Phần mềm Amarra ...
Discussion in 'Nguồn phát từ máy tính' started by cvision123, 1/4/10.
  1. phuongthu
    phuongthu Advanced Member
    Sai Gon
    Em cũng vậy Wav không cho add Artwork chán thật. Nhưng dân audio thích Wav thì nhất định không chịu convert qua mấy định dạng khác nên họ làm mấy chiêu thế này :
    * Họ tạo 1 file Mp3 thời gian ngắn nhất và không có âm thanh, xong họ add Artwork vào file này và để vào thư mục album đó...Chiêu lừa Itunes :
    iTunes artwork for wav files
    Submitted by Olive Empithrie on Mon, 08/25/2008 - 22:23
    Hi
    I recently found this forum and might soon ask for some advice on setting up what would be my first computer-based music system.
    I've seen one or two references here regarding not being able to use cover art in iTunes with wav files, so I thought I'd mention a simple workaround (I'm not suggesting wav is superior to any other format but if you, like me, want to listen to wav files for whatever reason - but like your iTunes album art as well, it can be done).
    Use any media editor and create a short file of silence, then save the file as mp3. You only need to do this once. My file is 1ms, or 1/1000 of a second long encoded at 320kbps (the top quality for an mp3 file, for no real reason really considering you can't actually hear the quality of silence :) The file of silence is tiny -- about 8kb -- so I could even email a copy of mine to anyone who wants it but doesn't have a media editor.
    So, when you come across an album that isn't in the iTunes store, all you do is copy this mp3 file of silence to the location where the album's wav files are, then in iTunes, select all the files in the album (the mp3 file together with the wav music files) and name the album title, artist etc as you would normally with a group of wav files. Then, select the mp3 file only and attach your cover art (that you've scanned or taken from Google image search or wherever). This works as iTunes only needs the cover art for one file per album - in this case the mp3 file. I normally name the file 00 Cover.mp3 so that for me it's the first track on any album but even if it turns up somewhere in the middle of the album you wouldn't notice a 1ms additional gap between music tracks unless it's a gapless album.
    This isn't perfect (for example, if for some reason you like or need to keep an accurate record of the number of songs you have in total, you're adding a "song" of 1/1000s silence to some albums) but it's very quick to do once you've practiced it a couple of times and it does avoid the need to convert to another music file format when you'd prefer wav - just because of cover art. So I thought I'd mention it here.
    *Dùng coverArt (chỉ chạy cho Mac thui nhớ đọc readme)
    Thanks to Geoff (silverlight) I have discovered the most wonderfully complete cover art solution for those of us who use WAV files (because despite arguments to the contrary, WAV files cannot accept cover art dragged in via iTunes). It also works on all formats, so feel free to try it there too. it is a python app and MAC only.
    Anyway, it's called Cover Art by Jacob Weber, can be found here
    http://www.jacobweber.com/coverArt
    and requires you to do some setup that, at first seems kludgy, but is simple once accomplished. Just follow the readme instructions (which include getting or confirming you have the right version of python, and requires a sign up for Amazon web services). What this python app does is intercept iTunes "get artwork" calls and creates a web page where all your unadorned albums will be listed. Click on the album name and Amazon Web Services will present you with various sizes it has found. Pick them, then run iTunes "get artwork" again and all will be loaded! Very cool.
    Of course we're talking iTunes and WAV, so this is a proprietary solution in that it all goes away if you export these WAv files somewhere else. This cover art is tied to an album file and stored in the iTunes library at the album level.
  2. Meomuop
    Meomuop Advanced Member
    Ha Noi
    Bác phuongthu cho hỏi chút: Tôi dùng iTune for Windows để chuyển CD sang HDD cũng đuợc kha khá.Nếu quay sang MAC để có thể dùng Amarra thì iTune for MAC có nhận đuợc library cũ không hay lại phải rip lại từ đầu bằng iTune mới?
    Nếu thế thì cũng ngại gớm.
