Focal - JmLab FC
Thảo luận trong 'VNAV's Fan Club' bắt đầu bởi Nacon, 1/6/09.
  1. Hungaudiocampha
    Hungaudiocampha Advanced Member
    Tham gia ngày:
    1/5/11
    1.121
    Đã được thích:
    17
    bác đã thay đổi dây trưa-dây loa,dây tín hiệu .nếu thay dây vẫn thế thì cho anh ba lên đường....
  2. pterpm
    pterpm Advanced Member
    Tham gia ngày:
    20/11/09
    69
    Đã được thích:
    hic, em đã tiễn rồi bác ạ, lỗ sặc máu luôn, paypal không lụm của mình hết 2.9% + 30 cents per transaction , + 2% tổng số tiền cúng cho tụi audiogon , + shipping charged + 4 tiền posting cho audiogon bác ạ
    em đang nghe theo bác atlantic kiếm em jolida đây, định kiếm em Jolida JD-1000RC http://www.underwoodhifi.com/pix/mods/jd1000rc.jpg
    http://www.underwoodhifi.com/pix/mods/jd1000rc2.jpg
    The Jolida JD-1000RC is an upgrade from the older basic JD-1000a. It adds a beautiful new look with a large window in front. In addition, the RC model has remote control as well as a preamp/sub outs, upgraded parts quality and a tape out. It also adds Simple Bias. This new bias system can be done without a meter in under a minute. It is better than auto bias as it does not limit power. Home Theater bypass is an option.
    The 1000RC uses four EL-34 output tubes per channel for 100 watts per channel of big tube power. The stock amp is a real deal at its $2400 price. Our Level-2 mod makes this amp a killer. It is now competitive with all comers under $5000. If you have been looking at tubes but thought that you could not find a great high-powered answer for your budget, look no further. The stock JD-1000RC is a good performer but the modified unit is a giant killer.
    This mod is fully covered by the 2-year Jolida factory warranty. The mod was designed by Chris Johnson, founder and former president of Sonic Frontiers.
    The following describes the JD-1000RC Level-2 mod [$1000 retrofit + freight; $2,790 for pre-modified new units + freight:
    Replacement of the stock"Chinese Jolida input/driver tubes with Russian ELECTRO-HARMONIX 12AX7 (2) and 12AT7 (2)
    4 x Polypropylene power supply bypass caps in the power supply
    8 x MULTICAP PPFXS signal path polypropylene film and tin foil coupling capacitors
    5 x AURICAP metallized polypropylene power supply bypass capacitors
    36 x Japanese Riken ½ and one watt signal path carbon resistors with gold-plated leads
    6 feet of Cardas 1x21.5 awg w/shield co-axial input signal wire
    4 x Hexfred ultra-fast soft-recovery high voltage rectifying diodes in the power supply
    4 x large EAR brand Sorbothane isolation fee
    2 x sheets of SoundCoat chassis damping material cut and applied where applicable
    1 x SF4007 Vishay-Telefunken diode added to the bias supply for stability
    TRT WonderSolder used throughout
    7 hours labor
    1 year warranty on modification for retrofits
    2 years on all pre-modified units
    Sonic changes of the Level-2 mod: The unit is quieter, the silences are blacker, thus resolving more low level detail, ambience and three dimensionality.
    It is much more detailed while also more dynamic. It seems to play louder while keeping that beautiful EL-34 midrange liquidity.
    Tonal balance is more eve.from lows to highs in addition to the amazingly liquid midrange of the stock machine.
    Imaging is better and more defined while bass is dramatically improved. It has full weight and authority, not flubby "one note" bass. It sounds much more like solid-state in this area
    em định kiếm em MOD rồi, các bác cho em ý kiến đi ạ
    bác alatic đâu òi, help em với
  3. Hungaudiocampha
    Tham gia ngày:
    1/5/11
    1.121
    Đã được thích:
    17
    bác chơi 836v nó đòi hỏi công suất tương đối đấy...
  4. pterpm
    Tham gia ngày:
    20/11/09
    69
    Đã được thích:
    em theo lời bác atlantic kiếm đôi dây kimber 8TC về đánh chung với con marantz pm 7000 nghe trong phòng ngủ cũng hay lắm bác ạ, nhà em đang làm nên chưa đem ra ngoài phòng lớn để nghe thử, em định thứ bảy này đi lên chỗ bán máy định vác con amp đèn về để try out không nhớ rõ là hiệu gì nhưng 5k lận mà chỉ có 40w/channel thôi
    bác có nghe gì về jolida không bác cho em xin ít review cái đi, định đổi qua chơi Klipsch P-37F đây bác ạ, bác có nghe hay chơi thử con này chưa bác, nó còn khủng hơn con 836 của em nhiều
  5. Electra
    Electra Advanced Member
    Tham gia ngày:
    3/5/11
    86
    Đã được thích:
    tình hình Focal FC dạo này im ắng quá nhẩy? .... không có bác nào mới chơi Focal nữa à??!?!
