Review plasma samsung PS50B650
Discussion in 'Màn hình/Máy chiếu' started by evnd1, 18/5/09.
  1. Hien_SG
    Hien_SG Advanced Member
    Hi Bác
    Về việc Burn-in Plasma theo tài liệu nước ngoài là 200 giờ.
    Nhưng theo nhận định riêng của em , các TV đời mới đã có chức năng " PIXEL SHIFT" rồi thì cũng kô đáng ngại lắm đâu. Khoảng sau 100 giờ, Bác cứ chỉnh chọt hình ảnh vô tư đi.
    Vụ nầy Bác Hookman đã có nhiều kinh nghiệm lắm đó !
    Kính
  2. Hien_SG
    Có bài viết nầy về Plasma-TV em sưu tầm được. Bác nào rảnh, dịch hộ dùm . em nghỉ là hữu ích lắm:
    DIY Plasma TV Calibration
    Don’t do this when you are tired or pissed off because it can get you even more tired and pissed off (and I’m speaking from experience). Considering you are not tired nor pissed off let’s get cracking!
    Select the Mode
    If your plasma TV allows you to switch between different modes, you should do this first. Common picture mode settings are Normal/Standard, Movie, Film, Theater, Cinema, Sports, Pro, Professional, Pure, Dynamic and Vivid. You should avoid Sports and Dynamic and especially Vivid which will wear up your plasma TV screen faster and are highly probable to offer very incorrect and unnatural image reproduction. In worst case choose Normal/standard. If you have Movie, Film, Theater, Cinema, Pro, Professional or Pure choose one of those. Try each of them and see how the picture looks using different signals (SD TV channel, HD TV channel, DVD, HD DVD or Blue Ray). Depending on that and what you intend to watch on a regular basis choose a picture mode from the recommended ones.
    Disable Image “Enhancements”
    Many modern plasma TVs have settings that are supposed to enhance the image. Such enhancements have names like Autocolor, Color Correction, Autocontrast, Noise Reduction, Edge Enhancement, Detail Enhancement, Flesh Tone, Black Level, etc. Unfortunately, if you have a good video source, usually they do more bad than good. Do try each of them the same way as you did with the “mode” setting and see how they affect the picture. You might notice that on certain types of content they have a positive influence – for example in the case of standard definition TV channels (SDTV), noise reduction and edge enhancement might look better. Even if for some type of content they seem to do good, turn off all of them for the time you calibrate your plasma TV. You can later use them if you find them to improve the picture quality – and this may be the case with lower quality content as standard definition programs.
    Set Color Temperature
    Color temperature setting changes the look of the entire palette of colors. It is important you set this right before adjusting the following settings. The ideal color temperature is 6,500 degrees Kelvin (K). Changing this setting to Warm, Normal or Low preset (whichever you have) should result in a closer match with the ideal temperature. Again, play with all the setting available just so you see how they look. Do this with all settings from now so you see the differences.
    Brightness
    This is also called “black level” and it makes the image brighter or darker. Setting the brightness too low will result in loosing details in the dark areas of the picture (e.g. shadows, night scenes, etc.). Setting it too high will make the light areas and even the whole picture become washed out. You want to set this in such way that you get a good amount of detail from dark areas without making the picture washed out.
    Insert a DVD with a movie that has scenes with dark areas (you will probably want to pause where such a scene is) and set Brightness to maximum. Start decreasing the brightness gradually until you see the details in the dark area disappearing. Leave the setting at the minimum value where you get full detail in the dark areas.
    If your plasma TV doesn’t have very good black levels you might prefer trading detail in the dark areas for deeper darks. See what looks better for you, after all the calibration process should make YOU happy.
    If you bought a calibration DVD, this step will be more easy and accurate. I will explain this in the appropriate section of this guide.
    Contrast
    The contrast setting is also called “white level” or “picture level” and has to do with the amount of detail you see. Again use a DVD with a movie that has black and white (or very close to that) areas side by side. The border between the black and white areas should be very sharp as opposed to a smeared/blurry one. Go to a scene where you have a lot of white with impurities on it like a white shirt where you can see the fabric texture or a large area covered with snow where you see cracks in the snow or light shadows. The key is to have the contrast as high as you can while still seeing those cracks in the snow or the shirt texture. It should not become completely white; you should distinguish well the slight differences in color of the snow cracks and shadows.
