AD1955, các bác cho vài lời nhận xét
Discussion in 'Thiết bị số' started by risc, 23/4/08.
  1. risc
    risc Advanced Member
    Em vừa nhận được 1 cap AD1955. Có bác nào đã từngnghe qua em này chưa? Đây là một số tính năng do hãng analog quảng
    cáo về em nó.
    FEATURES
    5 V Power Supply Stereo Audio DAC System
    Accepts 16-/18-/20-/24-Bit Data
    Supports 24-Bit, 192 kHz Sample Rate PCM Audio Data
    Supports SACD Bit Stream and External Digital Filter
    Interface
    Accepts a Wide Range of PCM Sample Rates Including:
    32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, and
    192 kHz
    Multibit Sigma-Delta Modulator with "Perfect Differential
    Linearity Restoration" for Reduced Idle Tones and
    Noise Floor
    Data Directed Scrambling DAC––Low Sensitivity to Jitter
    Supports SACD Playback with "Bit Expansion" Filter
    Differential Current Output for Optimum Performance
    8.64 mA p-p Differential Output
    120 dB SNR/DNR (not muted) at 48 kHz Sample Rate
    (A-Weighted Stereo)
    123 dB SNR/DNR (Mono)
    –110 dB THD + N
    110 dB Stop-Band Attenuation with 0.0002 dB
    Pass-Band Ripple
    8 Oversampling Digital Filter
    On-Chip Clickless Volume Control
    Supports SACD-Mute Pattern Detection
    Supports 64 fS/128 fS DSD SACD with Phase Mode
    Internal Digital Filter Pass-Through for External Filter
    Master Clock: 256 fS, 512 fS, 768 fS
    Hardware and Software Controllable Clickless Mute
    Serial (SPI) Control for Serial Mode, Number of Bits,
    Sample Rate, Volume, Mute, De-Emphasis, Mono Mode
    Digital De-Emphasis for 32 kHz, 44.1 kHz, and 48 kHz
    Sample Rates
    Flexible Serial Data Port with Right-Justified, Left-
    Justified, I2S, and DSP Modes
    28-Lead SSOP Plastic Package
    Tuy nhiên theo lời quảng cáo này chưa thì chưa biết võ công của nó thế nào, em muốn các bác cao thủ cho em vài lời nhận xét về AD1955 trước khi DIY mach DAC này.
    Em co gui kem datasheet theo cho các bác tham khảo
    http://www.analog.com/UploadedFiles/Data_Sheets/AD1955.pdf
    Cam on cac bac.
  2. DIY-lover
    DIY-lover Advanced Member
    TBG - HCMC
    Re: AD1955, cac bac cho vai loi nhan xet
    Em cũng đang định làm con này đây, Hiện đang là dòng đỉnh nhất của AD rồi còn gì!
    Vừa rồi nhờ Cậu Bạn mua một ít về dùng, cậu ấy bảo mua 500 con cho nó rẻ (chỉ ~$8/con), Em nghe hãi quá bỏ ý định luôn.
    Bác có dư cặp nào nhượng lại Em một bộ được không ạ. Còn mấy con IC đi kèm với nó Bác có đủ chưa ạ?
  3. risc
    Em chi có duy nhất 1 cap AD1955 thôi bác ạ. Em đang còn dư 1 cặp AD1958, cũng chưa nghe thử em này bao giờ nên ko biết chất âm của nó thế nào. Nếu bác ko chê em gả lại cho bác luôn, hihi.
  4. tivoi
    tivoi Advanced Members
    HCMC
    em cũng nghe đồn con này tốt lém mà chưa có thử :D
  5. risc
    Hị hị, thế thì em phải bắt tay vào thi công. Ngặt nỗi trong mach I/V va single-end output toàn dùng AD797. Con opamp này đắt lòi luôn các bác. Em đang có sẳn vài con OPA134. Thay bằng loại này có được không nhỉ? Các cao thủ cho em lời khuyên nên dùng con nào là tốt nhất?
  6. Lotomo
    Lotomo Advanced Member
    I/V buffer chơi đèn đi bác. Chơi đèn hiệu quả hơn OPA rất nhiều.
  7. Macao
    Macao Advanced Member
    THỦ ĐỨC GROUP
    Để em xem lại, hình như em có 1 cặp AD1955, nếu cụ thích ngâm cú thì em xin dâng ạ.
  8. risc
    Bác Lotomo cho em xin thêm thông tin về I/V đèn đi. Trước giờ em toàn sử dụng bán dẫn, về cái khoản đèn đóm này thì em mù tịt. Cảm ơn bác trước
  9. ClassA
    ClassA Moderator
    Con này rất đáng thử đây, hay là tập trung vào đặt hàng đi các bác ơi.
