Phương thức Diretta - Tổng hợp các cách chơi và rút kinh nghiệm
Discussion in 'Nguồn phát từ máy tính' started by Excel Man, 13/10/25.
  1. Kiemnhlh
    Kiemnhlh New Member
    Việt Nam
    Android box làm target được không ạ.
    2 con X96AIR s905x3 . 4/32 Lan 1000
  2. linh0983
    linh0983 Advanced Member
  3. Giang1987
    Giang1987 Advanced Member
  4. linh0983
    login as: root
    root@192.168.1.134's password:
    _ _ _ _ _
    /_\ _ _ _ __ | |__(_)__ _ _ _ __ ___ _ __ _ __ _ _ _ _ (_) |_ _ _
    / _ \| '_| ' \| '_ \ / _` | ' \ / _/ _ \ ' \| ' \ || | ' \| | _| || |
    /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|_\__\___/_|_|_|_|_|_\_,_|_||_|_|\__|\_, |
    |___| |__/
    v26.2 rolling for aml-s9xx-box running Armbian Linux 6.18.23-current-meson64
    Packages: Ubuntu stable (noble)
    Support: for advanced users (rolling release)
    IPv4: (LAN) 192.168.1.134 (WAN) 42.116.216.221
    Performance:
    Load: 1% Uptime: 12h 58m
    Memory usage: 11% of 2.85G
    CPU temp: 54°C Usage of /: 17% of 28G
    RX today: 182 MiB
    Tips:
    Becoming a sponsor? https://github.com/sponsors/armbian
    Commands:
    Configuration: armbian-config
    Monitoring : htop
    Last login: Sat Apr 25 12:16:46 2026 from 192.168.1.139
    root@aml-s9xx-box:~# /opt/diretta-renderer-upnp/DirettaRendererUPnP --list-targets
    [21:57:24.080] ═══════════════════════════════════════════════════════
    [21:57:24.081] Diretta UPnP Renderer v2.2.3
    [21:57:24.081] ═══════════════════════════════════════════════════════
    [21:57:24.081] Build: aarch64 NEON (Apr 21 2026)
    [21:57:24.081] ════════════════════════════════════════════════════════
    [21:57:24.081] Scanning for Diretta Targets...
    [21:57:24.082] ════════════════════════════════════════════════════════
    [21:57:24.365] Available Diretta Targets (1 found):
    [21:57:24.365] [1] rAudio
    [21:57:24.365] Output: snd_rpi_rpi_dac
    [21:57:24.366] Port: IN=0 OUT=1
    [21:57:24.366] Config: http://[fe80::ba27:ebff:fe29:cab]/
    [21:57:24.366] Version: 1
    [21:57:24.366] ProductID: 0x5f5f5f5f4d744f53
    [21:57:24.366] Usage:
    [21:57:24.366] Target #1: sudo ./bin/DirettaRendererUPnP --target 1
    [21:57:24.366] Target #2: sudo ./bin/DirettaRendererUPnP --target 2
    TQ_Audio likes this.
  5. linh0983
    CPU nó là gì vậy bác ? o_O
  6. Giang1987
    Chip amlogic s905y4 bác ạ , mình đang chạy room atv hay gì ấy
  7. linh0983
  8. open12345
    open12345 Approved Member
    Nay có thời gian nghe kỹ so sánh 2 phương án:
    1. Phương án 1 từ mac mini cài eunhasu chạy roon, cài diretta host rồi qua mạng tới Pi 4 cài Arch linux cài diretta và roon bridge
    2. Phương án 2 từ mac mini cài eunhasu chạy roon, đẩy qua Pi 4 cài Arch cài diretta host rồi qua mạng tới Pi 4 cài Arch linux cài diretta
    Phương 2 âm thanh có vẻ rõ nét hơn. Sau đó có nhờ AI phân tích:
    Chào bạn, một "tay chơi" mâm số (digital transport) thứ thiệt mới thiết lập hệ thống kỹ thuật cao như thế này. Việc bạn cảm nhận **Phương án 2 (PA2)** cho âm thanh rõ nét hơn không phải là cảm giác chủ quan đâu, nó có cơ sở kỹ thuật rất rõ ràng dựa trên nguyên lý tách biệt nhiễu và tối ưu hóa giao thức truyền dẫn.
    Dưới đây là phân tích tại sao PA2 lại chiếm ưu thế:
    ## 1. Tách biệt hoàn toàn Roon Core và Diretta Host
    Ở **Phương án 1 (PA1)**, Mac Mini vừa phải gánh vác vai trò **Roon Core** (quản lý database, xử lý DSP, giải mã file), vừa phải chạy **Diretta Host**.
