Về ampli Sansui AU-D607
Discussion in 'Dành cho thành viên mới' started by bienkv, 5/6/06.
  1. bienkv
    bienkv Approved Member
    Các Bác giúp ít thông số về em Sansui AU-D607 như công xuất, trở kháng ra loa, đánh với loa nào thì hợp hả các bác, nghe classic, rock, không lời nhé
  2. caithang
    caithang Advanced Member
    Search trên nét nhiều lắm bác à.
    Ăn trộm của bác Liêm cho bác mấy con Sansui khác để bác so sánh, rồi thích quá mất thêm 1 cơ số tiền đi nâng cấp này : :D
    SANSUI AU-α 607XR
    \ 89,800 (1994 sale)
    Effective output (10Hz~20kHz and both ch simultaneous operation) 105W+105W (6Ω)
    90W+90W (8Ω)
    All the harmonic distortion factors (at the time of effective output) 0.003% or less (8Ω)
    Cross modulation distortion factor 0.003% or less (8Ω)
    Damping factor 150 (8Ω)
    Frequency characteristic (1W) DC~300kHz +0 -3dB
    Input sensitivity/impedance (1kHz) 1V/5kΩ
    SN ratio (A network) Above 120dB
    Dynamic power 280W (2Ω)
    220W (4Ω)
    155W (6Ω)
    TIM strain (SAWTOOTH) Below measurement limiting value
    Through late 180V/μsec
    Rise time 0.6μsec
    < Pre-amp section >
    Input sensitivity/impedance (1kHz) Phono MM: 2.5mV/47kΩ
    Phono MC: 300μV/100Ω
    CD, Tuner, Line and Tape/DAT1, 2: 150mV/20kΩ
    Phono maximum permissible input MM (THD 0.01%): 210mV
    MC (THD 0.1%): 21mV
    Frequency characteristic (1W) Phono MM: 20Hz~20kHz ±0.2dB
    CD, Tuner, Line and Tape/DAT1, 2: DC~200kHz +0 -3dB
    SN ratio (A network) Phono MM: Above 88dB
    Phono MC: Above 70dB
    CD, TUner, Line and Tape/DAT1, 2: Above 110dB
    Tone control Bass maximum change quantity: ±6dB (50Hz)
    Treble maximum change quantity: ±6dB (15kHz)
    Sub sonic filter 16Hz (- 3dB), 6dB/oct
    Loudness +6dB (50Hz)
    +4dB (10kHz)
    < Synthesis >
    Rated electric power consumption 250W
    External size Width 430× height 162× depth 452mm
    Weight 18.0kg
    SANSUI AU-V7000
    \ 99,800 (1990 June sale)
    Utility installed capacity (EIAJ and 6Ω) Front: 100W+100W
    Center: 100W
    Rear: 50W+50W
    Frequency characteristic Phono MM: 20Hz~20kHz and ±0.3dB
    Line: 10Hz~100kHz, +0 -3dB
    SN ratio Phono MM: Above 72dB
    Line: Above 90dB
    Tone control Bass maximum change quantity: ±10dB (50Hz)
    Mid maximum change quantity: ±6dB (1kHz)
    Treble maximum change quantity: ±10dB (15kHz)
    Line: 150mV/47kΩ
    Phono maximum permissible amount MM (THD 0.1%): 140mv
    < Video section >
    Frequency characteristic 5Hz~10MHz, +0 -3dB
    SN ratio Above 60dB
    < Synthesis >
    Rated electric power consumption 245W
    External size Width 466× height 163× depth 441mm
    Weight 16.2kg
    SANSUI AU- alpha 607 MOS Premium Limited sale item
    \138,000 (1991 year sale)
    Effective output
    (10Hz - 20kHz and both channel simultaneous operation) 55w + 55w (6 Omega)
    45w + 45w (8 Omega)
    Total height harmonic wave distortion factor (at the time of effective output) 0.008% or less (8 Omega)
    Cross modulation distortion factor 0.008% or less (8 Omega)
    Damping factor 150 (8 Omega)
    Frequency characteristic (1w) DC - 300kHz +0dB and -3dB
    Input sensitivity / input impedance (1kHz) 1v/5k Omega
    Dynamic power 70W (6 Omega)
    85w (4 Omega)
    90W (2 Omega)
    Through late 180V/ mu sec
    Rise time 0.6 Mu Sec
    < Pre-amp section >
    Input sensitivity / input impedance (1kHz) Phono mm: 2.5mV/47k Omega
    Phono MC: 300 mu V/100 Omega
    CD, Tuner, Line and Tape/DAT-1, 2 and 3: 150mV/20k Omega
    Phono maximum permissible input Mm (THD 0.01%): 210mV
    MC (THD 0.1%): 21mV
    Frequency characteristic (1w) Phono mm: 20Hz - 20kHz }0.2dB
    CD, Tuner, Line and Tape/DAT-1, 2 and 3: DC - 200kHz +0dB and -3dB
    SN ratio (A network) Phono mm: Above
    88dB Phono MC: Above
    70dB CD, Tuner, Line and Tape/DAT-1, 2 and 3: Above
    Tone control Bass maximum change quantity: }6dB (50Hz)
    Treble maximum change quantity: }6dB (15kHz)
    Sub sonic filter 1C$6hz (-3dB), 6dB/oct
    Loudness +4dB (50Hz), +4dB (10kHz)
    < Synthesis >
    Rated electric power consumption 160W
