Đã có Firmware mới (ngày 09/5/2011) cho Popcorn Hour C-200: 02-04-110422-21-POP-408-000 Mời các bác quan tâm xem tại đây: http://www.networkedmediatank.com/showt ... ?tid=51992 "Release date : 9 May 2011 Firmware version : 02-04-110422-21-POP-408-000 1. Still same NMT apps 02-04-101104-21-POP-408 2. BD/AVCHD/DVD/CDDA - Fixed ISO and BD playback fail from USB, when started through certain flash app 3. Video and Audio playback - Fixed 3D output failure due to incorrect filename parsing (Bug #5002069/#0000541) - Fixed stuttering 25fps H264 video in MKV (Bug #5001993) - workaround incorrect PCM/WAV detection (Bug #5001942/#0000161) - AVI chunk data handling of padding to even boundary (Bug #5002058/#0000531) - Fixed FLAC playback random crashed due to stack violation (Bug #5002065/#0000539) - Fixed framerate sync issue with video-only file (Bug #5001539) - Fixed for small glitches during FLAC gapless (Bug #5001646) - External SRT subtitle "index.srt" loaded as default subtitle for simpleBD - Fixed wrong positioning of SSA subtitle text with move tag (Bug #5001944) - Fix Arabic character shaping issue (Bug #5002053/#0000272) - Fixed ability to extract Dolby Digital (AC3) core from TrueHD stream, can bitstream and downmix now. 4. Networked Media JukeBox (NMJ) - NFO file issue fixed - Fixed NMJ Scanning hangs occasionally when parsing certain MKV 5. System/Network - German translation changes - Fixed crash when click on GPL link in "open source license" screen - Fixed "moving up/PageUp from webservices with multiple pages generates an error" (Bug #5001534) - Fixed certain Audio CD ripping failed, due to special character in filename (Bug #5002061) - Added manual setting of YCbCr colorspace (BT.601 and BT.709). Auto colorspace is under development. =========================================================================================== NMT Apps Version : 02-04-101104-21-POP-408 Release Notes : 1. Minimum firmware version to use this NMT App is 02-04-101104-21-POP-408-000 2. Version stepping, practically same as 02-03-100427-21-POP-408" Bác nào mà C-200 có kết nối internet thì để máy update tự động. Còn bác nào chơi "offline" thì chịu khó "canh" link này, trong ngày hôm nay (10/5/2011) sẽ có link download: http://www.popcornhour.com/download/C20 ... -C200.html
theo như trang chủ http://support.cloudmedia.com/article.aspx?id=1089 thì cái bản thứ 2 "Only apply if you are using a firmware after 03-04-110530-21-POP-408-000 or later version" mà máy e đang ở bản 02-04-110422-21-POP-408-000 có liều recovery cái bản thứ 2 không các bác?