  6. lux
    lux Advanced Member
    Tham gia ngày:
    2/3/11
    288
    Đã được thích:
    E xin tham gia jmlap 1008be. Đang đợi chân. Gửi tạm các bác tấm hình e nó.
  7. tai_trau
    tai_trau Moderator
    Tham gia ngày:
    11/4/06
    15.561
    Đã được thích:
    5.131
    Nơi ở:
    Bác lux ơi chúc mừng bác. Em cực kì ấn tượng với trung cao của cặp loa này. Bác đánh 1008be với amply gì thế? Trước em cũng định loay hoay mà buông súng vì điều kiện không theo được.
  8. Electra
    Tham gia ngày:
    3/5/11
    86
    Đã được thích:
    cho tí người thật việc thật đi bác ... :)
  9. Quangbh
    Quangbh Advanced Member
    Tham gia ngày:
    23/9/08
    1.940
    Đã được thích:
    279
    Chúc mừng bác kiếm được cặp loa rất hay :D , à bác Lux sao em thấy nó giống 1007be đến 99% vậy bác chỉ khác là gỗ ở 2 bên loa mà thôi! em nó có còn khác gì nữa không bác? bác cố gắng kiếm cặp chân thật nặng(càng nặng càng tốt) và thật chắc thì em nó mới vâng lời bác được :D , rì viu chút xíu đi bác.
  10. Electra
    Tham gia ngày:
    3/5/11
    86
    Đã được thích:
    Em thông báo chi phí thay treble Beryllium bị thủng của em, khoảng 8 chai 5/ 1 loa treble (khoảng 400 USD). Đông Thành charge em.
    Các bác giữ gìn cẩn thận kẻo bị như em nhé ... :( :(
    Tình hình là em cũng vừa mod lại dây trong thùng loa luôn .... kết quả khá bất ngờ: treble sắc sảo hơn (rất rõ,khi em thay 1 bên xong mở tiếng ghitar - so với bên còn lại), bass sâu, mid đầy tình cảm ... (có thể em hơi quá lời ... vì phấn khích quá, các bác thông cảm) :) tăng 20% công lực của loa, volume lớn hơn 1 nấc.
    Mod cũng không khó khăn gì lắm, đi lại toàn bộ dây từ crossover lên loa và ra cầu loa phía sau. Dùng chì hàn WBT, các jack cắm mạ vàng, dây loa, dung dịch vệ sinh đầu hàn ... khoan lỗ các crossover to lên để lọt vừa dây. (dây zin của Focal electra 1027 là dây điện lõi đồng Trung Quốc 14 AWG Chung Dzi gì gì đó em quên rồi, có ghi trên dây).
    Thời gian: tổng cộng 6h cho cặp loa (loa sau làm nhanh hơn do quen tay)
  11. Quangbh
    Tham gia ngày:
    23/9/08
    1.940
    Đã được thích:
    279
    Chúc mừng bác đã nâng cấp cho em loa 1027 và đã thành công, em nghĩ chắc cặp loa của bác đã hết bảo hành nên bác mới mạnh dạn như thế, chứ như em lúc trước loa còn trong thời gian bảo hành mà kêu em thay như thế thì em chịu trận luôn :D
  12. andy
    andy Advanced Member
    Tham gia ngày:
    8/3/08
    1.092
    Đã được thích:
    15
    Nơi ở:
    HCMC
    Bác làm ơn cho tụi em biết bác mod lại dây gì ( hiệu dây - và mua ở đâu). Nếu được bác chụp hình lại cái cross sau khi bác mod dây xong . Để tụi em còn biết đường mà làm theo ah. Nghe bác nói tăng 20% làm em cũng nôn nao quá.
    thanks!
  13. lux
    lux Advanced Member
    Tham gia ngày:
    2/3/11
    288
    Đã được thích:
    E đang đánh tạm bằng cái plinius 9100. Sắp tới nâng cấp cái gì tính tiếp sau. Còn đang đợi chân loa. Đánh bằng 9100 tiếng ra cũng tương đối tốt rồi. Mong anh em chia sẻ thêm kinh nghiệm.
