Xin tư vấn ghép loa nht-st4 voi amplier nào cho hợp
Discussion in 'Dành cho thành viên mới' started by ndthovn, 26/8/15.
  1. ndthovn
    ndthovn New Member
    Specifications
    System Type : 3-way system, upper chamber-acoustic suspension, subwoofer chamber vented
    Drivers : 1' Fluid cooled neodymium magnet structure tweeter with NHT's proprietary aluminum heat sink. Mid-Woofer 6.5" polypropylene, high excursion. Woofer 8" polypropylene, long throw.
    Magnetically Shielded: Yes, except 8" woofer.
    Frequency Response : 31Hz- 22kHz +/- 3dB
    Crossover Frequency: 2.6kHz, 135Hz
    Sensitivity: 86dB (2.83V at 1M)
    Impedance : 8 ohms nominal
    Inputs : 5-way binding posts
    Recommended: Amplifier Power Minimum 15 watts/ch Maximum 200 watts/ch
    Dimensions : 38"H x 8"W x 12"D
    Weight : 47.5 lbs. each
    Finish : Black high gloss piano lacquer
    http://www.nhthifi.com/ServiceCenter/ST4