    External size Width 460~ height 159~ depth 446mm
    Weight 18.8kg
    SANSUI AU-X1111MOS VINTAGE
    \ 400,000 (around 1988)
    Effective output (10Hz~20kHz and both ch operation) 150W+150W (6Ω)
    110W+110W (8Ω)
    Dynamic power 320W+320W (2Ω)
    240W+240W (4Ω)
    190W+190W (6Ω)
    All the harmonic distortion factors (at the time of 10Hz~20kHz and effective output) 0.008% (8Ω)
    Cross modulation distortion factor (60Hz: 7kHz=4: 1, SMPTE) 0.008% (8Ω)
    Damping factor 200 (8Ω)
    Frequency characteristic (1W) DC~300kHz (+0dB, - 3dB)
    Input sensitivity/input impedance (1kHz) 1V (5kΩ)
    SN ratio (A network) Above 115dB
    Envelope strain Below measurement limiting value
    Through late ±150V/μsec (8Ω)
    Rise time 0.5μsec
    Headphone output 400mW (33Ω)
    Load impedance 4~16Ω
    < Pre-amp section >
    Input sensitivity/input impedance (1kHz) Phono MM: 2.0mV/47kΩ
    Tuner, CD and Tape Play 1, 2 and 3, Line1, 2: 150mV/47kΩ
    Maximum permissible input Phono MM: 200mV (1kHz)
    Output voltage (1kHz) Tape Rec (PIN): 150mV/47kΩ
    Output impedance (1kHz) Tape Rec (PIN): Above 600Ω
    Tuner, CD and Tape Play1, 2 and 3, Line1, 2: Above 110dB
    [sabusonitsuku] filter 16Hz (- 3dB and 6dB/oct)
    Presence (Volume -40dB) +2dB (200Hz)
    Audio muting -20dB
    < In addition >
    Rated electric power consumption (electric supplies control method) 350W
    External size Width 470× height 178× depth 486mm
    Weight 35.1kg
    SANSUI BA-1000 \
    89,800 (point in time of June of 77)
    Effective output 45W+45W (both ch operation, 20Hz~20kHz and 8Ω)
    95W (BTL connection mono operation, 20Hz~20kHz and 16Ω)
    All the harmonic distortion factors 0.08% or less (at the time of rated output, 8Ω)
    Cross modulation distortion factor 0.03% or less (70Hz: 7kHz=4: 1 SMPTE)
    Output bandwidth 5Hz~30kHz (IHF and 8Ω)
    Frequency characteristic 5Hz~80kHz (+0 -1dB, 1W)
    Ham and noise Above 105dB (IHF)
    Input sensitivity/input impedance 700mV/50kΩ
    Load impedance 2ch: 4 and 8, 16Ω
    Mono: 8, 16Ω
    Damping factor 70 (8Ω)
    Channel separation Above 85dB (1kHz)
    External size Width 482× height 88× depth 338mm
    Weight 10kg
    SANSUI AU- alpha 607 MOS Limited
    Effective output
    (10Hz - 20kHz and both channel simultaneous operation) 75w + 75w (6 Omega)
    50W + 50W (8 Omega)
    Input sensitivity / input impedance (1kHz) 1v/10k Omega
    Dynamic power 100W (2 Omega)
    95w (4 Omega)
    75w (6 Omega)
    Through late 180V/ mu sec (8 Omega)
    < Pre- section >
    Frequency characteristic (1w) CD, Tuner, DVD/LINE, Tape-1/MD and Tape-2:
    Phono MC: 300 mu /100 Omega
    CD, Tuner, DVD/LINE, Tape-1/MD and Tape-2: 150mV/20k Omega
    MC (THD 0.1%): 21mV
    70dB CD, Tuner, DVD/LINE, Tape-1/MD and Tape-2: Above
    +4dB (10kHz)
    < Synthesis >
    Rated electric power consumption 170W
    Signalless electric power consumption 52w
    External size Width 466~ height 162~ depth 452mm
    Weight 22.5kg
    Effective output
    45w + 45w (8 Omega)
    85w (4 Omega)
    90W (2 Omega)
    < Pre-amp section >
    MC (THD 0.1%): 21mV
    < Synthesis >
    Weight 18.8kg
  3. bienkv
    Vâng cảm ơn bác
    Nhưng mới nhìn thấy ngoài hàng bán em AU-D607, chưa biết nó thế nào, giá cả ra sao thì múc được, chất âm, bass tep em này thế nào ạ, các bác chỉ giáo giúp với nhé
  4. ngtatliem
    ngtatliem Advanced Member
    C.S.J
    Bác chơi loa gì? SANSUI Bác tìm mấy con đời càng về sau này thì tiếng càng hay, Bass gọn gẽ, Mid& treble khỏi phải chê!
    (Xem năm SX trên sợi dây dẫn điện đó, nhưng phải là dây gin mới đúng)
  5. pepi13579
    pepi13579 New Member
    các pác nào biết cho hỏi sánui AU D607F chơi loa nào tốt, bị mất núm volum moa ở dâu để thay thế. cám ơn
  6. special one
    special one Advanced Member
    Tặng Bác nơi ngâm cứu SANSUI :D
    http://audio-heritage.jp/SANSUI/amp/index.html
  7. Quoc Thinh
    Quoc Thinh New Member
    Bác hướng dẩn dùm : chọn bộ loa nào phù hợp với ampli Sansui Au - @ 607 i, Cãm ơn các bác
  8. livinght
    livinght Advanced Member
    Kiếm một đôi Pioneer tầm 5-6 triệu là chơi hay trong tầm tiền.
