Salas Shunt regulator - The Best Supply for PRE And Phono
Discussion in 'Đèn điện tử' started by quanghao, 5/12/09.
  1. thainhnh
    thainhnh Advanced Member
    Vũng Tàu
    Re: Simplistic Mosfet HV Shunt Regs
  2. mitxinh
    mitxinh Advanced Member
    Hello Mr Salas, em đăng ký với:
    1. ducanhle : 04 bo
    2. ddinhchi - HN : 02 bo
    3. vq_audio : 02 bo
    4. quanghao: 10 bo
    5. An-haiphong: 5 bo
    6. luongnhi : 02 bo
    7. Bachduong: 4 bo
    8. Vancao: 5 bo
    9. Pc_Chip: 4 bo
    10. niubai +Thainhnh =5 bo
    11. Cominup: 02 bo
    12. curock 02 bo
    13. mitxinh: 2 bo.
  3. PhanTran
    PhanTran Advanced Member
    1. ducanhle : 04 bo
    3. vq_audio : 02 bo
    4. quanghao: 10 bo
    6. luongnhi : 02 bo
    7. Bachduong: 4 bo
    8. Vancao: 5 bo
    9. Pc_Chip: 4 bo
    11. Cominup: 02 bo
    12. curock 02 bo
    13. mitxinh: 2 bo.
    14. PhanTran: 2bo
  4. khanh.na
    khanh.na Advanced Member
  5. phuongmitec
    phuongmitec Advanced Member
    Kim Mã - HN
    1. ducanhle : 04 bo
    3. vq_audio : 02 bo
    4. quanghao: 10 bo
    6. luongnhi : 02 bo
    7. Bachduong: 4 bo
    8. Vancao: 5 bo
    9. Pc_Chip: 4 bo
    11. Cominup: 02 bo
    12. curock 02 bo
    13. mitxinh: 2 bo.
    14. PhanTran: 2bo
    15.khanh.na: 2 bo
    16: phuongmitec: 1 bo
  6. thienthanh
    thienthanh Advanced Member
    Hạ Long - Quảng Ninh
    1. ducanhle : 04 bo
    3. vq_audio : 02 bo
    4. quanghao: 10 bo
    6. luongnhi : 02 bo
    7. Bachduong: 4 bo
    8. Vancao: 5 bo
    9. Pc_Chip: 4 bo
    11. Cominup: 02 bo
    12. curock 02 bo
    13. mitxinh: 2 bo.
    14. PhanTran: 2bo
    15.khanh.na: 2 bo
    17: hkthienthanh: 2 bo
  7. khuehn
    khuehn Advanced Member
    Ha noi
    1. ducanhle : 04 bo
    3. vq_audio : 02 bo
    4. quanghao: 10 bo
    6. luongnhi : 02 bo
    7. Bachduong: 4 bo
    8. Vancao: 5 bo
    9. Pc_Chip: 4 bo
    11. Cominup: 02 bo
    12. curock 02 bo
    13. mitxinh: 2 bo.
    14. PhanTran: 2bo
    15.khanh.na: 2 bo
    18: Khuehn: 02 bo
    Cụ ơi Hào ơi, bao giờ chốt số lượng đi làm mạch đấy :?:
  8. an-haiphong
    an-haiphong Advanced Member
    1. ducanhle : 04 bo
    3. vq_audio : 02 bo
    4. quanghao: 10 bo
    5. An-haiphong: 10 bo
    6. luongnhi : 02 bo
    7. Bachduong: 4 bo
    8. Vancao: 5 bo
    9. Pc_Chip: 4 bo
    11. Cominup: 02 bo
    12. curock 02 bo
    13. mitxinh: 2 bo.
    14. PhanTran: 2bo
    15.khanh.na: 2 bo
    18: Khuehn: 02 bo
  9. ducanhle
    ducanhle Advanced Member
    63 bo cho tới thời điểm hiện tại, cố thêm 5 bo nữa cho tròn 68 các bác ời & còn kịp nghe tết
  10. quanghao
    quanghao Advanced Member
    Thành Công
    Còn bác nào không?? 1 bo mất 110K + 20k vận chuyển! các bác check lại dùm em danh sách, còn bác nào nữa mau cho vào danh sách dùm em! bác nào không làm cũng báo cáo luôn nhé
  11. ducanhle
    bác quanghao cho cái lịch đóng tiền và bàn giao với.
