Loa ATC cùng vào chia sẻ!
Discussion in 'VNAV's Fan Club' started by Niagara, 25/8/10.
  1. aquasound
    aquasound Advanced Member
    Đây là hướng dân sử dụng của hãng
    Technical specifications ECI 5 MKII:
    The following technical data where measured on randomized test objects
    and are typical data. All measurements are made at 120V / 240V //
    50Hz / 60Hz Clipping point of the amplifier is set to a level where total
    harmonic distortion (THD) is 0.2 %.
    Preamplifier section
    Input impedance (Balanced input)................................... 47 kOhm
    Maximum input level .................................................... 10 Vrms
    Noise floor (1Vrms, 20 - 20 kHz, balanced).................... -135 dB
    THD + N (1Vrms, 20 - 20 kHz, balanced) ...................... <0.003%
    Gain (Balanced)............................................................ 0 dB
    Amplifier section
    Output Impedance ........................................................< 0,02 Ohm
    Frequency response (- 3 dB)............................................1 – 150 kHz
    Channel separation........................................................> 120 dB
    THD + N (20 - 20 kHz).................................................< 0.004%
    Maximum peak current...................................................>100A
    Damping factor (8 ohm load)..........................................>350
    Input sensitivity (120W output)......................................1.3Vrms
    Input sensitivity HT (120W output)...................................1Vrms
    Rated output power
    10 % change in line voltage will give approximately 20 % change in
    output power.
    8 Ohm2 x 120 W
    4 Ohm2 x 200 W
    2 Ohm2 x 370 W
    Power consumption (no load or signal) 100 W
    Standby - 1W
    The ECI 5 MKII is DC coupled from input to output.
  2. aquasound
    Amplifier section
    Rated output power
    output power.
    8 Ohm2 x 120 W
    4 Ohm2 x 200 W
    2 Ohm2 x 370 W
    Standby - 1W
  3. aquasound
    Hình như hãng này chỉ phục vụ thị trường Mỹ & Bắc âu thì phải :roll:
  4. superlazy
    superlazy Advanced Member
    Hay ô LNQ nghiên cứu đối SIA lấy ECI 5 MKII con của ô set được 240V chạy 60Hz là ngon đấy...
      49,9 KB
  5. sunofbeach
    sunofbeach Approved Member
    Chưa chuẩn, đầu vào ở đây là tín hiệu, có nghĩa chạy Balance vào sẽ lợi tiếng hơn RCA
  6. superlazy
    Ô lnq này có cả xlr và rca... dây nhợ đủ hết rồi có đổi gió tí ko ô?
  7. aquasound
    Rated output power
    output power.
    8 Ohm2 x 120 W
    4 Ohm2 x 200 W
    2 Ohm2 x 370 W
    bác dich sát nghĩa hộ em với ah
    kết nối Balance se hơn Unbalance ( RCA ) về không gian & âm nền
  8. sunofbeach
    Voltage ở đây là dòng tín hiệu phát, unbalance thường là 2.1V rms và balance là 4.2V rms, nếu là đầu đĩa than thì thấp hơn nữa. Nếu nghe ECI5 kết nối balance ở mức 9h thì tương đương RCA ở mức 11h.
    Kết nối balance cũng không hơn âm nền và không gian đc mà có thêm 1 đường grounded sẽ giảm noise, voltage cao nên dây dẫn có thể đi xa và ít suy hao hơn RCA.
    Còn nói điện đầu vào 110v và 220v, có nghĩa 100% đầu vào sẽ tăng 200% công suất thì có nghĩa cắm điện 220v Eci 5 có cs trên 300w ah?
    Tôi xin dừng chủ đề này, ko loãng topic ATC của anh em
  9. longnhaque
    longnhaque Advanced Member
    Nhân có cái này nên Em được mở mang tầm mắt vì trước đây chỉ nghĩ cái Aptomat cỡ 50A của Mềnh chắc là ổn nhưng thật sự không phải vậy.
    H1.
    Hình trên được lắp đặt bởi hãng ISOCLEAN với 1 Aptomat chủ 100A và rất nhiều Aptomat 35A đấu //, rồi nó được đấu vào thanh đồng mạ vàng 24K. Tất cả nhằm mục đích là để tăng mật độ điện, giảm trở kháng tại điểm tiếp xúc của cầu dao tới mức ưa thích là Zero Ohm (R=0).
    H2.
    Ở một hãng khác, họ không dùng CB mà dùng hộp đóng mở cầu chì (1 dạng của đóng ngắt điện).
    Ở nhà Em: Em đã mở Aptomat ra và nhìn mặt tiếp xúc thì quả thực tiết diện tiếp xúc quá bé, đã vậy Aptomat lại nhiều tiếp điểm, thanh nhiệt nữa nên khả năng chất lượng dòng điện đi qua là bị kém đi.
    H3.
    Vậy, EM dự định làm 1 cái tủ như ISOCLEAN với các CB nhưng hiện phân vân có nên dùng thanh đồng mạ Vàng không (kaka)??? Các Bác có kinh nghiệm chi giáo giùm.
  10. ADN
    ADN Advanced Member
    Bác ấy chê như thế nào vậy bác ? :)
  11. ADN
    ADN Advanced Member
    CB ở cột điện gắn công tơ có 40A thôi, nhà em lắp cái tổng 63A, sập................ nó lại sập ngoài cột mới đau. :mrgreen:
  12. longnhaque
    Ấy chết, ý Em dùng cái CB không phải vì an toàn điện mà để ứng dụng cho nó vào việc đóng ngắt điện, dùng ampe cao để lấy cái thanh dẫn điện bên trong nó to, dùng thanh dẫn bên ngoài là để đấu // nhiều cái nhằm mục đích tăng mật độ điện lên thôi.
