Mac mini làm transport/music server và các vấn đề liên quan
Discussion in 'Nguồn phát từ máy tính' started by Jacky5555, 24/6/11.
  1. asasas
    asasas Advanced Member
    Re: Mac mini làm transport/music server và các vấn đề liên q
    tks bác tui dùng dac weiss maxbock qua phần mền 3.0 amaza bản quyền.nhưng ko tìm dc dây firewire tốt :(
  2. Jacky5555
    Jacky5555 Advanced Member
    Dây firewire đúng là hiếm hơn usb vì giao thức này ko phổ biến.
    Bác thử tìm hiểu nhà phân phối audioquest xem sao.
    Còn ko phải lên mấy site Mỹ nhờ shop mua thôi.
    Em thấy dây Oyaide Neo D được đánh giá tốt, giá cũng phải chăng, amazon cũng có.
  3. Haolq
    Haolq Advanced Member
    Dùng thuderbolt cho nhanh các bác.
      83,9 KB
  4. dokien
    dokien Advanced Member
    Biết bác 5555 khoái anh Barrows e xin trích các câu của a ý trong CA về NAS:
    Originally Posted by barrows View Post
    The standard in the future will probably be Ethernet Renderers, like the Auralic Aries, Sonore Rendu and Signature Rendu. Using a purpose built, Ethernet Renderer designed and built to exacting high end/audiophile standards has some performance advantages over other approaches, most notably that Ethernet is already isolated by design, and the Renderer itself can be lower in noise than just about any other computer audio transport. A well designed Renderer will be purpose built for high end audio, with an ultra low noise linear power supply, internal isolation between stages, high performance ultra low phase noise clocks, and PCBs designed strictly for audio playback and nothing else, with no noisy DC/DC switching converters, and will be designed/built to high standards (rather than the cheapest parts possible which is what consumer computer boards have).
    By using an Ethernet Renderer, one can then store all their music files on a dedicated NAS/Server, well removed from the audio system, and control everything from a simple app running on a tablet or phone. Of course ultimately I like to see all this in one box (Renderer/DAC, like Linn Climax DS) but for those who want to use their current DAC the separate Renderers are going to be around for awhile.
    Có bác kia xem xong nói ntn:
    I am already so impressed with my tweaked mac mini...With my ordered LPS, planned passive cooling, hopefully Uptown Regen I am assuming this will be something. If you still say the other ethernet renderer will be still that much better....then I need to try them...
    Và Barrows trả lời:
    The point with a really well designed no compromise Ethernet Renderer is that there will be no advantage to adding tweaks, or anything else. You eliminate all the problems associated with normal consumer computer hardware, and just have a totally high quality, purpose built transport at your audio system: plug and play, perfect performance, no need for add ons or tweaks of any kind (OK, good cabling and perhaps vibration control will bring the last .1% performance gain...).
    Trích dẫn từ :http://www.computeraudiophile.com/f10-music-servers/digital-music-transport-suggestions-22802/
    Bác nào giỏi ngoại ngữ nếu có tg vào dịch hộ nhé (e chúa ghét cái máy dịch), dài quá e chịu :(
  5. Jacky5555
    hic, em ko biết chú Barrows là chú nào.
    Đoạn trên là chú ấy ca ngợi các thiết bị Ethernet Renderers được chế tạo riêng cho audio (như Auralic Aries) như cách li tốt, ít nhiễu,... dùng kết hợp với NAS là thôi chấm hết.
    Sau đó thì 1 người hỏi là đã rất hài lòng với 1 cái mac mini được tweak, mod thì có cần cái Ethernet Renderers kia nữa không?
    Thì Barrows trả lời là Ethernet Renderers không cần tweak, cắm là chạy, bản thân nó đã ưu việt.
    chốt lại là nên dùng Ethernet Renderers (theo Barrows)
    tuy nhiên cá nhân em đọc các ý kiến về Auralic Aries vẫn thấy khen chê lẫn lộn, cho nên môn này tốt nhất là thực nghiệm trên chính hệ thống mình và tự rút ra KL.
