Sansui 607 anpha Most premium
Discussion in 'Thiết bị khuếch đại' started by duonganh2004, 6/3/06.
  1. ngtatliem
    ngtatliem Advanced Member
    C.S.J
    Bác muốn nghe chất âm của dòng SANSUI Mosfet mà công suất lớn hơn thì tìm thằng SANSUI AU- alpha 607 MOS Limited.
    thông số của 2 em nó đây:
    Type Super audio amplifier
    < Power amplifier section >
    Frequency characteristic (1w) DC - 300kHz +0dB and -3dB
    Effective output
    (10Hz - 20kHz and both channel simultaneous operation) 75w + 75w (6 Omega)
    50W + 50W (8 Omega)
    Total height harmonic wave distortion factor (at the time of effective output) 0.008% or less (8 Omega)
    Cross modulation distortion factor 0.008% or less (8 Omega)
    Damping factor 150 (8 Omega)
    Input sensitivity / input impedance (1kHz) 1v/10k Omega
    SN ratio (A network) Above
    Dynamic power 100W (2 Omega)
    95w (4 Omega)
    75w (6 Omega)
    TIM strain (SAWTOOTH) Below measurement limiting value
    Through late 180V/ mu sec (8 Omega)
    Rise time 0.6 Mu Sec
    < Pre- section >
    Frequency characteristic (1w) CD, Tuner, DVD/LINE, Tape-1/MD and Tape-2:
    Phono mm: 20Hz - 20kHz }0.2dB
    Input sensitivity / input impedance (1kHz) Phono mm: 2.5mV/47k Omega
    Phono MC: 300 mu /100 Omega
    CD, Tuner, DVD/LINE, Tape-1/MD and Tape-2: 150mV/20k Omega
    Phono maximum permissible input Mm (THD 0.01%): 210mV
    MC (THD 0.1%): 21mV
    SN ratio (A network) Phono mm: Above
    88dB Phono MC: Above
    70dB CD, Tuner, DVD/LINE, Tape-1/MD and Tape-2: Above
    Tone control Bass maximum change quantity: }6dB (50Hz)
    Treble maximum change quantity: }6dB (15kHz)
    Sub sonic filter 1C$6hz (-3dB), 6dB/oct
    Loudness +6dB (50Hz)
    +4dB (10kHz)
    < Synthesis >
    Rated electric power consumption 170W
    Signalless electric power consumption 52w
    External size Width 466~ height 162~ depth 452mm
    Weight 22.5kg
    SANSUI AU- alpha 607 MOS Premium
    Type Integrated amplifier
    Effective output
    (10Hz - 20kHz and both channel simultaneous operation) 55w + 55w (6 Omega)
    45w + 45w (8 Omega)
    Input sensitivity / input impedance (1kHz) 1v/5k Omega
    Dynamic power 70W (6 Omega)
    85w (4 Omega)
    90W (2 Omega)
    < Pre-amp section >
    Phono MC: 300 mu V/100 Omega
    CD, Tuner, Line and Tape/DAT-1, 2 and 3: 150mV/20k Omega
    MC (THD 0.1%): 21mV
    Frequency characteristic (1w) Phono mm: 20Hz - 20kHz }0.2dB
    CD, Tuner, Line and Tape/DAT-1, 2 and 3: DC - 200kHz +0dB and -3dB
    70dB CD, Tuner, Line and Tape/DAT-1, 2 and 3: Above
    Loudness +4dB (50Hz), +4dB (10kHz)
    < Synthesis >
    Rated electric power consumption 160W
    External size Width 460~ height 159~ depth 446mm
    Weight 18.8kg
  2. Zorro
    Zorro Advanced Member
    Saigon
    Theo em được biết công suất của sò mosfet trong amp. Sansui luôn nhỏ hơn sò fet (có cùng đẳng cấp). Nếu em nhớ không nhầm thì công suất của 607mos Ltd là 40w/chanel.
    Thân.
  3. tranhung
    tranhung Advanced Member
    Sài Gòn
    Cách đây 1 tháng mình mua SANSUI AU- alpha 907 DR giá 5.000.000 ở Nhật Tảo.
    to: ZORRO. Em mới mua 1 con DENON DCD 3500G. Hôm nào rảnh mời anh ghé nhà nghe thử.
