Receiver cổ và khủng, hình + ý kiến vv......
Discussion in 'Thiết bị khuếch đại' started by Hai Lúa-USA, 28/2/08.
  1. Hai Lúa-USA
    Hai Lúa-USA Advanced Member
    Được chứ bác.
    from the MC7270 Owners Manual:
    CONNECTING FOR MONOPHONIC BRIDGE OR SINGLE
    CHANNEL OPERATION
    When the MC 7270 is used as a monophonic or single
    channel power amplifier, the two channels are added in a
    bridge configuration to produce output up to 540 watts.
    For monophonic operation using the MONO-BRIDGE
    mode, the amplifier can supply full power to output impedances
    of 2, 4, 8 and 16 ohms.
    Plug a shielded cable from the signal source or
    preamplifier to the RIGHT (MONO) input jack only.
    Change the MODE switch on the back panel of the
    amplifier to the MONO-BRIDGE position. The MONOBRIDGE
    switch internally connects the output of the right
    channel input amplifier to both left and right channel
    power amplifiers with the phase of the left channel inverted
    to achieve bridge operation and increased power
    output.
    BE CERTAIN THE MC 7270 IS NEVER OPERATED WITH THE
    BACK PANEL MODE SWITCH IN THE STEREO POSITION
    WITH THE AMPLIFIER CONNECTED FOR MONO BRIDGE.
    Operated with the MODE switch in the MONO-BRIDGE
    position, the circuit subtracts the left channel from the
    right channel L-R). The remaining difference signal is all
    that is then fed to the speaker.
    The MONO-BRIDGE operation of the MC 7270 amplifier
    always requires the speaker load to be connected between
    two opposite channel impedance terminals. The
    common terminals are not used. Do not connect leads independently
    between left and right channel impedance
    taps as this will cause high circulating currents and
    overheating. Connect the speaker leads to the output terminals
    as listed in this chart:
    Load Impedance Connect the Connect the
    In Ohms -Speaker Cables to: +Speaker Cables to:
    2 Left 1 Ohm Terminal Right 1 Ohm Terminal
    4 Left 2 Ohm Terminal Right 2 Ohm Terminal
    8 Left 4 Ohm Terminal Right 4 Ohm Terminal
    16 Left 8 Ohm Terminal Right 8 Ohm Terminal
    Neither output terminal is at ground potential.
    To use the MC 7270 to feed a line whose constant
    voltage is 25 volts, connect the speaker cables for 2 ohm
    MONO-BRIDGE output.
  2. Trang1958
    Trang1958 Approved Member
    E cám ơn Bác Hai nhiều,toàn tiếng Anh o mà trình của e bị yếu nên lúc nào có thời gian Bác có thể tóm tắt giúp e nha Bác,vụ này mà ba chớp,ba nháng hiểu o đúng là e làm tèo hết mấy amp thì e chết chắc với amp vô địch ở nhà,Bác cũng cho e hỏi thêm nếu chơi mono block có làm giảm độ hay và chi tiết của bộ giàn o vậy Bác,và dùng một pre để chơi với hai power phải o ạ.E nhờ Bác giúp để hiểu biết thêm,e cám ơn Bác nhiều,chúc Bác khỏe.
  3. Khi Gia
    Khi Gia Advanced Member
    Sài Gòn
    Nhờ Bác Hai giúp em tí: em đã từng xài Sansui 9090db và AR dòng connoisseur series thấy mid rất ngọt nhưng bass chưa sâu, em định nâng cấp thành Sansui G9700 hoặc Mcintosh 1900. Bác tư vấn giúp em em nào hay hơn? Hiện tại em đánh AR với bộ pre-pow onkyo khá hay, muốn kiếm thêm 01 em reciever để thình thoảng nghe đài chơi. Cám ơn bác nhiều.
  4. Hai Lúa-USA
    Cá nhân tôi ko thích bán dẫn receiver của McIntosh. Chúng quá yếu, quá mắc .. không thể bì với các loại khủng của Nhật Mỹ được. Nhất là để chơi AR ..
  5. mucmoc
    mucmoc Advanced Member
    Chào Bác!
    Em đang phân vân giữa Pioneer SX-1050 và SX 1080, phiền bác tư vấn giúp nên chọn e nào để chơi hơn và vì sao lại chọn như vậy ( giá cả, hình thức và máy móc tương đương nhau ). Rất mong có câu trả lời sớm của bác. Thân!
