Loa Usher S-520
Discussion in 'Loa' started by Dracula, 18/4/08.
  1. Only Time
    Only Time Advanced Member
    Thế lại thành 1 tiền gà 3 tiền thóc rùi, chúc các bác lên đỉnh với em ý :D
  2. ngthehung_1973
    ngthehung_1973 Advanced Member
    * Thế vẫn còn là ít . Tôi nghe bộ loa và amply . 1 tiền gà 20 thiền thóc :D
    ( loa china mua đồng nát 20n , amply cũng của đồng nát luôn 400n )
  3. Capstan
    Capstan Advanced Member
    tự sự của anh Tây
    Summary:
    Honestly, I bought this new based on the glowing reviews and found that it may not be up to my taste. The S-520 certainly has strong positives such as realistic imaging and clarity especially with solo instruments, but the brass needs more sparkle to sound realistic. The vocal also sound a bit thin unless it is paired with a real full sounding set of equipments. So it's a very focused speaker that can do most things at an acceptable level but to be as good as what the reviews said you need to pair these with some serious high end equipments and even then they'll sound excellent with certain types of music only. In the end you'll end up with a much more expensive amp and player than the speakers themselves. If I had to go back, I'd go straight to the PSB Alpha B1 that's much more flexible and has way better midrange. Though the highs on the Usher seems a bit more transparent.
    Strengths:
    Realistic imaging of instruments and vocals if positioned correctly with the right equipments. Unmatched cabinet and built quality at the price.
    Weaknesses:
    Vocals sound thin at the upper midrange. Inefficient means need a real powerful amp. Not good with bright equipments. Highs need more sparkle. Bass isn't deep nor tight enough.
  4. Only Time
    Thế này thì giá u sờ lại xuống thôi :)
  5. Capstan
    ai chán muốn bán alo em nhé. em trả 3 triệu một đôi. yêu cầu nguyên bản, hình thức đẹp, thùng, xốp đủ. em thích màu vàng và đỏ cho dễ bày :D
  6. ngthehung_1973
    Lần sau Bác có poss bài tiếng Tây thì nhớ mang cho em mượn cuốn tử điển nhé , không hiểu cái gì hết .
    Em đang định nâng cấp , Bác mua được rẻ thì bán lại cho Em nhé + 100n tiền hoa hồng nhé :D nếu em nhiều Đạn làm luôn con loa 520 new
  7. phidiep
    phidiep Advanced Member
    Bang chém zó
    Nó không phải là hay quá nhưng cũng không quá tệ, quan trọng là bn tiền thôi. Nếu loa 2hand mà 3,5-4 triệu/đôi thì em nghĩ nó lại rất hay đấy ạ.
  8. trumchande
    trumchande Advanced Member
    bác đòi hỏi cao thế thì làm sao mà mua được em nó với giá như vậy
  9. arn0ld
    arn0ld Advanced Member
    hic cái amply denon 1500ae đắt quá , 2nd mà hơn chục triệu >.< thế này chắc em phải đổi loa sớm mất thôi
  10. walkman
    walkman Advanced Member
    Bác nên kiên nhẫn, hôm trước em mới chia tay em Denon 1500AE zin nguyên tem đúng 10tr. Usher S520 mà đánh với 700AE trở xuống là không ra tiếng hay đâu :D
  11. Only Time
    Thế thì tiền Amp đánh U sờ làm luôn em quắc 12L... U sờ sao lại được ạ :lol:
  12. arn0ld
    Hic tiền amly đắt thế thì có nên chuyển sang loa b&w 685 + amly 5t kô các bác ?
  13. Only Time
    Tùy bác thôi, nhưng trước em đi nghe thử B&W 6xx em thấy không hay lắm trong tầm $... không biết có phải do đồ đánh hay không mà nghe cảm giác hơi mệt mệt, không tinh tế... Cái tai trâu của em nó thấy vậy... các bác BW đừng ném em nha :cry:
  14. vtlam
    vtlam Advanced Member
    Chính xác đó bác à. Em nghe gần hết 2 đĩa Áo Hoa Như Quỳnh là cảm thấy hơi mệt, đành lấy U xơ :p
  15. quocthai
    quocthai Advanced Member
    Sao giống nhau đến thế....