  4. caithang
    caithang Advanced Member
    Giá vậy hợp lý quá bác ơi, chắc mặt đen, hình thức + chất lượng được không, bác ghép với loa gì vậy
  5. tepriu
    tepriu Advanced Member
    hi bác tranhung
    em cũng đang để ý SANSUI alpha 907 dr,kx,mr mà chưa được nghe thử.bác cho em xin vài lơì nhận xét về em nó được không bác.
    nếu được khi nào bác có thời gian bác cho em wa nghe thử tý thì tốt nhất,các cao thủ vẫn thường khuyên như zậy ,em xin cảm ơn bác trước thật LỚN, chúc bác zui
  6. Zorro
    Saigon
    Chúc mừng Hùng có 2 món đồ chơi mới, 2 em này mình đã xài rồi, nhưng con Denon là 3500RG, chứ không phải 3500G như của Hùng.
    Hôm nào rảnh, mình ghé nghe nhé.
    Thân.
  7. tranhung
    Sài Gòn
    Hivuabidiec
    Hôm trước mình mua con SANSUI alpha 907 i ( không phải DR ) nhưng mình đưa cho thằng bạn dùng. Nếu bạn muốn nghe thử thì hôm nào qua nhà anh bạn mình nghe thử. Nhà anh bạn bên Cư Xá Thanh Đa.
    Về âm thanh thì mình cũng không rành lắm, chỉ thấy nghe con SANSUI alpha 907 i thì thấy tiếng Bas rất chắc, tiếng chép nghe thánh thót, còn tiếng MID thì mình chịu ( hổng biết hình thù tiếng MID nó như thế nào. hihihi )
  8. tepriu
    cảm ơn bác tranhung rất nhiều.
    nhà em có cặp B&W 602s3 đang ghép với MARANTZ SR 5400,nay muốn mua thêm AM stereo để nghe nhạc 2ch, mà ngân sách cho phép chỉ có 8m thôi,vì vậy em cũng đang quan tâm dòng SANSUI alpha 907 dr,kx,mr,
    các cao thủ audiophile có bác nào đã chơi qua 602s3 ghép với AM hiệu gì, model nào thì phát huy tối ưu với đôi loa này,cho em xin vài lời vàng ngọc
    em nghe nhiều loại nhạc trừ pop,roch,dance, em xin cảm ơn các bác nhiều , chúc các bác zui
  9. Hincaca
    Hincaca Advanced Member
    Bác không để ý rồi nó đây nè:
    http://www11.plala.or.jp/se_ke5583/SANS ... ntage.html
  10. nguyenstyle
    nguyenstyle Advanced Member
    Băng Nhà hát
    Các bác ơi, Sansui AU-X111 Mos Vintage ở mình bán độ bi nhiêu xiền nhỉ? Có bác nào bán em này ko ạ? Đứa em e nó thích, e đang tìm 1 cái để tặng nó.
    KÍNH
  11. ngtatliem
    C.S.J
    To Bác ZORRO,
    Bác cho em xin cái giá của con 3500RG với để em đi mua cho tiện, nhân tiện hỏi Bác luôn là hình như có con 3500GL là đới sau của con 3500RG, con này chất lượng cũng như giá cả thế nào hở Bác?
    Cảm ơn Bác nhìu!
  12. Zorro
    Saigon
    Denon 3500RG mình xài cách đây 3 năm rồi, nghe khoảng 8 tháng thì cho em nó đi ở. Giá lúc đó hơn 400USD, còn giá bây giờ thì mình không nắm. Em này rất nặng, 23Kg, bên trong chống rung, chống nhiễu rất kỹ, đặc biệt 2 tụ nguồn to như của amp vậy!
    Thân.
  13. seas
    seas Approved Member
    Saigon
    Bác Liêm ơi! mình cũng đang nghiên cứu SANSUI, đọc các Post của bác thấy hơi mâu thuẫn muốn hỏi lại bác cho rõ:
    Mình biết đôi loa của bác để ghép với SS la PIONNER S77-TwinSD, sao có lúc bác post đôi loa này không chơi được với 907, có lúc bác post chơi rất hay với 907
    Bác giải thích giúp mình chút nhé, rất hâm mộ các bài viết của bác, nhưng sau khi đọc hết thấy hơi lùng bùng, không hiểu bộ dàn hợp lý nhất dùng Loa PIONNER S77 là với SanSui nào?!
