Gryphon Fan Club
Discussion in 'VNAV's Fan Club' started by anhpham79, 19/12/10.
  1. dunganddiep
    dunganddiep Advanced Member
    Ôi! Em ngưỡng mộ bác quá! Có D300, Kharma 3.2fe đen rồi, thiếu miếng ghép như bác! Để thành bộ đen xì xì hị!
    dvh2806 likes this.
  2. quantrungyen
    quantrungyen Advanced Member
    Thông số kỹ thuật của Mikado Signature
    Four Dual-Differential 32-bit/192 kHz AKM Digital-to-Analogue Converters with separate regulated power supplies
    Upsampling to 32-bit/192 kHz for enhanced sonic performance
    Gentle digital filter roll-off for ultra-pure high frequencies
    Modular digital audio sections for possible future upgrades
    Two custom-built, temperature-compensated crystal oscillators with better than 5 parts per million accuracy
    Heavily modified Philips CD-Pro 2 transport with all-metal chassis
    True class A, fully discrete analogue circuits with no negative feedback
    First-order analogue filter with silvered Mica capacitor
    +/- 20 VDC regulated voltage supplies for best THD and noise suppression in analogue sections
    Four separate custom-built toroidal transformers for digital and analogue sections
    Completely isolated power supplies for digital section and transport/display
    15,000 microFarad power capacitor banks per channel
    True Dual Mono Configuration
    Ultra-short signal path with minimal Internal wiring
    Four-layer printed circuit board with silver surface for optimal signal transfer
    Balanced analogue outputs with PCB-mounted gold-plated Swiss Neutrik XLR sockets
    Single-ended analogue outputs with custom-made PCB-mounted gold-plated phono sockets
    Balanced 110Ω AES/EBU and 75Ω S/PDIF digital outputs
    40-gram precision-tooled anodized aluminium disc clamp
    Fully remote controlled operation
    Designed and built in Denmark
    Còn đây là của Gryphon Mikado CD Player
    •Four Dual-Differential 24 bit/96 kHz AKM Digital-to-Analog Converters with separate regulated power supplies
    •Upsampling to 24bit/96 kHz forenhanced sonic performance
    •Modular digital audio sections for possible future upgrades
    •Two custom-built, temperature-compensated crystal oscillators with better than 5 parts per million accuracy
    •Heavily modified Philips CD-Pro 2 transport with all-metal chassis
    •True class A, fully discrete analog circuits with no negative feedback
    •First-order analog filter with silvered Mica capacitor
    •+/- 20 VDC regulated voltage supplies for best THD and noise suppression in analog sections
    •Four separate custom-builttoroidal transformers for digital and analog sections
    •Completely isolated power supplies for digital section and transport/display
    •15,000 microFarad power capacitor banks per channel
    •True Dual Mono Configuration
    •Ultra-short signal path with minimal Internal wiring
    •Four-layer printed circuit board with silver surface for optimal signal transfer
    •Balanced analog outputs with PCB-mounted gold-plated Swiss Neutrik XLR sockets
    •Single-ended analog outputs with custom-made PCB-mounted gold-plated phono sockets
    •Balanced 110W AES/EBU and 75W S/PDIF digital outputs
    •40-gram precision-tooled anodized aluminum disc clamp
    •Fully remote controlled operation
    badboybeo likes this.
  3. Huangsong88
    Huangsong88 Approved Member
    Em thấy vẫn có nhiều Bác có Mikado bán đấy Bác ạ.
  4. Huangsong88
    Cảm ơn Bác chia sẻ thông tin. Em đã mua được chiếc Mikado Signature rồi ah.
  5. dunganddiep
    Chúc mừng bác! Em vẫn đang ước.
  6. quantrungyen
    Có thời điểm 2 sở hữu cả 2 và đc đối chứng cả 2 trên 1 bộ dàn. Nghe cũng thấy khác biệt khá rõ về độ chi tiết, bong tơi và nhưng lại mềm mại hơn bản trơn.
  7. Jacky5555
    Jacky5555 Advanced Member
  8. Babybaby
    Babybaby Approved Member
    Bác nào đã ghép Mephisto với Kharma lớn (như Veyron 4D, 5D) chưa ạ.
