FanClub Altec - JBL- Goto and ... Horns...
Discussion in 'VNAV's Fan Club' started by Haolq, 8/12/05.
  1. Unison250th
    Unison250th Advanced Member
    - Dung 1 cai FC8 + 4 AC la đu. Ly do minh dung 2 cai FC8 + 4 AC vi cam thay image duoc rong hon trong can phong lon.
    - Cai AC limit la 2000Hz, nhung minh cam thay xuong duoi 5000Hz thi am thanh hoi thieu, cho nen minh cat o 5khz, va lai cai duoi 2Khz , khong bao lau se lam hu diaphragm.
    - Am thanh cua Stacked Quad + tweeter + bass co the noi la mot dan loa co am thanh quyen ru, nghe dan nay cung man nguyen, ngay ca so voi tat ca nhung dan loa thoi nay. Dan nay kho hap voi nhieu nguoi vi can phai can phong lon, dung multi-amp, diaphragm cua ESL rat de lam chay, cho nen rat it nguoi dung dan Stacked Quad. Va lai Stacked Quad vi khong con ban tren thi truong tu nam 80, cho nen rat it nguoi hieu biet ve am thanh. Dan nay bay gio duoc thiet ke boi mot so nguoi DIY rat nho, co le nhung nguoi nay da duoc dip nghe Stacked Quad va kho co the quen am thanh cua no. Am thanh cua Quad rat nhanh la vi diaphragm rat mong , lam bang mylar voi do day duoi 20 microns, neu ma nhin chung quanh trong nha thi co le cha co vat dung gi mong hon diaphragm cua Quad.
    - Khi dung len dan Stacked Quad, minh muon nghe lai am thanh dan nay de lam reference cho nhung dan loa DIY sap toi, nhu ESL, ken, coax, Goto.... Ly do minh dung Supravox 8 inch tren OB la de thi nghiem voi FC15 bass va ESL, vá cung de mo dau cho nhieu thi nghiem khac trong tuong lai, nhu koa ken, hoac bat cu driver nao ma minh can thay co am thanh trien vong. Am thanh cua Supravox rat dac biet, la vi rat nhieu chi tiet that ro rang, va nhanh, ma tat ca nhung nguoi ban minh da co dip nghe qua hai dan may deu cam thay Supravox hay hon mot bat, nhung tat ca cung cam thay rang am thanh cua Quad cung qua hai long.
  2. thinhgia
    thinhgia Advanced Member
    Còn Lâu Mới Khoái Nhá
    Ý Bác là selector voltage ? cả bass driver và high driver đều có function này .
    Thường khi E nghĩ chắc bác cùng sài Maximum voltage chứ nhẩy vì liên quan tới độ nhạy mà?
    Em đang băn khoăn và có lẽ set-up cho nó 3 way trước vì sợ là nếu 4 way thì midlow của driver này sẽ bị uổng quá Em dự tính cắt khoảng 650hz cho nó vì phía trên là TAD-4001 sau đó thì muốn chế biến gì tiếp thì sẽ tính sau.
    Nếu Em dự tính cắt tại 650hz thì thêo bác nên chọn lỗ khoét trên panel tại vị trí nào thì thích hợp cho driver (single driver thôi bác )
    Bác nghe qua cặp high tweeter Onken OS-5000T chưa vậy?
    Em mới rước thêm được cặp này :D
  3. panguyen
    panguyen Advanced Member
    Quê lúa - Thái Bình 0977526789
    Các bác ở bển sướng thật, muốn rước cái gì thì có cái đó! Ở vn thỉnh thoảng mới có nhưng người ta toàn dìm hàng đi đêm với nhau thôi.. Chán!
  4. Elegant
    Elegant Advanced Member
    Regulator là cái ổn áp để cho điện đỡ nhảy múa :lol: ảnh hưởng đến chất lượng âm thanh vì field coil thay đổi độ nhạy theo voltage không phải selector bác Thinhgia. :)
  5. thinhgia
    Thê ý bác muốn giề :D
    Em còn kho toàn Lựu đạn nhưng chưa kiếm được Bin Laden :lol:
    Cảm ơn bác mấy cái này E sợ giựi nên hổng có bít
  6. Unison250th
    Bac xai voltage lam sao dung de cho driver nong qua, khong tot.
