-Chào các Bác, hôm nọ Em lọ mọ xem thấy có 1 website nói về các bóng sản xuất theo công nghệ Cryoset certified -www.cryoset.com , Em không biết có khác so với công nghệ thông thường không hay là đây chỉ là cách nhằm để quảng cáo nâng cao giá thành sản phẩm ( bóng 300B EH cừu vàng: $140/cặp , 300B EH cừu vàng Cryoset certified:$175/cặp ) -Em đọc thấy 1 vài tay DIY ở nước ngoài khen lắm , Bác nào có biết qua rồi vui lòng cho Em biết với , còn Em thì chả hiểu -Cám ơn các Bác
-Các Bác xem http://www.cryoset.com -What is Cryogenics? The proprietary Cryoset treatment process utilizes a computer controlled, cryogenic chamber to very gradually reduce the temperature of the tubes to 300 degrees below zero (Farenheit) and holding them there for a minimum of 24 hours. After the extended dwell at this cryogenic temperature, the vacuum tubes are then very slowly brought up to ambient temperature over the next 24 hours and stabilized. The process is a "dry" one that utilizes Liquid Nitrogen as a cryogen that is flashed into the chamber. The tubes are never exposed to the actual liquid. All these processes are microprocessor controlled under strict and verifiable conditions. Scientists have known for years that material transformations occur when they are exposed to cryogenic temperatures. Many of the early discoveries were more fully explored by NASA engineers who were trying to understand what would happen to metals when subjected to the extreme temperatures of space. Today, a wide range of commercial items - from softball bats to race engines - are cryogenically treated to improve their performance by enhancing the material properties with "cold treating" or cryogenic processing. This technology brings practical application to audio and other electrical components as well. Cryogenic treatment modifies the microstructure of the metals used in critical electronic components by reducing or eliminating voids and imperfections in the material. Crystal structures (or grains) have been shown to be modified after cryogenic treatment, creating a more uniform or homogenous microstructure. The thermal dissipation properties of the metals is improved, reducing hot spots and further contributing to extended life and improved performance. In addition, the physical contraction of the metals while under the deep freeze imparts a mechanical compression on the metals that contributes to improved signal transmission quality and speed. The materials used in electronics are highly fabricated and the manufacturing processes used impart or induce stresses in them. In addition, welding and soldering adds additional stress from concentrated areas of heating. Most everyone recognizes that welded components often fail AT the weld -- a "weak" spot. The weakness comes from residual stresses inherent in all materials, further exacerbated by manufacturing techniques or processes. Cryogenic treatment releives stresses and normalizes (or stabilizes) welded and soldered areas. This mechanism is founded in the observation first made by Bose (of Germany) and later by Einstein, that matter is at it most relaxed state when it has the least amount of kinetic energy (or molecular activity). Absolute zero (-459 Farenheit) is that point where no more energy can be extracted, or when a material is at its most "relaxed" state. While our Cryoset (R) thermal treatment does not get to absolute zero, you can understand how going to minus 300 degrees Fareneheit for an extend dwell time enables the material to become more relaxed and stress relieved. The transformations that occur as result of cryogenic treatment are a permanent, one time modification to them. The process makes a permanent change and the benefits do not deteriorate over time or upon return to operating temperature, it changes the whole way the vacuum tube performs. The major benefit has been a dramatic improvement in dymanic range. Bass response has been clearer with reduction in microphonics. The most starling fact has been how the tubes operates under saturated and overdriven conditions. This has made some of the more basic guitar amps sound fuller and warmer. Testimonials Tim Schultz after purchasing a pair of Cryoset EH6922 Preamp Vaccum Tubes wrote us, "Hi Ron, the tubes arrived on Friday and I swapped out the Telefunkens I was using in my Blue Circle preamp and have to admit these tubes are terrific as mentioned in your add. I noticed better more focused bass and better dynamics, I would add to this a wider and higher soundstage, better resolution and more natual balanced timbre. I am very happy with my purchase, these are an outstanding value far superior to the stock eh tubes that come standard in my pre amp. Best Regards, -Tim Schultz" Hank after purchasing a quad of Cryoset Electro Harmonix KT88EH Vaccum Tubes wrote us, "Hello Ron, I have received the second set of Cryo EH KT88s, just set the tubes in my amp, and wow man, great sound better than every other tube I have ever had. The stage is great and details is big. I expected that this will more growing after break-in time but I am very glad about this! Best Regards, Hank" Michael after purchasing a quad of Cryoset Mullard EL34 Vaccum Tubes wrote us, "Hi Ron, The tubes are definetely better sounding than the original GT-EL34Rs that were in my Crate VX5212 guitar amp. They are louder, more detailed and full body sounding! Thanx, - Michael"
Chào bạn hai đoạn trích dẫn này quan trọng nhất .Tạm hiểu : Vật liệu để chế tạo đèn được gia công và bảo dưỡng ở một nhiệt độ cao trong một khoảng thời gian nhất định ( ít nhất 24 giờ ) và được trả về từ từ nhiệt dộ làm việc của nó Kết quả của quá trình này khiến các điện cực của đèn làm việc ổn định trong môi trường nhiệt độ cao đều đặn của một đèn điện tử bình thường khiến dải động , đải thộng của đèn được cải thiện từ đó tăng cao tính chi tiết tính trung thực ổn định của đèn . Liêm tưởng , công nghệ đến từ các kỹ năng gia công vật liệu cho tầu vũ trụ : Tầu vũ trụ phải trải qua một quá trình thay đổi nhiệt độ rất lớn lúc cọ sát với bầui khí quyển và nhiệt độ buồng đốt , nếu vật liệu không chịu đựng được dải nhiệt độ đó thì tàu sẽ nóng chảy hoặc đông cứng . Hiện tượng này là có thực nhưng đèn mà người ta quảng cáo có thực sự được chế tạo như thế không lại là vấn đề khác . Nếu quả tình như vậy sự chênh lệc giá là quá ít ( bóng 300B EH cừu vàng: $140/cặp , 300B EH cừu vàng Cryoset certified:$175/cặp ) . Các bác có nghe nói nếu dầu phụ gia xe máy từ công nghệ vũ trụ của Mỹ và Liên xô trên thị trường không ? Tôi dùng thấy khong làm cho hơi xe khỏe lên chút nào Chúc vui
