[Software] Pure Music - Channel D
Discussion in 'Nguồn phát từ máy tính' started by online11, 3/6/17.
  1. online11
    online11 Advanced Member
    Pure Music® Version 3
    High Resolution Music Server Software for Apple Macintosh Computers - Version 3
    2015 - 2017 Absolute Sound Editors' Choice Award
    2010 - 2017 Stereophile Editors' Choice Recommended Components
    2011 Absolute Sound Golden Ear Award
    2011 Positive Feedback Brutus Award
    2010 Stereophile Computer Audio Product of the Year
    Runner-up (after Channel D Pure Vinyl™)
    Simply and automatically docks with iTunes
    • Based on Channel D's acclaimed Pure Vinyl audio playback engine
    • Pure Music handles all music playback; iTunes used as database, playlist organizer, etc.
    • Automatically docks with iTunes window, including automatic UI resizing / tracking
    • Native FLAC and DSD playback; Tracks appear in iTunes 2
    • Supports Apple Remote App for iPad/iPhone/iPod Touch
    • Automatic sample rate switching, up to 384 kHz PCM sample rate or 2.8 or 5.6 MHz DSD
    • The first music server and audio player software (June 2011) to directly play DSD format (dsf / dff, 64Fs and 128Fs) audio files with any DAC (real-time conversion to PCM during playback), plus full native DSD Audio Support (on DACs supporting DoP).
    • Audio Streaming Support with Pure Music's "Streamthrough" feature (included in Pure Music since 2011) which permits conveniently playing and enhancing other computer audio sources (Spotify, Qobuz, YouTube, iTunes Radio Internet audio streams, movies, etc.) through Pure Music, with full access to Pure Music's dithered volume control, 64 bit crossover, audio EQ plug-ins, NetSend streaming, metering, etc., all without needing to quit Pure Music 3
    • Automatic Gapless track playback and Memory Play
    • Adjustable Dithered Volume Control
    • Fast-Responding Firefly Metering, Monitor Input (Native) or Output (Post - Volume Control)
    • Real-Time Dynamic Range Meter
    • Supports All MacOS Compatible Sound Cards / DACs / Audio Interfaces
    • Supports all iTunes Compatible Audio File Formats (including WAVE, MP3, AAC, AIFF, Apple Lossless)
    • Plays music stored on networked volumes
    • REAL-TIME Sample Rate Conversion
    • Selectable REAL-TIME 64-bit upsampling 4
    • Mix to Mono, Exchange Left and Right Channels, Invert Polarity / Phase, Channel Balance Trim
    • Per-Track Polarity and Volume Tagging
    • CoreAudio Device HOG Mode Exclusive Access support
    • Internal Audio Device Selection and Setup (or use Apple Audio MIDI Setup)
    • Supports AudioUnit Audio processing plug-ins (Room Correction, Parametric EQs, etc.)
    • Uncompressed local audio streaming support with NetSend (up to 384 kHz and up to four separate connections)
    • 64-bit 2/3/4-way Crossover with time alignment and adjustable minimum phase (IIR) filters
    • Includes Mastering Quality File Converter / Downsampler for PCM, FLAC, DSD, DXD Files
    • Our own proven, optimized algorithms for sample rate and DSD to PCM conversion - not built from a patchwork of "open source" software
    • Supports both PowerPC (G4, G5) and Intel Mac Computers running Mac OS X 10.5 or later
    • Can install on more than one computer per purchased license 1
    • Customer Support: free email, telephone and Remote Support
    Version 3.0.6
    http://wikisend.com/download/984880/PurM306.zip
    https://www.fshare.vn/file/KVHJVL149L1Z Pass: vnav.vn
    tml3nr and nqkhanhn like this.
  2. phoenixvn
    phoenixvn Approved Member
    Thanks bác. Trên hệ thống của mình PureMusic nghe thích nhất bác ạ.
  3. khanh999
    khanh999 Advanced Member
    BRVT
    Bác nào còn giữ bản PureMusic cho em xin với (hoặc link down load cũng được). em cần để nghe DSD, thanks các bác
  4. Nguyenlb1977
    Nguyenlb1977 Advanced Member
    TPHCM
    Chào bác online11, không biết bác có còn giữ bản Pure Music nào không ạ, có thể chia sẽ cho em được không ạ, cảm ơn bác nhiều, chúc bác sức khoẻ
  5. Haolq
    Haolq Advanced Member
    Để em kiểm tra lại bản lưu còn sẽ up' lên cho các bác. Lưu ý là bản Pure music và Amarra chạy trên Macosx chạy không được với DAC dsd Giahuy nhé. 2 soft này nó chỉ support mấy sound, DAC của hãng.
    Nguyenlb1977 likes this.