    As in the case of brightness, the contrast setting is best adjusted using a calibration DVD.
    Color
    It is also called saturation and it controls how intense the colors are. A saturation of 0% (zero) means the picture appears black and white. A too high setting will make the colors look unrealistic. A too low setting will make the picture loose its impact making it look washed.
    This is a somewhat tricky setting because when you use it to make certain color tones look well it can make other tones look not that great. For example if you calibrate it correctly for skin tone you might end up with a setting value that makes the overall picture a bit unsaturated. If you make the picture look vivid, you might end up with skin that looks too redish like it would have sunburn.
    Use a DVD with a movie as usual, find a scene where you have a close-up on somebody’s face, ideally having other objects of various colors in the picture and adjust the saturation until that person’s skin looks natural but without making the other objects and colors look too faded and without life.
    Note that saturation can affect the three base colors (red, green and blue) differently. For example red might be too red while green or blue are more washed out. It is usually the case with red to be too saturated because it is enhanced by the plasma TV’s processing system.
    Tint
    You can play with it to see how it affects the image but it should be left at 50%. If you are using a calibration DVD you have chances of using this correctly, otherwise you will just mess things up.
    Sharpness
    If you have a sharpness setting you should leave it turned off when you watch high quality content as HD DVD, Blue Ray or regular DVDs and high definition TV programs. Applying the sharpness filter on a high quality image will make it look unnatural. When you watch standard definition programs or low quality content from other sources you can try it because it will probably enhance them a bit. Remember that a plasma TV, as well as any HDTV for that matter, is great at watching high definition content but for SD content it will probably enhance the flaws in the picture. The expression garbage in, garbage out comes in mind.
    Edge Enhancement
    Again it is a good idea to turn this off. This is somewhat a variation of the sharpness filter because it does the same thing (makes the image look sharper) but it’s supposed to be smart enough to sharpen (enhance) just the edges of the objects in the picture. It is also called VSM or SVM (Scan-Velocity Modulation).
  3. oldgaming
    oldgaming New Member
    Mấy anh confirm dùm em con Samsung 50b650 này ở VN sx có bị lỗi xử lý source 1080p/24 không ạ.Em đọc trên cnet thì họ nói con này lúc chuyển wa Cinema Smooth trong Film Mode ->black level sẽ thay đổi cho fù hợp.Nhưng khi chuyển wa mode khác thì nó ko chuyển black level lại bình thường.
  4. quacachua
    quacachua Advanced Member
    Re: plasma samsung 50 inches chọn HD ready hay full HD?
    Bác cứ quá khen SS chứ em dị ứng với hãng này.
    Nói thật nhé, ông bạn thân ôm liền 2 con 37'' và 42'', xem được mấy hôm con 42'' làm cái bụp, khét lẹt. Cái này tận mắt em chứng kiến thì còn sai vào đâu được.
    Vậy là biết chất lượng thế nào rồi. Đến nhân viên của mấy hãng điện tử đó còn không dám dùng. Bác cứ hỏi họ xem nó nhập hàng ở đâu để ráp?
    Đừng vì cái ngoại hình mà đổ tiền đi. Nó chỉ là cái vỏ nhựa thôi mà. Chức năng thì nhiều nhưng thử hỏi có dùng hết không? Các hãng khác chắc họ biết mà họ không làm được???? Công nghệ bây giờ tất cả các hãng đều tương đồng, cái còn lại là chất lượng mà thôi.
    Thấy bác so sánh em buồn cười quá, cứ như đem xe TQ với xe Nhật.
    Kính các bác trót mua rồi cố mà xem, đừng Review kiểu xinh xinh ngon ngon lên đây rồi có ngày nó làm cái bụp 1 cái thì có mà vỡ nợ.
    Tham khảo
    http://www.anninhthudo.vn/Tianyon/Index ... annelID=80
  5. Schumacher
    Schumacher Advanced Member
    Chắc là bác Cà Chua đang dùng Pioneer KURO ạ? Bác ở đâu để hôm nào anh em đến mở rộng tầm mắt với ạ?
  6. Hien_SG
    Chào Bác
    Lâu rồi mới thấy có ý kiến phản biện trong Topic nầy.
