So Sánh Marantz SR 14EX và Yamaha AZ1
Discussion in 'Khuếch đại, giải mã đa kênh' started by serenade, 10/5/06.
  1. altecta7
    altecta7 Advanced Member
    Hải phòng
    Theo các Bác nếu so với em này thì thế nào?
    Denon AVR-3806 7.1 CH Receiver
    Key Features:
    Equal Power Amplifiers 7ch
    Power Output; Watts Per Channel 120
    All Channels Rated @ 0.05 THD
    Low Impedance Drive Capability
    High-Current/Discrete Amplifiers
    Independent Power Supplies 4
    Dynamic Discrete Surround Circuit – D.D.S.C - D
    Dolby Digital, dts and DSP Modes – Analog Devices, HammerHead SHARC
    Processor(s) – Bit Depth and Type 32-bit Floating Point
    Dolby Pro Logic IIx – with Cinema, Music, Game Modes
    Dolby Digital Surround EX Decoding
    dts ES Discrete 6.1 Decoding
    dts ES Matrix 6.1 Decoding
    dts Neo:6 Stereo-to-Surround Cinema and Music Modes
    dts 96/24 5.1 for DVD-Video Processing
    HDCD Decoder
    Auto Setup Calibration
    Auto/Manual Room Equalization
    Auto Setup Microphone Included/Type Y/Mold
    AL24 Processing - All Channels AL24+
    24-bit/192-kHz DACs – Burr-Brown PCM-1791 2/8ch
    Analog-to-Digital Conversion - Bit Depth/Sampling Rate 24/192
    Variable High/Low Pass Crossover Points (12/24dB) 40/60/80/100/120/150/200/250
    True 24-bit/96-kHz Digital Input Capability
    True 24-bit/192-kHz Digital Input Capability
    Assignable Digital Inputs
    Digital Input – DENON Link 3rd (SACD Ready)
    Digital Inputs: Coaxial 2
    Digital Inputs: Optical 5
    Digital Outputs: Optical 2
    Digital to Analog REC Out
    Analog Audio Inputs, Incl. Tuner 11
    Phono Input
    Analog Record Outputs 3
    Front Panel A/V Inputs w/Cover * Composite and S-Video x* with Optical
    Video Conversion –Composite to S-Video to Component
    Video Conversion – Composite to S-Video to Composite
    DVI/HDMI Video Inputs – Compatible with 1.1 Spec. – Multi-Channel Audio 2 HDMI
    HDMI Video Outputs 1
    Composite Video Outputs 3
    S-Video Inputs 7
    S-Video Outputs 3
    Component Video Inputs x Bandwidth - *Assignable 3x100
    Component Video Outputs 1
    Dual Surround Mode Spkr. Selector
    Icon-Based On-Screen Display
    Front Panel System Setup Control
    Personal Memory Plus
    System Setup/Surround Parameters Lockout
    8-Ch. External Analog Input
    Audio Signal Delay (Sync. Audio with Video signal) – By source
    Pure Direct/Direct/Stereo Modes on Digital/Analog inputs
    Wide Screen 7.1 Mode 17.1
    Multi-Channel Stereo Mode 5/6/7/9
    DSP Effect Modes 7
    Auto Surround Mode (Analog or Digital Input Type)
    Active Center Channel In All Surround Modes
    Banana Plug Speaker Terminals, All Channels
    Cinema EQ
    56 Station Auto-Preset Memory Tuning
    XM Satellite Radio 'Connect and Play' Ready – with optional antenna
    Direct Function (Tone Bypass)
    Volume Control Un-muting
    Selectable Muting Levels (Full/-40/-20)
    Video Select Control
    RS-232 Port – Third Party Remote Controllers
    IR Serial Remote In/Out terminals
    Black Color
  2. altecta7
    Hải phòng
    Hình của em nó
    Mặt trước, giá mới tinh là $879.
