Cặp loa này thì có thông số KT như sau: HF unit 25 mm silk fabric dome, antireflection pole Ferrofluid cooled and damped. Magnetically shielded MF unit 130 mm chassis, alloy cone, with 32 mm coil, high-power, long-throw magnet system. Magnetically shielded lightweight alloy cone, pure piston driver with 32 mm coil, high-power, long-throw magnet system. Magnetically shielded LF unit 180 mm vented polymer chassis, critically shaped polypropylene cone, with long-throw magnet system. Magnetically shielded Crossover 3-way, 8 element 12dB/octave slope at 350 Hz and 3.2 kHz. High power inductor for bass. High quality OFC wire to drive units Power handling 30 – 150 watt max Overall frequency response 33 Hz – 22 kHz (38 Hz – 20 kHz ±3 dB) Sensitivity 90 dB/1 w/1 m Impedance 8 ohm Cabinet 15 mm MDF, full circumferential brace, gas-flowed, low-turbulence bass reflex ports. 25 mm MDF front baffle. Mass loaded Terminals Gold-plated bi-wireable binding posts Weight (excl. packaging) 16 kg each Dimensions (WxHxD) 192 x 880 x 220 mm