  3. phuongthu
    Sai Gon
    Itunes trên PC nhận thì trên Mac cũng nhận đủ hết, Itunes chỉ chê mổi thằng Wav thui nhưng cũng có cách cho nó nhận luôn...
  4. pc_chip
    pc_chip Advanced Member
    THỦ ĐỨC GROUP
    Này thì Amarra. Sau khi cài đi cài lại cái Hackintosh tầm chục lần ngày hôm qua thì cuối cùng em cũng đã tìm được bản iPC 10.5.6 này là em nó chịu chạy với cái máy cùi của em. Cài xong Amarra luôn rồi nhưng chưa nghe em đang cài lại cái bản iDeneb 10.5.7 một lần nữa xem em nó có chịu chạy với cái card Firewire không tên tuổi của em không! Bản iDeneb này nhìn sạch sẽ hơn cái bản iPC. Cái WIFI trong máy dù khá phổ biến là cái Atheros AR5007EG và trong bộ cài nào cũng có nhưng nó chả chịu chạy! :( Cái card mạng Broadcom NetLink Gigabit cũng không thèm chạy trong khi cái Bluetooth em chả cần thì nó lại chạy phà phà.
    Hy vọng tối nay có thể thưởng thức thử xem cái Amarra nổi tiếng này nghe nó ra sao! :wink:
  5. chickchick
    chickchick Advanced Member
    Em cài đặt xong Amarra trên MBP, dùng Snow Leopard 10.6.3 và nghe chất lượng âm thanh tốt. Nhưng không hiểu tại sao mỗi lần Itunes chuyển bài khác thì Volume của Itunes lại tự động về mức nhỏ nhất. Có bác nào biết cách khắc phục chỉ cho em với ạ.
  6. chickchick
    Em dùng CleanApp xóa bỏ Amarra để cài lại. Làm đúng theo các bước hướng dẫn mà không thể *** được. Bây giờ nó bắt dùng Demo. Bác nào giúp em với, nghịch dại quá. :twisted:
  7. pc_chip
    THỦ ĐỨC GROUP
    Cài lại SL đi bác ơi! Có đêm em cài lại cái Hackintosh đến 4-5 lần do nghịch dại đấy ạ! :lol:
    Vụ âm thanh nhỏ đi khi chuyển bài thì bác kiểm tra lại phần cross fade option của iTune xem để thế nào.
  8. cvision123
    cvision123 Advanced Member
    Một trong những tính năng chính của Amarra là cung cấp cho người dùng một playback engine chất lượng cao để thay thế cho playback engine mặc định của iTunes (bản thân iTunes cũng đã thuộc hàng chất lượng cao rồi). Khi này Amarra sẽ vô hiệu hóa khả năng chỉnh âm lượng của iTunes và điều khiển phần âm lượng bằng module của mình dẫn đến việc âm lượng trong iTunes bị "kéo" về 0. Nếu bác muốn chỉnh âm lượng thì bác có thể chỉnh bên phía Amarra.
  9. cvision123
    Việc cài đặt Mac OS sẽ rất đơn giản đối với các phần cứng của Mac nhưng hơi "khó chịu" khi mình cài trên PC. Kinh nghiệm của em là các bác muốn dọc thì chịu khó cài theo hình thức retail. Cụ thể là dùng bản gốc của đĩa cài đặt, khởi động với Boot 123 hay Chameleon rồi sau đó cài thêm các driver (kext extension) phù hợp với phần cứng của mình. Khi này Mac OS sẽ hoạt động rất tốt vì ta không thay đổi cấu trúc gốc của hệ điều hành (một số bản như Kalyway, ... có một số thay đổi về kernel, ... khiến cho việc cập nhật sau này gặp khó khăn).
    Một điểm lưu ý nữa là sau khi cài được một bản "kha khá" rồi thì các bác nên dùng phần mềm Carbon Copy Cloner để tạo bản sao của phân vùng đĩa cứng cài Mac OS (ta có thể hiểu nôm na là tạo ảnh ghost). Nếu trong quá trình dọc phá bị lỗi thì chỉ cần khởi động bằng đĩa DVD rồi chọn mục restore để phục hồi lại thôi.