    Bac cu lam giong cai OB cua minh, de horn va tweeter tren dau cai OB la de nhat, muon doi cung rat tien. Neu gan tren mat OB, roi doi y thi rat kho khan, va lai khi de horn + tweeter tren dau cua OB, rat vua tam vi ngang lo tai.
    Minh co nghe qua Onken mot lan thi thay am thanh rat tot, co le tot hon Goto vi 2 nguoi ben Phap co dan may noi tieng deu doi tu Goto qua Onken.
  7. thinhgia
    Em chưa biết sao nó nóng hay lạnh vì đến nay cũng chưa có dịp thử chúng. việc thay đổi hiệu điện thế voltage ở power supply như thế nào sẽ không làm nó nóng? hay là chạy max 24v thì chúng dễ sinh nóng hơn? phần power supply này nếu sài Battery 24v thì bên này nói chung là rẻ làm cặp bình Battery khô chắc 100us một cặp với battery charge nữa là ok bác.
    Ý em là nếu Em cắt khoảng 650hz thì chắc khoét lỗ chính giữa thì phù hợp hơn chứ bác?
    cái panel này em sẽ làm test trước sau này sẽ bỏ đi, còn phần gá treo Horn và tweeter em sẽ làm bộ giá giống của Tay thợ vẽ với thanh gác ngang phía trên để đặt horn trên đó khi đó việc treo horn sẽ dễ dàng và nhìn sẽ đỡ bị trông chênh,đồng thời sẽ vững chắc hơn cho systems.
    Onken thì đúng là mấy tay Người Pháp rất khoái vì em có search online và biết chút chút về chúng.
    Cặp Em mua khá mới không cũ như trong hình. trước đây Em không tin vào Woodhorn của Onken nên em không mua chúng vì khi bán họ kèm cả driver mid horn vô nên Em ngại tha nặng với cái woodhorn cồng kềnh.trong tương lai E sẽ kiếm thêm cặp Mid driver của Onken chơi cho biết
  8. Elegant
    Cặp Em mua khá mới không cũ như trong hình. trước đây Em không tin vào Woodhorn của Onken nên em không mua chúng vì khi bán họ kèm cả driver mid horn vô nên Em ngại tha nặng với cái woodhorn cồng kềnh.trong tương lai E sẽ kiếm thêm cặp Mid driver của Onken chơi cho biết[/quote]
    Nếu bác dùng acqui để cấp điện cho field coil là tốt nhất nhưng điện áp không chỉnh được. Theo em bác cứ làm cục biến áp DC mà có thể thay đổi điện từ 0-24v sau đó tìm xem điện áp nào nghe hay nhất và củ loa nóng vừa vừa lúc đó pin hay acqui mới hiệu quả.http://www.oteinstruments.com/cart/cata ... -2091.html
    Dùng đèn cấp field coil có trở ngại là nếu dòng cấp cho field coi lớn thì cục nguốn của bác sẽ phải rất nhiều bóng và tốn kém.
    Em chỉ biết có vậy vào đây hóng hớt tí :mrgreen:
  9. bobzazz
    bobzazz Advanced Member
    Dear anh Unison,
    Cho em hỏi kỹ hơn 1 chút về hệ thống Supravox 15inch + 8inch + tweeter:
    - Cái Supravox 15 inch thì nên chọn 400-2000 EXC hay version nào ạ?
    - Cái Supravox 8 inch thì nên chọn 215-2000 EXC hay version nào ạ?
    - Tweeter thì AC tốt rồi nhưng nghe anh tả ESL thấy hấp dẫn quá. Anh có biết về cái Electrostatic super tweeter hummingbird II của KingAudio không ạ ?: http://www.kingsaudio.com.hk/products.html
    - Phòng nhạc của em 40m2, diện tích này 1 cái 8inch là đủ hay nên 2 cái để tạo image như anh đề cập.
    Kính,
  10. vintdio
    vintdio Advanced Member
    Mình mới lượm được vài cặp driver lạ từ vựa ve chai, gởi các bác xem chơi! :)
  11. Unison250th
    Minh dung Supravox dung nhu bac list.
    Cai Electrostatic cua Kingaudio minh co dip coi o CES, hinh ban duoi $1000. Cai nay khong dung duoc vi do nhay rat thap, ngay ca dan loa ESL cua Kingaudio nghe khong duoc hap dan cho lam.
