Ông chú gửi từ US về nhưng không biết phối với em loa nào cho hợp nên lên đây nhờ các bác tư vấn dùm http://us.st12.yimg.com/us.st.yimg.com/ ... _137175946 còn đây là thông số kỹ thuật của em nó: Output Power, typical (per channel): * Continuous Average Output Power Both Channels Driven: * 8 ohms, 1kHz, 1% THD: 400 watts * 4 ohms, 1kHz, 1% THD: 655 watts * 2 ohms, 1kHz, 1% THD: 1000 watts * Continuous Average Output Power Bridge Mono Operation: * 16 ohms, 1kHz, 1% THD: 800 watts * 8 ohms, 1kHz, 1% THD: 1310 watts * Voltage Gain (dB): 34 * Sensitivity (for rated power @ 8 ohms): 1.12 Vrms * Distortion: SMPTE-IM, Less than 0.05% * Dynamic Headroom: 2dB at 8 ohms * Frequency Response: 20Hz to 20kHz, +0/-1dB, 1 watt * Damping Factor: Greater than 200 * Noise: 106dB below rated output (A weighted) * High Pass Filter Settings: 30Hz, 50Hz, out * Input Impedance: 20k ohms balanced and 10k unbalanced * Front: AC Switch. AC Circuit Breaker. Back: Stereo/Bridge ì Switch. Ch.1and Ch.2 Gain Knobs. 8 * * Position DIP Switch for ì Filter and Limiter. * PWR-ON: Green LED. CLIP: Red LED. * Connectors (each channel): Input: Barrier Strip and Neutrik ì "Combo" 1/4" TRS and XLR, tip positive. Output: "Touch proof" ì binding posts. * Cooling: Two-speed fan, rear-to-front air flow. * Amplifier Protection: Full short circuit protection, thermal, ì open circuit, ultrasonic, and RF protection. Stable into reactiveì or mismatched loads. * Load Protection: On/off muting. DC-fault protection. * Output Circuit Type: Class AB complimentary linear outputs. * Power Requirements: 120, 240 VAC, 50-60Hz * Dimensions: Faceplate Width: Standard 19" (48.3cm) Rack ì Mounting. * Faceplate Height: 7.0"(17.8cm). Chassis Depth: 10.8" (27.4cm) * Weight: Shipping (lbs/kg): 57/25.9 Net (lbs/kg): 54/24.5 Rất mong các bác tư vấn dùm em....Xin chân thành cảm ơn ạ.
Con này là con Power bác ơi ..em thấy trên ebay củng đang đấu giá con này :mrgreen: Con power này nghe cũng khá hay bass đánh xuống tròn khá sâu ,trung âm nghe rất mộc..có điều tép hơi bị tối ( nhưng có điều em này khó kiếm pre hợp cho em nó , rất kén ), Con này trị Loa chario thì hợp
Tại bác ít gặp thứ này chứ em thì em dùng hoài. Đánh cho loa fullrange tiếng tuyệt vời. Bác mà có nhu cầu hát kok thì lấy con này kéo bose 301 là vô địch.
