PS Audio Powerport Classic
Discussion in 'Linh kiện - Thiết bị khác' started by Wilson Fans, 31/5/21.
  1. Wilson Fans
    Wilson Fans Advanced Member
    TPHCM
    Tên mặt hàng: PS Audio PowerPort Clsssic
    Tình trạng, mô tả: Used,good
    Giá bán: 800k
    Khu vực: HCM
    Điện thoại: 0918161028
    Giao hàng: TQ
    Thông tin thêm: The Power Port is a high-end AV grade AC receptacle that will make a significant contribution to your system’s performance.
    At the heart of everything we do with AC power is the interface between our equipment and our power sources; the AC receptacle. Unfortunately, standard AC receptacles are made from cheap brass that does not provide the best levels of conductivity. The Power Port™ is a custom built, isolated ground, 15 to 20 amp receptacle that will insure a life-long level of excellence and superior conductivity. The Power Port exceeds hospital grade for grip strength, contact resistance and current delivery. Easy to install in your wall, this is one component you need in your listening room. 15 coats of polished nickel over high-purity brass, with the “grip of Mickey Mantle” and polished nickel plated hardware, this a must have in your system.
