Primare NP5 Prisma, streamer bá đạo...
Discussion in 'Nguồn phát từ máy tính' started by tml3nr, 8/2/20.
  1. tieuphi2006
    tieuphi2006 Advanced Member
    hay quá anh..
    Sent from my iPhone using Tapatalk
    tml3nr likes this.
  2. tml3nr
    tml3nr Advanced Member
    Primare có thông báo mới về NP5 MK2 ạ.
    July Updates and NP5 Prisma MK2 Notes
    12 July 2021
    Below find the latest information on forthcoming Prisma updates and additional information regarding the soon to be released NP5 Prisma MK2.
    July OTA Streaming Update
    Starting today we will begin rolling out a Prisma OTA streaming update in anticipation of Spotify HiFi launch, and additionally provides general platform improvements and bug fixes including: 
    • ‘Skip Next’ command issue with USB source
    • Win10 UPnP/DLNA noise from Windows Media Player 
    • Bubble UPnP app volume issue
    Streaming firmware version number is now # 14849, while MCU and Cast version numbers remain the same - click this link to check firmware versions in the FAQ on our website.
    Future Updates
    We continue to work on all other long promised updates, and are sorry for the delays, but much of it is out of our hands as there are considerable delays resulting from current conditions effecting the global AV industry:
    • Audirvana playback issues – we are in communication with Audirvana to allow Prisma to better coordinate with their particular UPnP implementation, but they appear to be fully occupied with finalising the new subscription-based Studio platform, resulting in slower progress than we would have hoped
    • Cast update – we are working with Google to improve cast capabilities and stability
    • Roon Ready for remaining Prisma models:
    • Roon software has been done for some time, with all that remains is integration into Roon’s user interface, but with the extensive control/configuration and input/output options available in the Prisma range, sorting out all the details from signal path representation to volume setting options is taking longer than both of our companies could have anticipated.
    • Some of you may be seeing uncertified Roon Ready software in the audio zone options. Please be aware that this software is not accessible until full certification. In the meantime, AirPlay and Chromecast as endpoint are the two available options.
    • Tidal Connect – there continue to be delays in our being able to provide Tidal Connect, but we are working toward having it available as soon as possible 
    We have received questions regarding the NP5 Prisma MK2 that make it apparent some clarification may prove beneficial.
    Most importantly, it must be understood that we would not have developed the MK2 version of the NP5 Prisma were it not due to the lack of the sample rate conversion chip used in the original version resulting from the AKM chip factory fire.
    We consider this to be a running parts change and not a new model, with the two versions being functionally identical for connectivity, control, and audio performance. All future updates for the NP5 Prisma platform will be for both the original and MK2 versions, including Spotify HiFi, Tidal Connect, Cast and other general bug fix updates expected now for this fall.
    The only substantive difference is the sample rate conversion chip used, (mistakenly identified as a re-clocking chip in our original announcement). In the original NP5 Prisma design, all files go through the SRC, preventing an MQA file from being detected by an MQA enabled DAC. When swapping out the chip we were able to design a direct passthrough for both digital outputs when Native playback is selected, and files are played at or below the selected resolution.
    So, for example if the associated DAC being used is limited to 24/96 kHz, 24/96 kHz should be selected in the Native playback settings, with the result that all files at that resolution or below will bypass the SRC, while any files at 24/192 kHz will go through the rate converter and be down sampled to 24/96 kHz.  As might be obvious, the recommendation for any DAC capable of 24/192 kHz is to set Native playback at 24/192 kHz for the widest range of what is now by strict definition “bit-perfect” playback.
    Note, only those with an MQA DAC will benefit substantially from this, and all users of either the original NP5 Prisma or the NP5 Prisma MK2 will be able to enjoy Tidal Master files to the first full MQA unfold offered by Tidal Connect when we are able to update both devices to that platform late this summer or early fall.
    Finally, current conditions, including a worldwide semi-conductor shortage leading to some chip costs being thirty times more than at the time of the original design, simply do not allow for us to offer a trade-in program and have led to the need to raise the retail price.
    Should you have any questions or need assistance, please feel free to contact us at any time, Terry
    PS: Thông báo cũ ngày 14/06/2021 ở đây:
    https://primare.net/new-primare-np5-prisma-mk2-to-be-released-august-2021/
  3. iolom
    iolom Approved Member
    • Until 31 July 2021, any NP5 Prisma MK2 ordered will be available at 50% of the retail price of €600/$750 or €300/$375.
