Cùng làm Pre HAY-RẺ-DỄ - Đăng ký board đợt mới Tr.132
Discussion in 'Đèn điện tử' started by DIY-lover, 10/2/09.
  1. Dztronic
    Dztronic Advanced Member
    Re: Cùng hiện thực hóa Rề HAY - RẺ - DỄ nhất mọi thời đại
    Lại nói về cái dzụ méo hài lẻ tăng chi tiết giải cao. Em cái tật là nói phải có sách mách phải có chứng. :D Không biết ma đưa lối quỷ đưa đường ra sao mà lại lạc vào bài báo Xì Tê Gê Ô Phai rì viu cái gề khủng mười mấy xấp BAT Rex. Em xin trích vài khúc trong đoạn rì viu:
    More impressive, though, were the Rex's musical performances. Why the plural? Based on my experience, the internally mounted AC Shunt Voltage Regulation switch in the power module that lets you choose between pairs of 6H30 and 6C45 tubes produced huge audible differences.
    Set to its 6H30 position, the Rex sounded "tube-like" in the clich éd sense of the word: rich, warm, "midrangey," somewhat soft overall, sluggish and thick in the bass —just the way some folks like it. Not me. The soundstage was narrowed and squeezed forward, producing Lava Lamp –like, slow-moving, lumpy images (I exaggerate for effect) —again, just the way some folks like it, and again, not me. I've heard this sound at audio shows and for the life of me can't understand why anyone thinks it has anything whatsoever to do with the sound of live —or recorded —music, I don't care what the genre!
    However, flipping the switch to the 6C45 position completely changed everything about the sound. It was like tightening a set of Koni shock absorbers (old school): now the sound was fast, properly stiff, taut, and responsive. The soundstage widened and receded to a proper "get outta my lap" distance, while maintaining its outstanding depth. Images suffering from elephantiasis shrank to their proper size and crystallized cleanly. The tonal balance became airy and expansive on top, rich and supple in the midrange, and tight and deep down below, combining the best of tubes and solid-state in one mesmerizingly excellent presentation.
    Set to the 6C45 position, the Rex produced an essentially neutral tonal picture: neither dark nor bright, with ideal top and bottom extension, and creamy-rich mids that brought out the fleshy essence of human voices, polished the brasses, rounded the woodwinds, slipped the drums some skin, and had the strings sporting wood. Yet at the same time, the Rex was able to pass with ease the essential spit and distortion of solid-bodied electric guitars and the squarewavy sound of purposely distorted digital overdrive, all laid out with unforced enthusiasm on a big, wide-open soundstage. In other words, in the 6C45 position, the Rex produced fast transients along with tubey warmth and grace.
    The Rex's performance at the frequency extremes was exemplary: extended, airy, and detailed on top; full, fast, and extended on bottom. Though some solid-state preamps I've heard are faster and tighter on the bottom, they couldn't compete with the Rex's expression of bottom-end weight and texture. Dynamically, the Rex was fully fleshed out at the whisper end of the scale, and packed a wallop at the other end. I could have happily and enthusiastically listened for weeks on end to this kind of sound. In fact, I did. But with the Rex set to its 6H30 position, I couldn't listen happily at all.
    Your tastes and system may produce very different results. However, if the goal is to route and control a signal's volume without otherwise altering the signal itself, the 6H30 position failed the test. It was like adding too much ground clove to an otherwise excellent apple pie: the Rex's sonic character was overwhelmingly large, and not subtle enough to recede into the background even after my ears had adjusted.
    Giải thích đại loại là chị Chon Át King Sân nghe xong bẩu cấu hình BAT Rex có khả năng dùng 2 nguồn dòng (CCS) và cho 2 âm thanh khác nhau: 1 là dùng bóng 6H30P và 2 là 6C45P. Chị nghe xong bẩu là dùng 6C45P âm thanh hay hơn, chi tiết, âm .... cái gì cũng hơn; trong khi dùng 6H30P tiếng lù đù, dày, và dính (?) ...