  6. espadon_vn
    espadon_vn Advanced Member
    Em thì thấy chú kia nói nhưng cũng chẳng phải là đúc rút ra từ trải nghiệm thực tế. Cũng chỉ là những kết luận theo kiểu dựa vào kỹ thuật.
    Qua đây nó rất gần với "truyện bịa" của em như thế này: Mấy bác vệ sinh dịch tễ khuyên người dân ăn chín, uống sôi và giữ gìn vệ sinh để tránh bị đau bụng đi ngoài, tránh bị dịch tả. Ông bán thuốc thì bảo, thích ăn gì thì cứ ăn, sạch hay bẩn không quan trọng vì chỉ cần có viên Béc Be Gin thủ sẵn trong túi là bạn không phải lo về vấn đề đau bụng, đi ngoài gì ráo :lol:
  7. Jacky5555
    Đúng rồi bác, CA là forum rộng và tầm ảnh hưởng khôg chỉ ở Mẽo nên nhiều khi các ý kiến cũng không khách quan lắm, nếu không muốn nói là cũng có mùi thương mại, đặc biệt là review của admin, cho nên đọc cũng cần có sự chắt lọc, và nếu đọc được rộng thì nhìn đa chiều hơn. Cái hay của mấy forum ngoại hơn chúng ta là member có những người là những nhà sản xuất, nhà thiết kế của chính các sản phẩm vào đó tranh luận cũng như nhận "gạch đá" khá vui.
  8. dokien
    E tưởng các bác like nhau vì có cùng chữ ký :lol:
    Để giải thích cho cái bảng so sánh của CA members thì e dẫn lời của cụ Barrows cho sinh động thôi chứ hôm nọ e cũng stream các kiểu nhưng trên bộ của e nghe thường như cái giường :lol:
  9. haingc
    haingc Advanced Member
    HCMC
    Các bác cho em hỏi con dac AZUR 851N thì thế nào? Em đang tìm hiểu nên muốn nhờ cao kiến các bác. Cám ơn
  10. asasas
    tks PH mình cũng đang dùng dây mạ vàng 2 đầu giắc và trên giắc có chữ +p còn thân dây ko có chữ ko biết hãng nào.thui dùng tạm vậy.email hỏi ô Daniel Weiss nói ko cần thiết dùng dây firewire đắt hihi
  11. Jacky5555
    Lâu rồi, em lại nghiêm túc nghe lại mac.
    Lần này là so sánh macbook pro 2014 (MBP) với mac mini 2011.
    So về cấu hình MBP 2014 hơn đứt mac mini 2011, với chip i5 haswell, ổ SSD512 và cùng 8GB ram.
    Cả 2 cùng chay Amarra 3.0, setup cùng thông số RAM. MBP chạy nhạc trực tiếp trên SSD của nó vs mac mini dùng SSD để chạy OSX còn nhạc chứa trên ổ firewire HDD.
    Mấy hôm trước, lúc bật MBP nguyên bản, thật sự em ngạc nhiên và thất vọng: tiếng bị mỏng, sân khấu 2D, tổng thể “digital”. Sau đó, em phải tweak mấy cái cơ bản cho nó công bằng, đầu tiên là chạy cái Script này:
    http://downloads.sonicstudio.com/misc/M ... _Setup.zip
    Rồi tắt hết các loại thu phát (wifi, BT), tắt hết Spell check, Time Machine…, lúc chơi tắt luôn màn hình (MBP có tùy biến này khá hay). Vào force to quit để tắt hết các ứng dụng đang chạy.
    Kết quả: tiếng MBP tốt lên rất nhiều, mềm mại hơn, nhạc tính hơn. So sánh lại với mac mini, thì MBP có ưu điểm: nền âm sạch hơn, do đó độ chi tiết nhỉnh hơn, có những âm mờ trên mac mini thì trên MBP có độ hiện diện tốt hơn. Nhưng về tổng thế, sân khấu vẫn cảm thấy thiếu độ nổi khối và chiều sâu so với mac mini, ngoài ra âm “ss”đầu lưỡi (khoai tây gọi là “sibilance”) nghe bị bén rõ hơn –em thì rất dị ứng âm này.