  14. lux
    lux Advanced Member
    Tham gia ngày:
    2/3/11
    288
    Đã được thích:
    E đang đặt rồi. Cuối tuần này hàng về. Mỗi bên nặng 32kg. E đặt chân giống y hệt chân rin chỉ khác là ốp gỗ ở thân thôi. Lúc nào hàng về e chụp ảnh gửi các bác
  15. lux
    lux Advanced Member
    Tham gia ngày:
    2/3/11
    288
    Đã được thích:
    E cũng chẳng biết nó hơn được gì. Đọc rì viu thấy bảo nó cho giải bass đầm và chắc chắn hơn. Còn dải cao chắc vẫn thế bác ạ
  16. loveBasso
    loveBasso Advanced Member
    Tham gia ngày:
    9/4/08
    2.170
    Đã được thích:
    110
    Nơi ở:
    Thuận An-Bình Dương
    Chúc mừng D. nhé, vân gỗ loa độc đáo quá. :D
  17. Electra
    Tham gia ngày:
    3/5/11
    86
    Đã được thích:
    dây loa thì cho em xin phép giữ bí mật thêm 1 tí để kiểm nghiệm....... (hiện hàng cũng đã hết, em gom sạch 40m làm linh tinh), dây loa là quả làm em bất ngờ nhất, vì trước lúc DIY em mới chọn được.
    Trước khi chọn, Em thử bằng cách lấy 4 loại dây khác nhau về (mắc nhất 60 USD/m, em không chọn loại mắc nhất), cắt đoạn 6 tấc làm dây loa bên ngoài nghe thử, nếu loa ngoài hay thì loa trong sẽ hay, cuối cùng thì chọn em xuất sắc nhất làm dây trong thùng loa (3 trong 4 dây ortofon 4000Q, Ortofon silver, vandehul dòng dây cuộn đỉnh nhất).
    Mod cũng không có gì khó, không can thiệp gì vào crossover chỉ thay dây thôi, xả chì hàn 2 đầu củ loa và crossover thay dây mới vào, chỉ giữ nguyên tắc độ dài dây gin sao giữ nguyên vậy (không quan trọng thiếu đủ).
    Loa em xách tay về chả bảo hành gì ... nên mới chiến tuốt (hư thì ra Đông Thành order lại part thay vào).
    Hình ảnh thì em vừa nhận được xong ..... giờ đi ra ngoài chút, tối về em up cho các bác xem cho vui.
    Bác nào dũng cảm DIY lại, đặc biệt là Focal, cùng em kiểm nghiệm xem sao.
  18. loveBasso
    Tham gia ngày:
    9/4/08
    2.170
    Đã được thích:
    110
    Nơi ở:
    Thuận An-Bình Dương
    Bác H. nhớ up hình lên nhé, em tò mò muốn biết crossover dòng này. Mod xong nghe hay hơn là thành công rồi! Em thì không đủ trình để mod!
  19. andy
    Tham gia ngày:
    8/3/08
    1.092
    Đã được thích:
    15
    Nơi ở:
    HCMC
    ANh đem xuống đây em mod cho, :D .
  20. Electra
    Tham gia ngày:
    3/5/11
    86
    Đã được thích:
    đang load hình về ..... các bác mà xem xong chắc mai mốt em thanh lý chả bác nào dám nhận :D :D :D
  21. Electra
    Tham gia ngày:
    3/5/11
    86
    Đã được thích:
    tổng cộng mỗi bên hết 3m (6m total), 5 cọng dây: 4 cọng từ crossover lên củ loa, 1 cọng từ crossover ra cầu loa.
    Zin:
    treble Beryllium mà đi với dây cùi bắp nà: (chắc trong ruột của Grand Utopia EM cũng rứa :))
    Crossover mặt trước
    Sau mod: cảm giác thế nào các bác?? em thanh lý cặp này có dám sờ vào không? :p
  22. andy
    Tham gia ngày:
    8/3/08
    1.092
    Đã được thích:
    15
    Nơi ở:
    HCMC
    bác dùng dây gì đễ mod vậy, mua ở đâu? Giá bao nhiêu bác ơi .
    thanks?
  23. Electra
    Tham gia ngày:
    3/5/11
    86
    Đã được thích:
    check pm nhé .... phần thưởng dành cho người dũng cảm. :) :)
  24. andy
    Tham gia ngày:
    8/3/08
    1.092
    Đã được thích:
    15
    Nơi ở:
    HCMC
    cám ơn thông tin thú vị của bác, Em cũng đang me xem ai bán dây ngon ngon thì em cũng mần thịt giống như bác đây :lol: . Hiện em đã dùng Nordost flatline chập đôi lại cho phần loa Bass, phải nói là khác biệt rất rõ. còn phần mid và super treb thì đang săn lùng...
  25. Electra
    Tham gia ngày:
    3/5/11
    86
    Đã được thích:
    bác dùng luôn super flatline, dòng top dây cuộn của nordost (flatline chi) mần thịt em nó đi bác ..... hình như giá đâu đó 30-35 USD/M. (Bên Nordost cũng có recommend em dùng em này)
    Chơi tới bến .... thì làm luôn Kondo mod dây thùng loa mới oách :D
    quyennguyen thích bài này.
Chia sẻ trang này
Đang tải...