    • Offer valid with the presentation of the serial number for the user’s I32 MM30, PRE32 MM30, NP30, or PRE60 to any authorised Primare dealer.
    • After 31 July 2021, the Update Program will be discontinued.
    Chà , đoạn này quan trọng nhất đây . Có bác nào có xài mấy cái sản phẩm còn lại của primare mà k có ý định mua np5 mkii thì cho em xin cái serial number để em book mua 1 cái nhé . Đội ơn mấy bác
    tml3nr likes this.
  4. tml3nr
    Em ghiền Apple Music lossless quá rồi các anh ạ. Nguyên tuần nay em nghe nó suốt.
    Âm thanh của nó rất đặc biệt. Tiếng thanh thoát rất lạ.
    Ngoài ra đám playlist của nó rất hay. Trước đây em có nghe một anh bạn nói nhưng em không nghĩ là nó ghê tới như vậy.
    Cách nó start một cái radio cũng cực kỳ xuất sắc. Ghép bài rất êm và đúng mood.
    Tặng các anh nghe chơi vài playlist nằm trong mood Focus em đã export qua Tidal.
  5. Nguyễn Đỗ Hoàng
    Nguyễn Đỗ Hoàng Advanced Member
    Các bác nào đã cập nhật Firmware Streaming lên 14849 như hình dưới đây :
    Khi chạy Roon bị lỗi : Uncertified[emoji3544] ( Chưa được chứng nhận ) lên Roon Ready như hình dưới đây :
    Thì đợi hãng Primare cập nhật nhé các bác, không phải lỗi thiết bị mà lỗi từ phần mềm mới cập nhật từ hãng.
    Email phản hồi từ hãng :
    This is known to Primare and they are working on it.
    From an email I received from support:
    Regarding "Uncertified" in Roon, I'm on it. Seems there was a model name error in latest firmware. Current model name is "Primare NP5" while Roon has "NP5" whitelisted.
    I will need to push out new firmware for NP5 Prisma to solve this issue
    [emoji732]️ Khi nào hãng cập nhật Firmware mới em sẽ thông báo sau ạ.
    [emoji93][emoji304] Chúc các bác giữ gìn sức khoẻ, hạn chế ra đường khi không thực sự cần thiết mùa Cô vy này ạ. [emoji6]
    iolom and tml3nr like this.
  6. iolom
    Em điện lên nguyễn audio thì bản mới chưa về , bản cũ hết hàng . Chưa trải nghiệm được . Hix
    tml3nr and Nguyễn Đỗ Hoàng like this.
  7. Nguyễn Đỗ Hoàng
    Ráng đợi tầm tháng 8 hoặc đầu tháng 9 bên nhà phân phối nhập hàng mới rồi mình trải nghiệm luôn bác. Hôm bữa có 1 bác bán mà vừa lên sóng là có người mua liền rồi. [emoji1]
    tml3nr likes this.
  8. Nguyễn Đỗ Hoàng
    Hãng đã cập nhật mới để tương thích với Roon rồi nhé các bác.. Các bác rút dây nguồn , bật wifi hoặc cắm Lan để cho em nó tự cập nhật qua OTA. Hãng Primare hổ trợ khách hàng cực kỳ nhanh, thích hãng này có bao nhiêu đây thôi [emoji6][emoji6][emoji6]
    tml3nr likes this.
  9. tml3nr
    Nhanh quá anh nhỉ. Em up lên 14849 được mấy hôm rồi nhưng ít dùng roon nên không biết vụ này.
    https://helpdesk.primare.net/hc/en-...-What-are-the-latest-Prisma-firmware-versions
    Ráng chờ thêm tháng nữa anh ạ. Chắc là nhà pp sẽ về hàng sớm vì chưa thấy ai cá trê em này :cool:
    iolom and Nguyễn Đỗ Hoàng like this.
  10. iolom
    Vâng , em cũng tính lấy về thay thử cái lap xem sao . Nếu cải thiện nhiều thì k cần suy nghĩ đổi dac .
    Em đang nghía mấy con dac tầm trung cao
  11. Nguyễn Đỗ Hoàng
    Em đang chơi Roon bản build 778 trên MacOS nên rất hài lòng với em nó anh ạ. Âm thanh nghe phê pha, đầy đủ 3 dãi, thích nhất dãi treble lung linh luôn ( phải đi với Coaxial Canare ) , nói chung là quá hời so với những gì em nó mang lại. [emoji6][emoji6][emoji6]
    tml3nr likes this.