    Em xin có vài lời như sau:
    -TV em và các Bác khác mua đều là TV mua chính hảng và có bảo hành 2 năm. Loại TV hàng phế thải, trôi nổi như cái link Bác đưa ra thì đố ai dám sờ vào, nên miễn bàn ở đây.
    -TV mới mua, nổ cái bụp khét lẹt, thì kêu bảo hành ( Hảng nào mà chả có sản phẩm bị sự cố). em xài hết 3 đời TV của SS rồi thấy có "nổ cái bụp khét lẹt" gì đâu? Trong Topic nầy có Bác nào bị "nổ cái bụp khét lẹt" chưa ? thông báo tí nào .
    -Công nghệ em đang thích thú ở đây là USB-Movies. Bác đơn cử 1 cái TV nào đang bán ở VN: 50" Full-HD có công nghệ nầy mà giá từ 22 đến 25 tr xem? em thấy giá tiền TV nầy là hợp lý với cái túi bèo nhèo của em, nên mua xài. Bác Quacachua cũng đừng dùng lời chua chát vậy, em tủi thân quá đi mất.
    -Việc các Bác khoai tây có review tốt cho cái TV nầy , em đưa ra là để chứng minh: Trên thế giới người ta cũng công nhận cái tốt của nó, chứ kô phải riêng em công nhận. Rồi ai cảm thấy thích, cứ mua mà xài, em đâu phải là nhà phân phối, hay bán hàng gì đâu mà phải quảng cáo cho nhiều.
    Đương nhiên khi có nhiều anh em cùng dùng chung 1 loại sản phẩm, thì sẽ dễ dàng có cơ hội chia sẽ kinh nghiệm , kiến thức xử dụng, nâng cấp ...điều nầy là tốt cho cộng đồng.
    Vài dòng chia sẽ
    Kính
  7. quacachua
    Cái này là em đánh giá khách quan vì những lý do sau:
    - Em đã dùng qua đời SlimFit từ ngày đầu, hình ảnh thì tạm nhưng cái nguồn thì kêu o o kinh khủng, nhất là về đêm đi ngủ mới thấy rõ.
    - Cái TV của bạn em nổ bụp đó là mua chính hãng có bảo hành hẳn hoi, mới dùng được khoảng 1 tháng thì hỏng. Nói thật chuyện đó rất hiếm khi sảy ra nhưng khi đã xảy ra thì đương nhiên phải đặt dấu hỏi thật to "VÌ SAO?"
    - Bạn em là người có tiền nhưng theo chiều hướng tiết kiệm nên mới vác 2 em SS về để phòng ngủ 1 cái phòng karaoke 1 cái nhưng bây giờ thất vọng về hãng này rồi.
    - Em chưa diện kiến KURO và không có nhiều tiền nên việc đưa ra quan điểm ở đây nhằm cho các bác và cả em có những đánh giá đúng khi bỏ đồng tiền ra vì nói thật làm ra tiền khó lắm, mà cái TV đó trên 25T đâu có rẻ, tầm tiền đó ngang ngửa với việc sắm gần đủ các thiết bị gia dụng khác rồi.
    - Theo em nên sài hàng nhập khẩu. Không phải vì không ủng hộ công nghiệp lắp ráp trong nước mà cái chính là chất lượng linh kiện thật sự không đáng với tiền của mình. Đơn giản như bác nào vào siêu thị thấy có cả giấy ăn cũng nhập khẩu, tại sao họ bán được?
    - Đồng ý với bác 1 việc là bác chọn Plasma, vậy thôi.
    Tiền thì của các bác chứ của em đâu nhưng nó là sức lao động đấy chứ.
    Chúc các bác khoẻ và cân nhắc thật kỹ khi mua đồ.
  8. vunn
    vunn Advanced Member
    Thủ đô Kangaroo
    Có bác nào xài SS PS63B680 chưa, xin cho em ít review. HÔm trước đi ra showroom coi thấy đã quá.
    VNN
  9. clavinova
    clavinova Advanced Member
    Ha Noi
    Cái 50 inchs Full-HD này giá thế là tốt, em cũng tin rằng xem rất đẹp, không nghi ngờ (Mặc dù chưa xem :D ).