    Sau đó chị dùng máy đo khủng đo méo hài và do cái gề rì viu bị trục trặc 1 kênh trái (Left) nên chị cũng đo thử và ký hiệu màu xanh dương. Em quan sát và đã đánh dấu 2 số đo ở hài 5kHz và 7kHz của CCS 6H30P và 6C45P. Của 6C45P hài bậc 5 (5kHz) và đặc biệt là 7 (7kHz) đều là hài lẻ đều cao hơn của 6H30P nếu chưa muốn nói là 6H30P không có hài bậc 7 (7kHz). Cả chị Chon và cả Victor Khomenko (thiết kết và chủ của BAT) đều thít chất âm của 6C45P hơn. Như em đã nói bóng 6H30P có hài lẻ cao tạo ra âm thanh chi tiết bán dẫn thì theo số đo của chị Chon thì ngoài hài bậc 2 (2kHz) và 3 (3kHz) bóng 6H30P còn có thêm bậc 5 (5kHz) và đôi khi bậc 7 (7kHz) tùy theo thay đổi thiết kế; trong khi nhiều bóng 3 cực khác nhất là họ 6SN7 thường chỉ có méo bậc 2 và 3 cùng lắm là 4 chứ ít khi nào có 5 trừ khi thiết kế quá méo.
    Và rõ ràng nếu theo số đo méo hài của chị Chon khi so sánh dùng CCS 6H30P và 6C45P thì 6H30P có số đo kỹ thuật tốt hơn vì ít méo hơn trong khi mấy thông số khác như băng thông, tổng trở ra đều tương tự nhau. Và sau khi nghe xong chị Chon cũng khen và xem ra thích nghe méo nhiều hơn ---> "Ô đi ô iz phun ớp Lai" hoặc có thể nói khác đi là tai chị Chon cũng có vấn đề (như tai của các chị em ta) ? Và nếu nói kiểu "so sánh rừng" là tai chị Chon còn chưa chắc nhạy hay "trình độ" bằng tai đệ tử guột của Trư Nguyên Soái trong 4rum chúng ta :lol:
    Và một lần nữa Goldmund cũng vẫn đúng là "nghe và đo" vẫn có sự liên quan với nhau! :wink:
    Tiếc thay thím Lọ không có máy đo khủng như chị Chon của báo Xì Tê Gê Ô Phai chứ theo ý riêng của em thì số đo gề "Ham Gẻ Dở" của thím Lọ có số đo kỹ thuật từ bằng cho đến vượt qua (xa) số đo cái gề mười mấy xấp BAT Rex này và đương nhiên là so với ngay cả khá nhiều gề Tube từ mấy xấp đến chục xấp. Em đề nghị đổi tên gề thím Lọ là "Quá Ham Gẻ Dở" :mrgreen:
  2. ssass
    ssass Advanced Member
    em nhà quê chỉ hiểu " méo hài " là " méo cười " được không ạ ! Méo nhiều cười nhiều , méo ít thì cười ít . :roll:
  3. Dztronic
    Đương nhiên là được !
    Tuy nhiên là người thiết kế sản phẩm kỹ thuật ở đây là cái gề "Ham Gẻ Dở" như thím Lọ hay những người thiết kế sản phẩm kỹ thuật khác thì họ cần phải hiểu theo nghĩa khác để mong giải cho mọi người hiểu hoặc/và thiết kế 1 sản phẩm kỹ thuật thiết thực, phù hợp với túi tiền cho chị em ta nói riêng hay nhân loại nói chung ... :wink:
  4. DIY-lover
    DIY-lover Advanced Member
    TBG - HCMC
    Hảo hảo, Em đã chiều theo ý Cụ Dzai.
    - Bẩm các Cụ, Tối qua lọ mọ thế nào cắm chập điện làm nổ tung tóe hết lô 12DZ9 nên không thể chộp hình báo cáo được, tiếc quá!!!
    - Để đợt tới bên "Ở đâu có đèn, ở đó có Điện Quang" họ thiết kế thêm vài loại bóng mới Em sẽ test thử và báo các các Cụ sau nhe :mrgreen:
  5. DIY-lover
    TBG - HCMC
    Để đợt tới Em quớt 1 mớ về đo cho đã nghen Cụ.
