Windows 10 LTSB bản tốt nhất cho Audio
Discussion in 'Nguồn phát từ máy tính' started by minhhoang, 4/3/18.
  1. suco4
    suco4 Advanced Member
    Em tìm thấy file của BSKhang bác tham khảo:
    Powershell Set-Service 'wuauserv' -startuptype "manual"
    Powershell Set-Service 'DPS' -startuptype "disabled"
    Powershell Set-Service 'Defragsvc' -startuptype "disabled"
    Powershell Set-Service 'MSiSCSI' -startuptype "disabled"
    Powershell Set-Service 'swprv' -startuptype "disabled"
    Powershell Set-Service 'SstpSvc' -startuptype "disabled"
    Powershell Set-Service 'SSDPSRV' -startuptype "disabled"
    Powershell Set-Service 'SysMain' -startuptype "disabled"
    Powershell Set-Service 'Themes' -startuptype "disabled"
    Powershell Set-Service 'upnphost' -startuptype "disabled"
    Powershell Set-Service 'VSS' -startuptype "manual"
    Powershell Set-Service 'WerSvc' -startuptype "disabled"
    Powershell Set-Service 'MpsSvc' -startuptype "disabled"
    Powershell Set-Service 'napagent' -startuptype "disabled"
    Powershell Set-Service 'iphlpsvc' -startuptype "disabled"
    Powershell Set-Service 'SCardSvr' -startuptype "disabled"
    Powershell Set-Service 'TrkWks' -startuptype "disabled"
    Powershell Set-Service 'UI0Detect' -startuptype "disabled"
    Powershell Set-Service 'WinRM' -startuptype "disabled"
    Powershell Set-Service 'fdPHost' -startuptype "disabled"
    Powershell Set-Service 'SNMPTRAP' -startuptype "disabled"
    Powershell Set-Service 'RpcLocator' -startuptype "disabled"
    Powershell Set-Service 'SharedAccess' -startuptype "disabled"
    Powershell Set-Service 'RemoteRegistry' -startuptype "disabled"
    Powershell Set-Service 'ALG' -startuptype "disabled"
    Powershell Set-Service 'PolicyAgent' -startuptype "disabled"
    Powershell Set-Service 'IKEEXT' -startuptype "disabled"
    Powershell Set-Service 'CertPropSvc' -startuptype "disabled"
    Powershell Set-Service 'WPDBusEnum' -startuptype "disabled"
    Powershell Set-Service 'Spooler' -startuptype "disabled"
    Powershell Set-Service 'Audiosrv' -startuptype "disabled"
    Powershell Set-Service 'AudioEndpointBuilder' -startuptype "disabled"
    Powershell Set-Service 'ShellHWDetection' -startuptype "disabled"
    Powershell Set-Service 'BFE' -startuptype "disabled"
    Powershell Set-Service 'FontCache' -startuptype "disabled"
    Powershell Set-Service 'CryptSvc' -startuptype "disabled"
    Powershell Set-Service 'DeviceAssociationService' -startuptype "disabled"
    Powershell Set-Service 'SessionEnv' -startuptype "disabled"
    Powershell Set-Service 'hidserv' -startuptype "disabled"
    Powershell Set-Service 'SamSs' -startuptype "disabled"
    Powershell Set-Service 'MSDTC' -startuptype "disabled"
    Powershell Set-Service 'VSS' -startuptype "disabled"
    Powershell Set-Service 'LanmanServer' -startuptype "disabled"
    Powershell Set-Service 'PlugPlay' -startuptype "disabled"
    Powershell Set-Service 'WinHttpAutoProxySvc' -startuptype "disabled"
    Powershell Set-Service 'COMSysApp' -startuptype "disabled"
    Powershell Set-Service 'SENS' -startuptype "disabled"
    Powershell Set-Service 'netprofm' -startuptype "disabled"
    Powershell Set-Service 'NlaSvc' -startuptype "disabled"
    hamvui55, asap and chauphuong like this.