    Bac co the kiem nhung mien ESL nhu trong nhung loa minh moi mua (de lay cai tweeter thoi)
    viewtopic.php?f=68&t=35996&start=125
    Do nhay cua 4 mieng kha cao, se hap voi Supravox.
    Neu bac mua may cai cell do ma do nhay khong duoc lon, thi co le câpcitor trong power supply phai can thay. Nhung tweeter nay cung tren 30 tuoi roi.
    Khong phai ESL nao cung hay het bac a, vi tuy theo cach biet che, neu dung diaphragm day thi rat ben, nhung am thanh khong duoc nhanh, neu dung Diaphragm mong nhu Quad thi de bi chay.
    Theo minh nhan thay, chi co vai loa ESL co tieng mid tru danh, do la Quad ESL 57, Beveridge, KLH9, va Stax.
  12. Unison250th
    Chuc bac may man va rang kien nhan!
  13. vintdio
    Tìm mấy món này cũng có duyên số bác ạ! Hy vọng mình sẽ có đầy đủ bộ sưu tập của em này trong tương lai gần.
  14. thinhgia
    Duyên bác to Tướng thế thì mấy cặp đó dớt easy chớ khó chi :lol:
    Chúc mừng bác nhá.Có điều Em nhìn cái Driver nó hơi lọa ?
    Chả biết nó là giề :D
  15. panguyen
    Hình như là mấy cái van để cắm đường hơi vào thì phải bác ạ! :)
  16. caithang
    caithang Advanced Member
    Nhìn thích quá bác Vintdio, giá ve chai 4 chú đó bao xiền ?
  17. vintdio
    Bác Thinhgia: Nhìn mấy drivers này giống người ngoài hành tinh không? Cái này do Philips sản xuất.
  18. thinhgia
    Vậy thì cái Tên nó bé tí nhẩy không bằng Go-to roài :lol:
    Em nghĩ Duyên bác to Tướng thế thì làm mấy cái khủng khoảng nữa cho nó sướng cái đời :lol:
    Em mà như bác thì Em Hát bài Diệt phát xít ngay :lol:
  19. Unison250th
    Khong co dau bac oi, minh co thu vai compression driver duoi $100 ma am thanh kha tot day bac, tat ca an nham cach lap rap va ampli cho hap thoi.
  20. thinhgia
    Gặp mấy bác nhà giàu là E cứ hô toáng lên cho máu :lol:
    Tuy nhiên E thấy mấy cặp ít tiền mà hay thì cũng không nhiều và thật mất thời gian mò mẫm cho ra,khi đụng vào đồ lớn nó mang lại cũng nhiều vấn đề, và chính vậy E cũng cắt ngắn giai đoạn được nhiều đó bác.
    Phần power-amp thì em cần thêm chút thời gian nữa để có thể bước qua tuổi võ lòng sau đó Em sẽ mang cái rổ transformer của em ra nghịch khi đó mới mong bắt nhịp theo bác được.còn bây giờ phần power-amp của em còn nhiều vấn đề và e biết chúng cần phải làm tốt hơn nữa rất nhiều.
    Tiếc là thời gian luôn kìm kẹp em :D
  21. vintdio
    Mình lại thích khám phá những em chưa có nổi tiếng đó bác Thinhgia. Tại vì những em đó không có nhiều để chúng ta tìm. Hehehe...
  22. thinhgia
    Em nghĩ có khi nào bác lại thích làm lính Cụ Hồ chăng? :lol:
    Khoái trèo đèo lội suối hơn mấy Anh Mẽo :lol:
    Em lại thích mấy A tay To nhưng sống Ẩn dật hơn là đào bới coi Xem là mấy anh là Ai? :D
    Bác biêt chơi Ù không nhẩy
    To tẩn bé gửi :mrgreen:
  23. bobzazz
    Dear anh Unision,
    Anh cho em hỏi dòng loa Supravox & tweeter AC có hợp chơi với Tact không anh?
    Kính,
  24. Unison250th
    Duoc bac, nhung neu bac dung Supravox voi G3 (hoi mac, nhung do nhay phu hop voi FC8) thi do ton them 1 ampli TAct.
  25. regular
    regular Advanced Member
    Non-Groups
    Em hỏi bác M. chút: có phải đó là 2 trong 100 cặp duy nhất được Phillips SX phải khg ạh? :wink:
    Em xin chúc mừng Bác!
