Tên mặt hàng: Denon AU-320MC Tình trạng, mô tả: + Winding wire ratio (pressure-up ratio): 1: 10 ; 1: 36 + Primary impedance: 40ohm, 3ohm + Secondary impedance: 4kohm + Frequency response: 10Hz - 100kHz + Deflection (as opposed to 1kHz): Less than>=1dB + Right-and-left separation rate: 60dB or more (20Hz - 50kHz) + Phase characteristic: Less than (20Hz - 50kHz) 10 degrees + Magnetic shield: Three-fold + Chord length: About 1m + Dimensions: Width 97x height 65x depth of 155mm + Weight: 0.8kg Khu vực: HN Điện thoại: 0975 032 không ba tám Giao hàng: Toàn quốc, ship COD Giá bán: 6.000.000