  6. Hai Lúa-USA
    Cái này hình như tôi đã từng trã lời. Theo tôi thì em 1050 hơn 1080 khá nhiều mặt. Thứ nhất theo khuynh hướng cổ 1050 đẹp hơn. Nó được làm công phu hơn, đồ mắc và chắc chắn hơn. Riêng sò mà nói thì có hư con 1050 cũng còn tìm được chứ 1080 là bó tay. Âm thanh thì 1050 cũng hay hơn bác ạ theo tai của các "cụ" từ 40 trờ lên ha ha ...
  7. mucmoc
    Cảm ơn bác!
  8. tandberg
    tandberg Advanced Member
    em chào bác Hai, bác xem pm nhé
  9. nghiact
    nghiact Advanced Member
    Cần Thơ
    Chào bác Hai, Em rất mê receiver cổ và hiện đang có cặp loa JBL Lancer 99 (đang ghép với ampli đèn), Em nhờ bác tư vấn cho em loại receiver nào hợp, Em chủ yếu nghe nhạc vàng trước năm 75 và sau năm 75 cũng mê nghe luôn. :)
    Em cám ơn bác trước Ah!
  10. Hai Lúa-USA
    Cặp này còn viền gân Lansalloy trắng ko vậy bác? Tới tuổi này mấy em gân trắng này cứng lại nghe không còn hay như trước nên cần phải thay.
    Về receiver cho hợp thì bác phải thử thôi, nhưng thử với các loại khủng cho đở mất thì giờ. Sansui G9000, Pioneer SX1250, Concept 16.5 ... đều ổn cả. Nếu thấy mắc quá thì tìm loại nhỏ 120W như SX1050, 1080, G8000, Marantz 2325 ...
  11. khuongkhangha
    khuongkhangha Advanced Member
    Can Tho
    Bác 2 USA cho em hỏi JBL 4425 ghép với ampli gì để nghe nhạc vàng từ năm 80 đến năm 91? viền loa này đã thay viền zin rồi mềm mại, cái khó của đôi loa này là phát huy được khả năng bass của nó. tks
  12. Hai Lúa-USA
    Bác qua bên JBL fan hỏi người ta có ý ra sao. Theo ý tôi thì loa đã thiếu Bass thì bác có xài 1000W/kênh bán dẫn McIntosh cũng ko thể cho nó thêm bass được, huống gì là các receiver cổ rẽ tiền yếu ớt này! Cách hay nhất là bác chơi thêm cái sub, ví dụ như B380 (với Adcom GFA555 có thể xuống đến 25hz), có người từng đề nghị thế. Có điều làm cái này mò mẩm hơi mệt. Hay là thay loa đi như tìm em 4344, 4430 chẳng hạn.
  13. tuansalon112
    tuansalon112 Advanced Member
    chào bác hai!em có xíu nhờ bác hai giúp em,em có cặp loa boe901 vi.nghe nói nếu ghép với amly BOSE SPATIAL là hợp lắm ,mà em thì chưa bao giờ nghe và thấy nó nữa,không biết bác hai nghe amly này chưa nếu bác hai nghe rồi cho em xíu nhận xét về nó ạ.thạt sự em thấy nó trên ebay khoảng 460$ nhìn nó thì thấy đẹp và gấu lắm :D .nghe nói amly bose spatial có đường dùng cho 901.mong chờ ý kiến của bác hai.chúc bác hai khỏe.cảm ơn bác.
  14. Hai Lúa-USA
    Loa Bose ko có âm hình bác ạ vì cái mid range nó bắn tùm lum khắp nơi. Tôi chỉ nghe nó 1 lần nhà ông anh mà ko chịu nổi. Có thể Home Theater hợp hơn chăng?
  15. nghiact
    Cần Thơ
    Dạ, Em cám ơn Bác Hai Lúa-USA nhiều. Loa của em đã thay gân màu cam thành gân màu xám rồi, em rất thích mấy dòng Receiver MC Tosch cổ mode: 1900, 1700 không biết có hợp không bác?
  16. viethai1819
    viethai1819 Approved Member
    Shop VungTau Audio có đấy Bác
  17. binhpv79
    binhpv79 Advanced Member
    HPH->SGN
    chào bác 2Lua USA,
    Em có ông anh gửi về cho 1 cái amp Onkyo M504, cái này có đánh hợp với loa Diaton không bác nhỉ.