    Trên hệ thống của em vốn trung tính, sạch sẽ, và đã không thiếu sự chi tiết thì em vẫn dễ chấp nhận chất âm dày dặn và truyền cảm của mac mini hơn là MBP, dù nó còn hạn chế ở dải trầm không thực sự gọn và chi tiết.
    Một số suy nghĩ:
    - Nếu phải chọn 1 trong 2 máy làm nguồn phát, thì em nghiêng về mac mini. Nhìn vào cấu hình, chúng ta dễ nhận định MBP tốt hơn: nguồn chạy pin, cấu hình mạnh hơn,nhưng bản thân MBP vẫn có cấu tạo phức tạp hơn, OSX phải điều khiển nhiều driver hơn, do đó mac mini vẫn là cấu hình giản đơn hơn khi vận hành, có thể đây là lý giải cho chất âm "nhạc tính" hơn của mac mini.
    - Vai trò của tweak/tối ưu hóa rất quan trọng, đó chỉ là những thao tác đơn giản, FREE, nhưng hữu dụng. Đặc biệt các bác tắt thử song wifi/BT thấy hiệu quả ngay. Hãy tắt hết email, chat,.. và các tác vụ bên trong để OSX toàn tâm toàn ý cho nhạc. Đừng nghĩ rằng cấu hình mạnh, nhạc load vào RAM thì chấp tất cả, rất nên tweak.
    - Cho những ai định nâng cấp mac mini: bộ đôi regen USB và nâng cấp nguồn cho mac mini của Uptone audio có vẻ là lựa chọn tốt nhất hiện nay. Tuy nhiên, em có thử gửi request trên website của hãng mà bặt vô âm tín luôn không thấy trả lời. -(
    http://uptoneaudio.com/collections/all
  12. trung224
    trung224 Advanced Member
    Em nghĩ với hệ thống đã tinh chỉnh như của bác Jacky5555 thì nên mua thêm Uptone Regen. Hệ thống của em dùng windows server 2012, Jplay,Fidelizer mà con Regen vẫn cho hiệu quả rất tốt. Đây là review con Regen của em
    http://www.hdvietnam.com/diendan/61-thi ... i-tro.html
    Con Regen đang là hàng hot nên bác muốn mua sẽ phải chờ ít nhất 1 tháng mới có hàng. Vì con Regen này có transferable warranty trong 4 năm nên bác có thể tìm mua cũ trên head-fi, audiologon hay computeraudiophile ví dụ như link sau
    http://www.computeraudiophile.com/f20-b ... ore-26634/
    sẽ có giá rẻ hơn và có ngay để trải nghiệm.
  13. Jacky5555
    Cảm ơn bác, rất có thể em mua cái này về test xem sao.
    Em đã contact được chú Alex Crespi của Uptone, chú ấy mặc dù đang đi nghĩ lễ tạ ơn nhưng trả lời 1 cái email dài vật làm em choáng quá.
  14. Jacky5555
    công nhận rẻ thật các bác ah
  15. g250
    g250 Advanced Member
    Như thường niên, mỗi ngày từ giờ cho đến Noel. Lynn lại tặng 24 Free Track nhạc Sudio Master. Các bác có nhu cầu thì download nhé.
    http://www.linnrecords.com/recording-cr ... =146135415
  16. espadon_vn
    Năm nay album giới hạn có 3 bài thôi, không nhiều như năm trước cụ ạ :)
  17. g250
    e loáng thoáng tưởng tính từ 1-12 đến này đc 3 bài :D. Năm nay ki bo chỉ off 25% trong 12 ngày thôi
  18. audioinme
    audioinme Advanced Member
    HÀ NỘI
    load về như nào nhỉ , các bác chỉ giúp e cái :D
  19. espadon_vn
    Em loáng thoáng thấy nói là mem của nước nào đó quanh mình còn không được tải về cơ. VN mình được 3 bài cũng khá là ưu ái rồi !
