  1. audio_pkh
    audio_pkh Advanced Member
    Tên mặt hàng: Energy Power Base
    Tình trạng, mô tả: new
    Giá bán: 4tr6
    Khu vực: tp. hcm
    Điện thoại: 0975012333
    System Type: 3-way system;
    built-in subwooferFrequency Response 65Hz to 20KHz +/-3dB
    Power Handling 160 watts peak
    Dimensions 4" (10.2 cm) H x 25" (63.5 cm) W x 14.1" (35.8 cm) D
    Inputs Bluetooth, 1 optical input, 1 dual RCA inputTweeter Two .78" (20mm) aluminum dome drivers
    Included Accessories One 4.9 ft (1.5m) digital optical cable, one 4.9ft (1.5m) 3.5mm to dual RCA cable, one remote control
    Midrange Two 3" (7.6 cm) IMG
    DriversWoofer Two 3" x 5" (7.62 cm x 12.7 cm) front firing composite cone/ported enclosure
    Weight 18.4 lbs / 8.3 kgTV
    Placement Requirements TV < 80 lbs (36kg) TV base < 23 (58cm) W x 12" (30cm) D"
