MERIDIAN fan' Club
Discussion in 'VNAV's Fan Club' started by ThuyLT, 6/10/08.
  1. lehoangdong
    lehoangdong Advanced Member
    Các Bác dung Meridian 508.24 có để ý vụ nút Dispay không ạ
  2. lehoangdong
    The hidden setup menu of the Meridian 508.24 CD player
    This apparently simple player secretly has some fine tuning abilities hidden in its configuration menu. In this menu you can adjust things like errorcorrection and servocontrol of the laser pickup. Read on!
    Before you begin please be warned that it's easy to mess up in these menus when you're not paying attention. Please be careful and follow the steps below. Just to be sure, take note of the factory-setting before you change it. As long as only the display button is used, you're only browsing. As soon as "previous" and "next" are used, you're changing items.
    Most interesting settings
    There are several adjustments to be made, but two of them are of the most interest to us: Errorcorrection and Servo Adjustment.
    Errorcorrection
    This function can be toggled on or off. In the on position the sound is very precise, measured and lightning quick. In the off position the sound is the opposite: fluid and relaxed. More "analog" in a sense. This is a matter of taste of course. Just try and see which you like best. There is no technical reason to use the on position because apparantly there still is some error correction going on somewhere because all cd's I played since are read quickly and flawlessly. Mayve this comes into play when using extremenly damaged cd's?
    Servo adjustment of the pickup lens
    This function adjusts the servo tracking in 5 steps. According to an article I read Meridian incorporated this function to be able to compensate for the variation in the supplied Philips transports. Officially position A is the best and most precise and dynamicsetting but it can also become a bit dry. It is this setting that lends the player it's most technicall correct sound. Switching from A to E the sound becomes increasingly more relaxed, distant and fluid. Especially the high frequency becomes a lot more silky but the bass loses some tightness.
    How to get into the configuration menu
    1.shut down the player using the switch at the rear.
    2.push the button "display" and keep it depressed.
    3.switch the player back on using the switch at the rear.
    4.let go of the display button when "config" is shown.
    You are now in the config meny. This is shown briefly in the display. After
    that the fisrt menu item is shown: 500. This is the remote protocol. Never
    mind that.
    5.choose the wanted item (error correction) using the display button.
    6.switch it on or off using "prev track" en "next track".
    7.choose the next wanted item (servo) using the display button.
    8.switch between the options A-E using "prev track" en "next track".
    9.shut down the player again using the switch at the rear.
    The settings are automatically saved when te player is powerd down.
    Em thử rồi thật hay các Bác ạ -> rất có giá trị :D
  3. vanbinhbl
    vanbinhbl Approved Member
    cc
    Bác làm ơn dịch ra dùm em .em cũng có Meridian 508.24 đây .Nhưng em dốt tiếng Anh thắng cha google dịch em chả hiểu gì cả .cảm ơn
  4. lehoangdong
    Em cũng dốt vậy
    Ý nó như vậy nhé:
    -A
    Về phần Servo thì khi ta can thiệp vào thì âm thanh sẽ khác đi
    Có 5 cách chọn A B C D E, Khi chọn A thì âm thanh sẽ chặc chẽ nhất, tốt nhất ( dynamic - setting) nhưng cứng hơn ngược lại khi chọn E thì âm thanh sẽ mượt hơn, thoải mái hơn, xa hơn míd mượt như nhung, dãi cao nhiều đẹp, mượt nhưng không chặc chẽ bằng ( bas mất độ kín), nó sẽ thay đổi từ A tới E
    -B
    Error_connection: để ON thì nó sẽ sửa lỗi -> âm thanh sẽ hay hơn
    Và cách làm thế nào
    1- ấn nút tắt máy đằng sau CD
    2- ấn và giử nút display mặt trước CD đồng thời bật công tắt mở đằng sau máy
    3- vào setup ( lúc này ta không dùng CD được)
    4- ấn nút display 1 lần từng lần xuất hiện chử Error_connection và dùng nút < > để chọn ON or Off
    Ấn nứt display 1 lần nữa cho xuất hiện Servo và dùng < > chọn A... E
    5- xong tắt nguồn đi máy sẽ giữ lại chế độ đã chọn cho đến khi người dùng chọn lai thôi.
    Cái này Meridian nói là do Meridian hợp tác với Cystan và lập trình ra món trên, chỉ có trên 508.24 508.20 và một số ít trong serial 500
  5. lehoangdong
    Khi em nghe Vocal thì chọn E nghe rất ấm áp, mượt mà như nhung
  6. lehoangdong
    Bác có 508.24 thì quá hay rồi, Em nghe 508.20 đã phê rồi huốn chi
    Hôm nào Bác cho em mượn 508.24 nghe nhe :lol: ( thật đó không đùa đâu )
  7. lehoangdong
    Thằng 508.24 hơn 508.20 nhiều lắm
    Về phần cứng:
    1- Mắt 5.24 dùng 12.5 jitter thấp hơn 5.20(12.4)
    2- Phần Servo
    3- chíp 24 bít 20 bít
    Âm thanh: về tổng thể thì chắc chắn 24 hay hơn 20 rồi nhưng em xem review tây thì theo gu có người nói 20 trầm ấm hơn ...
