ROON - Phần mềm chơi nhạc đa năng trên PC và MAC
Discussion in 'Nguồn phát từ máy tính' started by Gsduc, 26/2/16.
  1. Wingman
    Wingman Advanced Member
    In the Sky
    giaphongn likes this.
  2. Scorpio
    Scorpio Moderator
    VNAV
    Em vừa lên bản 1.3 build 269.. có vẻ mượt hơn !!!!
    Brigde cũng đang tự chạy update lên bản mới
    Bug Fixes and Performance Improvements in Roon Build 269:
    • KEF LS50 Wireless Support
    • Support Infrastructure improvements
    • Track delete flow includes additional checkbox confirm
    • DSP presets sort properly
    • Social sharing fixed on android
    • Fixed a crash in some Roon Ready devices when Cores are rebooted
    • Remote reconnects properly after Roon Server on win7 is rebooted
    • Optimizations to RAAT stream start behavior to increase stability on low-performance devices
    • Fixed bug preventing Tidal sync from completing due to a broken playlists
    • New channel mapping behavior for RAAT on Linux in 5.0 and 5.1 layouts–should help with HDMI
    • Sonos: stability improvements.
    • Issue preventing automatic rescan of some folders resolved
    • HQ Player: PCM playback no longer fails if the previous track was DSD
    • Fixed inaccessibility of multi-channel settings for exaSound users using ASIO on Macs
    • Empty watched folders automatically set to “offline”
    • Better copy for ‘Show Hidden Tracks and Albums’ option
    • Fixed issue adding a local track to a playlist using 3 dot menu in the Track browser
    • Fixed bad options on 3 dot menu on Track browser
    • Backup: “Canceled” status for manual backups can be reset
    • Backup: ‘Stop’ button no longer crashes
    • Backup: restore from dropbox works if internet connection was interrupted
    • Backup: doesn’t loop if backup period is set to 26 days or more
    • Backup: issue backing up to dropbox fixed
    • Backup: Fixed issue restoring from Dropbox
    • Backup: better error handling when drive is full
    • Backups: Fixed crash with “View backups”
    • hide “System Volume Information” and other hidden folders from roon file browser
    • Export no longer misbehaves in case interrupting network connection on the core
    • Allow setting of output name in api
    • Roon API consistently sends zone changed messages after transfer
    • System output mute setting respected after re-enabling the zone
    • Fixed issues that set volume to max even when ‘Max device volume at Playback start’ isn’t used
    giaphongn and Wingman like this.
  3. Scorpio
    Scorpio Moderator
    VNAV
    Bác thử cài Archphile cho C2...bản này cũng đã customizing khá tốt rồi
    Cài thêm roonbridge nếu chưa có
    http://archphile.org/
  4. Wingman
    In the Sky
    P_20171023_095226_vHDR_Auto.jpg P_20171023_094518_vHDR_Auto.jpg Em vừa làm tí tăng lực cho DietPi: AudioQuest JitterBug USB Filter.
    Trước khi test em nghe những bài quen thuộc, tắt khoảng 15 phút, sau đó cắm JitterBug vào và nghe lại tất cả các bài đó. Sự thay đổi không rõ ràng như khi thay dây Ethernet, nhưng cảm nhận được ngay. Treble bớt hẳn sibilants mà vẫn chi tiết, tiếng các nhạc cụ tách bạch hơn, đặc biệt tiếng bass rộng hơn đồng thời cũng chặt hơn, mở âm lượng lớn thoải mái thư giãn không căng thẳng. Tóm lại đáng chơi trong tầm tiền View attachment 249250 View attachment 249251 . Em đang đợi Uptone Regen về thành combo tăng lực. :)
    Chúc cả nhà tuần làm việc mới hiệu quả và thành công!
    tml3nr, Scorpio and giaphongn like this.
  5. giaphongn
    giaphongn Advanced Member
    Tăng lực của em. Nhưng tai trâu không / chưa cảm nhận được gì khác biệt :D
    Wingman and tml3nr like this.
  6. Haolq
    Haolq Advanced Member
    Hôm trước em đăng ký thử và vài hôm sau đã logout và uninstall rồi sao nó còn gửi thư nói trừ tiền mình trong thẻ nhưng do thẻ hết tiền nên nó không trừ được. Làm thế nào để nó khỏi trừ tự động vậy các cụ ?
    tieuphi2006 likes this.
  7. Wingman
    In the Sky
    Bác phải cancel bản trial mới đúng quy trình, nếu bác chỉ logout và uninstall thì Roon vẫn tính là bác đang dùng thử, sau 14 ngày sẽ tự động trừ tiền trong tài khoản của bác.
    tieuphi2006 and giaphongn like this.
  8. Wingman
    In the Sky
    Bác thử nghe một thời gian dài có thuốc tăng lực, sau đó bỏ thuốc ra xem có gì khác không. :)
    tml3nr and giaphongn like this.