  6. candy_sniper2007
    candy_sniper2007 Advanced Member
    Ho Chi Minh City
    Re: Cùng làm Rề QUÁ HAY - QUÁ RẺ - QUÁ DỄ nhất mọi thời đại
    he..he..em hàn xong board rùi bác LOVER ơi, chỉ có điều chỗ biến trở em ko có nên em tạm thời "cua" tắt qua biến trở và dùng con điện trở 390K thành 470K luôn được không bác. Tạm thời thôi vì cuối tuần mới ra chợ NT mua biến trở được. À, em chỉ có BA ngõ ra 0 -290V thôi, em quên cách tạo nguồi đôi từ nguồi đơn này rồi, bác giúp em với. Em nhét đỡ 2 cây đèn 6C4 vô chỗ 6J6 nhìn cũng đỡ ghiền nhỉ..he.he..
  7. DIY-lover
    TBG - HCMC
    Cụ tháo 4 cái đế đèn ra quay mặt lại hàn dùm Em gấp.
    Không có biến trở thì đừng nghe, khi nào có biến trở rồi nghe.
  8. candy_sniper2007
    Ho Chi Minh City
    À, em góp ý bác Lover sau này nhớ làm cho anh em cái điểm hàn cọc giữ đế gắn chân đèn trên chassic nhé (nó nằm giữa vòng tròn chân đèn í). Mỗi lần em cắt bỏ nó đi thấy tiếc tiếc sao ấy mà lại mất đi chỗ trợ lực do để nguyên thì lại đụng mạch in.hi.hi..
  9. ThivanAudio
    ThivanAudio Advanced Members
    812/39 Trường Sa, Phường 9, Quận 3, TPHCM
    Trời, Ông Lover ổng thích cải tiến (lùi ???) dzay đó Bác ơi.
  10. anhlongtranf
    anhlongtranf Advanced Member
    Bác Diy-love ơi? Đã có bo chưa vậy? Sao bác candy_sniper2007 đã có bo rồi vậy bác?
  11. candy_sniper2007
    Ho Chi Minh City
    Oh, bác ơi, bác thông cảm bác í đi, em nhận cái này từ hồi đầu topic lận bác ơi..hi.hi.. bác thấy mạch in của em thuộc version cũ còn khu vực gắn relay để đóng trễ nữa không....he..he...
  12. ducanhle
    ducanhle Advanced Member
    bác cẩn thận nhé, link kiện hàn ngược được chứ chân đèn thì...chắc là ko được rồi :twisted:
  13. candy_sniper2007
    Ho Chi Minh City
    Ah há, nhờ bắc nhắc em mới nhớ, em cứ hay lẫn lột chân 1 của đèn..hi.hi..cảm ơn bác nhé.. :mrgreen:
  14. DIY-lover
    TBG - HCMC
    BO PRE HAM RE DO - HAY RE DE ĐÃ HOÀN THÀNH
  15. candy_sniper2007
    Ho Chi Minh City
    Troi ơi, đẹp quá, em lại nổi lòng tà nữa rồi...hu..hu...
  16. migiang
    migiang Advanced Member
    Vietnam
    Đẹp quá !... bác cho anh em kích cỡ của bo mạch để anh em làm chassis cho hợp lý ! Theo bác thì W-H-D cỡ bao nhiêu cm thì vừa xinh ? Cám ơn bác trước !...
  17. Sibachao
    Sibachao Advanced Member
    TP.HCM
    "Xấu quắc", khi nào em có 1 bộ em mới thấy đẹp :lol: :lol: !
  18. al1412
    al1412 Advanced Member
    :cry: :cry: :cry: :cry: sao mà nhìn thích vậy trời!!!
  19. ducanhle
    Ủa sao chơi đèn 7 chân hả bác DIY :oops:
  20. DIY-lover
    TBG - HCMC
    Dạ, đúng Cụ ạ.
    Đây là những đèn nhỏ mà âm thanh không nhỏ đâu ạ. Không dùng thì người ta đập bán ve chai hết, sau này có muốn cũng không có mà chơi.
    Không dưng mà Em thiết kế cấu hình này đấu với 6H30, 417 của Cụ Chip, Cụ Via đâu ạ. :wink:
  21. DIY-lover
    TBG - HCMC
    Re: Đăng ký bo mạch Rề HAY - RẺ - DỄ nhất mọi thời đại
    KẾT SỔ
    Em chia theo vùng miền để gởi, các Bác kiểm tra xem có đúng không
    - HÀ NỘI: Nhờ 1 bác đứng ra nhận giúp!
