  1. anhduc220375
    anhduc220375 Approved Member
    Ha Noi
    Tên mặt hàng:pC fanless mini QOTOM 3865U
    Tình trạng, mô tả:đã qua sử dụng còn đẹp hoạt động bình thường
    Giá bán:3.000.000đ
    Khu vực:Hà Nội
    Điện thoại:0566179179
    Giao hàng:TQ
    Thông tin thêm:Máy không có ram, wifi ( mua về tự lắp theo nhu cầu của từng mục đích sd ) có ssd 120GB. ai cần thêm hình ảnh ad zalo 0566179179 -0777838689 mình gửi thêm hình ảnh
    Cấu hình máy
    Structural standard Industrial motherboard
    148 x 104mm
    CPU Onboard Intel Celeron processor 3865U 1.8GHz dual core, 2M cache, 15W
    chipset CPU integration
    display Integrated Intel HD Graphics HD610
    1 x HDMI
    The internet 6 x Intel I211-AT NIC chip, PCI-E bus Gigabit NIC
    1 x MiniPCIE, default half-height mode supports extended WIFI module, optional full-height mode supports extended 3G/4G module
    Audio no
    storage 1 x mSATA interface
    1x SATA3.0 interface (6Gb/s)
    LVDS not support
    eDP not support
    Watchdog stand by
    Heat dissipation method Fan, active cooling
    Front interface
    switch 1 x power switch
    Serial port 1 x RS-232 (COM1)
    Display interface 1 x HDMI interface
    USB 2 x USB 3.0, 4 x USB 2.0
    Back interface
    Power interface DC 12V3A, outer diameter 5.5mm, inner diameter 2.5mm
    Power Indicator 1 x power indicator, 1 x hard drive indicator
    Network Interface 6 x Intel I211-AT network interface
    Internal interface
    Memory slot Support 1 DDR4 notebook memory, up to 16GB, 2133MHz/2400MHz
    m-SATA Default full height specification solid state drive interface
    SATA interface SATA 3.0 standard socket, Core series optional support 2 groups
    SATA power supply 2.0mm pitch socket
    Mini-PCIe Default half-height specification, support WIFI module / Bluetooth module (optional full height specification, support 3G/4G module)
    SIM card holder Standard SIM card holder
    Fan socket 1 x CPU fan power outlet
    Call to boot 2.54mm pitch pin header, switch through jumper cap or BIOS setup
    LVDS not support
    eDP not support
    GPIO 2.0mm pitch pin
    Serial expansion pin 1 set, 2.0mm pitch pin (COM1/COM2 optional 485 mode, 9th pin optional 5V or 12V, need to be set at the factory)
    VGA expansion pin 2.0mm pitch pin
    Power input pin Default without, optional
    USB extension pin 2.54mm pitch pin header for 4 USB 2.0 extensions
    Audio extension pin no
    Panel extension pin 2.0mm pitch pin header, (extended power indicator, hard disk indicator, reset button, power switch)
    operating system
    operating system Support for Windows 7, Windows 8, Windows 10, Linux
    working environment
    Operating temperature 0°C~50°C
    Storage temperature -20 ° C ~ 80 ° C
    environment humidity 10%~90% without condensation