    Nhưng đúng thật là bỏ tiền ra mua Samsung thấy cũng hơi sợ sợ 1 chút. Cũng là người thật việc thật, em có 2 ông bạn chết Plasma Samsung rồi, toàn vào đúng lúc vừa hết bảo hành, mà trước đây mua Plasma 50" đâu có rẻ. 1 ông thì điên tiết xót xa quá định làm ầm lên nhưng cuối cùng lại thôi vì thấy mình cũng chẳng có lý gì (Bọn bảo hành bảo thay panel, mà thay có khi đắt hơnmua tivi mới). Còn thì những bác chết LCD, Plasma Samsung có đưa thông tin lên mạng thì nhiều vô kể rồi, không nói.
    Cũng là Korean company nhưng em chưa được thấy sản phẩm của LG chết như vậy, thế mới lạ. Cũng không thể nói được rằng Samsung bán nhiều hơn thì chết nhiều hơn, bán nhiều hơn một chút nhưng tỉ lệ chết quá cao so với tất cả các hãng khác. Khó hiểu quá.
    Vậy nên Plasma là cứ cố gắng Panasonic, hy vọng ít rủi ro hơn SS.
  10. cunmap
    cunmap Advanced Member
    Hay trong tầm giá chắc áp dụng trong trường hợp này bác nhỉ! :wink:
  11. dunlopillo
    dunlopillo Advanced Member
    Tôi nghe mấy bác chê Samsung cũng như chê xe Hyundai/Kia là: Một, quá ít cập nhật thông tin. Hai, sính "Nhật" mặc dù chưa dùng đồ Hàn xẻng. Mấy cái loại TV đời ơ kìa của Samsung không bàn ở đây vì công nghệ lạc hậu.
    Tôi dùng Pioneer 436 từ năm 2005, máy chiếu 720P Z5 cũng chơi từ năm đấy. Năm ngoái tôi có mua 1 con Sony SXRD 60 inch và cách đây độ 1 tuần có mua con Samsung PS50B650. Tôi có thể khẳng định các bác yên tâm mà dùng. Độ 2-3 năm lại đây, Nhật bây giờ đang đau đầu vì Hàn rồi các bác ạ vì chất lượng càng ngày càng khẳng định. Samsung và Hyundai đã lọt vào top 100 hãng được nhận dạng thương hiệu. Con TV này quá ổn so với giá. Dân Mỹ cũng dùng ầm ầm. Các bác vào AVS forum à xem, thread về Samsung quá nhiều.
    Bây giờ toàn cầu hóa. Cách đây 1 năm, Sony còn dùng Panel LCD do Samsung làm cơ mà. Tôi đồng ý có điều kiện thì mua Nhật nhưng các bác có biết cái TV LCD Sony X, Sony Việt Nam nó bán gấp 2-3 lần ở Mỹ, ta có nên mua không trong khi Samsung bán gần như tương đương ở thị trường Mỹ?
  12. dunlopillo
    Sao tôi chạy TVIX, phim nén 1080p, tôi kích hoạt 1080 24p ở TVIX, chức năng smooth cinema kích hoạt được nhưng HDMI black level thì mờ không chạy. Hay phải đúng BR mới kích hoạt được HDMI black level nhỉ?
  13. quacachua
    Bác hơi nhầm :lol:
    Cái em nổ cái bụp lại là em hot 42'' của SS cách đây mấy tháng.
    Mà thôi, bàn luận với bác thế là đủ. Góp ý cũng thế là đủ.
  14. clavinova
    Ha Noi
    Em chả coi thường Samsung cũng như Kia, Hyundai. Dạo này thấy con Kia Forte đẹp thế, đang thèm đây. Mà cũng đã bảo giá tốt, hình đẹp rồi cơ mà.
    Thế nhưng sao Plasma Samsung nó hay chết đột tử thế, toàn rơi vào người quen của mình, thế trong trường hợp của em thì nói chung là có nên bị ảnh hưởng tâm lý và định kiến không? Bác nào phân tích về sự hay đột tử của nó cái thì hay.
    Mà chú Samsung này đang hot nhưng sắp tới trên diễn đàn này sẽ có 1 "ngôi sao" nữa nổi bật hơn nhiều đó. Em chắc thế, ngon bổ rẻ, thương hiệu lắm các bác ui !!! hehe.