    Xin cho review nhé
  9. Doan Thang
    Doan Thang Advanced Member
    Chào các bác!
    E đang chơi pow Gryphon S100, ghép với pre Octave 500Hp, đang lỗi chập chờn lúc được lúc 1 bên, có lúc vặn volume mạnh thì lại ra đủ 2 bên
    Em nhờ các bác chỗ sửa pow ở Hà nội.
    E cám ơn các bác!
  10. Nguyen trung hieu
    Nguyen trung hieu Advanced Member
    Bác nên kiểm tra từ nguồn phát, pre, dây tín hiệu rồi đến pow (dây tín hiệu thì nên đảo chéo sang nhau, hoặc dùng đồng hồ đo thông mạch)
    Luancd likes this.
  11. Doan Thang
    Thanks bác!
    Cũng thử cả rồi, trước bị loẹt xoẹt rồi có lúc mất 1 bên, văn volume to thi lên cả 2, giờ thì lúc mất bên này lúc mất bên kia, có lúc tịt hẳn.
    Nguyen trung hieu likes this.
  12. Luancd
    Luancd Approved Member
    Các bác cho hỏi dây LOA thích hợp hay cho loa Mojo - em đang dùng Zoro nhưng mỏng tiếng
  13. newkoi
    newkoi Advanced Member
    Có bác nào ghép pow Gryphon với loa Wilson Audio chưa ạ?
    Em đang định tìm cái pow Gryphon công suất cao chút để ghép với cặp Wilson.
  14. Diatone81
    Diatone81 Advanced Member
    Thấy tây lông cũng ghép nhiều đó bác, bác thử xem :)
    440901122_287378757777259_2729371339998068865_n.jpg 440999513_1108925987063082_2918928056163626513_n.jpg 440882485_320101034288271_6318661025686547464_n.jpg
    newkoi likes this.
  15. anhpham79
    anhpham79 Advanced Member
    Hà Thành
    Nếu bác ở m.bắc thì liên hệ e , bê cả mephisto vs pandora về thử . e đang ghép với Trident2 .
  16. ndtt
    ndtt Advanced Member
    Các bác cho hỏi:
    Amply gryphon diablo 250 dùng dây nguồn nào hợp.
    1-Shunyata sigma hc.
    2-Zensati zorro.
    Thk.
  17. chitrung7121985
    HÀ NỘI
    Bọn gryphon e thấy khá kén dây nguồn... Bác nào choie gryphon vs avalon cho em ít kinh nghiệm dây loa cho phù hợp ạ
  18. caosau
    caosau Advanced Member
    Dây nguồn nếu dùng cho pow Gryphon thì e thấy NBS 3s khá hợp, còn dây loa thì taralabs.
  19. chitrung7121985
    HÀ NỘI
    E đnag chơi inakustik nên hỏi thêm để thêm lựa chọn... Kubala sao bác nhỉ
  20. caosau
    Inakustik hay kubala e chưa chơi nên ko dám cho ý kiến. Dây nguồn cho Gryphon nếu có đk thì Odin 1 cũng rất hay.
  21. dunganddiep
    Mình chơi D300, dây ps4.1, giắc furu 50Rh ncf. Thấy hài lòng. Giắc cắm cũng rất quan trọng
  22. dunganddiep
    Bác thử Kimber 3035 hoặc 3033 xem sao
  23. Củ Mì
    Củ Mì Advanced Member
    Theo tôi thì Pow Gryphon phù hợp với các dây nguồn có lõi càng to càng tốt. Bạn dùng thử dây Zansati No.#3 xem sao?
  24. manhquynh23
    manhquynh23 Advanced Member
    Em đã thử Gryphon với dây nguồn Anzus P2 và A2 cũng tuyệt lắm
  25. anhpham79
    Hà Thành
    Nhẹ nhàng đầm ấm thì Stealth V16 up - Hoành tráng mạnh mẽ thì Zensati Angel up . E đang chơi full Gry và đã ko dưới 10 lần thử các hãng dây , chia sẻ chút với các bác . ( dây nguồn )
