Tên mặt hàng: Lumin S1 đã nâng cấp dây DC Tình trạng, mô tả: Như mới, đầy đủ hộp xốp, sách vở, gang tay Giá bán: 100 tr Khu vực: Vũng Tàu Điện thoại: 0913840635 Giao hàng: Toàn quốc Ảnh chụp thực tế Thông tin thêm: Moden đầu bảng một thời của Lumin
Lumin chỉ giải mã file DSD theo music server hoặc ổ cứng cắm vào bác ạ. Chứ không giải mã như 1 DAC riêng biệt cho máy tính nên ko có cổng USB type B in
SPECIFICATION S1 SPECIFICATION DSD SUPPORT: Up to DSD128 5.6MHz, 1-bit PCM SUPPORT: Up to 384kHz, 16–32-bit, Stereo ANALOG OUTPUT STAGE: 4 ESS SABRE32 9018 DAC chips – 2 units per channel delivering 16 DACs per channel in parallel Fully balanced layout with high-quality components Output connectors coupled with dual LUNDAHL LL7401 output transformers DIGITAL OUTPUT STAGE: HDMI: DSD 2.8MHz, 1-bit PCM 44.1–192kHz, 16–24-bit, Stereo BNC SPDIF: PCM 44.1kHz–192kHz, 16–24-bit DSD (DoP, DSD over PCM) 2.8MHz, 1-bit POWER SUPPLY: External dual-toroidal Available in 240V and 110V versions PHYSICAL: FINISH: Raw brushed aluminium or black anodised brushed aluminium LUMIN (SOLID ALUMINIUM CHASSIS): 350mm (W), 345mm (D), 60mm (H), 8kg PSU: 100mm (W), 315mm (D), 55mm (H), 2kg SPECIFICATION FOR ALL LUMIN MUSIC STREAMERS STREAMING PROTOCOL: UPnP AV protocol with audio streaming extension (OpenHome) Roon Ready Spotify Connect AirPlay-compatible Gapless Playback On-Device Playlist APP FEATURES: Native support for TIDAL, MQA, Qobuz and TuneIn Radio. Tidal MQA icons to identify high-res music Qobuz high-res icons to identify high-res music Volume control High-resolution artwork Artwork caching Search Multiple tag handling Composer tag support Album-grouping in playlist Automatic internet links to artists/album/songs Saving and restoring of playlists (including Tidal and Qobuz) SUPPORTED AUDIO FILE FORMATS: DSD Lossless: DSF (DSD), DIFF (DSD), DoP (DSD) PCM Lossless: FLAC, Apple Lossless (ALAC), WAV, AIFF Compressed (lossy) Audio: MP3 MQA INPUT: Ethernet RJ45 network 100Base-T USB storage, flash drive, USB hard disk (Single-partition FAT32, exFAT and NTFS only) ANALOGUE AUDIO OUTPUTS: XLR balanced, 4Vrms, pin 2 Hot RCA unbalanced, 2Vrms SUPPORTED CONTROL DEVICES: Apple devices. iOS 11.0 or later (List of supported devices) Android devices. Android 4.0 (Ice Cream Sandwich) or later required OTHER: Leedh Processing lossless digital volume control Programme of Continuous Development – Firmware-upgradable for further features and enhancements
Con này nôm na được hiểu là con music server Lumin U1 đầu bảng lắp thêm phần DAC nên rất đẳng cấp và tiện lợi. Theo em thì dùng con này là đủ không cần thêm DAC ngoài nữa vì đã quá ngon rồi, còn nếu dùng DAC ngoài thì sẽ chọn con thuần music server Lumin U1 chi phí sẽ thấp hơn (tiết kiệm được 50 triệu).
em đang có music server Cocktail X50D , nó gắn đc ổ cứng trong máy luôn , giờ em muốn từ cái này xuất tín hiệu vào cái Lumin S1 này thì kết nối bằng cổng nào để nó ra dsd128 , hay chỉ ghim ổ cứng vô là nó đọc được file dsd128 rồi
lumin ko có cổng digital in nhé b, mà bỏ con X50D kia đi, thay = con S1 này cho cả streammer và DAC, ổn hơn nhiều
Đúng rồi bác, Lumin S1 thiết kế nhằm mục đích đó mà bác: Cắm ổ cứng HDD vào đường USB, Ổ NAS vào đường và đường Internet (LAN, J 45), nghe trực tiếp nhạc mạng như TADẠL, Qobuz....nói tóm lại nó chạy đủ các loại nghe nhạc hiện hành. Bác tham khảo https://www.hifivietnam.vn/thu-vien-review/lumin-s1-nhac-so-chieu-long-cac-tin-do-analog/
minh không thích lumin 1 điểm không có digital in. bác nào có transport muốn nghe cd có sẵn coi như bỏ
Sorry bác mình cũng tìm hiều e này, nhưng mình nghĩ nêu bỏ ra 100tr thì chắc bác mua cũng nghiên cứu những điều tối thiểu đó mà bác