    1 - tta60: 1 bộ
    3 - Vusonlvb : 1 bộ
    5 - ducanhle: 1 bộ
    6 - ThuyLT: 2 bộ (1 cho em, 1 cho em gái thích đèn đóm)
    7 - Addicted - 1 bộ
    8 - NgoCanh - 1 bộ
    9 - PhanTran - 2 bộ
    11- Mesl45 - 1 bộ
    13 - quanghao168 - 1 bộ
    18 - VQ_audio - 1 bộ
    - HUẾ: Bác Minh Triết cho xin địa chỉ?
    17 - Minh triết - 1 bộ
    - TPHCM: đến quán Rùm Beng nhận giúp Em :)
    14 - vuthanh6 - 1 bộ
    15 - linh moi - 1 bộ
    16 - anhlongtranf - 1 bộ
    19 - Pc_Chip - 1 bộ
    20- Regular!- 1 bộ
    Em không biết ở đâu, đề nghị các Bác chuyển vào vùng tương ứng ở trên gấp.
    2 - detec: 1 bộ
    4 - Migiang: 1 bộ
    10-Hoaphuc - 1 bộ
    12- ChiMD - 1 bộ
    - Thứ 2 là có mạch, mời các bác chuẩn bị linh kiện, khi nhận bo là hàn ngay đem quánh thử nghe xem phê hông :)
    - Từ hôm nay lo chuẩn bị biến áp là vừa rồi.
    Bo này Em tích hợp luôn cả 2 kênh và phần nguồn dzô luôn, cực kỳ đơn giản, linh kiện dễ tìm, ở đâu cũng có. Chỉ cần thêm cái BA nguồn là chạy luôn.
    - Đốt tim AC trực tiếp từ biến áp.
    - Thêm tùy chọn xuất direct hay qua tụ cho các bác chưa rành cân chỉnh mạch hoặc hơi yếu tim :mrgreen: , tốt nhất là xuất direct nghe là phê nhất, thể hiện đúng khả năng nổi trội của mạch OCL OTL này, còn muốn xuất tụ cho chắc ăn thì lo mua 1 cặp tụ thiệt xịn ~ 10uF/200VDC mới có thể đạt được 9.5 phần công lực so với xuất trực tiếp.
  22. linh moi
    linh moi Advanced Member
    Re: Cùng làm Rề HAY - RẺ - DỄ nhất mọi thời đại
    Bẩm cụ DIY lover :)
    Cụ thương thì thương cho trót .....cụ mách nhỏ cho em chổ nào bán mấy cái bóng nầy, mấy bửa rày em củng có thăm dò thị trường , bảo là có tay đầu nậu gom hết rồi :) Linh kiện thì em không ngại , chơi đồ xịn không nổi em chơi linh kiện cô hai củng xong , biến áp thì em lại nhờ đại cao thủ DIY đặt dùm .......... Cụ trên cao cao ngó xuống tí cho em nhờ ...........nếu không em bị treo nick vì luật 49 ngày tội em lắm cụ ơi :)
    Kính cụ
    P/S biến áp theo cụ phán thì có phải là như vậy hay không :vào 220v ra 120v - 0 (50mA) , 120v - 0( 50mA ), 6v3 - 0 ( 0,6A ) . 6v3 - 0 (0,6A)
    Em làm 1 cuc biến áp ra như vậy có xài được hay không , hay là phải chơi 2 cục biến áp ( em kỉ tính nên hỏi cụ đừng có rầy em nhe ) :)
  23. Dztronic
    Không hiểu sao tên topic cứ bị đổi qua đổi lại vậy hà? :evil:
  24. DIY-lover
    TBG - HCMC
    Bẩm Cụ thít tên gì thì cho Em biết để Em . . . đổi típ ạ ?
  25. DIY-lover
    TBG - HCMC
    - 6J6 thì tương đương với 1 bóng 6DJ8 đấu chung cathode
    - 6C4WA thì tương đương với 1/2 bóng 12AU7
    1 Cục biến áp thông số như trên là được.
    cám ơn Cụ đã chỉ điểm Em chỗ mua Volume :)