  3. hugo
    hugo Advanced Member
    Gia Định Thành
    Sory bác altecta7 nha nếu bác cứ lựa chọn lòng vòng như vậy thì bác khó mà mua được reciver lắm mặt dù số tiền của bác có nhiều sự lựa chọn. Theo như đánh giá chủ quan của em về 3 loại reciver này bác thử xem nhé.
    - Dòng receiver Marantz. Loại này cho ra chất âm ấm mượt khi xem phim và nghe nhạc. (tuy nhiên xét về coi phim thì không được đã cho lắm theo ý của nhiều người còn riêng em thì lại coi như thế là êm tai :D . Dòng reciver này nói chung tiếng bass hơi yếu nhưng theo em còn tùy theo mình đầu tư vào cục sub có gấu không thôi).
    - Dòng receiver Yamaha. Dòng này xem phim thì ok nhất nhưng xét về nghe nhạc thì không được ổn cho lắm chất tiếng hơi khô.
    - Dòng receiver Denon thuộc khoảng giữa của 2 dòng receiver trên. Nếu xét về nghe nhạc thì không bằng Marantz nhưng hơn hẳn Yamaha, còn về coi phim thì thua thằng Yamaha nhưng nhỉnh hơn thằng Marantz. Dòng receiver này theo em tiếng hơi xé và chói dễ nịnh lỗ tai hơn.
    - Nhận xét trên chỉ là nhận xét của riêng em dựa trên những dòng receiver phổ thông mà thôi và em cũng nghĩ rằng nếu số tiền của bác sẳn có như vậy theo em bác nên đầu tư làm 2 bộ khác nhau sẽ hay hơn vì receiver dù có gấu gì đi nửa khi nghe nhạc chắn chắn cũng không thể nào bằng được ampli 2 kênh đâu. Mong bác tìm được 1 bộ dàn ưng ý.
  4. AudioTo
    AudioTo Advanced Member
    Xét về độ gấu linh kiện thì con 14EX có phần hơn ,còn về công nghệ thì DZP-AZ1 hơn .Nhưng tóm lại là 14EX là rẽiver 5.1 còn AZ1 là receiver 6.1 ,điều đó đã cho thấy là công nghệ của AZ1 hơn hẳn 14EX .Còn nhận xét về chất âm thì cũng tùy theo gu nghe của từng người và cách phối ghép .Theo cá nhân em thì AZ1 xét về mọi mặt hơn 14EX .
  5. altecta7
    Hải phòng
    Cám ơn Bác Hugo, em thật sự không biết nên mua cái nào nữa, em có 02 cặp Dick Sequerra Metronome Model 7 và 01 cục sub Metronome model 8 (Không cắp điện, dual coil, 30 cm), hiện đang chơi vào cặp Re-pow Rotel Prologic (Rotel RSP960 AX và RB 956 AX) nghe hơi chán. Các bác có kinh nghiệm xin cho em vài ý kiến, em muốn xem phim là chủ yếu, nghe nhạc thì nghe DVD, còn nghe CD em có đồ chơi rồi. Cám ơn các Bác.
  6. a607photo
    a607photo Advanced Member
    Phú nhuận HCM
    bác này chỉ được cái nói rất đúng
  7. duyle
    duyle Approved Member
    Chắc tại chị Bích Vân quảng cáo Denon và Pioneer đây mà hi hi....
    cũng theo quan điểm mỗi người thôi chị ơi....
  8. Jacky5555
    Jacky5555 Advanced Member
    Con Marantz SR-14EX thấy khá nhiều ở HN cách đây 2-3 năm, hồi đó thấy hàng lướt tầm $800. Build quality thì gấu vì là hàng đời cao của Marantz, nhưng software thì đã lạc hậu rồi.
    Theo em, nó không so với AZ1 được vì phần decoder của AZ1 ngon hơn nhiều. AZ1 cũng gấu lắm vì từng là top of line, made in JP nếu em nhớ không nhầm (trong khi tầm thấp của YA phần lớn made in Malay). Về nghe nhạc thì chưa so sánh thử nhưng em nghĩ rằng bất kỳ ai cầu kỳ 1 chút cũng không dùng receiver để nghe nhạc, vì thế ưu thế của 14EX (nếu có) là không đáng kể.