    Cảm ơn bác 2.
  18. Hai Lúa-USA
    Ko trã lời chắc chắn được bác ạ tuy tôi đoán hơn 90% là hợp :wink: 10% kia thì hi hi .. do tai của các bác. Tôi thường né các câu hỏi như loa này có hợp với amp kia hay ko, là vì các loại câu hỏi có tính chủ quan nên trã lời hơi khó. Trừ phi amp quá yếu mà méo quá nhiều, đa số tai chúng ta ko phân biệt được sự khác nhau khi nghe cùng 1 loa ở cùng 1 volume . Đây củng là lý do tôi nghi ngờ vào kết quả các loại testing mà các anh em trong này tổ chức để tìm amp ... vô địch. Trên nước Mỹ chưa thấy ai dám làm thế này :roll:
    Phối ghép đối với ý kiến chủ quan của tôi đó là 1 sự mò mẫm lâu dài và tùy thuộc quá nhiều yếu tố; mà 2 yếu tố quan trọng nhất là loa và phòng (bao gồm vị trí của loa, thiết kế phòng và vị trí người nghe). Chứ amp có hợp loa hay ko thì rất là thứ yếu, chỉ nên để ý khi nào các yếu tố chính đã hoàn hảo mà thôi.
  19. nghiact
    Cần Thơ
    Bác Hai ơi , nếu chọn giữa Mc1700 (hình như phần pre chạy đèn) và MC 1900 thì chọn cái nào để ghép cho jbl lancer 99 hả bác? Em thích âm mid mềm mại ngọt nào, bas ấm áp, trep dịu nhẹ không chói gắt.
    Bác tư vấn dùm em nhé, em đang phân vân giữa 02 cái này.
  20. Hai Lúa-USA
    Bác thử cả 2 mới biết rõ được tuy tôi nghiêng về cái mới và mạnh hơn là MC1900. Ngày xưa Mc làm cái Mc1700 lúc đó bán dẫn mới ra đời (như Fisher 800T) nên chỉ có tai các cụ mới cho là hay. :lol:
  21. thanhtien
    thanhtien Advanced Member
    Chào bác hai lúa, bác biết ở đâu có bán volume sansui 7070 không vậy (vừa công suất + balance), thanks
  22. music_lover
    music_lover Advanced Member
    Hanoi - Vietnam
    Không hiểu sao mấy cái receiver cổ và khủng này có sức lôi cuốn quá thể. Em đã định thôi không chơi nữa vậy mà hôm trước vừa khuân về cái Sansui 9090db thay cho cái Pioneer SX1250.
    Em để nghị bác Hai mở thêm cái topic cho Loa cổ và khủng nữa để anh em tập hợp cho vui.
  23. BTP
    BTP Advanced Member
    Vâng, E cũng đồng ý với đề xuất của bác music_lover.
    Con người khác mọi vật ở chỗ: con người ngày càng mất giá trị đích thực trong cuộc sống theo thời gian (nhất là về khoản..vốn nhân sinh), nhưng đồ vật thì khác: càng có giá trị theo thời gian. Vậy nên khi còn có giá trị thì sưu tầm vật có giá trị, kẻo sau này khi mất giá mà sưu tầm vật có giá thì giá trị đồ vật kia mất giá theo người mất giá :lol: (E nói với amp vô địch nhà E như vậy để E tiếp tục đi theo con đường đau khổ audio).
  24. phambinh
    phambinh Advanced Member
    Bác Hai cho em hỏi: Em đang cần đối tác cho JBL L-112 để nghe nhạc vàng (cả trước và sau 75)
    Bác recommned cho em vài cái tên của Reciver với nhé.
    Cám ơn bác,
  25. Hai Lúa-USA
    Cái này hình như là 250k ohm potentiometer. Bác tháo ra coi part number là gì rồi search Google thử sao. Theo tôi biết thì 7070/8080/9090 đều dùng chung 1 loại pot nên nếu được bác hỏi anh em bạn bè có ai có part này ko từ mấy cái máy hư rồi đó mà?
    Cái 9090 mà thay 1250 thì hơi uổng đó bác.
    Cái này nói nhiều rùi. Bác xem lại nhé.
