Hioki 3233 Digital Hi Tester
Discussion in 'Linh kiện - Thiết bị khác' started by akai122005, 17/10/19.
  1. akai122005
    akai122005 Approved Member
    Tên mặt hàng:Hioki 3233 Digital Hi Tester
    Tình trạng, mô tả:used
    Giá bán:2200000
    Khu vực:HCM
    Điện thoại:0918072477
    Giao hàng:free
    No.of Digits: 4
    DC Volts Range: 300mV
    AC Volts Range: 3V
    Easy-to-read 18mm-height characters, bench type DMM
    Wide range, maximum reading 3199 digit.
    Capacitor measurement up to 32 µF.
    Optional 9200 DIGITAL PRINTER is available for convenient data printing.
    DC/AC power supply system.
    Continuity
    Diode Check
    Range Switching
    BCD signal output
    Performance Characteristics of the 3233
    Form Factor Benchtop
    Number of Digits (Max) 4 digits
    DC Volts Minimum Range 300 mV
    DC Volts Maximum Range 1000 V
    DC Volts No. of Ranges 5 QTY
    DC Volts Maximum Reading Rate 2.5 pt/sec
    DC Volts Basic 1 yr accuracy 0.35 %
    AC Volts Minimum Range 3 V
    AC Volts Maximum Range 750 V
    AC Volts No. of Ranges 4 QTY
    AC Volts Minimum Frequency 40 Hz
    AC Volts Maximum Frequency 500 Hz
    AC Volts Maximum Reading Rate 2.5 pt/sec
    AC Volts Basic 1 Year Accuracy 1.0 %
    True Rms (?) No
    DC Current Minimum Range 30 mA
    DC Current Maximum Range 10 A
    DC Current No. of Ranges 3 QTY
    DC Current Maximum Reading Rate 2.5 pt/sec
    DC Current Basic 1 yr accuracy 1.0 %
    AC Current Minimum Range 30 mA
    AC Current Maximum Range 10 A
    AC Current No. of Ranges 3 QTY
    AC Current Maximum Reading Rate 2.5 pt/sec
    AC Current Basic 1 Year Accuracy 1.2 %
    Resistance Minimum Range 300 Ohm
    Resistance Maximum Range 30 MOhm
    Resistance No. of Ranges 6 QTY
    Resistance Basic 1 yr accuracy 0.4 %
    Minimum Frequency 300 Hz
    Maximum Frequency 300 kHz
    Frequency Accuracy 0.1 %
    Maximum Display Value 3199 count
    LH: 0918072477
