Tên mặt hàng: pre Audio GD HE-1 (2019 version) Tình trạng, mô tả: Như mới, cần nâng cấp thanh lý. Đây là Pre Thuần nhé các bác Một vài tính năng tiêu biểu Built in regenerative power supply Fully balanced class A design built by discrete analog stages without any OPA or coupling caps in the signal channels. Non- feedback ACSS analog output stage. Uses three R-core transformers (In total 260W ) and more than 100,000uf audio grade NOVER capacitors are used to ensure ample and smooth power delivery. Separate class A PSUs power supply for regenerative drivers and audio signal amps . Four-channel 100 steps digitally controlled relay-based volume control avoids channel imbalance and improves sound quality. Supper Exponential Volume Characteristic, easy match the volume with different power amp and speaker http://www.audio-gd.com/HE/HE-12017/HE-12017EN.htm Giá bán: 35tr (new 45) Khu vực: Hà Nội Điện thoại: 0908025888
