HN_Bán switch audio Motu avb và macbook air 2019
Discussion in 'Digital - Computer' started by casperhn, 10/7/22.
  1. casperhn
    casperhn Advanced Member
    Tên mặt hàng:
    1. Switch Motu 5 port có hỗ trợ AVB cho chất lượng truyền dữ liệu tốt hơn. Một số thử nghiệm so sánh của anh em đánh giá sân khấu rộng, độ động tốt.
    Hàng new seal. Giá 8t5
    What is AVB (Audio Video Bridging)
    AVB (Audio Video Bridging) is an extension to the Ethernet standard designed to provide guaranteed quality of service, which simply means that audio samples will reach their destinations on time. AVB allows you to create a single network for audio, video, using an AVB-compatible switch.
    AVB offers several features that make it ideal for the home studio:
    1. A single lightweight CAT5e or CAT6 cable can be run up to 1328 feet. This makes it easy to have audio I/O located in different rooms and run multichannel audio between them in real time.
    2. Low, predictable latency. AVB latency is 2 ms (or less) when sending an audio stream over up to seven “hops” (trips through switches or other devices) on a 100 Mbps network.
    3. Scalable, with high channel counts. AVB’s bandwidth is sufficient to carry up to 512 real-time channels using a single Ethernet cable. This offers the future possibility of expanding your system with additional devices that contain different kinds of audio I/O, multiple controllers, and other useful functions.
    4. Integrated clock signal. In a digital audio system with multiple devices, having a master clock is critical to maintaining audio fidelity. The AVB specification defines such a clock to be accurately distributed to all devices in the system.
    2. Macbook air 2019.
    Cấu hình Core i5, ram 8G, ssd nvme 256, sạc 125 lần. Máy đẹp hoạt động hoàn hảo.
    Giá: 14t5
    Anh em quan tâm e gửi anh chi tiết qua zalo
    Liện hệ: Trung 097.25.58.899
    Xã Đàn - Đống Đa - Hà Nội
  2. Tran Chau Tuan
    Tran Chau Tuan Approved Member
    cần mua 1 con motu này ai có báo mình nhé