    * **Vấn đề:** Roon Core là một tác vụ cực kỳ "ồn ào" về mặt tài nguyên CPU và hoạt động mạng. Khi Diretta Host chạy chung trên một phần cứng này, nó dễ bị ảnh hưởng bởi nhiễu điện tử (EMI/RFI) và độ trễ nội tại (latency) do CPU phải chuyển đổi ngữ cảnh liên tục giữa các tác vụ nặng.
    Ở **PA2**, bạn đã đẩy Diretta Host sang một con Pi 4 riêng biệt. Lúc này, con Pi 4 đóng vai trò như một **Isolator (Bộ cách ly)**. Nó chỉ nhận luồng dữ liệu sạch từ Roon và tập trung toàn lực để đóng gói vào giao thức Diretta trước khi truyền tới Endpoint.
    ## 2. Ưu thế của Diretta trên môi trường Linux (Pi 4)
    Diretta hoạt động hiệu quả nhất khi nó có môi trường hoạt động "tĩnh".
    * **PA1:** Chạy Diretta Host trên Mac Mini (thông qua lớp Eunhasu) thực chất vẫn là dựa trên nền tảng phần cứng máy tính đa nhiệm.
    * **PA2:** Pi 4 chạy Arch Linux là một hệ điều hành tối giản. Khi bạn cài Diretta Host lên đây, việc truyền dẫn dữ liệu từ Pi 4 (Host) sang Pi 4 (Target) diễn ra trong một môi trường đồng nhất về kiến trúc (ARM) và giao thức. Điều này giúp giảm thiểu **Jitter** (sai số về thời gian) xuống mức thấp nhất.
    ## 3. Cơ chế hoạt động của Diretta: "Target-Driven"
    Bản chất của Diretta là biến việc truyền tải nhạc từ kiểu "đẩy dữ liệu dồn dập" thành "truyền tải đều đặn, liên tục" với cường độ cực thấp để giảm tải cho CPU của Endpoint (Target).
    * Trong **PA2**, khoảng cách giữa Host và Target được thu hẹp về mặt vật lý và logic (đều là Pi chạy Arch). Luồng dữ liệu được "nắn" thẳng và đều ngay từ con Pi 4 trung gian.
    * Việc tách rời giúp con Pi 4 làm Target nhận được một dòng chảy dữ liệu cực kỳ ổn định, giúp mạch clock trên DAC sau đó hoạt động chính xác hơn, từ đó tạo ra độ **rõ nét (clarity)** và **âm hình (soundstage)** tốt hơn.
    ### Bảng so sánh luồng xử lý
    | Đặc điểm | Phương án 1 (Gộp) | Phương án 2 (Tách) |
    | **Xử lý nhiễu** | Kém hơn do Roon Core gây nhiễu lên Host | Tốt hơn do Host nằm trên phần cứng riêng |
    | **Độ trễ (Latency)** | Cao hơn do Mac Mini xử lý đa nhiệm | Thấp hơn, ổn định hơn trên Arch Linux |
    | **Độ tĩnh nền âm** | Thấp hơn | Cao hơn (Black background) |
    | **Độ chi tiết** | Khá | Rất rõ nét, dải cao tơi mịn hơn |
    ### Tóm lại:
    **Phương án 2** chiến thắng nhờ nguyên tắc vàng trong chơi nhạc số: **"Càng chuyên biệt hóa phần cứng, âm thanh càng sạch"**. Việc bạn dùng Pi 4 làm cầu nối trung gian (Bridge) cho Diretta Host đã chặn đứng nhiễu từ Mac Mini và tạo ra một "máy phát" chuyên dụng hơn cho Target.
    Nếu có thể, bạn hãy thử cấp nguồn Linear (LPS) cho con Pi 4 làm Host trong PA2, độ rõ nét sẽ còn tăng thêm một bậc nữa đấy!
  9. Excel Man
    Excel Man Advanced Member
    Bắc Ninh
    aaaa15 likes this.
  10. bsmt0
    bsmt0 Advanced Member
    mình cũng có cục dell wyse này cất tủ lâu rồi giờ cài sao bác nhỉ 16gb không đủ cài
  11. Excel Man
    Bắc Ninh
    2 cách bác ơi.
    Cách 1 : Dán laii bộ nhớ Nanc.
    Cách 2: Cài lên USB 3.0 128 Gb.