    Chúc các bác "mất ăn mất ngủ" với Hackintosh sớm ngày thành chánh quả :)
  10. pc_chip
    THỦ ĐỨC GROUP
    Em cài bản iDeneb 1.5.1 của phiên bản Leopard 10.5.7 với kernel Vanilla thấy cũng tương đối đơn giản. Thiết bị nào chạy thì nó đã chạy ngay. Riêng có cái WIFI Atheros 5007EG lục nát các diễn đàn rồi mà cũng không ra giải pháp! :(
    Cài sở dĩ em hay phải cài đi cài lại nhiều một phần cũng do mình không có kinh nghiệm nên đôi khi chọn sai một vài option trong khi cài đặt hay muốn thử cái option khác mà chưa có kinh nghiệm để lấy được các cái kext khác trong các đĩa cài mà không phải cài lại! :oops:
    Theo em hiểu thì cài bản nào cũng được miễn là dùng kernel Vanilla thì đều có thể update trực tiếp từ Apple được. Em đã thử up từ 10.5.7 lên 10.5.8 bằng cách download trực tiếp về và thấy rất suông sẻ. Chỉ có điều up xong lại phải mò mẫm tìm kext cho một số thiết bị vốn chạy ngon từ bản cài trước do "Quả táo thối" ghi đè hết lại thành bản mặc định của hắn! hihi...
    Cài xong mà ưng ý cái thì tất nhiên phải làm một cái copy đem cất ngay nhưng mà mãi em vẫn chưa ưng ý! hihi...
  11. phuongthu
    Sai Gon
    cái WIFI không chạy thì kiếm cái chạy gắn vào, Em mua cái wifi dell 1390 củ chỉ 150k vnd gắn vào chạy wifi phà phà...thay gì tìm kext hay lựa bản hac có kext thì lâu quá...
  12. bufaloears
    bufaloears Advanced Member
    Spam tý!
    Một plugin tương tự Amarra cho Itune nhưng thằng Burwenbodcat này lại cho Windows Media Player.
    Có bác nào dùng soft này chưa. Thằng này kinh lắm, nó còn không cho cả bản demo.
    http://www.burwenbobcat.com/
  13. phuongthu
    Sai Gon
    nó cho bản demo mà bác khai thông tin đầy đủ buy cash với giá 0$ download về thử xem, Em download rồi tự động cài luôn mà chưa vọc thử thế nào ?nó chỉ là file DLL chép nó vào đâu trong Windows Media Player để xài zậy Bác ?
  14. chickchick
    Em thử chỉnh Volume bằng Amarra rồi, không thấy có tác dụng. Chẳng lẽ không có cách nào khác ngoài cài lại SL?
  15. cvision123
    Bác chơi file nhạc lossless phải hông? Hiện giờ Amarra chỉ support AIFF, Apple Lossless thôi. Trong tương lai thì Amarra sẽ support FLAC nữa. Nếu nghe file AAC hay MP3 thì Amarra sẽ hổng có tác dụng.
    Em đã từng bị lỗi logic khi Amarra kiểm soát volume. Bác thử cách đơn giản sau.
    • Tắt cả Amarra và iTunes
    • Chạy iTunes lên (khi này Amarra sẽ không tự động nạp lên)
    • Chỉnh âm lượng lên maximum
    • Tắt iTunes
    • Chạy lại Amarra (khi này Amarra sẽ tự động nạp iTunes lên)
    Phần điều chỉnh âm lượng sẽ trở về như ban đầu
  16. chickchick
    Thank bác nhiều, em làm đúng như bác hướng dẫn và vấn đề Volume đã được giải quyết. Hiện giờ em đang lọ mọ *** Amarra.
  17. cvision123
    Thật ra thì Amarra gần như hổng có gì để dọc phá hết :-(. Chỉ có tùy chọn chỉnh dither, parametric equalizer. Hình như thằng nào càng chuyên dụng để chơi nhạc thì càng ít thứ để chỉnh hay sao í :-(. Giống như mấy cái CDP hay Amp đắt tiền thì có ít nút để chỉnh hơn :)
  18. coolboy_dn85
    coolboy_dn85 Advanced Member
    Đà Nẵng City
    HIx. Em chép file burwenshellext.dll vào thư mục cài đặt WMP mà chả thấy nó động tĩnh ji cả .