  8. vanbinhbl
    cc
    Rất cảm ơn Bác Để rãnh em sẽ làm thử coi sao ! Em cũng không biết 508.24 có hơn 508.20 nhiều không ,chắc không nhiều lắm đâu ,508.24 nghe vocal thật tuyệt ,nhưng nghe cổ điển hơi bị rối .Bộ giàn em đang sử dụng là dưới chữ kí đó Bác .
  9. audioinme
    audioinme Advanced Member
    HÀ NỘI
    508.24 gần như top của dòng 500 đó bác ,trang stereophile.com uy tín khen ngợi cd này lắm đó nếu bác mua được máy đẹp cũng rất đáng để sưu tầm , thế mạnh của meridian ko phải là classic nhưng ko đến mức bị rối đâu :D , Em cũng rất thích chất tiếng meridian và cd 508.24 nói riêng , nhưng khi muốn mua thì ko gặp ,hoặc gặp thì giá cao ,nay đã dùng đồ khác , nói chung nếu bác đang sở hữu 508.24 mà máy như new chữ chưa bị bay thì cũng đã rất quý rồi, ko phải cứ muốn mua là có đâu :D
  10. lehoangdong
    Tìm 588 xem thử như thế nào vậy
  11. nghiaaudiohl
    nghiaaudiohl Advanced Member
    TP Ha long Quang ninh
    Các bác cho e hỏi là G08 thì có vụ setup phức tạp như 508.24 ko ah?
  12. lehoangdong
    G08 em chưa chơi nên không biết
    Vụ " The hidden setup menu of the Meridian 508.24 CD player " đây là menu ẩn trong 508.24 là 1 tính năng hay, nếu ta biết khai thác khéo léo thì rất hay để phù hợp từng loại nhạc và gu nghe thôi.
    Nếu không thích thì cứ để mặt đinh là E mà chơi thôi.
  13. audioinme
    HÀ NỘI
    :D
    Bác tìm được là hay đấy , bên chính quốc còn ít ,Ngoài hà nội em mới nghe nói có 1 bác đang dùng 588 nhưng chưa thấy có ý ... :D
  14. phunghung_79
    phunghung_79 Advanced Member
    Cơ 500 của em có một số đĩa copy không đọc được. Các bác chỉ giùm em lý do vì sao. Thank
  15. audioinme
    HÀ NỘI
    Bác mang qua bác tuấn văn hương kiểm tra nhé :D , của bác là 500 trơn hay mk2 ( mắt philips quăng hay thẳng )
  16. lehoangdong
    Em nghĩ Bác nên để vậy, Em dùng nhiều CD Meridian nên thấy thỉnh thoảng như vậy, còn Đĩa zin thì cái nào cũng đọc.
    Theo em đoán Transport 500 bác dùng Mk1, mắt quăn
  17. audioinme
    HÀ NỘI
    Nói chung là nếu cd ko hỗ trợ định dạng chạy cd-r ...thì đừng nên dùng đĩa copy cho ổn định , những đầu cd đời mới dùng dvr cho phép nhận cd-r ... Thì ổn :D
  18. phunghung_79
    Vâng em cám ơn các bác đã tư vấn. Có lẽ thôi cứ để nó như vậy chứ chọc ngoáy vào em cũng hơi ngại. Em cứ tưởng mắt nó kém mới sợ.
  19. audioinme
    HÀ NỘI
    Nếu ko nhận đĩa cd-r mà vẫn đọc cd xịn , tq in công nghiệp phà phà ...ko bị vấp ...thì khả năng mắt đọc cái meridian 500 của bác nguyên bản rất cao , nếu vậy bác nên để nguyên đừng chỉnh làm gì , nếu trước vẫn đọc cd-r mà nay ko đọc thì mới cần mang qua thợ bác ạ
  20. lehoangdong
    Em nghĩ Bác nên để vậy! Đi thợ làm gì.
  21. vanbinhbl
    cc
    Các bác cho em hỏi 508.24 đọc đĩa copy
    rất tốt ,tuy nhiên có một số đĩa khi bỏ vào thì man hình
    display hiện len chữ T.O.C . máy vẫn đọc nhưng không có tiếng.
    Nếu em nhấn nút pause xong nhấn nút play lần nữa thì
    có tiếng và hát bình thường. Có bác nào biết vụ này
    chỉ dùm em .Cám ơn.
  22. audioinme
    HÀ NỘI
    Chắc là phần mềm hay tuỳ chỉnh nào đó , bác load hướng dẫn về tìm xem các chức năng của máy . Nói chung là bác ko nên dùng cd-r nhiều vì sẽ có thể ko tốt cho mắt đọc , máy bền là do người sử dụng , nên dùng đĩa tốt thì các chức năng của máy sẽ tốt hơn bác ạ
  23. yeuamnhac1234
    yeuamnhac1234 Advanced Member
    Tphcm
    Ming các bác giúp em về em này.
  24. giotthanhcong
    giotthanhcong Advanced Member
    TP.HCM
    Các bác cho em hỏi về Meridian 602 CD Transport với ...
    602 hơn Meridian 500 CD Transport nhiều không ?
    Em đã có DAC rồi, đang dùng Teac 10SE làm cơ, em đang hy vọng sắm 1 cái Transport thì sẽ hay hơn, 2 cái trên nằm trong khả năng của em .....
    Em cám ơn ạ!
  25. audioinme
    HÀ NỘI
    Cả hai cái đó làm cơ chưa chắc đã hơn được 10se đâu bác ạ :D