    Cảm ơn Bác,
    Post From ngtatliem
    Em cũng vừa đi Xì gòn về làm được con 607XR.Loa của em chỉ chơi với 607 thôi, chứ 907 chịu không nổi! Hôm nào Bác có đi Vũng tàu ghé em chơi em mời BÁc nghe thử hen! Thằng 607XR tiếng nó còn đã hơn mấy thằng DR & KX nữa. Em đang phê cái đĩa THành phố biển 2 của mấy BÁc HN gửi cho.
    Chào bạn,
    Mình ghép SANSUI AU-alpha907DR với loa PIONNER S77-TwinSD tiếng rất hay đều cả 3 dải, đặc biệt trung âm thì khỏi phải chê rồi.
    regard Laughing
  14. ngtatliem
    C.S.J
    Chào Bác Seas
    S77-TwinSD cuối cùng là hợp với SS AU-607,Còn 607 nào thì đời càng về càng sau này càng hay hơn, mid càng trong trẻo hơn thôi!
    Mình sorry nha vì trả lại mà quên đình chính, cảm ơn Bác đã nhắc nhở, Em đã sửa lại rùi!
    Thân!
  15. seas
    Saigon
    hi Bác Liem, tui thấy bác nghiên cứu SS nhiều nhất ở đây!
    Nhờ bác cho ý kiến D590 ghép với SS nào thì hợp, bác đã mua D590 chưa? thứ tự đời 607 như thế nào? cái nào trước cái nào sau? S77-TwinSD bác mua ở đâu vậy? bây giờ có săn được không?
    cám ơn bác!
  16. ngtatliem
    C.S.J
    Dạ cảm ơn Bác quá khen, Em hay chowi sansui vì giá mềm mà lại hợp với loa của em.
    Ý của Bác hỏi em trả lới đây:
    1.Em nghỉ D590 chả chơi hợp với SS nào hết, Em đã đem ghéo thử tiếng trung thì tốt,treble tốt, Bass thì tròn gọn nhưng lại không sâu được, cũng đôi loa đấy ông chủ tiêm vác 2000IVR ra thử em chịu thua vác SS về!
    2.Em chưa mua được D590, my Deam!
    3.SANSUI VERSION
    4.Đôi loa Pionner S-77TwinSD của en mua ở Vũng Tàu của một ông Bán đồ 2hand,đôi này ổng để dành nghe,em quen nài nên ổng để lại. Hàng này em thấy hơi ít Bác thử hỏi Các Bác trên mạng coi!
    Chào Bác!
  17. caithang
    Tìm mãi cả trong và ngoài nước cặp này ít thấy bán. Cuối năm vào Vt năn nỉ bác ngtatliem là bê cặp này ra :lol: . có 590 cho dream rồi là bác Liem bán :lol:
  18. Zorro
    Saigon
    Nếu bác ở HN thì cố gắng chờ và săn, sắp có 1 cặp S-77TwinSD ra xứ Bắc đấy, nghe đâu giá hơn 4tr.
    Thân.
  19. ngtatliem
    C.S.J
    Có đâu mà rẻ dữ vậy bác ZORRO, Em mà thấy là em ôm liền! Các Bác không có phần đâu! :lol:
  20. ngtatliem
    C.S.J
    Khà khà, Nghe thì em mời Bác cả ngày nhưng bán thì không, kỷ niêm của em đó Bác. em còn đang săm thêm cặp S-1000TwinSD và S-5000Twin.
    Em sẽ gửi spec của nó để tham khảo.
  21. ngtatliem
    C.S.J
    S-1000Twin SD đây:
    Pioneer S-1000twin
    \ 220,000 (1 units, 1989 sale)
    The speaker system where it followed the technology which is cultivated with the studio monitor for the professional and the development etc of EXCLUSIVE S5, furthermore freely used individual technology and wave front control technology and was developed.
    To focusing on the eater the vertical twin who arranges two woofers in the top and bottom is employed.
    Because of this, because from the limits to sound of all to high pass is emitted the eater low on the center, the rich sound field impression and clear acoustic image normal position are obtained.
    Furthermore to develop this technology, developing & introducing new wave front control technology.
    As for this, the wave of sound from the speaker how spreading, being something which elucidates scientifically whether it arrives to the ear of the listener, “has been pointed the point that improvement it controls wave front diffraction “with the time base to the woofer it controls the energy time of the eater”, “to the woofer it controls the directivity of the eater”, “it controls electric phase such as network”, with baffle form,”.