    Cái này mà chạy ngon lành giống em Amrra , thì kết hợp với out ASIO nữa là tuyệt.
    link em nó đây ! em post lên đây cho các bác tiện dow về mà test thử.
    http://www.mediafire.com/?lmkzg2wmojz
    media = 12345
  19. Rainbow
    Rainbow Advanced Member
    Đà Nẵng
    Một số thông tin mình xin chia sẻ thêm:
    - Có bác khi kéo volume của Amarra và Itunes lên max thì nghe có sự lặp lại, đó là cùng lúc cả Amarra và Itunes cùng playback. Vì Amarra phải load nhạc từ Itunes nên bị lag time. Vì vậy, để nghe được playback engine từ Amarra thì ta nên kéo volume trong iTunes về 0.
    - Một cách nữa để tránh iTunes playback thì chọn bài trên iTunes xong qua Amarra click load để Amarra 'nạp' bài vào và playback hẳn trên Amarra. Lúc đó, iTunes không cho phép kích hoạt volume nữa (thường là mình dùng kiểu này)
    - Nếu bác nào đang dùng Airport Express (như mình) muốn Amarra playback thì PHẢI chạy Airfoil. Nếu không dùng Airfoil, lúc đó CHỈ có iTunes mới cho phép playback. Nhiều bác nhầm tưởng Amarra cho phép playback with wireless nhưng thực sự lúc đó các bác đang nghe wireless qua iTunes chứ không phải Amarra nếu không dùng qua Airfoil.
    - Một điều nữa (mình gặp phải) là lúc install Airfoil rồi thì các bác cũng phải install luôn Hickjack (pls check spelling). Nếu chưa thì Airfoil chạy nhưng chưa chịu tải tín hiệu wireless đến AE.
    Thân.
  20. chickchick
    Sau một đêm loay hoay, xóa đi cài lại nhiều lần bây giờ sau khi cài MacPorts và chạy lệnh sudo port install bsdiff em nhận được kết quả:
    Chẳng biết tiếp tục thế nào nữa. Bác nào có kinh nghiệm vụ này giúp em với.
  21. pc_chip
    THỦ ĐỨC GROUP
    Em đọc qua phần hướng dẫn sử dụng thì thấy chú này không hoạt động tương tự như chú Amarra. Chú Amarra nếu không dùng phần EQ thì có tác dụng bỏ qua Core Audio của MAC và dùng engine với thuật toán gì đấy tạm cho là tốt hơn nhiều để phát trực tiếp tín hiệu digital ra DAC.
    Chú Burwen_Bobcat này thì lại dựa dẫm hoàn toàn vào WMP engine nên nếu máy tính không bỏ qua được ảnh hưởng của Kernel mixer, không hiểu chú này sẽ phát huy tác dụng thế nào! Đọc tính năng thì em thấy chẳng qua chú Bobcat này chẳng khác gì một plug-in EQ với 19 presets định sẵn cho các loại âm nhạc khác nhau! Chú này tính năng chính là sửa lỗi thu âm của các đĩa CD (kiểu này thì tiêu, xưa giờ ta toàn nghe CD thu âm bị lỗi không thế này!) :wink:
  22. coolboy_dn85
    Đà Nẵng City
    - Dùng plugin ASIO bản hổ trợ cho WMP có thể bỏ qua Kernel mixer
    - Nếu EQ thì WMP cũng tích hợp sẵn rùi mà bác (cả DFX nữa ...)
    => em nghỉ không phải đâu. Quan trọng là làm thể nào để chạy được Bobcat là rõ tất cả!