    Tks n' b.r
  12. quanghao
    Thành Công
    Ok!
    Cá bác bắt đầu đóng cho em kinh phí từ bây giờ đến hạn chót là ngày 25 thánh 12 năm 2009
    Khi đủ kinh phí em sẽ làm luôn. Dự kiến có bo vào đầu năm mới!
  13. quanghao
    Thành Công
    Thêm môth thành công dùng mạch Salas shunt cho tube 26
  14. quanghao
    Thành Công
    Re: Simplistic Shunt
    :D
  15. ducanhle
    hi bác quang hào, bo này em ưu tiên dùng cho pre 6h30, layout như trên thì ko thể bố trí 2 bo nguồn trong 1 chassis đc roài. em thấy bác cứ giữa lại layout như cái bác dùng cho 6h30 thì ok hơn, bác xem như thế ổn không?
  16. quanghao
    Thành Công
    Ok thôi! định nâng cấp đây! bác cất nhà mà chưa cất lóc à!
    Yên tam đi em lam nhiều option trên 1 bo!
  17. ducanhle
    Vẫn cái chassis của saigonhifi đó, nếu kích thước như cỡ board bác NoBG (mầu đỏ, or xanh đợt đầu càng tốt :)) thì mới lắp vừa bác ạ, nếu dính cả bo đốt tim thì móm luôn vì bác cũng biết là cần lắp tấm tản nhiệt khá lớn, dùng pre6h30 mà dùng tản nhiệt loại liu riu như hình trên thì ko chịu nổi :(
  18. quanghao
    Thành Công
    Vẫn cái chassis của saigonhifi đó, nếu kích thước như cỡ board bác NoBG (mầu đỏ, or xanh đợt đầu càng tốt :)) thì mới lắp vừa bác ạ, nếu dính cả bo đốt tim thì móm luôn vì bác cũng biết là cần lắp tấm tản nhiệt khá lớn, dùng pre6h30 mà dùng tản nhiệt loại liu riu như hình trên thì ko chịu nổi :([/quote]
    Bác muốn
  19. ducanhle
    Bác muốn[/quote]
    CHÍNH NÓ :), hoặc để tiện cho tất cả mọi người thì lấy 1 nửa bên phải là ổn đấy bác ạ
  20. quanghao
    Thành Công
    CHÍNH NÓ :), hoặc để tiện cho tất cả mọi người thì lấy 1 nửa bên phải là ổn đấy bác ạ[/quote]
    Em sẽ làm cả tấm như thế! ai dùng 1 cái thì bẻ ra! Nhu vậy rất hay
    một tấm liền mất 200k. một nửa tấm 100k! cac bác Đk nhanh chóng đóng khói lửa dùm em!
    Cảm ơn nhiều!
  21. quanghao
    Thành Công
    Ảnh chụp bo em đã dùng và tét tại trang 1 của Pre818 link:
    viewtopic.php?f=46&t=17439
    Danh sách các bác tham gia bo mạch Sals Simplistic Shunt
    1. ducanhle : 04 bo
    3. vq_audio : 02 bo
    4. quanghao: 10 bo
    6. luongnhi : 02 bo
    7. Bachduong: 4 bo
    8. Vancao: 5 bo
    9. Pc_Chip: 4 bo
    11. Cominup: 02 bo
    12. curock 02 bo
    13. mitxinh: 2 bo.
    14. PhanTran: 2bo
    15.khanh.na: 2 bo
    18: Khuehn: 02 bo
    Còn bác nào nữa cho vào danh sách dùm em!
  22. curock
    curock Advanced Member
  23. quanghao
    Thành Công
    Danh sách các bác tham gia bo mạch Sals Simplistic Shunt và chuyển khói
    1. ducanhle : 04 bo
    3. vq_audio : 02 bo
    4. quanghao: 10 bo
    6. luongnhi : 02 bo
    7. Bachduong: 4 bo
    8. Vancao: 5 bo
    9. Pc_Chip: 4 bo
    11. Cominup: 02 bo
    12. curock 03 bo đã chuyển khói sáng nay 350k ( CK) OK
    13. mitxinh: 2 bo.
    14. PhanTran: 2bo
    15.khanh.na: 2 bo
    18: Khuehn: 02 bo
  24. skyrider
    skyrider Advanced Member
    Skyrider 01 bo :)
  25. ducanhle
    Em đã chuyển khói 04 bo chiều nay, bác quanghao check giùm nhé