    Đó là ...
  15. clavinova
    Ha Noi
    Bác đun lốp thông cảm, đa số anh em còn nghèo mà cái chính sách chăm sóc khách hàng ở VN này nó tệ bạc quá nên anh em mới đắn đo do dự, hay nghĩ đến "tuổi thọ" của sản phẩm là thế. (nghe bác nói mua 436 và Z5 từ 2005 thì em hãi rồi :) ). Cách đây 2 năm đã có 1 vụ người ta đập 1 Plasma SS trước trạm bảo hành của hãng gây xôn xao 1 dạo..., rồi thì dòng LCD F81 đỉnh cao 1 thời là dòng bị lỗi, hãng cũng công nhận...
    Nhưng thực tế, một phần em không thiện cảm với SS và LG cũng là vì bọn chúng "nổ" to quá, các thông số kỹ thuật thường hay phóng đại cho người ta khiếp, cùng 1 sản phẩm, ở thị trường phương tây thì 1 thông số, VN 1 thông số khác to hơn nhiều. LCD thay đèn nền bằng LED thì cố tình gọi là LED Tivi để gây chú ý và nhầm lẫn ở 1 số lớn người tiêu dùng chưa biết thật sự LED TV là thế nào (cái này khiến thằng Sony phải lên tiếng). Đó là chưa kể các cài đặt màu sắc (không cho người thường can thiệp) thường để quá rực rỡ chói lòa, chẳng dịu dàng chân thật như thằng Nhật... mà em thì ghét những cái như thế.
    Ấy nhưng mà nếu bác đun lốp nói riêng và dòng Samsung mới ra hiện nay nói chung dùng vài năm chưa hỏng, không bị lỗi nữa thì có lẽ em sẽ dần thay đổi quan điểm. Ít ra là như vậy chú như bác nói, mới mua được vài tuần mà khẳng định là nó tốt, sẽ không sao đâu thì em e rằng sự khẳng định đó là hơi sớm và chưa đủ căn cứ.
    Dù sao 50 inchs Full HD của Samsung đẹp và rẻ vậy đối với em là tin vô cùng vui vì nó ngầm nói với em rằng: Panasonic sẽ không để Samsung làm vậy lâu, là nhà sản xuất Plasma hàng đầu, họ sẽ có những câu trả lời tuyệt vời, có lợi cho người dùng ngay bây giờ thôi.
    Và đã lấp ló rồi đấy các bác...
  16. dunlopillo
    Các bác không nên lấy hiện tượng để suy ra bản chất. Mới chỉ vài cái của người quen bác hỏng mà bác đánh giá là nó hay lỗi là chưa đúng. Tôi mua hộ cho bạn bè và gia đình anh chị em cỡ gần 10 cái LCD và 1 cái plasma Samsung cỡ 2 năm nay nhưng chưa một ai bị hỏng. Hồi năm 2005, con plasma 435 của tôi còn bị lỗi phần mềm, không bật lên được, phải vác qua Hồng Công để sửa. Sau tôi để cho ông bạn và đổi con 436. Tôi cũng có đánh giá là Plasma PIO là chất lượng kém đâu. Quan trọng là tỉ lệ xác suất lỗi trên 1000 sản phẩm là bao nhiêu. Trước đây, nếu là thời CRT, Samsung thua xa Sony. Nay gần nhiều rồi.
  17. dunlopillo
    Cái quan điểm về màu sắc rực rỡ cũng khác rồi bác ạ. Tôi thấy LCD của Sony màu cũng rực bỏ xừ. Các bác cứ vào AVS mà xem người dùng họ đánh giá về chất lượng plasma Samsung thế nào, trên cả thế hệ 10 của Pana. Về plasma hiện tại chỉ còn 2 đại gia lớn là Pana và Samsung. Chúng ta sẽ được hưởng lợi của việc cạnh tranh của hai ông này. Nói thật, tôi dùng rất nhiều đồ điện tử nhưng hai cái hỏng là 1 con TV 29 LG từ rất lâu (hỏng thạc anh phần tiếng) và con PIO 435 (bị lỗi phần mềm)
    :lol:
  18. dunlopillo
    Việc recall của các hãng cũng là bình thường. Toy, BMW, Mer vẫn thỉnh thoảng recall sản phẩm. Tôi thấy đấy là trách nhiệm cao của nhà sản xuất khi thông báo lỗi sản phẩm và khắc phục miễn phí. Nếu có lỗi họ dấu nhẹm đi thì đáng trách.