    Tóm lại vẫn là AZ1.
  9. duyle
    Rất xin lỗi chị BV vì câu đùa ko đúng lúc làm chị phật ý
    - Cá nhân em chỉ nghĩ rằng hãng nào cũng có dòng hay và dở trong tầm tiền của nó cả,
    - Các nói là Marantz nghe ko bằng với Denon mà Pioneer thì cũng đúng, nhwng còn trong trường hợp các bác ghép với loa gì nữa chứ.....
    - Nếu các bác ghép với các loa center và rear laọi rẻ tiền như JBL control1, các loa không đồng bộ với loa font thì em ko tin :lol:
    - Nếu các bác ghép Denon hay Yamaha hay Pioneer với B&W đầu 6, đầu 7hay Tannoy 638 639, D500 mà nói hay hơn Marantz SR 14-EX thì em cũng ko tin
    EM nghĩ là do mình phối ghép hợp với tai của mình thôi
  10. hugo
    Gia Định Thành
    Ôi em chơi toàn hàng cỏ không à nên nhận xét lung tung ấy mà, nhưng được chị BV nhận xét như vậy cũng vui :D
    - Nói thiệt với các bác nha khi xưa em mới chơi nhạc khi đi nghe dàn máy 5.1 là em bị hớp hồn liền, tiếng nhạc, tiếng bom trong phim nghe chí chóe dễ bị lôi cuốn lắm ( :D không tin mấy bác cứ rủ người không biết chơi nhạc về nhà thử dàn máy nghe nhạc 2 kênh và dàn xem phim thử coi. Em đảm bào với mấy bác trên 80% là chọn bộ xem phim).
    - Vì thế em mới nghĩ thôi thì mình cứ chơi 1 bộ reciver cho tốt vào vì dù gì bỏ vào phòng nhỏ vừa được xem phim vừa được nghe nhạc thế là ổn.
    - Nhưng giờ thì phải suy nghĩ lại vì thật ra khi ban đêm mà nghe bằng 2 loa main tắt loa sub đi thì tiếng bass nghe không đầy, còn khi vặn loa sub lên thì tiếng bass nghe nó rền rền sao đó mặt dù đã cắt đúng tần số. Cho nên nếu có khoảng 2.000usd thì em dùng khoảng dưới 1.000 cho cả bộ xem phim còn lại bao nhiêu em đổ vào 2 kênh thế là ổn cho 2 nhu cầu xem phim, nghe nhạc pop rock..., còn nghe nhạc trữ tình Jazz...thì chơi 2 kênh :D
    - Với tiêu chí như thế em cứ có khả năng bao nhiêu là nhắm chọn reciver đời mới mà tẩn trước cho ổn dàn reciver vì em nghĩ, càng đời mới thì công nghệ lúc nào cũng phải hơn đời củ chứ (ví dụ như bộ giải mã các máy đời sau này là 192/64bit, đời trước là 96/64bit). Nói như thế không phải là em chê hàng cũ nhưng vì tầm tiền của em mà đi tìm mua hàng cũ lỡ có trục trặc gì thì khỗ, mà cái khổ đó hiện tại em bị đây( hiện em có con marantz SR 7200 đang bị chết con giải mã phần mạch bên loa sub vì lỡ đem ra ông thợ già đầu ngõ vệ sinh, em không biết ông làm kiểu gì, giờ để đó trưng làm kỹ niệm đợi nhờ anh em cao thủ tìm giúp chổ sửa hay con giải mã khác thay thế).