  20. espadon_vn
    Cụ phải đăng ký một tài khoản với họ :mrgreen:
  21. Jacky5555
    ui hội Linn này năm nay ky bo quá nhỉ. :D
    Em mới đặt mấy đồ của Uptone: nguồn ngoài JS2, đổi nguồn gắn trong mac mini, regen USB, cable...
    Tính ra cũng chả rẻ nhưng lâu ko có gì nghịch, thử xem thế nào.
    10/12 này Uptone ship hàng.
    Nếu ngon thì tiếp tục chơi mac mini là chính, song song với bryston.
    Mac mini vẫn có cái hay là thỉnh thoảng nghịch ngơm được, ngoài ra itunes + Remote vẫn là top notch về quản lý và dễ sd.
  22. audioinme
    HÀ NỘI
    xời , chờ bác load về xong mình qua copy có phải tiện hơn ko nhỉ :D
  23. nghia19712002
    nghia19712002 Advanced Member
    Bác dùng phân tần chủ động ạ. Bác cho tí tí kinh nghiệm. E cũng đang định chơi passive.
  24. audioinme
    HÀ NỘI
    bài viết này rất rõ ràng và dễ hiểu :D
  25. trung224
    Bác pchip có vẻ đã hiểu sai một số ý quan trọng trong bài viết trên amr-audio.co.uk
    - Thứ nhất, trong phần conclusion của bài viết, tác giả đã nhấn mạnh rằng: "The computer is a great music server but also the source of jitter and other RF interferences that are detrimental the sound quality, even when bit-perfect reproduction is ensured", dịch ra là máy tính là 1 music server tốt nhưng nó vẫn là nguồn của jitter và các sóng RF làm suy giảm chất lượng âm thanh, kể cả khi bit-perfect đạt được.
    - Thứ hai, tác giả viết: "The player software needs to optimize and streamline the audio path to minimize these adverse effects essentially linked to the processing load synchronous to the audio streaming. Achieving “source direct” in addition to “bit perfect”is key". Ý của tác giả là một software audio tốt phải đảm bảo việc tối ưu hoá truyền tín hiệu để giảm thiểu những tác động không tốt từ máy tính như việc các tác vụ khác của máy tính được xử lý đồng bộ với việc truyền và xử lý tín hiệu audio.
    Một chút nói thêm, vấn đề tối ưu hoá máy tính và truyền tín hiệu như XXhighend, Jplay, Fidelizer, Optimizer Audiophile trên windows hay Audionirvana trên MAC đã làm tốt chính là lý do nó cho chất lượng tốt hơn foobar, Jriver hay itunes. Vì trong digital audio, bit-perfect ko bao giờ là đủ, nó còn phụ thuộc rất nhiều vào việc truyền cái lượng thông tin đó một cách liên tục nhất, "direct" nhất và ít bị ảnh hưởng nhiễu nhất.
    - Thứ ba, truyền tín hiệu usb ko đồng bộ ( asynchronus usb streaming) ko loại bỏ được jitter, mà chỉ làm giảm nó đi. Chính tác giả bài viết này cũng thừa nhận khi viết: "More recent and advanced USB devices use asynchronous transfer mode where the DAC controls the flow of audio data, buffers it, and uses its own stable-low-jitter clock. Thus it is immune to short interruptions of USB stream (e.g. bus reset, other device burst transfer, …), and much less prone to computer jittery clock." much less prone chỉ là ít bị ảnh hưởng chứ ko có nghĩa là loại bỏ hoàn toàn
    Về firewire đúng là nó truyền tín hiệu audio tốt hơn usb nhưng hiện nay nó đã chết, trừ khi bác còn dùng Mytek 192DSD, thậm chí chính Mytek trong DAC Broklyn sắp ra (bản nâng cấp của Mytek 192DSD) cũng đã từ bỏ firewire rồi. Các DAC cũ cũng chỉ có rất ít hỗ trỡ firewire.
