YAMAHA'S FAN CLUB
Discussion in 'VNAV's Fan Club' started by Nacon, 31/7/07.
  1. Ahoang
    Ahoang Advanced Member
    Đôi loa nay tôi đã dùng từ lâu rồi, hôm nay mới xin tham gia vào hội YAMAHA
    YAMAHA NS-890
    NATURAL SOUND SPEAKER 89,000
    In 1978, the bookshelf type speaker system where Yamaha sells. Relative the enclosure of depth
    You supplied four units, even in Yamaha history with unusual 4 way speaker systems, NS-1000M
    And the NS-690 series was 1 units which had the charm which in addition is different.
    The beryllium dome unit which was developed with NS-1000M at that time high pass playback ability in vivid of vivid extent
    Although so high appraisal is obtained hardness of sound and there was a surface where difficulty etc of the being connected of the limits were pointed out low.
    Actually, with NS-1000M, sweet low the fact that balance of high pass in the limits and spicy is taken is secret of managing
    With, it was difficulty.
    NS-890 beryllium dome type mid- loads the mid- bus of high and cone type as a medium limits unit, densely
    With being connected with with, low from high pass extending through the limits as smoother, the speaker system which it is easier to sound
    Being something which it tries to do, they were 4 way constitution for that.
    To as for eater, with JA-0520 of dome type of 3.0cm aperture, NS-1000M in the same way beryllium diaphragm harvesting/adopting
    Business it had done. Applying the electron beam vacuum vapor deposition method which can use beryllium for semiconductor manufacturing technology, the dome
    Being something which formed in type, scientific coating of thickness of 5 microns by doing, activity beryllium the sky
    It was protective from the air substance. In the beryllium diaphragm, the aluminum ribbon line edge where heatproof processing is administered
    [ta] of the special fiber to which wise volume voice coil is connected directly, double coating does the visco-elastic polymers and the thermosetting metaplasia resin
    It was supported by [njienshiyaruetsuji]. Center pole of space of voice coil back t
    To per condition, filling up the acoustic material in the opening, you held down the influence with resonance.
    As for magnetic circuit, at diameter 80mm and weight 0.8kg, 14,500 gauss in flux density, entire magnetic flux 20,000 Maxwell
    To use the ferrite magnet, playback frequency zone to actualize 2kHz~20kHz, the especially 3 next distortion factor components
    You used above little 6kHz.
    Mid- high, with JA-0521 of dome type of the 5.0cm aperture, to the eater adopts the beryllium diaphragm in the same way,
    The copper ribbon line edge wise volume voice coil where heatproof processing is administered to be connected directly, the visco-elastic polymers and the thermosetting metaplasia resin
    It was supported by the tangential edge of the special fiber which double coating is done. Movement of edge
    To bore the air hole through the outer pole of the edge rear in order to make smooth, letting escape the air of the edge rear
    It was. In addition, as for the air cell which attaching the taper, hollowed out the center pole, at back of the diaphragm air resonance
    Linear of the preventing and the diaphragm guaranteeing operation, you held down the distortion at the time of large input.
    As for magnetic circuit, diameter 100mm and weight 1.2kg, entire magnetic flux 12,000 Maxwell, flux density 15,500 [gau]
    The ferrite magnet of [su] was loaded. This beryllium mid- as for high, the playback of 500Hz~10kHz lap
    Wave number zone was actualized, the part of 2kHz~6kHz where even among these the especially distortion is little was used.
    As for the mid- bus, with JA-1205 of cone type of the 12cm aperture, using the cone paper which is finished lightweight, now
    It did. Voice coil was being something which winds the copper ribbon line where heatproof processing is administered, diameter 42mm.
    As for the edge, the cloth being something which was processed specially with the resin material, vis-a-vis the amplitude inside use zone the high linearity the truth
    You had displayed. As for magnetic circuit, with ferrite magnet of diameter 90mm and weight 1kg, entire magnetic flux 60,500 [matsu]
    Those which are 11,300 gauss in [kusuueru] and flux density were loaded. As for this mid- bus, 400Hz~
    It actualizes the playback zone of 8kHz, using the part of 600Hz~2kHz where even among these the especially distortion is little, now it does,
    It is.
