Naim - Tìm người cùng sở thích
Discussion in 'VNAV's Fan Club' started by LuanHN, 26/5/08.
  1. kothequen
    kothequen Advanced Member
    Theo iem nà các bác cứ nàm iem NDS cộng với hai iem 555PS lữa nà khỏi phải năn tăn ngọn sóng gì hết :D
  2. thangpn
    thangpn Advanced Member
    Theo thông tin specification cua Naim, e thấy Naim Dac vẫn có cổng giao tiếp USB đấy chứ.
    http://www.naimaudio.com/hifi-products/pdt-type/dac
    If exceptional music making is the first hallmark of the Naim DAC, the second is versatility. Versatility comes thanks to S/PDIF inputs that can accommodate either optical or coaxial connections and USB inputs that can accommodate memory sticks and iPod and iPhone models. It arises also from the numerous Naim system upgrades that the DAC makes possible. Simultaneously with its introduction, the CDX2 and CD5 XS CD players have gained S/PDIF outputs and can now benefit significantly from use with the DAC. With the addition of a DAC, existing preamplifiers can be incorporated into digital audio systems. The Naim DAC can be controlled by a Naim preamplifier remote control, seamlessly integrating analogue and digital inputs across the two units. The DAC becomes an extension of the preamplifier. And when a USB stick, iPod or iPhone is docked, the DAC front panel input buttons transform to operate as playback controls.
    Everything comes together
    iPod: connect an iPod (generation 5 models and above) to play its stored music
    iPod Touch/iPhone: connect an iPod Touch or iPhone to play its stored music or music streamed from your network through UPnP over Wi-Fi.
    Games console: connect a games console digital audio output to play audio from a game.
    DVD player: connect a DVD player digital output for stereo playback of DVD-A discs.
    PC: connect a PC external sound card digital output to play stored or network music.
    Mac: connect a Mac digital output to play its stored music or music streamed from your network via UPnP over Wi-Fi.
    Hard Disk player: connect a hard disk player or music server to play stored or network music.
    CD player: connect a CD player digital output to play CDs.
    TV: connect a TV digital output to play TV audio.
    Satellite TV receiver: connect a set-top-box satellite TV receiver digital output to play satellite TV audio.
    Streaming device: connect a music streaming device to play multi-room streamed music.
    USB stick: connect a USB memory stick to play stored standard or high resolution music.
  3. 0208_Audio
    0208_Audio Advanced Member
    nghe theo ông kothequen khác nào nhảy xuống hố vôi đang sôi :mrgreen:
  4. ThanhtrangHTKT
    ThanhtrangHTKT Advanced Member
    Chào các bác! Em đang dùng CDP Linn Karik IV với pre Kairn, pow LK100 và loa Epos!
    Em tính đổi CDP sang Naim CD3 để nghe nhạc Việt! như vậy có hợp lý không ạ?
    Naim CD3 mạnh về thể loại nào? Cảm ơn các bác!
  5. kothequen
    Theo em nếu bác thích giọng đó thì nên cố lên CDi hoặc CD2 thì hợp lý hơn sau này đỡ mất công loay hoay.
  6. qpduong76
    qpduong76 Approved Member
    Há há... Được thế còn j bằng bác ơi... mà có khi đợi hẳn ND555 x 2 555PS DR :mrgreen:
    @thangpn: nDac có usb nhưng ko nối được với computer bác ơi ( chỉ để đọc file wav, flac từ ổ usb và kết nối với apple iphone, ipad).
  7. kothequen
    DR là mạch ròi có thể nâng cấp riêng được mà bác, Discrete Regulator dịch nôm là mạch điều khiển rời rạc thực tế thì nó có tác dụng giảm thiểu hơn nữa độ nhiễu thôi mà, quan điểm của em thì nhiều khi sạch quá cũng không phải là hay.
  8. Thebigshow
    Thebigshow Advanced Member
    Ko biết khi nào Thanh Tùng cung cấp dịch vụ nâng cấp DR nhỉ? em cho cục Hi cap lên đời phát !
  9. littledream
    littledream Advanced Member
  10. g250
    g250 Advanced Member
    Cái bác nói là nDac chứ ko phải dac-v1. Theo e so sánh 2 Dac này với nhau hơi khập khiễng. Tùy vào nguồn phát là gì mà ta chọn Dac. NDac chuyên dành cho các đầu cơ, đặc biệt là đầu chạy ổ cứng Naim Hdx, usb chỉ là cổng giao tiếp với dock ngoài cho iphone, ipod hoăc nghe trực tiếp mp3 qua usb thôi. Còn Dac V1 lại chuyên cho nguồn phát computer bác ạ, các hãng đang chạy đua công nghệ cho nguồn phát computer ( mac, lap) nên Naim cũng ko ngoại lệ.