    Em thì đang oánh với cd 3300g và amp 1500r, lúc đầu thấy lạ nhưng giờ quen tai lại thấy hay. Các bác thay đổi vị trí kê loa để tìm điểm nhé, e thấy bass cũng có tý uy đấy chứ nhỉ
  16. X_man0005
    X_man0005 Advanced Member
    em định ghép user520 vói creek 5350se các bác cho em y kiến vói. liệu có ổn ko ạ
  17. arn0ld
    các bác ơi loa s520 nghe với ampli marantz pm80 hơn hay pm80af hơn hả các bác . pm80 giá 4t2 và pm80à 5t6 giá đã chuẩn chưa hả các bác . mong các bác tư vấn em sớm với em mót nghe loa lắm rồi >.<
  18. phidiep
    Bang chém zó
    Tất nhiên PM-80a phải hơn PM-80 rồi bác, giá cả thì bây giờ ngày càng kên cao, cao nữa và cao mãi nên chả biết đâu mà lần. Theo em thì PM-80a khoảng 5 triệu, còn PM-80 khoảng 4 triệu. Nếu màu đen thì rẻ hơn cỡ 500k cho mỗi loại. Theo em PM-80 hay PM-80a ghép với Usher S-520 nghe được thôi chứ chưa hoàn háo! :)
  19. arn0ld
    vậy 5t6 là hơi đắt hả bác , ampli đi xem thì test thế nào ạ ? hôm nay em tìm hiểu chân loa của 1 bác chuyên bán online , giá tầm 1t7-2t2 hic hic chat quá , loa có mấy triệu mà mua ampli với chân loa còn hơn tiền loa . bác biết ở đâu bán chân loa chuẩn kĩ thuật + rẻ thì chỉ em với , chỉ cần hợp loa đúng kĩ thuật kô cần đẹp ạ :(
  20. phongvan2000
    phongvan2000 Advanced Member
    Khổ thân các bác cứ loay hoay ghép Usher S-520 với mấy cái ampli Marantz với cả DENON
    riêng em đi theo con đường khác -em ghép với con Receiver Cambridge Azur 540R cực độc
    này (riêng cái Receiver Cambridge này không còn cái thứ 2-hàng mới ở VN đâu nha) , đập chết nát bét các ampli 2 kênh dưới 1000 thằng mỹ của các bác luôn
    hay đừng có hỏi , vừa nghe nhạc mà lại vừa xem phim "Anh tài tụ nghĩa"
    riêng về khoản nghe nhạc 2 kênh , hay hơn cách phối ghép ở Congaudio nhiều lần, chất âm -sở trường của em Usher S-520:độ động, âm hình, nhạc tính bị em Cambridge Azur 540R moi ra bằng hết luôn , hình như chúng nó sinh ra để dành cho nhau thì phải ........ :roll:
    còn bác nào mà lại lăn tăn vì Receiver thì làm sao nghe nhạc 2 kênh lại hay bằng ampli 2 kênh thì cứ phải đến nghe thử và sẽ tự mình trả lời thôi
    bác nào ở HN , đang và sẽ chơi Usher S-520 , đến em cho nghe thử mấy bản hòa tấu dàn trống Drum&Tracj Disc của Sheffield Lab xem có khác gì nghe live không :lol: , đừng có kêu là Usher S-520 tiếng bass hơi thiếu uy lực , cho các bác tung bay..tung bay đàn hải âu luôn
    còn có bác chê dải cao của S-520 hơi chói chứ gì , em test hẳn bằng Anh Thơ-bài XA KHƠI cho mà xem , không hề chói hay gắt gỏng một chút nào ,nhiều loa khác bài này không tải nổi đâu
    để các bác biết là tại sao các tạp chí nghe nhìn oánh giá là USHER S-520 – “Không sờ sao biết”
  21. trungz001
    trungz001 Advanced Member
    Q3 HCMC
    em cũng đang muốn kiếm 1 đôi S520 , giá 3tr yêu cầu loa nguyên bản , hình thức tương đối còn lại các thứ khác ko cần thiết ( tất nhiên là cầu nối loa phải có ) cụ nào chán để lại em :D
  22. Capstan
    bác pót muộn quá. có amp đánh ra tiếng rồi ko ai bán nữa đâu. receiver CA kêu hay suy ra amp kêu hay. amp CA thì có bán ở ta đấy :D
  23. trungz001
    Q3 HCMC
    em cũng từng đc nghe 1 lần em này nối chung là trường âm rộng nhưng ko thể kì vọng quá vào em nó vì dải bass của nó chỉ ở lanh quanh đâu đó khoảng 50-52 Hz thì ko thể nói là bass sâu và lực các bác cứ tham khảo thống số của em nó sẽ rõ thôi ạ nhưng phải nói là hay trong tầm giá , ko biết em nói thế có sai ko nhỉ
  24. arn0ld
    nối theo cách của bác là nối thẳng từ loa vào receiver kô cần ampli hả bác , em nghe nhạc = vi tính thì vẫn nối theo kiểu đấy đc chứ ? cục receiver và cái chân của bác bao xiền và mua ở đâu thế chỉ em với
  25. Aries
    Aries Advanced Member
    VNAV
    Bác ghép tài quá, anh em bê Marantz với cả DENON chạy thui, kẻo chết :mrgreen:
