Tình hình là em vừa kiếm được đôi loa Nhậ cỏ loại thùng kín Victor SX3 II Công suất: 60W/loa Trở kháng: 6om Với tham số gì em không rõ, ghi là: 88dB Các bác chỉ giúp em là đôi này dùng với âm ly nào thì ổn ạ, em thích nghe Pop, hòa tấu...trừ Rock, Rap. Cám ơn các bác nhiều
VICTOR SX-3II \ 36,800 (1 units, around 1974) SX-3 type in the base furthermore the speaker system which raises degree of completion. The 25cm cone type woofer is loaded to the limits low. The KDU cone paper which is adopted for also SX-3 is adopted to the diaphragm. To 5cm software dome type the eater is loaded to high pass. This unit to software dome type of SX-3 type the eater being something which furthermore assures improvement to the base, 200Hz lowering the breath which we would like to take charge has made to 2kHz from 1.8kHz. Because of this, the cavity which is closed airtight to the unit rear section is added, fo and Qo of unit are held down low. Furthermore, the copper cap which makes the electric current strain decrease is adopted to the magnetic circuit. The network section increases high cutting of the woofer, to both low cutting of the eater being designed with 12dB/oct. Furthermore, we build in the loss of time before the cutoff of the woofer which it is easy to occur with the inductance component and near cutoff the compensating circuit vis-a-vis resonance, actualize smoother high cutting. In addition, the coil of the silicon steel sheet core which is strong to also large input is adopted to the coil. The north american product coniferous Douglas fur plywood, specification of SX-3 transferring such as resounding/affecting stick and ester wool acoustic material being adopted by the front and back surface baffle inside, it increases the enclosure. Rating of type System 2 ways 2 speakers airtightness system bookshelf type Unit It is low the for limits: 25cm cone type For high pass: 5cm dome type Impedance 6Ω Largest input 60W Output overpressure value 88dB/W/m Frequency characteristic 35Hz~20kHz Lowest resonance frequency 60Hz Crossover frequency 1.8kHz Level control Fixed resistance continual yes deformation External size Width 315× height 520× depth 290mm Weight 13.5kg
Loa của bác có độ nhạy thấp ( 88 dB/W/m ), trở kháng 6 ohm, công suất nhỏ, thùng loa kín thì có khả năng tiếng bass sẽ hơi nhẹ. Theo em nên kiếm amly Nhật nào có công suất hơi lớn một chút ( có thể là Sansui dòng 607.... gì đó) thì ghép được. Thân.
Đèn thì em chưa đủ trình độ để chơi như các cao thủ được, phải từ từ thôi ạ. Tóm lại là em phải mua con Amp nhật công suất lớn có pjair không ạ, các bác có thể cho em biết cụ thể là loại nào thì tốt quá @Lion_Heart: (có thể là Sansui dòng 607.... gì đó) bác cụ thể hơn giúp em và giá nó tầm boa nhiêu ạ Cám ơn các bác nhiều
Bác ơi nếu chưa từng trải lắm về các đời âmly thì bác cứ chơi các đời cổ thôi cho đỡ tốn học phí: Sansui AU 7900, AU 607...(nhiều đời này lắm), Pioneer 7800 II, 8800 II, 8900 II.....và còn nhiều nữa. Về giá cả thì tùy từng địa phương mà giá có thể khác nhau. Theo em bác nên tham khảo kinh nghiêm chơi của anh em ngay trên 4r này, còn giá cả thì theo nơi mà bác sẽ mua thôi. Chúc bác vừa ý.
