Giao lưu, họp mặt thành viên vùng Bay Area: SF, SJ, etc.
Discussion in 'Bang hội / Câu lạc bộ' started by Hai Lúa-USA, 17/10/08.
  1. Unison250th
    Unison250th Advanced Member
    4 con do chac cung gia roi. Chua bao gio thay Gloden Lion nhu vay.
  2. habas
    habas Advanced Member
    Bác Unison.
    mình hỏi tên Bob 1 đàng nó trả lời lòng vòng giống mấy thằng used car sellerman thiệt :lol:
    Q: Hi Bob. I have 1 question before placed bids: Those Golden Lion output tubes come with amps, are Reissued ? They don't look like NOS as mine, physically ! regards. Jan-02-10
    A: Hi'du, These Gold Lions are Mike Mathews's (Genelex's owner) masterpiece! They are that good. As far as I can tell, he has been trying for the last decade to build a great KT88/6550, and I for one must say he has succeeded in spades with this tube. I begin: Before I got some of these tubes to try, I did not know what to expect, and in truth was slightly suspicious of them. I have lots of the worlds great output tubes in my collection including Sylvania, GE, RCA, Genelex, Tung-Sol, as well as several of modern and recent manufacture. There are several important tests that show ultimate performance quality: Pull-down voltage(the ability to turn-on perfectly at maximum drive), maximum voltage swing into varying loads(the ability to drive difficult speakers and a measure of its power output vs load response), maximum possible output current, distortion (a measure of linearity), I could go on and on, but against ALL the parameters that I hold dear, Mike's masterpiece performed as follows: Pull-down, 48 volts (the lower the better), max current,0.68 amperes, linearity, 1.2%. Most of the other NOS tubes performed close to, if not quite equal to these. The most interesting comparison was the original British Genelex against these: Pull-down,48 volts, max current,0.68 amps, distortion, 1.3%. The sound? Well, that has as much to do with the circuit the tubes are used in - probably more - than the tube itself. Bottom line, these are great tubes equal in EVERY way to the original British versions. The only thing I can't know about is will they last 50 years? Here's hoping! Thanks for asking a super question, Bob Carver
  3. Unison250th
    Mike Mathew la tu New Sensor bac, bay gio lam KT88 reissue ben Lien So (nhu hinh minh da post tren do), va luon ca 6550 Tung SOl. Tube nay moi ra doi duoi mot nam ma Carver dam bao la "last for 50 years" . Cap ampli do cha dang gia lam dau, vay ma nhieu nguoi dam bid len tren $6000, linh kien dung rat tam thuong. Kinh te rat kho khan nen bac Caver cung phai "ha. minh xuong de kiem an"
    Day la mot nguoi ben Duc noi ve tube KT88 cua Mike Mathew:
    This tube is a Russian made tube, in the REFLEKTOR company. They make this tube since 2007 and it is said to be a true copy of the Genelex GOLD LION. Which it is definitely not. The plate construction looks like the normal Electro Harmonix tubes to me, and fails the characteristic of the original Golden Lion.
    Trang duoi day co nhieu chi tiet hay ve tube, moi may bac nen doc tung chi tiet de sau nay mua tube khoi bi lua:
    http://images.google.com/imgres?imgurl= ... N%26um%3D1
  4. longthp61
    longthp61 Advanced Member
    it's fake tube?
  5. Unison250th
    Chu gi nua bac, chua bao gi Golden Lion lam tube nhu vay!
  6. Hai Lúa-USA
    Hai Lúa-USA Advanced Member
    Chúc các bác vùng vịnh và thân hữu 1 năm mới an khang thịnh vượng, nhất là sức khỏe dồi dào. Đến cái tuổi bây giờ mới thấy sức khỏe quí > vàng đó mấy bác ạ.
  7. cd149dc
    cd149dc Advanced Member
    Bóng này của bác longthp61 đúng là bóng Gold Lion do MOV, trực thuộc hãng GEC -England làm đó. Những bóng co in logo Sư Tử nhỏ trên bóng được làm vào những năm 80s.
    Còn bóng của thập kỷ 70s thì không có hình Sư Tử ở trên phần thủy tinh mà chỉ có chữ Gold Lion to được viết hoa. Trên phần đế có chữ GENALEX màu đỏ. Còn đèn Reissue nó chơi cả 2 logo trên bóng và đế cho máu hơn.