    Low the cone type woofer of 20cm is adopted to the limits.
    In the magnetic circuit at S-99twin ratio approximately 12% the magnetic circuit by the alnico magnet which was made to raise is adopted.
    In addition, the diaphragm adopts those which laminate the high-molecular film in the pulp cone which is used with TAD unit, CRA (Cap Resonance Absorber) has administered to the center cap same as S5.
    We adopt zinc die-cast to the frame, because it has the relative importance, 2.6 times that the aluminum, we obtain high rigidity.
    In high pass to 3cm dome type in the eater, the [itayakaede] laminate of the same material as EXCLUSIVE S5 shaving, W.F due to start. ([ueibuhuronto]) the die/di rec tar is adopted.
    It agrees the wave front in the listening position of the listener the time base which adjusts the position relationship with the woofer controlling and it controls the directivity with horn form, with.
    In addition the ceramic graphite diaphragm of carbon purity 99.9% is adopted to the diaphragm, the alnico magnet is used to the magnetic circuit.
    Each both unit we adopt midship mount system, because the vibration of unit is not conveyed to the baffle, we lock each unit inside the enclosure.
    Furthermore being thorough non vibration non resonance conversion over, the whole system, such as the floating top which holds down the unnecessary vibration of the top board and the sealed frame which holds down the unnecessary vibration which is transmitted to the frame it has pursued.
    Network frees the eater circuit with to the woofer circuit, to especially caulks the connection with the eater and is connected to direct with bonding wiring.
    In addition also the mount of each element administers vibration-proof processing, in order not to receive the influence of the crosstalk, is arranged.
    The enclosure uses the real wood of the walnut, administers the oil stain finish.
    Furthermore, the baffle aspect and to flat surface it converts the saran net, because tuning of sound is done when the saran net is installed, it is possible to enjoy with while the net is attached.
    In addition, unnecessary radiant sound from the duct (the medium limits component) avoiding, you adopt the rear duct.
    Furthermore in the open part interference of the open part is prevented by the fact that the sound-absorbing felt is attached.
    The terminal whose bi- wiring connection is possible is adopted to the input terminal.
    Because it corresponds to the floor such as flooring and carpet, the spike and the felt have belonged.
    The name plate is made with the maple.
    Rating of type System 2 ways 3 speakers [basurehu] system [toruboi] type anti magnetic design
    Use unit It is low the for limits: 20cm cone type ×2
    For high pass: 3cm dome type +W.F. die/di rec tar
    Impedance 6Ω
    Playback frequency zone 28Hz~20000Hz
    Output overpressure value 91dB/W/m
    Largest input (EIAJ) 180W
    Crossover frequency 1800Hz
    External size Width 276× height 1060× depth 407mm
    Weight 44.0kg
  22. ngtatliem
    C.S.J
    S-5000Twin đây, thứ này mới là thuốc độc, mua được em này thì chắc phải kiếm 907NRAII chơi quá :lol: :lol: :lol:
    Pioneer S-5000twin
    \ 500,000 (1 units, 1990 sale)
    Speaker system of the vertical twin system which adopts all the crystalline diamond diaphragms.
    Low spending the time of 4 years in the limits, new ALCC which it developed (the alginic acid composite cone) you adopt the 20cm cone type woofer by the diaphragm.
    As for this diaphragm, mixing the aramide fiber 抄 in the pulp, in the coupling oscillation edition which is produced, the alginic acid which is extracted from the seaweed is made filamentous, to fiber it is something which mixes the alginate fiber which is converted, it increases the binding power of both due to the fact that the alginate fiber exactly carries out the function of the binder of the pulp and the aramide fiber, rigidity has improved.
    In addition, the high linearity magnetic circuit which is expanded to plate thick former 2.5 times is adopted to the magnetic circuit. We actualize the short voice coil conversion to which voice coil is settled completely in the magnetic gap, decrease of flux density is held down at also the time of large amplitude of voice coil. In addition you can obtain high flux density, the alnico magnet where the distortion factor is little is adopted.
    Furthermore, while adopting zinc die-cast it has the relative importance of 2.6 times that the aluminum to the frame, decreasing the unnecessary vibration with high rigid conversion, in order for aerodynamic drag to the diaphragm to become small, the device is made form.
