, tác động của phụ kiện không thể mạnh mẽ bằng thiết bị chính được. Dễ dàng nhất là đổi DAC hoặc đổi bộ lọc trong Player
    Thanh Tam likes this.
  13. cuongtruongvan
    Cái cảm nhận của bạn thấy đọc trong các topic audio, nhiều người cũng trải qua vì khả năng tiếp nhận nhạc, và theo mình cả đọc sách, xem phim sẽ phụ thuộc vào trạng thái, sức khỏe tinh thần và cả thể chất của người nghe. Mình rảnh rổi nên nghe nhạc thích nhật là buổi sáng, sau khi ăn sáng vừa cafe vừa nghe nhạc. Sau khi ăn tối lại không thích nghe nhạc nữa, thích đọc sách hoặc xem phim.
  14. cuongtruongvan
    Chắc bác đang nói về dây IC và dây loa chứ tôi chưa nghe ai nói dây nguồn có "mầu âm". Dây nguồn nó chỉ có thể cung cấp đủ hoặc thiếu dòng điện cho thiết bị và có bị nhiễu lọt vào khi truyền điện thôi.
    POCOLO likes this.
  15. FieldCoil Adventure
    FieldCoil Adventure Advanced Member
    D
    Đó cũng là điều hiển nhiên. Thời điểm đó ,không gian yên tĩnh cũng như hầu như không có nhiều tác động bên ngoài. Âm thanh sẽ rõ ràng hơn, và việc tập trung nghe nhạc nhiều hơn.
  16. lethanhngoc
    Màu âm dây loa hiểu sao cho đúng vậy bác?
  17. cuongtruongvan
    Mình nói lại ý bác TrueHD ở trên thôi chứ mình cũng không biết.
  18. tuanhcm
    tuanhcm Advanced Member
    Màu âm có lẽ ở đây không phải là nghĩa đen như màu xanh màu đỏ, mà là âm thanh mang lại khi phối bộ giàn kết hợp cặp dây loa dây av,dây nguồn.
  19. Haolq
    Haolq Advanced Member
    Nói chung bán ve chai toàn bộ dây nguồn, phụ kiện ... dồn tiền vào làm cặp Raidho TD6 thôi các bác, show Hiend cho thấy cầu chì QSA, Stromtank , ... chả có tâc dụng gì . Âm thanh chỉ loa và ampli, nguồn phát quyết định . Đặc biệt là loa, nó mới là đặc trưng âm thanh của dàn máy .
    Tuilaai and cuongtruongvan like this.
  20. cuongtruongvan
    Trải nghiệm của bạn giống của mình. Dây dợ chỉ giá 5% bộ dàn của mình.
  21. Haolq
    Ví dụ cặp Wilson Shasha ghép với FM Acoustic của Đông Thành, các anh có đổ 10tr usd phụ kiện cũng chỉ hít khói cặp Raidho TD6 và Pow Moon 888 của Nguyễn Audio giá ~ 300k usd .
  22. Chucuimia
    Chucuimia Advanced Member
    Cái so sánh của bác quá là khập khiễng rồi, giống bác nói dàn mini Denon có chơi dây dẫn 10 tỷ cũng ko thể bằng Naim-Proac vậy đó. Gió tầng nào mây tầng đó thôi bác, chơi sao cảm thấy hài lòng nhất đối với mình là được. Em thì ko phản biện hoặc đồng tình với những gì các bác comt trên đây, nhưng cái nào e thấy các bác chia sẽ hay thì em sẽ thử và trải nghiệm trong điều kiện cho phép của mình rồi mới dám phát biểu.
    Vinhoankiem, Vu01 and Wilson Fans like this.
  23. Haolq
    Tuỳ các bác, chơi audio mà bị Định hướng- thuốc "Phụ kiện" ngay từ đầu là chỉ có chết - bị thương thôi .
  24. Chucuimia
    Bác khuyên mọi người bán hết dàn cũ và dây dẫn phụ kiện chỉ để mua cặp loa TD6 thì đó mới là sự "Định hướng và thuốc xa xỉ nhất đó", nếu có điều kiện thì bác làm thử bộ đó và dùng tất cả dây Trần Phú rồi cho ae nghe ít cảm nhận về trải nghiệm của bác. Âm nhạc là nghệ thuật cảm nhận riêng tùy theo mỗi cá nhân, liệu cơm gắp mắm tùy theo hoàn cảnh kinh tế từng người và cảm thấy hài lòng, đó mới là ko bị Thuốc.
  25. Wilson Fans
    Wilson Fans Advanced Member
    TPHCM
    Bạn thấy ở đâu ghép vậy chưa hay là tự nghĩ ra thế ?
    Vinhoankiem likes this.