  12. Nguyễn Đỗ Hoàng
    Theo cá nhân của em thì anh nên chọn 1 con chuyên nghiệp DAC , đừng tích hợp nhiều thứ lên nó quá sẽ mất cái hay của DAC. [emoji1306][emoji41]
    tml3nr and iolom like this.
  13. iolom
    Đó giờ em vẫn chơi dac rời và nguồn phát rời . Dac em đang dùng north star audio impulso . Nói chung hệ thống đang bị tình trạng dính nhẹ ở những khúc cao trào trong những bản nhạc tiết tấu nhanh . Nên đang ngâm cứu thử nguồn phát khác thay laptop . Còn dac khá hài lòng với chất âm ấm áp của nó nên cũng k muốn đổi dac lắm
    Hiện roon đang chạy trên win tối ưu , để chế độ native dsd
  14. tml3nr
    Đã có app Apple Music v3.6 bản chính thức cho Android rồi các anh ạ. Chạy mượt hơn các bản beta nhiều.
    Hãng đang cho free 3 tháng. Các anh nên dùng thử cho biết. Em ghiền nó lắm rồi :D
    Dùng IOS phát airplay tiếng cũng rất hay. Mình có thể dùng account thứ 2 để nghe nhạc và down app store. Acc chính để quản lý icloud.
    Khi nào cần update những app mua bằng acc chính. Chỉ cần nhập pass vào là xong. Rất tiện ạ.
  15. chauphuong
    chauphuong Advanced Member
    bác @tml3nr phát nhạc Hires từ Apple Music qua Chromecast có ok ko? Tôi phát nhiều file thấy ghi là hires mà trên DA chỉ thấy báo 44.1khz (dĩ nhiên đã setup hires trong Apple Music app). Lẽ nào hires của Apple đều là 24/44? Vẫn là Chromecast, phát upnp từ minimserver thì ok, lên đến 24/96.
    tml3nr likes this.
  16. trung224
    trung224 Advanced Member
    Theo em biết là Hires của apple music chỉ xuất ra Hires khi thiết bị kết nối là thiết bị Apple (iPhone, iPad, Mac) thôi. Cũng ko lạ lắm vì đây cũng là cách làm thường thấy của Apple
    tml3nr and chautranthanh like this.
  17. chauphuong
    Hic vậy trên app android nó bày ra hires làm gì nhở?
  18. chautranthanh
    chautranthanh Advanced Member
    không biết có phải do tai trâu hay không nhưng nghe AM từ IPhone X thấy hay hơn nghe các file DSD hay lossless từ IPhone X tất cả xuất ra Dac
    tml3nr likes this.
  19. tml3nr
    Em set lossless rồi nghe luôn nên không chú ý lắm ạ. Cái dac của em không có display nên em cũng không biết nó đang là gì :D
    Âm thanh của AM lossless theo em thấy là hay nhất từ trước tới giờ trong số các món Tidal, Qobuz, Deezer, Amazon HD ạ. Tiếng của nó hay lạ kỳ.
    Thích nhất là các playlist của nó và cách nó start radio. AM phải nuôi dàn mood editor rất hùng hậu mới phân loại được tốt như vậy.
    Rất nhiều bài nhạc hơi lạ tai, trước đây em start radio ở các dịch vụ khác không vừa ý. Nhưng AM làm rất xuất sắc.
    chautranthanh and Quang61 like this.
  20. chautranthanh
    Nhờ các hãng cạnh tranh nhau mình được thưởng thức thêm nhiều âm thanh hay mới lạ hơn
    Quang61 and tml3nr like this.
  21. ttho
    ttho Advanced Member
    Từ app android làm sao bắn âm thanh qua chromecast hay airplay được vậy bác?
    tml3nr likes this.
  22. Thịnh159
    Thịnh159 Advanced Member
    Shop nào phân phối NP5 mkii vậy anh em?
    tml3nr likes this.
  23. Nguyễn Đỗ Hoàng
    Bên Nguyễn Audio đang là nhà phân phối của Primare , NP5 MKII ra mắt vào tháng 8 này đó bác.
    Thịnh159 and tml3nr like this.
  24. tml3nr
    Cũng tương tự như app stock của Tidal, Qobuz, Deezer, Spotify... Apple Music chạy trên Android nó cho mình xuất âm thanh ra chromecast ạ.
    Để phát nhạc ra Airplay mình nên dùng IOS hay Mac OS, dùng Android hơi khó.
    Quang61 likes this.
  25. ttho
    Em làm được qua chromecast rồi. Còn qua airplay trên android không làm được. Em không có IOS/MacOS.
    tml3nr likes this.