  6. Nguyenlb1977
    TPHCM
    Em cảm ơn bác Hào nhiều ạ. Vì em vừa rồi có mua con Mac mini 2009, về tới nhà em tháo quạt, tháo luôn ổ CD ra rồi, để cái quạt hút phía đằng sau, nối nguồn riêng cho nó, nghe nhạc bằng Audirvana 7-8 tiếng liên tục vẫn bình thường. Muốn trãi nghiệm Pure Music xem có khác với Audirvana không, nguồn nhạc em để riêng ở NAS, DAC của em là Wadia 321, chắc Pure Music sẽ nhận tốt ạ.
  7. Haolq
    http://www.mediafire.com/file/rzb7p4pr4aof4ew/pm306.zip
    tml3nr, duckim and Nguyenlb1977 like this.
  8. Nguyenlb1977
    TPHCM
  9. duckim
    duckim Advanced Member
    Bác cảm nhận phần mềm này thế nào với Wadia 321? Mình cũng đang dùng wadia!
  10. Nguyenlb1977
    TPHCM
    Dạ, em đang đi làm nên chưa thử được bác ạ. Chiều tối về em thử xem sao, hiện tại em đang sử dụng Audirvana 3.2.6, Audirvana load nhạc được lưu từ NAS và tạo playlist theo ý mình rất nhanh. Tiếng Audirvana theo em là chi tiết (em không convert hay upsampling gì cả), tuy nhiên hơi sáng ở trung cao. Hy vọng nghe qua Pure Music sẽ khắc phục được điểm này vì em nghe nói nếu không upsampling thì Pure Music nghe sẽ trung thực và tốt hơn Audirvana. Cũng có thể do em sử dụng cặp loa hơi sáng tiếng là Elac 247.3 nên mới bị vậy.
    Sau khi cài và so sánh với Audirvana, em sẽ chia sẽ với bác ạ, nhưng theo em thì còn tuỳ thuộc vào bộ dàn nữa.
    duckim likes this.
  11. Haolq
    Hôm nào xách qua nhà em test với Pure Dsd của SIG và Lynx aurora8 bác.
  12. Nguyenlb1977
    TPHCM
    Dạ, ý bác là xách con DAC đó hả bác. Qua nhà bác lâu quá rồi nên bác cho em lại địa chỉ, em sẽ qua. Mà chắc phải cuối tháng này mới được ạ, vì tuần này và tuần sau em đều có việc không ở TPHCM
    Haolq likes this.
  13. Nguyenlb1977
    TPHCM
    Tối qua về cài vào, thấy chỉ cho chạy 15 ngày. Nguồn nhạc em để trên NAS mà mày mò mãi không biết add vào thế nào nên em cũng chưa biết chất âm nó có khác gì so với Audirvana. Em thích cách tạo playlist của Audirvana, nó cho add vài chục folder vào trong 1 playlist, rất tiện vì em thường bật nhạc nghe cả đêm
  14. Haolq
    Bản đó có cr** mà bác. Pure music và Amarra rất khó dùng, mỗi lần vào phải refresh device rất bực mình. Tiếng ko hay bằng Audirvana đâu. Mua cái Amarra hồi giảm giá 50% mà mỗi lần mở lại bực mình. Ko hiểu cái hãng này nó đi trước về audio computer mà sao soft chạy dở thế ko biết. Pure audio và HQplayer tiếng giống nhau, phần bass tròn tiếng hơn audirvana chứ ko có gì đặc biệt. Nếu mua soft thì bác chỉ nên mua Audirvana thôi, chơi dc hết tất cả các loại file, chạy nhẹ, dễ sử dụng.
  15. Nguyenlb1977
    TPHCM
    Dạ, vậy em nghe theo bác thôi, xài Audirvana cho nhẹ đầu, khỏi lăn tăn nữa. Cảm ơn bác đã chia sẽ ạ
  16. binna
    binna Advanced Member
  17. tml3nr
    tml3nr Advanced Member
    Nguyenlb1977, nvss and binna like this.
  18. beou
    beou Advanced Member
    Quận 3 TPHCM
    bác có thể làm cho tiếng A+ bớt sáng theo 2 cách. cách 1 bác tích vào direct mode, xong phần integ mode sẽ có mode1&2, chọn mode2 tiếng sẽ ấm hơn. cách 2 là vẫn chọn direct mode, integ mode1 nhưng bên mục pre ring của SoX giảm xuống 69 thay vì 73. e thì thích nghe cách 2 hơn kaka
  19. Nguyenlb1977
    TPHCM
    Em cảm ơn chia sẽ của bác #beou nhiều, chiều nay em về set lại theo các của bác ạ.
  20. vdung1972
    vdung1972 Advanced Member
    Nhà em
    Amarra trên máy em cứ mỗi lần bật lên là nó load nguồn nhạc lâu kinh, mất mấy phút, em đang add tầm gần 900 album. Trong khi Audirvana ko bị, mở cái ăn luôn.
