SG - Arcam Diva A85 Integrated Amplifier
Discussion in 'Amplifiers' started by JB Vintage Audio, 9/12/22.
  1. JB Vintage Audio
    JB Vintage Audio Advanced Member
    Remote control included
    Amply hay- Made in UK, giá sách $1500 ,hàng cargo Mỹ, dễ xài, đa chức năng, làm pre làm power amp cũng được, impedance 4-16 ohm, công suất 85W nhưng lực rất mạnh, lý tưởng cho book shelf và những loa cột power-hungry ,voltage 120-240V
    Giá thương lượng 9tr9
    Thank you ae
    Description: Remote-controlled integrated amplifier. Inputs: 7 line-level: 2 Tape In/Rec Out (one can double as a VCR or second audio tape source), Power In/Pre Out, optional MM/MC cartridge module. Voltage selector and trigger out. Two sets of speaker terminals configured to British Federation of Audio standards. Power output: 85Wpc continuous average power into 8 ohms (19.3dBW), both channels driven. Frequency response: 20Hz-20kHz, ±0.25dB. Distortion (80% power at 1kHz): 0.005%. Nominal preamp output level and output impedance: 700mV; ±3 ohms. Line and tape inputs: Signal/Noise (2V input, CCIR-weighted, tone controls bypassed): 105dB. Input impedance: 22k ohms. Input sensitivity (for rated 8 ohms power output): 250mV-1.6V. Power consumption: 600VA maximum.
    Dimensions: 16.9" (433mm) W by 3.9" (100mm) H by 13.25" (340mm) D. Weight: 20 lbs (9kg).
    Finishes: Silver, black.
    Price: $1499. Approximate number of dealers: 150.
    Manufacturer: Arcam, Pembroke Avenue, Waterbeach, Cambridge CB5 9PB, England, UK. Tel: (44) (0)1223-203200. Fax: (44) (0)1223-863386. Web: www.arcam.co.uk. US distributor: Audiophile Systems Ltd., 8709 Castle Park Drive, Indianapolis, IN 46256. Tel: (888) 272-2658 (toll-free), (317) 849-5880. Fax: (317) 841-4107. Web: www.audiophilesystems.com
  2. thanhgiang23
    thanhgiang23 New Member
    Hello bạn. 7tr mình xem nhé.
  3. tuannh66
    tuannh66 Advanced Member
    máy còn không? Cho xin số điện thoại nhé!