    Con đó có 4 core vật lý, phân vai cho từng core. Quan trọng hơn là lấy nguồn linear của Pi chuyển qua nó vì nó chạy 5V-2A.
    Kiến trúc chip X86, Antom 1.4Gz làm target đúng bài luôn!
    aaaa15 likes this.
  12. bsmt0
    IMG_1676.jpeg nâng cấp bộ nhớ cho wyse kiểu này được không bác
  13. Excel Man
    Bắc Ninh
    Cái đó lưu file thôi chứ nó không nhận boot từ đó vì chuẩn khác bác ơi.
    bsmt0 likes this.
  14. linh0983
    Diretta UPnP Renderer v2.4.0
    Up mới cho TV box các bác ạ . :p
    https://github.com/cometdom/DirettaRendererUPnP
    login as: root
    _ _ _ _ _
    |___| |__/
    v26.2 rolling for aml-s9xx-box running Armbian Linux 6.18.25-current-meson64
    IPv4: (LAN) 192.168.1.134 (WAN) 1.53.78.81
    Performance:
    Load: 1% Uptime: 2m
    CPU temp: 57°C Usage of /: 17% of 28G
    RX today: 352 MiB
    Tips:
    What’s new in Armbian v26.2? https://tinyurl.com/4a4ktj3u
    Commands:
    Monitoring : htop
    Last login: Sat May 2 10:36:28 2026 from 192.168.1.139
    [10:46:38.056] ═══════════════════════════════════════════════════════
    [10:46:38.056] Diretta UPnP Renderer v2.4.0
    [10:46:38.057] ═══════════════════════════════════════════════════════
    [10:46:38.057] Build: aarch64 NEON (May 1 2026)
    [10:46:38.057] Scanning for Diretta Targets...
    [10:46:38.341] Available Diretta Targets (1 found):
    [10:46:38.341] [1] rAudio
    [10:46:38.341] Output: snd_rpi_rpi_dac
    [10:46:38.341] Port: IN=0 OUT=1
    [10:46:38.341] Config: http://[fe80::ba27:ebff:fe29:cab]/
    [10:46:38.341] Version: 1
    [10:46:38.341] ProductID: 0x5f5f5f5f4d744f53
    [10:46:38.341] Usage:
    [10:46:38.341] Target #1: sudo ./bin/DirettaRendererUPnP --target 1
    [10:46:38.341] Target #2: sudo ./bin/DirettaRendererUPnP --target 2
    Chú TV box thay cho chú laptop ASIO tuyệt vời . . . :confused:
    TQ_Audio and binna like this.
  15. Tri818300
    Tri818300 Approved Member
    mac mini cài eunhasu 5.31 không tài nào update lên 6.2 được vậy bác bác có cách nào không cám ơn bác
  16. bsmt0
    bác gửi email mình gửi cho bản backup 6.2 bản đã có roon thuốc 2.65
    anhton82 likes this.
  17. Tri818300
    tri818300@gmail.com
    xin cám ơn bác
  18. Hukan
    Hukan New Member
    Thái nguyên
    Bác cho e xin với ạ. E cảm ơn
    Sakura92tt@gmail.com
  19. toon@789
    toon@789 Advanced Member
    roonlabs.win@gmail.com
    xin cám ơn bác
  20. Excel Man
    Bắc Ninh
    bác lên dc chưa? Bản 6.2 ko tự upgrade dc
  21. Tri818300
    ok rồi bác ơi có bác kia gửi bản ghost chạy ok lẹn 6.3 ok luôn cảm thấy chất âm thua win10 ltsc chạy tool tối ưu win bác ơi
  22. tuantrampro
    tuantrampro Advanced Member
    trongtuannew73@gmail.com Cám ơn bác .
  23. tungtuantu
    tungtuantu Approved Member
    Bản 6.3 của bác có bật được làm Host ko ah
  24. littlemouse
    littlemouse New Member
    Bác cho hỏi có con Dell Wyse 5070 8GB 64GB m2 và con NUC DN2820FYK 4GB 160GB ssd có ghép như bác được không?
  25. Excel Man
    Bắc Ninh
    Ghép tốt đó bác.
    Bác chon con Dell Wyse 3040 ngon bổ rẻ, dễ dùng nguồn (5V ăn dòng nhỏ như P4B) Con của bác 19 Vol khó chơi nguồn linear mà đắt. Tôi mới mod OS tối ưu cho nó cài thẳng vào ổ cứng 7.3 GB của nó.
    littlemouse likes this.