    It is possible to hold down the reflection of sound from the cone and the edge, by administering flock processing to the gasket surface of the woofer. Furthermore, the playback sound where the turbidity of sound is little due to the damping effect of the gasket itself, is obtained.
    In high pass to the 3cm dome type by all the crystalline diamond diaphragms the eater is adopted.
    This diaphragm is not something which until recently coating does the diamond on the surface of material such as the titanium which is, we do from polycrystals of 100% diamond, utilizing the diamond original quality which is close to the ideal of the diaphragm, we increase.
    Because of this, speed of sound approximately 3.3 times that titanium, playback frequency zone and approximately 3.4 times that titanium, internal loss actualizes approximately 3~5 two times the titanium.
    To furthermore on the eater front, new W.F wave front control technology was freely used. ([ueibuhuronto]) adopting the die/di rec tar, it increases. [itayakaede] laminating which in high rigidity is superior in acoustic quality it starts shaving the material of the die/di rec tar, with has become, as diaphragm installation position is adjusted in order to adjust the energy response of the woofer, horn form of the die/di rec tar oneself is done in order to improve the extent of oriented characteristic of top and bottom direction.
    In addition you adopt the alnico magnet to the magnetic circuit, to you adopt zinc die-cast it has the relative importance of 2.6 times that the aluminum even in the flange of the eater. Furthermore excessive resonance is held down with administering flock processing to the surface of zinc die-cast.
    Unit arrangement has become the vertical twin system which freely used wave front control technology, to sound of all zone has been emitted the eater on the center. In addition, actualizing the silent playback which has volume by the fact that it makes the twin woofer of the small aperture it increases.
    With the technology which is elucidated scientifically whether as for wave front control technology, the wave front of the sound which is emitted from each unit how keeps spreading, to the ear of the listener arrives, “to the woofer the energy time response of the eater with the time base is adjusted”, “to the woofer controls the directivity of the eater, “makes electric phase coincide such as network with all the frequency zones””, control is done strictly “the wave front diffraction with baffle form is controlled” over 4 points.
    Because the unnecessary vibration from each unit is not conveyed to the baffle, adopting full midship mount system, it increases.
    As for the woofer in the inner baffle inside the enclosure, to as for the eater through flock layer, we are fixed from back of the baffle, by mounting unit in the place other than the baffle surface, the unnecessary vibration of the baffle we have decreased.
    Furthermore the floating top which holds down the unnecessary vibration of the top board, we adopt the sealed frame which cuts off the vibration from the frame, also the mount of network separates each unit circuit, to especially in the eater circuit spreads the felt from under and removes the unnecessary vibration from the enclosure.
    To the woofer circuit it becomes independent separates the eater circuit, caulks and does bonding wiring and has decreased the transmission loss of the signal.
    Also the mount of each element administers very careful vibration-proof measure, in order not to receive the influence of the crosstalk, considering, has designed.
    In addition, input to network, in order the signal to be able to transmit to direct and uniformity, has adopted radial supply of electricity system.
    The enclosure with the high-class walnut real material sudden board pasting, has utilized the grain of the natural inscription wood. Furthermore it increases the frequency of grinding in comparison with usual oil finish, it has become the finish which raises smooth characteristic.
    In addition, the wool where the sound-absorbing effect is high, is superior sound quality is used for the acoustic material, the unnecessary standing wave inside the enclosure has been decreased.
    The bi- wiring connected terminal which it can separate can supply electricity the circuit for bass and the treble is adopted.
    Impedance 6Ω
    External size Width 298× height 1080× depth 425mm
    Weight 49.5kg
  23. Zorro
    Saigon
    @caithang: Vừa rồi SG có về 1 cặp, nhưng em nghe nói lái HN đã lấy rồi.
    @ngtatliem: Hehe, em thấy mà không ôm, cũng tiếc nỉ!!! Em nhớ cách đây khoảng 13 năm, tại SG có bán cặp loa này hàng mới tinh đấy, giá gần 800$.
    Thân.
  24. ngtatliem
    C.S.J
    Thân.[/quote]
    Riêng em thì tiếc thật vì em rất ưng chất âm của dòng loa này, nghe nó mộc mạc & dịu dàng làm sao ý! Nói chung là phê lòi! :lol:
  25. caithang
    Sansui AU-X111 Mos Vintage hơi khó tìm nguyên bản, con này nghe nhạc nhẹ nhàng vocal rất hay