  19. dunlopillo
    Cái thông tin mà bác quacachua đưa chả liên quan gì đến chất lượng của Samsung mà phải hiểu là cẩn thận khi đi mua hàng điện tử của Samsung, không mua phải hàng lỗi của hãng đã bị loại. Cái này do các cá nhân thông đồng, khi đem hàng đi tiêu hủy lại bán các sản phẩm đó, làm hại người tiêu dùng. Các bác mua hàng có bảo hành đàng hoàng. Có gì mà ngại.
  20. Hien_SG
    Thôi các Bác à
    Tập trung vào chuyên môn đê
    Thông báo : đã có 2 FW mới cho TV B650 , các Bác nào thích nâng cấp thì load về xài nhe:
    FW 1010.1
    http://org.downloadcenter.samsung.com/d ... L7DEUC.exe
    FW 2001.0
    Có Bác dùng FW 1010.1 xong báo lại rằng nó đọc được các file MKV mà FW 1004.5 kô đọc được. thử xem sao các Bác.
    Tiện đây cũng xin báo luôn là các FW có mã số T-CHL7DEUC thì đều dùng chung cho các dòng TV sau của SS:
    -LCD dòng B650 B750
    -Plasma dòng B650 B680
    Kính báo
  21. Hien_SG
    THÔNG BÁO:
    V/V Kiểm tra lỗi " DEAD PIXEL" Trên TV Samsung
    Khi đi mua TV , muốn kiểm tra lỗi " chết điểm ảnh " trên panel TV. Nhưng ngặt cái đang ở Siêu thị, kết nối với Laptop của mình mang theo để kiểm tra cũng kô tiện. Làm sao đây?
    Mách nước nè:
    Mượn cái remote của ông bán hàng. Sau đó thao tác thật nhanh các bước sau:
    -TV ĐANG Ở CHẾ ĐỘ CHỜ.
    -Nhấn trên Remote lần lượt các phím: INFO-->MENU-->MUTE-->POWER.
    -Màn hình Service menu hiện ra: tại cửa sổ CONTROL nhấn enter-->TEST PATTENRT-->enter-->LOGIC PATTENRN SEL--> nhấn mũi tên phải nhiều lần để chọn các chế độ test màn hình (quá nhiều kiểu để test).
    Sau khi test xong nhấn nút POWER để tắt .
    Ngoài ra trong menu test nầy còn có các ứng dụng dùng để sửa chửa màn hình đã bị " cháy điểm ảnh " rất thú vị.
    Thử xem sao các Bác
    Kính báo
  22. Schumacher
    Em xin up thêm mấy cái ảnh lởm về 50B650 của em ạ:
    Em chụp bằng phone nên ảnh không đẹp lắm. Em nghĩ là với mức giá của SS thì chắc là không có sự lựa chọn khác tốt hơn. Còn nếu các đầu tư nhiều hơn thì không nói làm gì. trên SS thì Panasonic, trên Panasonic thì Pioneer chẳng hạn.
  23. Hien_SG
    Hi Bác Schumacher
    Là Bác khoe cái TV của Bác, hay Bác khoe cái " cô kô mặc áo" trong TV?
  24. Schumacher
    Em khoe cái phone lởm của em có máy ảnh đấy bác ạ :lol:
  25. Hien_SG
    Thắc mắc không biết hỏi ai:
    Lúc mua con TV B650. về nhà em tự kiểm tra thì thấy có chết 1 điểm ảnh. nhưng em nghỉ 1 điểm ảnh có chết thì cũng kô ảnh hưởng gì đến hòa bình thế giới, nên thông qua lun.
    Xử dụng TV khoảng vài ngày sau, kiểm tra lại thì : Điểm ảnh chết đó đã kô còn nữa. tức là panel TV toàn vẹn pixel 100%.
    Bác nào có thể giải thích hộ em trường hợp hồi sinh nầy là thế nào kô vậy?
    cảm ơn nhiều