    As for woofer, with cone type unit JA-3065 of 30cm aperture, conical type of corrugation entering
    The [re], the pulp cone also the division vibrations were few held down. In the edge the urethane which is superior in airtightness
    The roll edge was adopted. As for magnetic circuit, diameter 156mm and weight 4.4kg, entire magnetic flux 200,000
    The powerful large-sized ferrite magnet which is 10,000 gauss in Maxwell and flux density was adopted.
    [nometsukusu] of nylon fiber type of the Dupont corporation to be adopted by the voice coil bobbin, [etsu] of the copper ribbon line
    Adopting the long voice coil of the [jiwaizu] winding, the operation where the linearity is good was guaranteed. Plug
    The copper cap being put in the tar pole, the magnetostriction was held down.
    As for this woofer, lowest resonance frequency 20Hz, as for playback frequency zone with 20Hz~2kHz, below 600Hz
    The zone where the distortion is little was used. As for frame with the aluminum die-cast make of 1.3kg, gross weight 6kg
    It had become the structure which supports the woofer securely.
    Network wound the [horumaru] line whose in the coil direct current resistance is little in the bobbin of the ferrite core entering
    Being installed mutually perpendicularly in order is used, to decrease the inductance of the coil now
    It did. The MP condenser whose quality is good was adopted for the condenser. Crossover cycle
    As for number, woofer mid- bus at the clo sou over frequency of 600Hz 12dB/oct, mid- bust, mid-
    High with 2kHz 12dB/oct, to mid- high the eater was made 12dB/oct with 6kHz.
    As for enclosure, with bookshelf type of complete closed mold, as for surface oak finish, only baffle plate black
    It had become the finish. As for material, also the whole surface with particle board, as for baffle plate and liner thickness 25mm,
    Other things with thickness 18mm, had become strong ones which administer reinforcement to the various parts.
    Like above, as for NS-890, as a Yamaha ordinary model, as 4 way systems of the enthusiastic design SI
    They were 1 units where also lifting and the being settled of sound were thought well. It was put between name machine NS-1000M and NS-690
    There was the feeling which with feeling, loses, but, also elbowroom of the playback range was felt, it was the speaker of capability group.
    Below, portion of the catalog of that time is introduced.
    ________________________________________
    Tweeter of beryllium mid- highly
    New design mid- bus and woofer.
    Being bright in total, luxurious
    To new dimension, it flies with the character,
    Being luxurious, unique tall boy type
    Yamaha 4WAY.
    The specification of ●NS-890-
    Type 4way4 speaker airtightness type
    Use unit Woofer JA-3065.30cm cone type
    Mid- bus JA-1205.12cm cone type
    Mid- high JA-0521.5cm dome type
    [tsuita] JA-0520.3cm dome type
    Maximum permissible input 80W
    Rated input (JIS continuation) 40W
    Output overpressure value 92dB/W/m
    Frequency characteristic 40Hz~20,000Hz
    Lowest resonance frequency (fo) 40Hz
    Impedance 8Ω
    Crossover quality Bass - concave sound: 600Hz (12dB/oct)
    Concave sound - medium treble: 2kHz (12dB/oct)
    Medium treble - treble: 6kHz (12dB/oct)
    Level control Mediant treble continual yes deformation
    Enclosure content volume 55 liters
    Enclosure Particle board
    Wrapping finish Oak make-up
    External size 375 (W) ×745 (H) ×317(D) mm
    Weight 31kg
  2. Ahoang
    Ảnh của nó đây ạ
  3. Nacon
    Nacon Advanced Member
    HN
    Đôi này ác quá ta!
    bác đang dùng amp gì vậy?
  4. Ahoang
    Đôi loa này tôi ghép với Sansui alpha 607Extra, đầu đọc Teac ZD5000 đánh thẳng qua đường Power amp, nghe âm thanh gần giống băng cối.
  5. phonoaudio
    phonoaudio Advanced Member
    Em cũng đang dùng đôi này nghe đĩa than jazz và classic rất hay.
    Càng nghe càng thấy hay. Đôi này độ nhạy 92db.