  2. suco4
    asap likes this.
  3. chauphuong
    chauphuong Advanced Member
    Máy của tôi cài bản win nói trên + tinh chỉnh này nọ + tắt explorer thì khoảng 31-32 service. Làm theo mớ lệnh kia thì còn 23 nếu tắt explorer, và 32-33 nếu ko tắt. Vậy là ngon đấy.
    asap and suco4 like this.
  4. bskhang
    bskhang Advanced Member
    Em dựng con ms này chỉ để chơi nhạc nên em mạnh tay disable. Em xài server 2012r2, gở bỏ gui, opti mạnh. Vẫn chơi từ nas, từ mạng được. Sẽ gửi mấy script sau
    suco4 and asap like this.
  5. chauphuong
    TRÙNG BÀI..............................................
  6. chauphuong
    Danh sách một só service tắt được chia sẻ trên CA:
    1. AllJoyn Router Service
    2. Application Layer Gateway Service
    3. Bluetooth Support Service
    4. BranchCache
    5. Certificate Propagation
    6. CNG Key Isolation
    7.
    8. DMWAPPUSHSVC
    9. Downloaded Maps Manager
    10. Diagnostic Tracking Services - (Windows Phone home tracking service also called Telemetry)
    11. Geolocation Service
    12. HomeGroup Listener
    13. HomeGroup Provider
    14. Hyper-V Data Exchange Service
    15. Hyper-V Guest Service Interface
    16. Hyper-V Guest Shutdown Service
    17. Hyper-V Heartbeat Service
    18. Hyper-V Remote Desktop Virtualization Service
    19. Hyper-V Time Synchronization Service
    20. Hyper-V VM Session Service
    21. Hyper-V Volume Shadow Copy Requestor
    22. Internet Connection Sharing (ICS)
    23. Internet Explorer ETW Collector Service
    24. IP Helper
    25. Microsoft ® Diagnostics Hub Standard Collector Service
    26. Microsoft iSCSI Initiator Service
    27. Microsoft Windows SMS Router Service
    28. Netlogon
    29. Offline Files
    30. Print Spooler (leave enabled if you want to use printer)
    31. Printer Extensions and Notifications
    32. Remote Access Auto Connection Manager
    33. Remote Access Connection Manager
    34. Remote Desktop Configuration
    35. Remote Desktop Services
    36. Remote Desktop Services UserMode Port Director
    37. Remote Procedure Call (RPC) Locator
    38. Remote Registry
    39. Retail Demo Service
    40. Routing and Remote Access
    41. Sensor Data Service
    42. Sensor Monitoring Service
    43. Sensor Service
    44. Smart Card Device Enumeration Service
    45. Smart Card Removal Policy
    46. SNMP Trap
    47. Storage Service
    48. Superfetch
    49. SSDP Discovery
    50. Touch Keyboard and Handwriting Panel Service
    51. Windows Biometric Service
    52. Windows Connect Now - Config Registrar
    53. Windows Media Player Network Sharing Service
    54. Windows Mobile Hotspot Service
    55. Windows Remote Management (WS-Management)
    56. Windows Font Cache Service.
    57. Workstation
    58. Xbox Live Auth Manager
    59. Xbox Live Game Save
    60. XboxNetApiSvc
  7. Hagemi
    Hagemi Advanced Member
    Cảm ơn bác chủ nhiều. Đúng thứ em đang tìm.
    Bản windows 10 lite với bản LTSB thì bản nào nghe hay hơn vậy các bác nhỉ?
    khongcogi and panzer90 like this.
  8. minhhoang
    minhhoang Advanced Member
    Hay hơn bác phải thử test, cá nhân e test bản này ổn định + chất âm solid hơn cho máy yếu nhiều đó bác.
    Hagemi likes this.
  9. nguyenlan
    nguyenlan Advanced Member
    Q.12 - Hồ chí Minh
    Thanks .