    Đây là ảnh CB 30A
  13. 0208_Audio
    0208_Audio Advanced Member
    Mạnh dạn thôi bác, hàng hãng thì ko nên băn khoăn nó mạ bằng cài gì ạ
  14. thangkv
    thangkv Advanced Member
    Ah bác ý bảo tiếng Bass loa của em quá kém chán. Tai em nó lèng mèng nên sau khi đi nghe thử ATC 7 thì đúng như vậy, nhưng các cái khác thì ACT 7 chưa chắc đã qua được đôi loa hiện tại của em. Cơ bản em cũng thích ATC nên chắc cày thêm vào bữa nữa mua về loay hoay thử.
    cảm ơn bác
  15. kiamorning
    kiamorning Advanced Member
    Rốt cục thì bác cũng không chịu nói bác nghe loa gì :lol:
    Vậy thì mua ATC đi bác
  16. 0208_Audio
    em cố gắng giúp đỡ bác nhé :D
    - bác cho em hỏi bác đi nghe ATC được mấy lần và cảm nhận của bác với những lần đi nghe với các phối ghép khác nhau ?
    - Nếu bác mới chỉ đi nghe ATC có 1 lần thì nên đi thêm vài lần nữa, cố gắng nghe và cảm nhận, ko nên vừa nghe vừa so sánh với cái này với cái kia ...
    - Bạn bác bảo loa của bác bass "quá kém chán" bác có thấy thế ko ? " cái khác của đôi ATC 7 "chưa chắc qua được đôi loa hiện tại" bác có đổi tiếng bass của ATC lấy các cái khác mà đôi loa của bác đang có ko ???
    em gợi ý tới bác như sau: bass của ATC chính là điểm yếu của hãng này, nếu phối ghép ko tốt bass của ATC nghe rất tệ.
  17. thangkv
    Cảm ơn các bác!
    Em đi nghe được 2 lần ATC v1 và v3.
    Chắc em sẽ đi nche thêm.
    Do em phải đặt loa gần tường nên loa ATC ko có lỗ thông hơi nên em thấy phù hợp phòng nhà em.
    Chắc em cố cày để làm bộ ATC 11 kèm đồ đánh của hãng luôn cho dễ.
    Hiện em đang dùng loa peachtree D5 và amli của hãng luôn.
  18. longnhaque
    Hôm nay rảnh rỗi E lại bóc 1 con aptomat ra, loại này ampe cao và đời mới hơn nên hệ thống tiếp điểm lại khác, mặt tiếp xúc to và dầy hơn, không dùng thanh nhiệt nên truyền dẫn đảm bảo hơn. Hic
  19. doanhnhan2000
    doanhnhan2000 Advanced Member
    Ha Noi
    Em cho rằng hiểu như bác Aquasound mới là đúng!
    Ở đây bác Sun đang giải thích về độ gain> 10% giữa kết nối Balance và Rca, do đó cùng một âm lượng balance sẽ cho âm thanh kêu to hơn. Chứ ko liên quan tới vấn đề tăng điện áp đường dây 10% làm tăng công suất đầu ra thêm 20% mà Hãng đang đề cập.
    Như chúng ta biết, điện áp từ 220-240V được sử dụng rộng rãi ở Châu Âu và nhiều nước châu Á, châu Phi và dĩ nhiên trong đó có Việt Nam chúng ta. Tiếp theo là điện áp 100-127V được sử dụng rộng rãi tại toàn bộ lãnh thổ Bắc Mỹ, một số nước Nam Mỹ, Nhật Bản và Đài Loan. Nói là tăng điện áp đường dây 10%, nghĩa là cùng trong điện lưới 220v-240V hoặc 100v-127v, chứ không phải so sánh 110v-220v. Thực tế cá nhân e nhận thấy, amp quy định điện áp vào 220v, thì tầm 230V nghe là hay nhất, lên tới 240V, tiếng có phần hơi căng, mà thấp xuống 200V thì hụt hơi.
  20. longnhaque
    Cuối cùng thì Em cũng tìm được cái Aptomat để làm switch on/off cho hệ thống mà không bị bó hẹp. Cái này tiếp điểm có tiết diện to gấp 2 dây điện và được thiết kế đảm bảo tiếp xúc toàn phần, mặt được đính kim loại quý.
  21. cacavk
    cacavk Advanced Member
    Các bác trong fan ATC! Có ATC SCM 20 SLT ở shop VT kìa :D
  22. teppi79
    teppi79 Advanced Member
    HP-HN
    Đẹp quá, bác cavavk múc thôi... :mrgreen:
  23. cacavk
    Em đang chơi loa nhỏ bác ui, có lẽ cặp kế tiếp sẽ là ATC 7 hoặc 11 gì đó! :D
  24. fuongdo
    fuongdo Approved Member
    Em chào bác, em đang quan tâm tới atc. Phòng của em 12m thì theo bác em nên chơi 7v3 hay 11v1, 11v2 ạ? Amp & dây thì nên chọn hãng nào đạt tiêu chí ngon - bổ - rẻ ạ.
    Cảm ơn bác đã chia sẻ kinh nghiệm.
  25. fuongdo
    Cặp loa đẹp quá, nhìn mà thèm. Phòng em có 12m mà em loay hoay chưa biết nên chọn 7v3 hay 11mkii ạ :(