  6. Ahoang
    Chao ban: phonaudio
    Đôi loa này tôi cũng chuyên dùng để nghe classic, tôi thích âm thanh của nó, vì có thêm loa trung màng giấy. Tôi chưa được nghe 1000M nên không dám so sánh, còn NS690 thì tiếng không hay bằng nó. Đôi loa 890 nay cũng ít xuất hiện trên thị trường.
    Thân mến
  7. Nacon
    HN
    Trước em dùng NS- A 1235 cũng thấy hay hơn NS 1000 M. :D :D
  8. phonoaudio
    Chào bác Ahoang!
    Em thấy ưu điểm đáng kể của nó là tiếng cân bằng, thể hiện tiếng nhạc cụ tốt, nhất là khi thể hiện giao hưởng, đặc biệt em thích nó vì nó không áp đặt tính cách cho bản nhạc mà chính người nghe sẽ cảm nhận được nhạc tính của bản nhạc đó một cách tự nhiên. Đầu tiên nghe nó hơi lạ, sau chính vì ưu điểm đặc biệt trên mà em thích nó.
    Em chưa nghe 1000M nhưng chắc là khó đánh hơn em này, và khi nghe đĩa than em mới hiểu tại sao các bác khác lại khó phối ghép như vậy....
  9. phonoaudio
    Bác Nacon được nghe các dòng khác của YAMAHA, thật là may mắn.
  10. Nacon
    HN
    Trước em cũng lọ mọ tìm hiểu nhiều về các model, giờ nếu có điều kiện thì sưu tầm cũng hay, và để thỉnh thoảng nghe đổi giọng. Em vẫn thích sự truyền tải nhanh, chính xác của dòng loa này. :)
  11. Nacon
    HN
    Tháng trước có bác bán cặp NS- A 7700. mà mua hụt mất. :roll:
  12. Sherry
    Sherry Advanced Member
    Cái power Yamaha của em, 4 tụ Yamaha to bằng lon sữa bò mỗi cái 22.000mF + 4 tụ For audio Elna to bằng lon Heineken mỗi cái 100.000 mF :shock: - toàn bộ tụ to nhỏ lớn bé ... không biết bao nhiêu cái ... đều là For audio Elna - khoe tí chơi :
  13. Ahoang
    Power Amp yamaha sê ri gì mà trông gấu thế bác ơi, em này mà đánh vào loa của mình thì chắc là hợp.
  14. Nacon
    HN
    Có chú 101 M này cũng có 580 W/ kênh
  15. Nacon
    HN
  16. Nacon
    HN
  17. hieuats
    hieuats Advanced Member
    Em có 2 em này thì mời khách luôn.
    Bóc sò 1 em đem nướng, bóc Bia ken 1 em đem uống, phê ù 2 tai khỏi cần nghe nhạc. hehe dân nhậu.
  18. tannguyenba
    tannguyenba Advanced Member
  19. Nacon
    HN
    Để sưu tầm thì đáng quá rồi còn gì, để nghe thì phải xem.
    Nếu chán thì bán sang Mẽo, bọn này thích Ya lắm! :D :D
  20. Sherry
    Em có bộ này:
  21. dongsongbac
    dongsongbac Advanced Member
    móa ơi cặp pre-pow khủng long quá, hic hic em thèm quá
  22. dongsongbac
    Cặp này em nghe rồi, miễn bàn quá hay
  23. chich_bong_oi
    chich_bong_oi Advanced Member
    Lâu không được nghe tiếng dòng Yamaha, em thấy nhớ, nay muốn tìm một đôi NS10M hoặc NS1000M để thỏa sầu, có bác nào biết ở đâu có loa tốt cần bán vui lòng cho em biết với nhé. Em cảm ơn các Ya-Fan trước nha.
    Thân mến
  24. vqthuthach
    vqthuthach Advanced Member
    1 em pow dầu bảng trong dòng b2 ghép với 1 em pre cuối bảng trong dòng c2 , sao bác ko kiếm 1 em c2x cho nó môn dăng hộ dối
    :D :D :D
  25. cuncon
    cuncon Approved Member
    Có C2x ở đâu mách em với anh Long