    ==> Đánh giá sơ qua của em về các dòng reciver của các hãng (chỉ là đánh giá theo em thôi nha) :wink:
    - Để xem ca nhạc trữ tình pop nhẹ như Thúy Nga và xem phim thì nên chơi Marantz (em đã nghe và chơi mấy đời marantz rồi nhưng con marantz 14EX này nó thuộc hàng gấu nên chất lượng âm thanh cũng gấu luôn, mấy bác nên nghe nó đi rồi phát biểu, đừng kết luận vội khi đem so sánh, mà đặt trưng của dòng marantz này hình như ăn volume khá nhiều). Đánh giá 9/10 vì theo lổ tai và sở thích của em tuy nhiên dòng marantz này hơi nhẹ bass
    - Nếu chuyên về xem phim và 1 chút thể loại nhạc nào đó mà không đòi hỏi cao như bộ 2 kênh thì nên chơi YAMAHA vì hãng này nổi tiếng về công nghệ chíp giải mã dùng cho xem phim, mà YAMAHA AZ1 cũng thuộc là hàng bố đỉnh rồi còn gì. Đánh giá 8,5/10 vì lỡ mê marantz rồi :D
    - Receiver DENON dùng để chơi những thể loại nhạc tiết tấu nhanh, nó mà cặp chung với bộ dàn loa và sub JBL 3tất5 thì khi chơi nhạc và xem phim là mệt luôn, mà nghe lâu coi bộ mệt thiệt vì tiếng nghe một hồi rát lỗ nhĩ quá. :D Đánh giá 8/10
    - Receiver Pioneer em nghe nói cũng hay lắm, mà hình như nó có chức năng loudness dùng để nâng tiếng bass khi nghe mức volume nhỏ (chú ý khi nghe lớn coi chừng dễ bị méo tiếng), mà hình như hãng này được thị trường mỹ quốc chơi nhiều lắm. Em chưa chơi qua không dám phát biểu :lol:
    - Receiver Onkyo , Hamankadom, Carver....... và còn nhiều hãng để nghiêm cứu lắm, em đã nghe sơ qua rồi nhưng chưa nghe kỹ lắm nên không dám phát biểu đánh giá :lol:
    * Vài lời tâm sự góp vui vì lâu quá rồi mới thấy mấy bác tranh luận lại thú chơi receiver, em chỉ nhãm nhí thôi mấy bác thấy không đúng cũng nên bỏ qua hạng rùa như em nhá :D :( :D
  11. bv
    bv Advanced Member
    Saigon
    Lời đóng góp của Bạn Hugo rất thanh bình và dễ thương! là sự hữu ích cho BV để học hỏi thêm.
  12. anhkhoi
    anhkhoi Approved Member
    Em cũng tập tành và chuẩn bị sắm bộ xem phim,
    mấy hôm nay cũng đi nhiều cửa hàng khảo sát thì thấy các cửa hàng điều đế cao Yamaha và Denon trong lĩnh vực này... bây giờ thì em nhất quyết chọn Denon vì chất âm mạnh mẽ phù hợp với xem phim, em cũng có hỏi thăm về Marantz thì các người tư vấn điều lắc đầu ngao ngán, ngay cả ở ĐT từng là đại lý của Marantz cũng nói Marantz rất yếu trong lĩnh vực Reciever...
    Ở đây em lại thấy anh Hugo chấm Marantz 9, Denon có 6 làm em hoang mang quá...
  13. a607photo
    Phú nhuận HCM
    Nếu xem phim, bác mua ya nhé.Chân Thành
  14. hugo
    Gia Định Thành
    Bác anhkhoi ơi em đã nói là vì lở mê marantz rồi mà nên em mới chấm nó là 9/10 đó chứ bác không coi kỹ lại lăn tăn và trách em rồi. Nói thiệt bác nghe chứ em chơi marantz cộng với cục sub Jamo SW-600 bự chảng bỏ vô phòng 12m2 tiếng bass của nó nghe dư mặt dù đã giãm volume tối thiểu rồi, ngồi coi phim 1 hồi mệt và ù lổ tai luôn ấy chứ, vì thế mỗi lần coi phim em lại mở tung các cửa ra mới ổn, mặc dù vậy nhưng em vẩn thích. :D :( :D . Khi xưa em cũng lăn tăn như bác vậy nhưng em nghĩ mình bỏ vô phòng nhỏ để 1 giàn vừa xem phim vừa nghe nhạc được em mới chơi marantz để đủ cả 2 tiêu chí đó chứ :D
    - Nói ra thì thị trường reciver dạo này chỉ có 2 hãng DENON và YAMAHA cạnh tranh với nhau thôi, cho nên họ thường chê hàng của hãng khác, nhưng chẳng lẽ hãng khác lại không có khách hàng riêng của mình sao :?: .
