Hegel Music System - Fan Club
Discussion in 'VNAV's Fan Club' started by online11, 6/10/15.
  1. LQMH
    LQMH Advanced Member
    Bác muốn mua mức giá nào? Chứ H300 thì shop Dế Mè và bác Củ Mì có...
  2. LQMH
  3. HDStudio
    HDStudio Advanced Member
    @LQMH : Vâng em ghép với B&W 804 D3 bác. Bộ nghe nhạc và xem phim của em đây ạ. Trước nghe đủ CD, LP. Gần đây em nghe nhạc số nhiều hơn. Dùng chính DAC tích hợp của Hegel 360 thấy cũng ổn.
    nqkhanhn, Vinh Luu and LQMH like this.
  4. LQMH
    Nếu cables phù hợp, em nghĩ H360 đánh B&W 804d3 ... hay. Hồi xưa em chơi 803S, dây loa Trans music wave ultra mm2, tín hiệu zensati #3 - thấy rất hợp.
    HDStudio likes this.
  5. Nhim meo
    Nhim meo Advanced Member
    Tks bác, mình lấy ampli naim Supernait ghép với loa ProAc thấy hay và hợp lắm rồi
  6. lòi ruột
    lòi ruột Approved Member
    Da Nang
    Bác nghe jbl với hegel chưa ah?
  7. LQMH
    JBL nghe rồi, Hegel cũng nghe rồi, nhưng 2 thứ đó ghép lại thì chưa.
  8. lòi ruột
    Da Nang
    "Với" là ghép với nhau đó bác.
    LQMH likes this.
  9. LQMH
    @ “Compared to the Gryphon, the Hegel sounds flatter, more compressed. The Diablo was also far more quiet. While both are highly resolving, I could consistently hear a smidge more through the Diablo 300. Further, the Hegel’s ultraclean, ultrasmooth sound differed from the Gryphon’s, which was sweeter and more robust. The biggest difference between the two was the level of engagement with the music that I enjoyed. The Gryphon was a big step up from the Hegel in its musicality and realism. With the H360 in my system, especially through Magico’s top-shelf S1 Mk.II speakers, I felt I was listening to a very high level of reproduction of music. But with the Diablo 300 driving the Magicos, my experience of music was more transcendent, pushed the envelope more; in a word, it sounded more real. The Hegel is excellent for the money. The Gryphon is excellent, period.“
    https://www.soundstageultra.com/ind...o-designs-diablo-300-integrated-amplifier-dac
  10. LQMH
    08273D37-D094-451E-8FBF-1023E5A5113B.jpeg 2E0B3190-DB29-468D-918B-C9A00D86F474.jpeg 145B38C3-83B4-4D0C-BFA5-6B79CF6DCBF9.jpeg Một vài hình ảnh Hegel h360
  11. LQMH
    0954D0A2-4D74-4229-AE37-9E7983CAC3CA.jpeg Power supply: 2000VA dual mono, 270 000uF capacitors
    Output stage: 56 pcs 15A 150W high speed bipolar transistors
  12. LQMH
    8D01178D-60E7-41BF-B881-BF51091051EA.jpeg che bụi và ... trang trí
    online11 and nqkhanhn like this.
  13. ninu
    ninu Advanced Member
    Các Bác cho em hỏi tí
    Con dac Hegel HD11 giá tầm 500$ # 11 triệu em có nên mua không ạ ?
  14. katie
    katie Advanced Member
    Hà nội
  15. online11
    online11 Advanced Member
    Theo mình giá đó hơi mắc và không nên mua. Nếu Bác có khả năng tài chính thì nên mua HD 12 luôn nha.
    ninu likes this.
  16. online11
    Bác kỹ thế làm cả miếng kiếng che bụi.
  17. Vinh Luu
    Vinh Luu Advanced Member
    Em mới mua B&W 804 Nautilus cỏ, không phải dòng Diamon như của bác. Em muốn hỏi bác chút là bác ghép B&W với Hegel có thẩy ổn với nhu cầu nhạc nhẹ, nhạc vàng, thi thoảng pop, guitar không?
    Cảm ơn bác
  18. HDStudio
    Em thấy hợp bác ạ. Hegel tiếng trong, ấm, lực đánh của amp rất mạnh so với các amp tích hợp khác, nên thổi ra được chất của B&W mà không tốn kém quá.
    LQMH likes this.
  19. online11
    [QUOTE="Vinh Luu, post: 1930834, member: 78116]Em muốn hỏi bác chút là bác ghép B&W với Hegel có thẩy ổn với nhu cầu nhạc nhẹ, nhạc vàng, thi thoảng pop, guitar không?
    Cảm ơn bác[/QUOTE]
    Hegel H360 là giãi pháp ít tốn kém và đáp ứng hết nhu cầu nghe của Bác đó. Phần DAC của H360 cũng rất khá nếu Bác đầu tư phần dây USb và máy tính tốt thì mình nghĩ không cần CDP luôn.
  20. katie
    Hà nội
    Hegel H360 là giãi pháp ít tốn kém và đáp ứng hết nhu cầu nghe của Bác đó. Phần DAC của H360 cũng rất khá nếu Bác đầu tư phần dây USb và máy tính tốt thì mình nghĩ không cần CDP luôn.[/QUOTE]
    Bác nào cần liên hệ H360 thì bảo em nhé. Em cảm ơn
    Vinh Luu and Nhim meo like this.
  21. LQMH
    H300, H360, H200 phù hợp với B&W dòng 803D, 803S, 803N, 804S, 804N về tầm giá, công suất, chất âm.
    Hegel mạnh, tiếng đầm, mid dày, ... nên B&W sẽ bớt la, ra được bass. Trở kháng min 2ohm nên chìu được B&W trở kháng xuống đến 3ohm. Với h360, bộ nguồn đến 1.2kva, dàn tụ lớn nên thoải mái về năng lượng.
    Hegel ... xấu, chasis cũng xấu. Nhưng chơi B&W thì tránh được 1 tiền gà 3 tiền thóc - tiền amp ~ tiền loa.
    @ Chọn dây loa phù hợp. Theo trải nghiệm, mình thấy Transparent tầm musicwave super, ultra mm2 trở lên ok.
  22. CuongAcoustic
    CuongAcoustic Advanced Member
    Hà Đông, HN
    Bác nào cần liên hệ H360 thì bảo em nhé. Em cảm ơn[/QUOTE]
    Tiếc quá, em vừa lấy H300 hôm qua, giá h360 mà tốt thì em vẫn thích đời mới hơn :D
  23. CuongAcoustic
    Hà Đông, HN
    ATC cũng rất hợp bác ạ. Em đã từng nghe và nghép ATC với rất nhiều amp như: Rogue, Electrocompaiet, AVM, Primare, Sugden, Atoll... nhưng đến khi ghép SCM 20 với Hegel H360 mới thực sự thuyết phục.
    LQMH likes this.
  24. LQMH
    Loa bookshelf mà cứng đầu. ->300W http://atcloudspeakers.co.uk/hi-fi/loudspeakers/classic-series/scm20/
    CuongAcoustic likes this.
  25. CuongAcoustic
    Hà Đông, HN
    vâng, atc thuộc dòng kén amp, để em nó kêu được thì dễ nhưng để kêu hay và đúng thứ âm thanh đặc trưng thì phải cần đồ đánh hợp + gấu 1 chút. Tiền amp bao giờ cũng phải hơn tiền loa, đây là kinh nghiệm sau 3 tháng bê vác, cắm rút để khai thác SCM 20 của em bác ạ :D
    LQMH likes this.