  8. longthp61
    bác Tùng xác nhận là em yên tâm rồi :D
  9. NoBG
    NoBG Advanced Member
    Bác có thể tham khảo Website nầy.
    http://www.jacmusic.com/nos/images/Fakes/index.htm
  10. Unison250th
    Ua , vay la bac khong tin minh sao? Deu rat de nhan xet la bac co 4 cai matched, chan van bong luong, hop nhu con oi nguyen xi, deu nay chung to tube nay khong phai lam 30 nam ve truoc!
    Bac doc o day ne, co mot nguoi mua tube giuong het cua bac tren Ebay, va cung dat cau hoi nhu bac muon biet:
    I was send this picture by someone who found those on Ebay, and who was afraid they were fakes. Well, yes they are fakes. Inside is the Chinese KT88 system clearly visible.
    What is even worce about these, they were offered as NOS, and they are in the box with a bad vacuum getter. This kind of getter wear out comes from use. It is no "air" inside, but tube outgassing which cuases this coloring.
    Conclusion: These are not NOS Genelex Golden Lion. Faked tubes from China.
  11. cd149dc
    Bóng của bác longthp61 đưa hình lên là thiệt đó anh Hồ. Có điều đã dùng khá nhiều rồi nên phần thủy ngân bị thu nhỏ vào. Bóng Reissue tụi Seller làm ăn bố láo nó in giả thì dễ nhưng để bắt chước làm giống hệt kết cấu thì không được đâu. Trước đây em cũng có gần chục bộ bóng này. Đủ các đời từ đầu thập kỷ 70 đến cuối 80s. Tiếc là đã bị tụi Nhật hốt hết rồi.
    Hiện bạn em đang dùng 1 bộ. Vừa nghe vừa cho mượn lung tung gần 6 năm nay mà chân đế vẫn còn bóng loáng hơn của bác longthp61 nhiều lắm.
    Cái hình anh Hồ đưa lên chính xác là bóng Shuguang đời trước của anh Ba. Đã được in lại thành KT88 MOV-GEC. Và cũng không phải là KT88 Reissue luôn.
  12. cd149dc
    Và đây mới đúng là KT88 Reissue do Nga SX.
  13. Hai Lúa-USA
    Chán ghê ... mấy bửa nay cái Esoteric CD Transport bị hư phải dùng cái Pioneer CD player cùi nghe. Có bác nào dư cái CD transport nào không xài thì để lại cho tôi nhé :)
  14. liveaudio
    liveaudio Advanced Member
    Cái Esoteric CD Transport của bác là hàng mới mà sao mau hư vậy? Mà nó bị hư bệnh gì vậy bác ?
  15. Hai Lúa-USA
    Con này ... đời đầu tiên của Teac đó bác, P-10, ra đời hồi 1990 đến nay là 20 năm rồi nên cái mechanical đẩy ra vô nó bị trục trặc. Hôm nay mở ra bơm tí dầu thấy nó cũng khá hơn chút. Chỉ sợ cái motor nó bị hư thì kiếm part có lẽ cũng khó.
  16. HST
    HST Advanced Member
    Tân Bình - HCMC
    Giao Lưu Gặp mặt cuối năm Kỷ sửu 2009.
    Nhân dịp cuối năm anh em TBG và GVTeam SE phát pháo tổ chức 1 buổi gặp mặt thân mật - giao lưu giữa các thành viên.
    Thân mời các bác trong TBG, GVTSE và các bác trong các bang hội khác dành chút thời gian cuối tuần tham gia họp mặt với TBG và GVTSE.
    Thời gian và địa điểm: 5h chiều, thứ 7 Ngày 16/01/ 2010 tại quán A Quí - 323 Đào Duy Anh, Quận Tân Bình.
    Lưu ý: Các bác thuộc bang hội khác đến giao lưu với TBG - GVTSE sẽ được tặng quà DIY :)
    Trân trọng kính mời toàn thể anh em.
    HST
  17. THỦ ĐỨC GROUP
    THỦ ĐỨC GROUP Advanced Member
    Thưa Quý vị và các bạn
    Cứ mỗi dịp xuân về, tết đến, mỗi người trong chúng ta ai ai cũng rạo rực trong lòng. Mái ấm gia đình, sự quây quần bên nhau trong ngày xuân sum họp cũng chính là thời khắc mà mỗi chúng ta đều mong đợi.