  10. Hagemi
    Bác cho em xin script với nhé. Em cài bản LTSB và chạy script của bác mà bác suco4 chia sẻ hiện tại còn 41 processs, 537 thread khi chạy foobar chơi PCM
  11. Hagemi
    Nhờ các bác xem đánh dấu giúp e những service nào có thể tắt đi thêm được nhé
    0E58D0FD-B585-479E-8B20-B6075354F859.jpeg B7B2FD21-C112-43BA-B222-39BC7BBDF15C.jpeg
  12. giaphongn
    giaphongn Advanced Member
    Em lang thang trên mạng, vô tình lượm được bí kíp: Product Key để active Windows 10 LTSB. Lúc đầu nhập vào thì báo Product Key không đúng, nhưng sau khi khởi động lại thì báo đã active thành công. Các bác thử xem
    VTNMT-2FMYP-QCY43-QR9VK-WTVCK
    Ặc. Xem kỹ lại thì ở góc phải bên dưới màn hình chỉ được có 90 ngày thôi :(
    lazygirl likes this.
  13. ko853
    ko853 Advanced Member
    Thấy có win lean mới ra là bản nhỏ gọn dành cho máy yếu nên chắc tốt cho audio. Có bác nào thử chưa?
  14. ko853
    Em cài thử win 10 lean thì thấy chạy nhiều service hơn bản LTSB nhưng ít hơn nhiều win 10 pro, ngoài ra vẫn còn contana, app store... nên sẽ chọn LTSB.
    JupR74, anhhung and asap like this.
  15. ko853
    Bác @bskhang có thể chia sẻ script cho win LTSB cho ae dc ko ah?
  16. Hạt Cát Mong Manh
    Hạt Cát Mong Manh Approved Member
    Đánh dấu bản enterprise này tối về cài thử cho ver 1809,ver 1607 cũ quá rồi,đang ghet bản Pro vì nó thả cả đống game và xbox,cortana các kiểu,trông rác máy quá
  17. rfc647
    rfc647 Advanced Member
    em dùng bản LTSB tắt còn 23 process và 500MB ram vẫn dùng làm BRIDGE tốt.
  18. chauphuong
    Win10 chạy headless (tắt video card trong bios), cho foobar hoặc Jriver khởi động thay thế windows explorer sẽ chỉ còn độ 20 process, đặc biệt là thằng cortana cứng đầu sẽ biến luôn. Tắt video card tác dụng lớn nhất.
    nhson, tieuphi2006 and TQ_Audio like this.
  19. rfc647
    tắt vga có lẻ đỡ nhiễu tí nữa,cài win xong tắt video card có tác dụng ko bạn hay phải cài win bằng remote.
  20. sieunhangao88
    sieunhangao88 Advanced Member
    vãi đại ca xúi người ta đi cài win 10 nữa... làm gì có cái vụ nghe hay hơn ấm hơn .. bỏ đi ... lo mà đầu tư dac và amply hay loa kìa ...
  21. minhhoang
    có mấy bác, nghe qua là biết mấy process đang chạy nữa kìa. lo mà tắt đi bác :)))
    dqmvn likes this.
  22. theaminh8182
    theaminh8182 Shop
    Bình Dương
    Cho e hoi cài bản rút gọn rồi có cần chạy tối ưu của bac thovannhim nữa không để hay hơn ạ
  23. Hagemi
    Bác cứ cài bản pro đầy đủ rồi chạy cái tối ưu thì tốt hơn bác nhé
  24. theaminh8182
    theaminh8182 Shop
    Bình Dương
    đạ, vậy em đã làm vậy ạ, thanks bác nhiều
    tieuphi2006 likes this.
  25. ko853
    Em vừa cài LTSC ver 1909 bản gốc từ MS thì nó chạy tầm 128 service, cao vãi. Các bác xài LTSC (chưa tối ưu) có bao nhiêu service vậy?