  9. giaphongn
    Vụ này không có bác @Wingman cảnh báo trước thì em có lẽ cũng bị trừ. Nhưng hình như nếu bác mua lifetime thì nó cũng trừ cho bác khoản này thì phải (chỉ trả them phần còn lại)
  10. giaphongn
    Em đồ rằng hình như sợi dây USB của Schiit từ máy tính đến thuốc chưa tương xứng, nhưng em chưa có điều kiện thay cọng khác :D
  11. Wingman
    In the Sky
    Bác thay dây USB của Supra hoặc Furutech Formula 2(đừng lấy GT-2 Pro), chưa cần thêm nhiều tiền đã khác ngay.
  12. mtbc
    mtbc Advanced Member
    Q3, Saigon
    Nghe mộc thì Supra, còn nghe hơi ẻo lả mềm mại thì Formula 2 ;)
  13. Wingman
    In the Sky
    Supra dùng cho Roon, Onkyo HF Player, JRiver; còn Formular 2 dùng cho Foobar. ;)
    mtbc likes this.
  14. giaphongn
    Em có sợi Wireworld Starlight 7 (1m) thấy cũng ổn, chưa dùng qua Supra hay Furutech. Bác nào đã dùng qua cả 3 loại cho em xin them vài dòng so sánh ạ
  15. Wingman
    In the Sky
    Em chưa trải nghiệm dây USB Wireworld Starlight 7. Supra và Furutech Formular 2 đều ổn trong tầm tiền, tùy gu nghe. Em thích Supra hơn Formula 2 ở nhạc tính, tuy nhiên độ tĩnh của dây USB Supra chưa phải hoàn hảo.
    Cá nhân em đề cử Nordost Blue Heaven LS, cực tĩnh lặng, chi tiết, tách bạch, không gian tốt, giá cả hợp lý, có thể chơi lâu dài. Munich Hi-end Show 2017 có bộ vẫn dùng dây USB Blue Heaven LS để set up.
  16. dnh
    dnh Advanced Member
    Hải phòng-TP.HCM
    Bác Scorpio ơi cho em vài đường chỉ dẫn để cài Archphile lên C2 với ạ, em loay hoay mãi mà không được. Xin cám ơn bác nhiều.
  17. Scorpio
    Scorpio Moderator
    VNAV
    Em thấy cài cũng giống pi mà
    Download image Archphile C2: https://sourceforge.net/projects/archphile/files/odroidc2/0.99.6-beta/
    Dùng chương trình ghi thẻ như Win32DiskImager (https://sourceforge.net/projects/win32diskimager), Etcher (https://etcher.io/)... ghi img này lên thẻ miniSD
    Cắm thẻ vào C2 và đóng điện
    https://wiki.odroid.com/odroid-c2/gettingstart/linux/install_linux
    Cài Roon Bridge
    SSH vào C2 với
    username : root
    pass: archphile
    Chạy 3 lệnh này
    curl -O http://download.roonlabs.com/builds/roonbridge-installer-linuxarmv8.sh
    chmod +x roonbridge-installer-linuxarmv8.sh
    sudo ./roonbridge-installer-linuxarmv8.sh
    tieuphi2006 and tranman like this.
  18. lmcuong4u
    lmcuong4u Advanced Member
    Chào các bác hội Roon!
    Em chạy Roon core trên máy tính và remote bằng ipad.
    Em chơi bằng Dac của bác giahuy, xuất usb vào board Amareno.
    Trong phần device Setup vẫn hiện ra bảng thông báo như của các bác (hình dưới em mượn của bác @giaphongqn ạ). Của em nó báo nhận được DSD512 luôn.
    Nhưng em không tìm được chỗ để upscale file lossless lên DSD ạ. (Dac của em chỉ nhận file DSD thôi).
    Các bác giúp em với ạ!
    Em thích chơi theo Folder mà thằng Roon này tìm mãi không thấy...
  19. giaphongn
    Hình không xin bản quyền nên không post được :D
    lmcuong4u likes this.
  20. dnh
    dnh Advanced Member
    Hải phòng-TP.HCM
    Em ghi file img lên thẻ và cắm vào C2, đóng điện thì chỉ thấy con LED xanh chớp chớp mấy cái rồi sáng hoài luôn. Seach hoài không thấy IP. Đã cài lại mấy lần vẫn không được bác ạ:(
  21. Scorpio
    Scorpio Moderator
    VNAV
    Bác thử cái Volumio xem có chạy được không: https://volumio.org/get-started/
  22. welldonehd
    welldonehd Advanced Member
    TPHCM
    Sợi usb của Schiit PSYT nghe chán! Thay đi bác.
  23. giaphongn
    Thay sang loại nào bác tư vấn giúp em. Em thì cũng thích Wireworld Starlight 7 rồi đấy, nhưng không rõ tầm giá đó có loại nào xuất sắc hơn không. Hơi ngại chờ đợi vì lại phải mua qua amazon
    duckim likes this.
  24. welldonehd
    TPHCM
    Mua cái uspcb của bọn Uptone cũng đc!
  25. lmcuong4u
    Cụ @welldonehd giới thiệu chưa tới nhé!!!!
    giaphongn and welldonehd like this.