    Mái ấm Thiên Ân - nơi nuôi dưỡng hàng trăm người cao tuổi không may mắn có được sự hạnh phúc nơi mái ấm gia đình cùng con cháu. Mái ấm này hiện là gia đình của họ, là nơi họ gửi gắm những năm tháng còn lại trong những tấm lòng nhân ái.
    Để cùng góp chung một tấm lòng, mang lại chút ấm áp mùa xuân trong lòng các cụ, nhóm Audio Thủ Đức (TĐG) tổ chức phát hành CD với chủ đề Tết để nhận sự đóng góp của các bạn với hy vọng những món quà này sẽ nhân thêm niềm vui cho các cụ trong dịp năm mới.
    Rất mong nhận được sự ủng hộ của quý vị và các bạn trong chương trình này. Xin trân trọng cảm ơn.
    Chi tiết về chương trình như sau:
    - Số lượng phát hành dự kiến: 300 CD (đĩa được dập trên dây chuyền công nghiệp).
    - Nội dung: các bản nhạc Xuân được yêu thích qua nhiều thời kỳ.
    - Hình thức quyên góp: bán CD với giá 50.000 (VND)/cái cho các thành viên đăng ký trên topic này hoặc mua trực tiếp tại buổi liên hoan DIY Tube-amp Contest 2010 tại Thủ Đức.
    - Thời gian đăng ký: Từ hôm nay đến hết ngày 24/01/2010.
    - Thời điểm phát hành: 31/01/2010.
    - Hình thức nhận tiền: tiền mặt hoặc chuyển khoản.
    Tên tài khoản: Lê Huy Bình
    Số tài khoản: 0251001750009
    Ngân hàng: Vietcombank chi nhánh Bình Tây, HCM
    - Vận chuyển: chuyển phát nhanh bằng bưu điện đi các tỉnh ngoài Tp.HCM (người nhận chịu phí).
    - Thông tin chuyển tiền BTC sẽ cập nhật cách mỗi ngày một lần trên topic này.
    - Toàn bộ số tiền thu được từ việc bán CD sẽ dùng làm quà tết cho các cụ đang cư trú tại mái ấm Thiên Ân, 93/6 đường Tam Châu, Phường Tam Phú, Quận Thủ Đức. Đt 08.38971548.
    Yêu cầu thông tin đối với các bạn phải chuyển CD qua bưu điện
    1. Thành viên gởi PM thông tin cá nhân chi tiết nhất cho ban tổ chức sau khi đăng ký mua CD. Nick nhận PM là THỦ ĐỨC GROUP
    2. Khi chuyển khoản ATM cần ghi rõ với cú pháp như sau: X _ Y
    - X là (nick đăng ký mua CD)
    - Y là (chuyển tiền mua CD ủng hộ từ thiện)
    3. BTC sẽ tổng hợp và thực hiện việc gởi CD qua bưu điện sau ngày 31/1/2010.
  18. Unison250th
    May bac co biet ai quen o New Jersey khong? Co cap loa nay minh muon mua nhung seller khong chiu ship.
  19. Cau Yem
    Cau Yem Advanced Member
    Em có người quen ở phía DC thôi, nhưng cặp loa có lớn không?
  20. Unison250th
    Lon bac, lon bang cap Magnepan lon nhat.
  21. Cau Yem
    Anh em vùng Vịnh có nên họp mặt ăn mừng mưa gần sắp tạnh không? :D
    Hỗm rày mưa nhiều quá không đi đâu được hết!
    Mấy cái thùng của bác Unison chắc cũng chưa xong hén vì trời mưa kéo dài quá (?)
  22. Chitock
    Chitock Advanced Member
    Mai sang som uong càe duoc khong may bac? Paloma di!
  23. Chitock
  24. Unison250th
    Mai sang cafe khong bac?
  25. danthanhpho
    danthanhpho Advanced Member
    Sáng mai tầm khoảng 8:00AM - 8:15AM là vừa nhẩy ? Theo tin thời tiết, có lẽ sáng mai sẽ không mưa. Hẹn gặp anh/em tại quán Paloma.
