Em thấy ebay bán em này rẻ quá , cũng dùng chip 24 bit WM8740 cao cấp như mấy em Arcam FMJ CD đời mới mà đắt hơn em này nhìu.Em muốn hỏi là nghe = CDP đơn thuần thì có hay hơn cái CDP chơi tất cả các thể loại như em này ko ? em nhìn spec thì cũng khủng lắm mà . Có khi nào mạch rắc rối quá thì nghe ko hay ko ạ . TKS các anh . Spec của nó đây ạ : The Arcam DV135 1080p upscaling universal DVD Player /CD/SACD player Reg. $1665.00 shown here in silver. New, Factory sealed cartons with warranty. Available in Black Only. Download the owners manual <= lots of detailed information in the manual. Take a look! Features Summary ABT1010 video scaler to 720p, 768p, 1080i and 1080p DVD-Video, DVD-Audio, CD audio, SACD audio, DiVX video playback Motion adaptive progressive scan HDMI digital video/audio output On-board video setup wizard for user video display calibration 'always-on' composite and SCART video Audiophile sound quality from all disc formats for movies and music CR515 handset, a sleek new design OSD improved - the new user interface features full colour graphics and easy to use menus Designed and manufactured in the UK Video Zoran Vaddis 888S processor with built-in per pixel motion adaptive progressive scan engine ABT1010 Advanced 10bit video scaler (supporting 720p, 1080i, 1080p, 768p to HDMI out) Internal video setup wizard for calibrating display to DVD player (Brightness, Contrast, Sharpness & Colour) RGB SCART and component video outputs – latter supports both 525p and 625p video HDMI video output, supporting the following formats: 480i, 480p, 576i, 576p, 720p, 768p, 1080i, 1080p Dedicated 768p output for 768 line screens with appropriate HDMI input No Chroma Upsampling Error (CUE) NTSC to PAL and PAL to NTSC conversion High quality zoom function with 1.25 and 1.5 settings to fill 'wrong aspect ratio' screens 'Always On' composite video output for multi-room applications 6 x 11 bit 216 MHz Analog Devices video DACs - for simultaneousoutput of interlaced component (or RGB), S-video and composite video RGB, component and composite buffered 75 ohm video outputs, capable of driving long cables without distortion Supports DVD-Video, VCD, SVCD, DVD-R, DVD-RW, DVD+R, DVD+RW discsplus CD, SACD, MP3, WMA, DiVX, Photo CD and JPEGs Digital Audio Dolby Digital, DTS, CD, plus stereo and multi-channel DVD-Audio and SACD playback 32bit Zoran audio DSP for optimum fidelity Top of the line 24bit 192kHz Wolfson WM8740 DACs for all 6 audio channels Global audio delay manager, 0-150ms, for perfect lip sync with digital processors / displays Comprehensive bass management supported for most audio formats, including variable crossover frequencies from 50-150Hz in 10Hz steps, plus loudspeaker delay and level setting Ultra-low jitter audio clock circuitry State of the art audiophile CD replay from a DVD player, including HDCD decoding Quick and easy SACD/CD hybrid layer change for fast comparisons Replays MP3 and WMA files from CD, with dedicated on-screen browser Coaxial, optical and HDMI digital audio outputs support 2-channel PCM up to 24bit / 96kHz (HDMI V1.1 up to 6ch 24bit 192kHz PCM), plus DTS and Dolby Digital streams Dual laser DVD drive reads CD-R/RW discs and most copy protected audio CDs Custom Install Full duplex RS232 control and RC-5 remote input jack Full suite of discrete IR RC-5 codes, including separate on / off etc 'Always On' stereo audio down-mix outputs available from CD/DVD/DVD-A for audio distribution 'Always On' composite and RGB SCART video always available for video distribution General Features Extended internal buffer memory means no DVD layer change delays 4-layer fibreglass main circuit board for best audio and video performance Arcam-designed mixed mode power supply (linear for audio switched for digital & video) Over spec Toroidal mains transformer Arcam 'Mask of Silence' EMC damping technology Sturdy all metal cabinet construction from heavy gauge steel and aluminium Front panel 'Navi' button simplifies disc navigation when not using remote control New stylish remote control, type CR515 Size 430mm wide, 340mm deep, 85mm high Weight 8Kg