  11. littledream
    [/quote]
    Cái bác nói là nDac chứ ko phải dac-v1. Theo e so sánh 2 Dac này với nhau hơi khập khiễng. Tùy vào nguồn phát là gì mà ta chọn Dac. NDac chuyên dành cho các đầu cơ, đặc biệt là đầu chạy ổ cứng Naim Hdx, usb chỉ là cổng giao tiếp với dock ngoài cho iphone, ipod hoăc nghe trực tiếp mp3 qua usb thôi. Còn Dac V1 lại chuyên cho nguồn phát computer bác ạ, các hãng đang chạy đua công nghệ cho nguồn phát computer ( mac, lap) nên Naim cũng ko ngoại lệ.[/quote]
    Vâng, cám ơn bác! Bác đã nghe 2 loai này chưa, và cảm nhận về chất lượng âm thanh giữa 2 loại này (khi nghe cùng 1 file nhạc như nhau: 1 nguồn phát PC qua cable và 1 tực tiếp từ USB ?
  12. ThanhtrangHTKT
    Em đã đưa về ghép thử rồi! Thấy tiếng Naim CD3 mid mềm hơn, tổng thể sáng hơn Linn Karik IV, nhưng sân khấu có vẻ hẹp hơn!
    Nếu nghe nhiều về thể loại nhạc Việt, nhạc dân ca, trữ tình thì loại nào phù hợp hả bác?
  13. kothequen
    Bác đã nghe cả hai em rồi thì quyết định thuộc về bác chứ ạ
  14. thuandt
    thuandt Advanced Member
    Nếu nghe nhiều về thể loại nhạc Việt, nhạc dân ca, trữ tình thì loại nào phù hợp hả bác?[/quote][/quote][/quote]
    Theo gu của bác e vote cho Naim cd3
  15. ThanhtrangHTKT
    [/quote][/quote]
    Theo gu của bác e vote cho Naim cd3[/quote]
    Vâng! thế mắt Naim CD3 có lành không ạ?
  16. ThanhtrangHTKT
    Wom! Em vừa bán Linn Karik để rước Naim CD3 về! vì thích nghe nhạc Việt thể lọa trữ tình nên Karik em thấy mid hơi lạnh, chưa có độ ấm! Còn thể loại nhạc cụ thì Karik nó thể hiện rất tốt!
  17. naboo
    naboo Advanced Member
  18. 0208_Audio
    tiếc nhỉ..,., hệ thống của bác khá hay....tuy nhiên cần đầu tư tốt hơn một chút thì đỉnh luôn :)
  19. 2-Fi
    2-Fi Advanced Member
    Em nhờ các bác tư vấn giúp vụ này:
    Hiện nay đang có một em Nait 2 đã Recapped trong tầm ngắm với giá khoảng 25Tr.
    Bộ Naim em đang dùng là NAC 102 + Hicap - NAP 140.
    Em NAIT 2 có xứng đáng để sưu tầm không? Giá như vậy có phù hợp? Điểm mạnh, điểm yếu so với 102 + 140 như thế nào?
    Cám ơn lòng nhiệt thành của các bác.
    (Giá khoảng 20 Tr. không phải 25Tr. như trên)
  20. isophon1
    isophon1 Approved Member
    hai phong
    Em đang muốn kiếm một em ampli Naim còi còi để ghép thử với Totem Staff. Bác nào biết ai có và muốn giao lưu thì làm ơn mách cho em với nhé!
  21. kothequen
    Nếu bác tách bạch hai vế ra thì Nait 2 rất đáng để sưu tầm nhất là đời Olive. Nhược điểm công suất hơi yếu phù hợp loa vừa phải, độ nhậy cao chút. Làm em Hicap nữa là chuẩn
  22. g250
    Báo cáo các bác 200/202 của e từ uk đã về đến nhà và ko phí công e mong đợi :). Giờ chờ bác nào thừa ra hicap và napsc thôi ạ :)))
  23. 2-Fi
  24. kothequen
  25. HaMinhABC
    HaMinhABC Advanced Member
    Các bác cho em hỏi Naim Nait 3R công suất bao nhiêu vậy ạ? tìm các thông số của Naim thấy ít thông tin quá! Em tính dùng Naim Nait 3R để kéo Epos ES14 không biết có ổn không?