    - Tiền thì trong túi của bác nên bác có quyền chọn lựa theo đúng sở thích của mình chứ đừng nghe sở thích của người khác lại lăn tăn, nếu có điều kiện thì bác cứ chơi thử qua nhiều hãng đi rồi sẽ biết mình thích gì mà. Khi xưa em do ít tiền nên cũng hay điện thoại hỏi mấy bác trên đây ấy chứ nhằm tránh học phí ấy mà :D . Bác cũng nên nghe anh em họ khuyên là nên chơi 2 bộ khác nhau đi và lựa chọn receiver cũng trung bình thôi vì dạo này hình như chưa có công nghệ nào mới đâu ngoài cổng HDMI nhưng theo em cổng này ít dùng tới. :!: .
    - Chúc bác chọn được bộ hometheter ưng ý nhé (nếu bác chọn DENON rồi thì nên chơi với loa JBL nhé, theo em chúng hợp với nhau đó nghe pop, rock nhạc dance là ok )
  15. trongcuchi
    trongcuchi Advanced Member
    nếu bác thích nghe nhạc nhiều hơn thì chon marantz còn thích xem phim nhiều hơn thì chọn yamaha.dừng quá chú trọng xuất xứ hoặc linh kiện,vì linh kien có tốt cỡ nào thì củng đại diện cho hai phe ,nhe nhạc và xem phim.vài dòng góp ý cùng bác
  16. Dzungnt
    Dzungnt Approved Member
    Ha Noi
    Topic này đã qua 2 năm :D
  17. procos
    procos Advanced Member
    Bác mua 14EX đi, nghe nhac hay hơn, Yahmaha AZ1 không hay lắm nhưng nhìn gấu hơn 14EX
  18. Hi_en
    Hi_en Advanced Member
    EM CŨNG ĐANG DÙNG CON SR14EX MỌI THỨ : NGHE NHẠC, XEM PHIM ĐỀU HAY THEO NHẬN XÉT CỦA EM. CÓ THỂ GU CỦA EM DỄ NGHE CHĂNG.
    CÁC BÁC ĐANG DÙNG 14EX CHO THÊM Ý KIẾN NHÉ. CÁC ƠN CÁC BÁC.
  19. Raemit
    Raemit Advanced Member
    Sài Gòn-Gia Định
    Em cũng đã dùng Marantz SR-14EX lâu nay và chưa hề thất vọng về nó cả. Nếu biết set up loa thì khi xem phim rất thích. Em chưa sở hữu nhiều receiver tại nhà nhưng đã lọ mọ nghe thử mòn tai. Bản thân em nghĩ, cùng thời và cùng tầm giá này thì khó có receiver nào qua mặt được Marantz SR-14EX.
  20. AMD_Team
    AMD_Team Advanced Member
    TrungTuyenPC : 152 Hoa Bằng - Yên Hòa - Cầu Giấy -
    SR14EX bây giờ các bác có biết chỗ nào bán không, em đang muốn thử xem chất âm của nó thế nào
  21. Hi_en
    chào bác.
    em đang dùng em này. em ở Biên Hòa, nếu tiện bác cứ ghé em chơi. pm cho em nhé.
    em sử dụng suộc direc cho âm thanh chuẩn nhất.
    cám ơn các bác.