    Trích nguyên văn mà nó quảng cáo
    Lossless music files play with higher quality than a CD player
  23. pc_chip
    THỦ ĐỨC GROUP
    Em đọc lòng vòng trang của chú này mà không hề thấy chú Bobcat này khuyến cáo gì đặc biệt là phải dùng ASIO plug-in và sound card cả! Đây là đoạn chú ấy viết trong hướng dẫn sử dụng mà em cho là EQ:
    LISTENING
    Burwen Bobcat provides 19 fixed processing selections for simple operation. The 18 above are
    in the Big Bobcat window and a universal basic bobcat selection appears in the small Basic
    Bobcat window.
    1. BURWEN BOBCAT RE works only with the Windows Media Player.
    2. When playing your disc, or music file select the sound you want, basic, vocal,
    jazz, pop, classical, or movies and compare to no bobcat. Use the sound you like best.
    3. For additional tone adjustment, use the Windows Media Player's Graphic Equalizer
    available under View, Enhancements, Graphic Equalizer.
    Và đây nữa:
    A computer with BURWEN BOBCAT can sound better than my $13,000 player? How can it be?
    BURWEN BOBCAT does not attempt to make the analog signal an accurate replica of the digital signal as
    your player does. It actually improves the signal by adding nearly inaudible high frequency reverberation
    and subtle tonal balance correction (equalization).
    BURWEN BOBCAT adds what I describe as ambiance without echo. It includes a lot of what audiophiles call
    "air". Rough sounding recordings become smoother and more musical because the extreme high
    frequency reverberation averages out the grit. Unlike natural reverberation, which tends to obscure
    transient sounds, BURWEN BOBCAT stretches transients in time so they are more easily perceived and
    become clearer.
    Đây là toàn bộ phần hướng dẫn sử dụng:
    http://www.burwenbobcat.com/BURWEN_BOBCAT.html
    Trong mục hỏi đáp thì chú này có ghi rõ là không hề cho phép dùng thử phần mềm này:
    Is there a free trial period for the software?
    No.
    Thế này không gọi là EQ thì không biết gọi là gì bác nhỉ! Chắc là phải gọi là Tone Control (Equaliztion) như chú ấy gọi thôi!!! Tạm dịch là (chỉnh tông và làm cân bằng) :roll: :wink:
  24. coolboy_dn85
    Đà Nẵng City
    Có đấy bác ! Ngoài ra nó có rất nhiều tính năng. Rip nhac ( mặc dù WMP đã có nhưng như theo quảng cáo thì cho chất lương tốt hơn). Theo như bác nói vậy cái mà em dow về và cài vào mấy là cái ji nhỉ ? Nếu vậy thì mất công toai rùi bác ơi ! :(
    To assure highest audio quality we recommend playing through a Digital to Analog Converter or
    sound card capable of 24 bits.
    # It works with any DAC including your computer's sound card
    # Save (rip) all your CDs as lossless WMA files on your hard drive. Processed if you want.
    # Listen via BURWEN BOBCAT.
    # Burn processed CDs for your car.
    # Convert to processed MP3s or WMA lossless for your iPod or cell phone.
    # CD irritation and listening fatigue disappears. You can listen longer and louder.
    # It makes historical recordings beautiful, natural, and sounding like they were recorded
    yesterday.
    # Hear the detail, dynamics, smoothness, and clarity of the music whether loud or soft.
    # BURWEN BOBCAT bridges the gap between highest quality of the past and cell phones and
    iPods today
  25. pc_chip
    THỦ ĐỨC GROUP
    Hi hi,
    Mấy cái nén, chuyển đổi định dạng, ghi đĩa gì gì đấy chỉ là mấy cái râu ria phụ trội đưa ra để đánh lạc hướng sự chú ý mà thôi. Cái tính năng chính là để phục vụ cho việc phát nhạc thì mấy chỗ em đưa dẫn chứng ở trên ghi khá rõ rồi còn gì ạ!
    Chẳng cần biết cái máy tính của người dùng ra sao, dùng kết nối kiểu gì mà quảng cáo chỉ dùng mỗi cái plug-in cho WMP mà biến cái máy tính chơi tốt hơn CD Player 13K Obama! Ôi sao mà bác ấy vui tính thế không biết! :lol:
