Mua tivi ở châu Âu về dùng tại VN
Discussion in 'Màn hình/Máy chiếu' started by genevebxl0811, 1/2/12.
  1. genevebxl0811
    genevebxl0811 Advanced Member
    Mấy con tivi em đang ngắm đều support PAL, DVB-T, DVB-C, DVB-S (các chuẩn giải mã tín hiệu truyền hình kỹ thuật số phố biến hiện nay). NTSC chắc chỉ phổ biến ở Bắc Mỹ nên mấy em này ko support.
    Em đọc được trên wiki đoạn này:
    "The situation with worldwide digital television is much simpler by comparison. Most current digital television systems are based on the MPEG transport stream standard, and use the H.262/MPEG-2 Part 2 video codec. They differ significantly in the details of how the transport stream is converted into a broadcast signal, in the video format prior to encoding (or alternatively, after decoding), and in the audio format. This has not prevented the creation of an international standard that includes both major systems, even though they are incompatible in almost every respect.
    The two principal digital broadcasting systems are ATSC standards, developed by the Advanced Television Systems Committee and adopted as a standard in the United States and Canada, and DVB-T, the Digital Video Broadcast – Terrestrial system used in most of the rest of the world. DVB-T was designed for format compatibility with existing direct broadcast satellite services in Europe (which use the DVB-S standard, and also sees some use in direct-to-home satellite dish providers in North America), and there is also a DVB-C version for cable television. While the ATSC standard also includes support for satellite and cable television systems, operators of those systems have chosen other technologies (principally DVB-S or proprietary systems for satellite and 256QAM replacing VSB for cable). Japan uses a third system, closely related to DVB-T, called ISDB-T, which is compatible with Brazil's SBTVD. The People's Republic of China has developed a fourth system, named DMB-T/H."
    Như vậy theo em hiểu thì sẽ dùng tốt ở VN dù là thu tín hiệu analog (PAL) hay kỹ thuật số (DVB-T).
  2. thangsamnec
    thangsamnec Advanced Member
    Hải Phòng
    Thế bác kiểm tra thêm về phần hệ tiếng nếu có cả hệ BG và Dk là ok đó. Trước đây e có gặp một người cũng cầm TV LCD Sony từ Tây Ban Nha về , hình thì bình thường nhưng tiếng sôi ầm ầm, e tìm chỉnh hệ tiếng cho đúng thì không có chức năng này, vì nó là 1 hệ tiếng thôi.
  3. Jacky5555
    Jacky5555 Advanced Member
    Để yên tâm, bác down cái user manual về, xem trang cuối bao giờ cũng có đầy đủ thông số.
    Đây là manual của con 40D3000 nhà em:
  4. taicun
    taicun Advanced Member
    Tại sao giá thành ở châu Âu lại rẻ quá trời vậy?
    Mình cũng rất mê tv màn hình lớn, nhưng giá ở Vn thì trên trời.
