Tìm thông tin loa.
Discussion in 'Loa' started by an1234, 26/8/22.
  1. an1234
    an1234 Advanced Member
    GÒ CÔNG quê hương TRƯƠNG ĐỊNH
    Em tìm trên Google mà không thấy thông tin của cặp loa này, bác nào có thông tin xin cho em link,loa này phù hợp với ampli nào, sở trường nhạc, em xin cảm ơn nhiều! 20220826_113830.jpg 20220826_113811.jpg
  2. nguahoangphonui
  3. Kevin01
    Kevin01 Advanced Member
    HCM
    Mirage M-990, 3-Way, Ported, Bi-Polar Speakers
    Incredible floor-standing speakers designed by Ian Paisley
    Front and rear venting for a 360 degree listening area
    1" titanium dome tweeter
    4.5" rear-facing full range transducers (both recently refoamed)
    Two 6.5" injection molded polypropylene drivers with rubber surrounds
    Frequency response: 32 Hz - 22 kHz
    Crossover Points: 450 Hz, 2 kHz
    Sensitivity: 87db
    Max Power Handling: 200 watts
    Dimensions: 43 ½" x 10" x 12" (110.6 X 24.5 X 28.6 cm)
    Weight: 70 Lbs. - 31.8 Kg. each
    an1234, fleethl and Wilson Fans like this.