  10. Lotomo
    Bác Risc có thể tham khảo 1 mạch I/V. Mạch này do 1 cao thủ trên VNAV tặng em.
  11. risc
    Đèn trong mạch này là loại nào vậy bác? Mình có thể tìm mua ở cửa hàng nào (ở SG)?
  12. Lotomo
    Ah quên, em dùng đèn 6C3P của anh Hai. Có nhiều đèn có thể làm IV rất tốt như 6DJ8, 5687...
  13. risc
    Cám ơn bác, để em ngâm cứu vụ I/V đèn này. Có thắc mắc gì về vụ đèn em lại lên đây réo bác nữa :D
  14. risc
    Bác cho em hỏi chút, em thấy trong mạch của bác, Ibias = 2mAm điện áp ngõ ra đo được Vo = 0V.
    Theo spec của AD1955 thì Ibias = -3.24 mA, bác có thể giúp em tính lại các thông số diện trở và tụ điện trong mạch
    I/V đèn của bác được không?
  15. tivoi
    HCMC
    cái bias đèn chỉ định chế độ chạy của tube thôi ah, Ngõ ra của ad1955 biến thiên trong khoảng 8.64. nên chỉ cần chỉnh R3 sao cho ac out = Iout x R3 x muytube = 2V la được ah (muytube la hệ số khếch đại của tube)
  16. risc
    Cám ơn bác Tivoi. Phần digital cho DAC này em đã vẽ PCB xong, chỉ còn phần analog này là phải tiếp tục ngâm cứu kĩ.
  17. risc
    Theo datasheet AD1955, Ibias = -3.24 mA, Iout(full scale) = 8.64 mA peak-to-peak. Em làm phép tính sơ bộ như thế này
    => dong điện ngõ ra của AD sẽ là từ [-7.56 mA, -3.24 mA, -1.08 mA]
    Vi DAC này la differential current output nên ta phải sử dụng 2 mạch I/V, sau đó dùng một mạch trừ (opamp hay đèn?!) để tạo Vout phải là từ [-2.828V, 0V, +2.282V] (2 Vrms). Như vậy tại Ibias = -3.24 mA, điện áp ngõ ra của mạch I/V đèn ko thể là 0V. Dùng công thức của bác tivoi với đèn 6C3P (gain=50), R3 = 10 ohm, thi Vout = -1.62V @Ibias=-3.24 mA.
    Các bác xem có hợp lí ko.
  18. BachDuong
    BachDuong Moderator
    Với mạch trên thì gain của 6C3P không được 50 đâu. Bác dùng R3 cỡ khoảng 30ohm là vừa.
    Ngoài ra em thấy con trở R4 bé quá
    Thôi em trốn đây kẻo anh vẽ mạch anh ấy uýnh chết :mrgreen:
  19. risc
    Em thấy trong datasheet của 6C3P ghi là khoảng 50, nên em mới tính sơ bộ như vậy.
  20. tivoi
    HCMC
    trên lý thuyết la 50 trong thực tế thướng ko đạt tới giá trị này ah, :D :lol:
  21. risc
    Trong lúc chờ đợi mua được đèn, em thi công mạch I/V bằng opamp theo reference design trong datasheet với một vài thay đổi nhỏ cho phù hợp.
    Kết quả sau 1 buổi làm việc nó ra thế này:
    Receiver CS8416 và vi điều khiển 16F873A
    Nhân vật chính cần tét hôm nay: AD1955, I/V opamp, single-ended output
    Cổng Coax 0 đang cắm sẳn vào PC, em mở bản "I love you" và "The messenger" của Jeff Martin để thử
    Thêm vài hình khi tét với CDP, "Silent night", Dave Koz and Friends, âm thanh thật ấm áp, mộc mạc làm sao, hị hị
    Cuối âm thanh cũng hét lên ở căp loa (giựt mình vi để volume lớn quá :mrgreen: )
    Theo cảm nhận của riêng của em, tiếng đàn ghi ta chi tiết nhưng ko quá sáng như PCM1793A (ko biết đây có phải là đặc điểm chung của Burrbrown ko nữa), giọng nam ca thì ấm áp, dễ chịu =>> kết em AD1955 này rồi.
    Đó là vài dỏng cảm nhận của em.
  22. tivoi
    HCMC
    nhà em cũng có tầng IV na na cửa bac :lol:
  23. ClassA
    ClassA Moderator
    Sao tầng IV của bác dùng lắm opam thế nhỉ? Mà bác risc kiếm đâu được mấy cái PCB ngon thế?
  24. tivoi
    HCMC
    con này ngõ ra blance anh class A ui, qua tầng đầu là 4 con opamp đơn để IV , 2 con don tang sau de chuyen BTL > single
    tí cũng có làm cái giống vậy mà :D
  25. risc
    Bác Tivoi nói đúng đấy bác ợ.
