Tên mặt hàng: JBL S4700 Tình trạng, mô tả:hàng nguyên thùng của Thanh Tùng Audio. Giá bán: 157t. Khu vực: HCM Điện thoại: 09 ba 8 694 nam khong nam Giao hàng: Ảnh chụp thực tế Thông tin thêm: Một cặp loa thuộc hàng cao cấp của JBL. Với rất nhiều công nghệ mới. Bass 380mm, mid 45mm, treble 19mm. Độ nhạy cao 94db, chỉ cần ampli nhỏ hơn bằng 300w. Trọng lượng 55kg. Rất đẳng cấp, sang trọng và rất đẹp.
THÔNG SỐ KỶ THUẬT : Frequency Response: 38Hz – 40kHz (–6dB) Recommended Amplifier Power: 300 watts Sensitivity: 94 dB (2.83V @ 1m) Nominal Impedance: 6 Ohms Crossover Frequencies: 800Hz, 12kHz UHF Drive Components: 19mm HF Drive Components: 50 mm LF Drive Components: 380 mm Enclosure Type: 1" (25mm)-thick MDF stock, ported Dimensions (W x H x D): 500 x 1068 x 371 mm Weight: 54.5 kg
https://www.musicdirect.com/speakers/JBL-S4700-Tower-Speakers Stocked with Professional-Grade Drivers, Voice Coils, and Horn Assemblies S4700 is built upon the same professional-grade technology used in JBL's Project K2 S9900, one of the most advanced and sophisticated loudspeakers in the world. At its foundation, S4700 uses an all-new cast-frame 15-inch woofer (2216Nd) with a powerful, dual three-inch voice coil and neodymium motor structure for outstanding balance with the horn-loaded compression drivers. Mid- and high-frequencies are reproduced by a pair of titanium diaphragm compression drivers and a single-piece, SonoGlass dual horn assembly. The two-inch Aqua-Plas™-coated titanium diaphragm compression driver (175Nd-3) is mated to a 90° x 60° Bi-Radial® horn and delivers mid- and high-frequencies with lifelike dynamics and startling realism while an ultra-high-frequency 0.75-inch titanium diaphragm compression driver (138Nd) with a 60° x 30° Bi-Radial horn recreates critical air and spaciousness. Premium-quality network components and dual binding post inputs ensure audiophile performance in any application. The attractive furniture-grade cherry wood veneer enclosure is internally braced at critical points and is tuned via a rear-firing port.
Hiện nay một số shop bán hàng cũ đã xài rồi (demo) với giá mới. Chứ thật sự ko có hàng mới với giá này đâu bác. Loa này mới 99.99% full box. Giá sách cặp này là $15k. Là dòng thứ nhì được kế thừa trọn vẹn của K2S9900 huyền thoại. Rất đáng để trải nghiệm
Loa bé bé có cái giá to to: https://www.mainguyen.vn/khui-hop-loa-bowers-wilkins-a5-tai-mai-nguyen.html
